26 Haziran 2019, 00:35:11
esp8266 web sitesinden veri gönderme
Başlatan forzac, 10 Mayıs 2019, 21:49:08
forzac
10 Mayıs 2019, 21:49:08 Son düzenlenme: 11 Mayıs 2019, 03:37:27 forzac
arkadaşlar merhaba...web sitesi ile pic i haberleştirmeye çalısıyorum
kullandığım kütüphanenin tamamı bu
 * C library for the ESP8266 WiFi module with a PIC microcontroller
 * Copyright (C) 2015 Camil Staps <info@camilstaps.nl>
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License along
 * with this program; if not, write to the Free Software Foundation, Inc.,
 * 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
 *ORIGINALLY CREATED AS
 * File:    esp8266.h
 * Author:  Camil Staps <info@camilstaps.nl>
 * Website: http://github.com/camilstaps/ESP8266_PIC
 * Version: 0.1
 * MODFIED AND IMPROVED BY
 * File:    esp8266_functions.h
 * Author:  Aswinth Raj B  <mailtoaswinth@gmail.com>
 * Website: circuitdigest.com
 * Version: 0.1
 * See:   https://circuitdigest.com/microcontroller-projects/how-to-send-email-using-pic16f877a-esp8266 for more explanation
 * This is the header file for the ESP8266 PIC16F877A library where ESP runs on 115200 baudrate.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#define ESP8266_STATION 0x01
#define ESP8266_SOFTAP 0x02
#define ESP8266_TCP 1
#define ESP8266_UDP 0
#define ESP8266_OK 1
#define ESP8266_READY 2
#define ESP8266_FAIL 3
#define ESP8266_NOCHANGE 4
#define ESP8266_LINKED 5
#define ESP8266_UNLINK 6
int len;
///***______________________ESP module Function Declarations__________________**///
void _esp8266_putch(unsigned char);
unsigned char _esp8266_getch(void);
/** Function prototypes **/
char esp8266_isStarted(void);        // Check if the module is started (AT)
char esp8266_restart(void);          // Restart module (AT+RST)
void esp8266_echoCmds(bool);        // Enabled/disable command echoing (ATE)
// WIFI Mode (station/softAP/station+softAP) (AT+CWMODE)
void esp8266_mode(unsigned char);
// Connect to AP (AT+CWJAP)
void esp8266_connect(unsigned char*, unsigned char*);
// Disconnect from AP (AT+CWQAP)
void esp8266_disconnect(void);
// Local IP (AT+CIFSR)
void esp8266_ip(unsigned char*);
// Create connection (AT+CIPSTART)
char esp8266_start(unsigned char protocolcharipunsigned char port);
// Send data (AT+CIPSEND)
char esp8266_send(unsigned char*);
// Receive data (+IPD)
void esp8266_receive(unsigned char*, uint16_tbool);
/** Functions for internal use only **/
// Print a string to the output
void _esp8266_print(unsigned const char *);
// Wait for a certain string on the input
inline uint16_t _esp8266_waitFor(unsigned char *);
// Wait for any response on the input
inline unsigned char _esp8266_waitResponse(void);
void Lcd_Set_Cursor(char char b);
void Lcd_Print_Char(char);
void Lcd_Print_String(char *);
void _esp8266_login_mail(unsigned char*, unsigned char*);
void _esp8266_mail_sendID(unsigned char*);
void _esp8266_mail_recID(unsigned char*);
void _esp8266_mail_subject(unsigned char*);
void _esp8266_mail_body(unsigned char*);
//********__________________End of Function Declaration_________________********///
//***Initialize UART for ESP8266**//
void Initialize_ESP8266(void)
//****Setting I/O pins for UART****//
TRISC6 0// TX Pin set as output
TRISC7 1// RX Pin set as input
    //________I/O pins set __________//
    /**Initialize SPBRG register for required
    baud rate and set BRGH for fast baud_rate**/
SPBRG 10;
BRGH  1;  // for high baud_rate
    //_________End of baud_rate setting_________//
    //****Enable Asynchronous serial port*******//
SYNC  0;    // Asynchronous
SPEN  1;    // Enable serial port pins
    //_____Asynchronous serial port enabled_______//
    //**Lets prepare for transmission & reception**//
TXEN  1;    // enable transmission
CREN  1;    // enable reception
    //__UART module up and ready for transmission and reception__//
    //**Select 8-char mode**//
TX9   0;    // 8-char reception selected
RX9   0;    // 8-char reception mode selected
    //__8-char mode selected__//
//________UART module Initialized__________//
//**Function to send one byte of date to UART**//
void _esp8266_putch(unsigned char bt)
    while(!
TXIF);  // hold the program till TX buffer is free
TXREG bt//Load the transmitter buffer with the received value
//_____________End of function________________//
//**Function to get one byte of date from UART**//
unsigned char _esp8266_getch()
    if(
OERR// check for Error
CREN 0//If error -> Reset
CREN 1//If error -> Reset
    while(!
RCIF);  // hold the program till RX buffer is free
return RCREG//receive the value and send it to main function
//**Function to convert string to byte**//
void ESP8266_send_string(charst_pt)
    while(*
st_pt//if there is a char
_esp8266_putch(*st_pt++); //process it as a byte data
//___________End of function______________//
//**End of modified Codes**//
//**Function to configure soft_AP**//
unsigned char esp8266_config_softAP(unsigned charsoftssidunsigned charsoftpass) {
_esp8266_print("AT+CWSAP=\"");
_esp8266_print(softssid);
_esp8266_print("\",\"");
_esp8266_print(softpass);
_esp8266_print("\",5,3\r\n");
    return
_esp8266_waitResponse();
//**Function to stations IP/MAC**//
void esp8266_get_stationIP()
char rex;
ESP8266_send_string("AT+CWLIF\r\n");
Lcd_Set_Cursor(1,1);
Lcd_Print_String("IP:");
    do
rex _esp8266_getch() ;
Lcd_Print_Char(rex);
    }while(
rex!=',');
Lcd_Set_Cursor(2,1);
Lcd_Print_String("MAC:");
    do
    }while(
rex!='O');
 //**Function to enable multiple connections**//
void _esp8266_enale_MUX()
_esp8266_print("AT+CIPMUX=1\r\n"); //Enable Multiple Connections
  //**Function to create server on Port 80**//
void _esp8266_create_server()
_esp8266_print("AT+CIPSERVER=1,80\r\n"); //Enable Server on port 80
 /*Enter into Start typing the mail*/
void _esp8266_start_mail()
_esp8266_print("AT+CIPSEND=4,6\r\n");
_esp8266_print("DATA\r\n");
/*Entered into the typing mode*/
 /*End the Mail using a "."*/
void _esp8266_End_mail()
_esp8266_print("AT+CIPSEND=4,3\r\n");
_esp8266_print(".\r\n");
/*End of mail*/
 /*Quit Connection from SMPT server*/
void _esp8266_disconnect_SMPT2GO()
_esp8266_print("QUIT\r\n");
/*Disconnected*/
 /*Connect to SMPT2GO server*/
void _esp8266_connect_SMPT2GO()
_esp8266_print("AT+CIPSTART=4,\"TCP\",\"mail.smtp2go.com\",2525\r\n");
_esp8266_print("AT+CIPSEND=4,20\r\n");
_esp8266_print("EHLO 192.168.1.123\r\n");
_esp8266_print("AT+CIPSEND=4,12\r\n");
_esp8266_print("AUTH LOGIN\r\n");
/*connected to Server*/
 /*LOG IN with your SMPT2GO approved mail ID*/
    /*Visit the page https://www.smtp2go.com/ and sign up using any Gmail ID
     * Once you gmail ID is SMPT2GO approved convert your mail ID and password in 64 base format
     * visit https://www.base64encode.org/ for converting 64 base format online
     * FORMAT -> _esp8266_login_mail("mailID in base 64","Password in base 64");
     * This program uses the ID-> aswinthcd@gmail.com and password -> circuitdigest as an example
void _esp8266_login_mail(unsigned charmail_IDunsigned charmail_Pas) {
len strlen(mail_ID);
len+= 2;
char l2 len%10;
char l1 = (len/10)%10;
_esp8266_print("AT+CIPSEND=4,");
     if ((
l1+'0')>'0')
_esp8266_putch(l1+'0');
_esp8266_putch(l2+'0');
_esp8266_print("\r\n");
_esp8266_print(mail_ID);
len strlen(mail_Pas);
len+= 2;
//    char l2 = len%10;
//    char l1 = (len/10)%10;
    if ((
l1+'0')>'0')
_esp8266_print(mail_Pas);
/*End of Login*/
void _esp8266_mail_sendID(unsigned charsend_ID)
len strlen(send_ID);
len+= 14;
char l2 len%10;
     if ((
l1+'0')>'0')
_esp8266_print("MAIL FROM:<");
_esp8266_print(send_ID);
_esp8266_print(">\r\n");
void _esp8266_mail_recID(unsigned charrec_ID)
len strlen(rec_ID);
len+= 12;
char l2 len%10;
     if ((
l1+'0')>'0')
_esp8266_print("RCPT To:<");
_esp8266_print(rec_ID);
void _esp8266_mail_subject(unsigned charsubject)
len strlen(subject);
len+= 10;
char l2 len%10;
     if ((
l1+'0')>'0')
_esp8266_print("Subject:");
_esp8266_print(subject);
void _esp8266_mail_body(unsigned charbody)
len strlen(body);
len+= 2;
char l2 len%10;
     if ((
l1+'0')>'0')
_esp8266_print(body);
 * Check if the module is started
 * This sends the `AT` command to the ESP and waits until it gets a response.
 * @return true if the module is started, false if something went wrong
char esp8266_isStarted(void) {
_esp8266_print("AT\r\n");
    return (
_esp8266_waitResponse() == ESP8266_OK);
 * Restart the module
 * This sends the `AT+RST` command to the ESP and waits until there is a
 * response.
 * @return true iff the module restarted properly
char esp8266_restart(void) {
_esp8266_print("AT+RST\r\n");
    if (
_esp8266_waitResponse() != ESP8266_OK) {
        return
false;
    return (
_esp8266_waitResponse() == ESP8266_READY);
 * Enable / disable command echoing.
 * Enabling this is useful for debugging: one could sniff the TX line from the
 * ESP8266 with his computer and thus receive both commands and responses.
 * This sends the ATE command to the ESP module.
 * @param echo whether to enable command echoing or not
void esp8266_echoCmds(bool echo) {
_esp8266_print("ATE");
    if (echo) {
_esp8266_putch('1');
    } else {
_esp8266_putch('0');
_esp8266_waitFor("OK");
 * Set the WiFi mode.
 * ESP8266_STATION : Station mode
 * ESP8266_SOFTAP : Access point mode
 * This sends the AT+CWMODE command to the ESP module.
 * @param mode an ORed charmask of ESP8266_STATION and ESP8266_SOFTAP
void esp8266_mode(unsigned char mode) {
_esp8266_print("AT+CWMODE=");
_esp8266_putch(mode '0');
 * Connect to an access point.
 * This sends the AT+CWJAP command to the ESP module.
 * @param ssid The SSID to connect to
 * @param pass The password of the network
 * @return an ESP status code, normally either ESP8266_OK or ESP8266_FAIL
void esp8266_connect(unsigned charssidunsigned charpass) {
_esp8266_print("AT+CWJAP=\"");
_esp8266_print(ssid);
_esp8266_print(pass);
_esp8266_print("\"\r\n");
 * Disconnect from the access point.
 * This sends the AT+CWQAP command to the ESP module.
void esp8266_disconnect(void) {
_esp8266_print("AT+CWQAP\r\n");
 * Store the current local IPv4 address.
 * This sends the AT+CIFSR command to the ESP module.
 * The result will not be stored as a string but byte by byte. For example, for
 * the IP 192.168.0.1, the value of store_in will be: {0xc0, 0xa8, 0x00, 0x01}.
 * @param store_in a pointer to an array of the type unsigned char[4]; this
 * array will be filled with the local IP.
void esp8266_ip(unsigned charstore_in) {
_esp8266_print("AT+CIFSR\r\n");
unsigned char received;
    do {
received _esp8266_getch();
    } while (
received '0' || received '9');
    for (
unsigned char i 04i++) {
store_in[i] = 0;
        do {
store_in[i] = 10 store_in[i] + received '0';
        } while (
received >= '0' && received <= '9');
 * Open a TCP or UDP connection.
 * This sends the AT+CIPSTART command to the ESP module.
 * @param protocol Either ESP8266_TCP or ESP8266_UDP
 * @param ip The IP or hostname to connect to; as a string
 * @param port The port to connect to
 * @return true iff the connection is opened after this.
char esp8266_start(unsigned char protocolcharipunsigned char port) {
_esp8266_print("AT+CIPSTART=\"");
    if (
protocol == ESP8266_TCP) {
_esp8266_print("TCP");
    } else {
_esp8266_print("UDP");
_esp8266_print(ip);
_esp8266_print("\",");
unsigned char port_str[5] = "\0\0\0\0";
sprintf(port_str"%u"port);
_esp8266_print(port_str);
    if (
        return
0;
    if (
_esp8266_waitResponse() != ESP8266_LINKED) {
        return
0;
    return
1;
 * Send data over a connection.
 * This sends the AT+CIPSEND command to the ESP module.
 * @param data The data to send
 * @return true iff the data was sent correctly.
char esp8266_send(unsigned chardata) {
unsigned char length_str[6] = "\0\0\0\0\0";
sprintf(length_str"%u"strlen(data));
_esp8266_print("AT+CIPSEND=");
_esp8266_print(length_str);
    while (
_esp8266_getch() != '>');
_esp8266_print(data);
    if (
_esp8266_waitResponse() == ESP8266_OK) {
        return
1;
    return
0;
 * Read a string of data that is sent to the ESP8266.
 * This waits for a +IPD line from the module. If more bytes than the maximum
 * are received, the remaining bytes will be discarded.
 * @param store_in a pointer to a character array to store the data in
 * @param max_length maximum amount of bytes to read in
 * @param discard_headers if set to true, we will skip until the first \r\n\r\n,
 * for HTTP this means skipping the headers.
void esp8266_receive(unsigned charstore_inuint16_t max_lengthbool discard_headers) {
_esp8266_waitFor("+IPD,");
uint16_t length 0;
unsigned char received _esp8266_getch();
    do {
length length 10 received '0';
    } while (
    if (
discard_headers) {
length -= _esp8266_waitFor("\r\n\r\n");
    if (
length max_length) {
max_length length;
/*sprintf(store_in, "%u,%u:%c%c", length, max_length, _esp8266_getch(), _esp8266_getch());
    return;*/
uint16_t i;
    for (
0max_lengthi++) {
store_in[i] = _esp8266_getch();
store_in[i] = 0;
    for (;
lengthi++) {
_esp8266_getch();
 * Output a string to the ESP module.
 * This is a function for internal use only.
 * @param ptr A pointer to the string to send.
void _esp8266_print(unsigned const char *ptr) {
    while (*
ptr != 0) {
_esp8266_putch(*ptr++);
 * Wait until we found a string on the input.
 * Careful: this will read everything until that string (even if it's never
 * found). You may lose important data.
 * @param string
 * @return the number of characters read
inline uint16_t _esp8266_waitFor(unsigned char *string) {
unsigned char so_far 0;
uint16_t counter 0;
    do {
counter++;
        if (
received == string[so_far]) {
so_far++;
        } else {
so_far 0;
    } while (
string[so_far] != 0);
    return
counter;
 * Wait until we received the ESP is done and sends its response.
 * Currently the following responses are implemented:
 *  * OK
 *  * ready
 *  * FAIL
 *  * no change
 *  * Linked
 *  * Unlink
 * Not implemented yet:
 *  * DNS fail (or something like that)
 * @return a constant from esp8266.h describing the status response.
inline unsigned char _esp8266_waitResponse(void) {
unsigned char so_far[6] = {0,0,0,0,0,0};
unsigned const char lengths[6] = {2,5,4,9,6,6};
unsigned const charstrings[6] = {"OK""ready""FAIL""no change""Linked""Unlink"};
unsigned const char responses[6] = {ESP8266_OKESP8266_READYESP8266_FAILESP8266_NOCHANGEESP8266_LINKEDESP8266_UNLINK};
unsigned char response;
bool continue_loop true;
    while (
continue_loop) {
        for (
unsigned char i 06i++) {
            if (
strings[i][so_far[i]] == received) {
so_far[i]++;
                if (
so_far[i] == lengths[i]) {
response responses[i];
continue_loop false;
            } else {
so_far[i] = 0;
    return
response;
internet sitesine bağlanmak için çağırdığım fonsiyon şu şekilde
    if (
    } else {
_esp8266_print(ip);
    if (
        return
0;
    if (
        return
0;
    return
1;
main kısmındaki ilgili alanı şu şekilde düzenledim
do
Lcd_Clear();
Lcd_Print_String("Siteye baglanamadi");
__delay_ms(1500);
    }while(!
esp8266_start("TCP","http://atikermuhendislik.com/nodemcu/data.txt","80"));
Lcd_Clear();
Lcd_Print_String("Siteye baglandi");
__delay_ms(1500);
lcd de sürekli "siteye bağlanamadı" yazısı alıyorum
bu projeyi nodemcu da yapmıstım ama ordaki kütüphaneyi buna uyarlayamadım...yol gösterebilecek birisi varsa çok mutlu olurum
