Gömülü Linux üzerinden pppd ile apn'e dahil olma , ip sorunu
Başlatan saucompeng, 27 Kasım 2014, 10:26:20
saucompeng
Herkese selamlar;
Linux board üzerinden GL865 telit modem kullanarak pppd ile şirketimizin apn'ine bağlanarak ip alıyorum. pppd den aldığım çıktılar aynen şu şekilde. SOnrasında ağımda bulunan bir bilgisayara ping atıyorum ama herhangi bir şekilde cevap alamıyorum. Sorun nerededir?
PPPD ÇIKTISI
root@phyCORE:~ pppd call gprs
OK
OK
OK
OK
OK
OK
Script chat -v -f /etc/ppp/chat/gprs_chat -e finished (pid 822), status = 0x0
Serial connection established.
using channel 9
Using interface ppp0
Connect: ppp0 <--> /dev/ttymxc1
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xaf9beef0> <pcomp> <accomp>]
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0xaf9beef0> <pcomp> <accomp>]
rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <auth pap> <magic 0x87f04400> <pcomp> <accomp>]
sent [LCP ConfAck id=0x1 <asyncmap 0x0> <auth pap> <magic 0x87f04400> <pcomp> <accomp>]
sent [LCP EchoReq id=0x0 magic=0xaf9beef0]
sent [PAP AuthReq id=0x1 user="asist1" password=<hidden>]
rcvd [LCP EchoRep id=0x0 magic=0xa2f04400]
rcvd [PAP AuthAck id=0x1 "Welcome!"]
Remote message: Welcome!
PAP authentication succeeded
sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
rcvd [IPCP ConfReq id=0x1 <addr 172.20.53.200>]
sent [IPCP ConfAck id=0x1 <addr 172.20.53.200>]
rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
sent [IPCP ConfReq id=0x2 <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0x2 <addr 172.20.53.200>]
sent [IPCP ConfReq id=0x3 <addr 172.20.53.200>]
rcvd [IPCP ConfAck id=0x3 <addr 172.20.53.200>]
local  IP address 172.20.53.200
remote IP address 172.20.53.200
IFCONFIG ÇIKTISI
ppp0      Link encap:Point-to-Point Protocol
          inet addr:172.20.53.200  P-t-P:172.20.53.200  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:4 errors:1 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:52 (52.0 B)  TX bytes:58 (58.0 B)
www.teknikyazi.com --üşenme,erteleme,vazgeçme...
ercan_t
merhaba,
ping atarken isim mi kullanıyorsun yoksa ip mi
cihazda DNS tanımlı olmayabilir
ping 8.8.8.8
dene
saucompeng
Internete çıkan bir network değil . Bağlanmak istediğim makine 172.16.20.90 nolu ip ye sahip.
saucompeng
Karşı tarafta icmp kısıtlaması olduğundan dolayı ping lere yanıt alamıyormuşum. Herhangi bir problem yokmuş.
EMP_Otto
@ saucompeng hocam ppp ile bağlantıyı nasıl yaptığınızı biraz anlatabilirmisiniz?Nasıl bir config scripti kullandınız.Yada modemi sisteme nasıl bağladınız?
Şimdiden teşekkürler...
Bu işler zordur,özveri ister...
