Gönderen Konu: Universal bir proglamlayıcı yapıyoruz ...  (Okunma sayısı 111569 defa)
Çevrimdışı e3
  • Profesyonel Üye
  • İleti: 1195
« Yanıtla #30 : 01 Ağustos 2006, 15:14:42 »
@ Ziya hocam size PIC komponentleri için adaylar buldum. :D Buyrun inceleyin, yakışıklıları seçin bir kenara bırakın. :P Saygılar.Kolay gele. ;)
Kod: [Seç]
DSPIC30F5016
DSPIC30F2010
DSPIC30F2011
DSPIC30F2012
DSPIC30F3010
DSPIC30F3011
DSPIC30F3012
DSPIC30F3013
DSPIC30F3014
DSPIC30F4011
DSPIC30F4012
DSPIC30F4013
DSPIC30F5011
DSPIC30F5013
DSPIC30F5015
DSPIC30F6010
DSPIC30F6011
DSPIC30F6012
DSPIC30F6013
DSPIC30F6014
PIC10F200
PIC10F202
PIC10F204
PIC10F206
PIC12C508
PIC12F508
PIC12C508A
PIC12C509
PIC12F509
PIC12CR509A
PIC12C509A
RFPIC12C509AF
RFPIC12C509AG
PIC12F510
PIC12CE518
PIC12CE519
PIC12F629
PIC12F635
PIC12C671
PIC12C672
PIC12CE673
PIC12CE674
PIC12F675
RFPIC12F675F
RFPIC12F675H
RFPIC12F675K
PIC12F683
PIC14000
PIC16F54
PIC16F57
PIC16F59
PIC16C61
PIC16C62
PIC16CR62
PIC16C62A
PIC16C62B
PIC16CR63
PIC16C63
PIC16C63A
PIC16CR64
PIC16C64
PIC16C64A
PIC16C65
PIC16CR65
PIC16C65A
PIC16C65B
PIC16C66
PIC16C67
PIC16C70
PIC16C71
PIC16C72
PIC16F72
PIC16CR72
PIC16C72A
PIC16F73
PIC16C73
PIC16C73A
PIC16C73B
PIC16F74
PIC16C74
PIC16C74A
PIC16C74B
PIC16LC74B
PIC16F76
PIC16C76
PIC16C77
PIC16F77
PIC16F83
PIC16C83
PIC16CR83
PIC16F84
PIC16C84
PIC16CR84
PIC16LF84A
PIC16C84A
PIC16F84A
PIC16F87
PIC16F88
PIC16C432
PIC16C505
PIC16F505
PIC16F506
PIC16C554
PIC16C558
PIC16C620
PIC16C620A
PIC16C621
PIC16C621A
PIC16C622
PIC16C622A
PIC16CE623
PIC16CE624
PIC16CE625
PIC16F627
PIC16F627A
PIC16F628
PIC16F628A
PIC16F630
PIC16F636
PIC16F639
PIC16C641
PIC16C642
PIC16F648A
PIC16C661
PIC16C662
PIC16F676
PIC16F684
PIC16F685
PIC16F687
PIC16F688
PIC16F689
PIC16F690
PIC16C710
PIC16C711
PIC16C712
PIC16C715
PIC16C716
PIC16F716
PIC16C717
PIC16F737
PIC16C745
PIC16F747
PIC16C765
PIC16F767
PIC16C770
PIC16C771
PIC16C773
PIC16C774
PIC16F777
PIC16C781
PIC16C782
PIC16F785
PIC16F818
PIC16F819
PIC16F870
PIC16F871
PIC16F872
PIC16F873
PIC16F873A
PIC16F874
PIC16F874A
PIC16F876
PIC16F876A
PIC16F877
PIC16F877A
PIC16F913
PIC16F914
PIC16F916
PIC16F917
PIC16C923
PIC16C924
PIC16C925
PIC16C926
PIC16F946
PIC18F242
PIC18C242
PIC18F248
PIC18F252
PIC18C252
PIC18F258
PIC18F442
PIC18C442
PIC18F448
PIC18F452
PIC18C452
PIC18F458
PIC18C601
PIC18C658
PIC18C801
PIC18C858
PIC18F1220
PIC18F1320
PIC18F2220
PIC18F2320
PIC18F2331
PIC18F2410
PIC18F2420
PIC18F2431
PIC18F2439
PIC18F2455
PIC18F2480
PIC18F2510
PIC18F2515
PIC18F2520
PIC18F2525
PIC18F2539
PIC18F2550
PIC18F2580
PIC18F2585
PIC18F2610
PIC18F2620
PIC18F2680
PIC18F4220
PIC18F4320
PIC18F4331
PIC18F4410
PIC18F4420
PIC18F4431
PIC18F4439
PIC18F4455
PIC18F4480
PIC18F4510
PIC18F4515
PIC18F4520
PIC18F4525
PIC18F4539
PIC18F4550
PIC18F4580
PIC18F4585
PIC18F4610
PIC18F4620
PIC18F4680
PIC18F6310
PIC18F6390
PIC18F6410
PIC18F6490
PIC18F6520
PIC18F6525
PIC18F6527
PIC18F6585
PIC18F6620
PIC18F6621
PIC18F6622
PIC18F6627
PIC18F6680
PIC18F6720
PIC18F6722
PIC18F8310
PIC18F8390
PIC18F8410
PIC18F8490
PIC18F8520
PIC18F8525
PIC18F8527
PIC18F8585
PIC18F8620
PIC18F8621
PIC18F8622
PIC18F8627
PIC18F8680
PIC18F8720
PIC18F8722
DSPIC30F6010A
DSPIC30F6012A
DSPIC30F6013A
DSPIC30F6014A
DSPIC30F6015
DSPIC30F6011A
Alın size PIC için Good-Prog 8O . ( Baba Programlayıcı :P )
.eem.
Çevrimdışı mp3dragon
  • Profesyonel Üye
  • İleti: 1125
« Yanıtla #31 : 02 Ağustos 2006, 00:25:20 »
@Ziya,
Universal programlayıcı yapıyorsak eğer hedef chip seçimi projeyi universal olmaktan çıkarır. Devreyi biraz büyük tutup bir kere yaptıktan sonra algoritma değişimi ile tüm chipler programlanmalı. Hatta daha piyasada olmayan chipler bile. Benim önerim;
1. Vpp ve Vcc programlanabilmeli,
2. 40 bacaklı zif soket üzerinde tüm bacaklar giriş/çıkış/vpp/vcc/gnd olarak seçilebilmeli
3. yanlış chip, hatalı ve ters takma durumunda koruma ve uyarı olmalı
4. ICSP/JTAG için konnektör olmalı
5. PC bağlantısı USB olmalı
6. Devre ayrı kaynaktan beslenmeli (bazı laptopların USB çıkışları 200 ma olabiliyor. Devre için 25 volt Vpp de düşünüldüğünde yetersiz gelebilir. voltaj dalgalanmaları istenmeyen bir durum)
Çözüm önerilerim ise;
1. LM317 + dac veya digital pot
2. Transisör + buffer + 1n4148
3. Vpp ve Vcc akımının sürekli ölçümü akım bir değer üzerine çıktığında uyarı ve koruma
4.
5.ft232/245
6.24 volt AC
Çevrimdışı Allegro
  • Global Moderator
  • Profesyonel Üye
  • İleti: 5202
  • Oku, düşün, çalış, keşfet, bir sonraki işe başla!
« Yanıtla #32 : 02 Ağustos 2006, 00:43:25 »
Alıntı yapılan: "mp3dragon"
3. Vpp ve Vcc akımının sürekli ölçümü akım bir değer üzerine çıktığında uyarı ve koruma...
Evet Jetprog 16 adet 16F628A yi ust uste programlamama izin verirken 17. de "Aşırı Akım Hatası" veriyor.
Yani programlama esnasında akımlar ölçülüyor.... :D
Çevrimdışı Ziya
  • Profesyonel Üye
  • İleti: 1423
    • http://www.nukleer.web.tr
« Yanıtla #33 : 02 Ağustos 2006, 02:52:32 »
@Ziya,
Sorun da burada. 40 bacaklı zif soketler 16 bitlik eepromlar için yetersiz kalıyor. En azından data ve adres hatları arttırılması gerekiyor.
Alıntı
Benim önerim;
İkinci madde bence pratikte mümkün değil. Vpp olarak belirlenen bir bacağa gerektiğinde 12.5 Volt verilecek. Fakat bu bacak çıkış olarak kullanıldığında bu çıkış işlemcinin bşr bacağına gelecek. Arada optocoupler gibi bir şey olmadan bunu yapmak mümkün değil. Hedef çipleri belirleyelim demekten kastım aslında hangi bacaklar Vpp ve Vcc olacak, hangilerine gerektiğinde 5 yada 12.5 volt verilecek bunları belirlemek idi. Vpp olarak gösterilen bir bacak başka bir çip için çıkış olması gerekiyor ise o bacağın Vpp ile bağlantısı kesilmeli (röleler ile). Bunun bütün bacaklara uygulanması pratikte mümkün değil (yani zor ve gereksiz anlamında demek istiyorum).
Alıntı
Bu da aslında karmaşık bir işlem ama olması gerekir. Yanlış bacağa Vpp vermemek gerek.
Alıntı
Bunlar tamam.
Alıntı
4.
5.ft232/245
6.24 volt AC
USB çipi için ayrı para ödemektense USB'si üzerinde olan işlemci kullanmayı tavsiye ediyorum. Bu konuda ARM7 işlemciler kullanılmalı derim. Bulunması zor demiştiniz. Bakın böyle bir pazar oluşturunca onun da bulunması kolay olacak. 2 yıl önce 18 serisi picler bulunmuyordu. Şimdi pek çok yerde var. Neden?
LM317 ve DAC her bacak için kullanılabilir mi? Her bir bacak için bir DAC adresi belirlemek ve voltaj değerini DAC'a yüklemek gerekir. Her bir bacaktaki değeri okuma için de ADC mi kullanmak gerekir bu durumda?
Bence Vpp ve Vcc için kullanılabilecek bacaklar belirlendikten sonra bunlara röleler vasıtasıyla değişik düzenlemeler yapılarak (gerektiğinde bir bacak Vpp olmaktan çıkıp, çıkış olarak işlemcinin bir bacağına yönlendirilebilmeli). Tabi bu durumda gelecekte çıkacak olan işlemcilere destek verilebilir mi burası işlemicinin tasarımcısına bağlı kalacak.
Çevrimdışı Ziya
  • Profesyonel Üye
  • İleti: 1423
« Yanıtla #34 : 02 Ağustos 2006, 03:25:52 »
Protection,
rf picler normal b6,b7 pinlerinden de programlanabiliyormudur? (yani rfsiz)
  • Profesyonel Üye
  • İleti: 1125
« Yanıtla #35 : 02 Ağustos 2006, 04:36:48 »
@Ziya,
Alıntı
maksimum 40 bacaklı DIP paket harici çipler için adaptör şart zaten
Alıntı
zor olduğu kesin ama bir kere yaptıktan sonra değmeyin keyfimize. willem de olduğu gibi pcb1.0, pcb3.5 gibi donanım değişikliği gerekmez. Sadece ihtiyaca göre adaptör kartı yapılır.Universal programlayıcıların fiyatı da malum. Fiyat konusunda sıkıntımız olacağını zannetmiyorum.
Alıntı
çok karmaşık değil sadece vpp ve vcc nin çektiği akım ölçülecek ve datasheetlerde verilenden fazla bir değer varsa uyarı verecek. Hatta vpp ve vcc kademeli olarak arttırılabilir. MCU Pic serisi olursa içerisindeki adc iş görür.
Alıntı
USB gömülü ARM kullanmak elbette projeyi süper yapar ama işin zorlukları da var.
1. ARM de USB için kodu kendimiz yazmamız lazım PC tarafındaki driver dahil. USB protokolu RS232 kadar da basit değil.
2. Forumda ARM tecrübesi yok denecek kadar az.
3. ARM işlemcilerde gerektiğinde asm'ye inmek pic ve muadili işlemciler kadar rahat değil. Yani ARM de işlemciye pic kadar hakim olmak o kadar kolay değil.
4. ARM USB işi ile de ilgilenmesi gerekeceği için ekstra kod ve zaman çalacaktır.
Alıntı
Vpp ve Vcc üretimi ayrı ayrı değil tek bir lm317 + dac ile olacak, sadece hangi bacağa bağlanacağı tarafımızdan seçilecek. Her bacakta ölçüm değil sadece Vpp ve Vcc çıkışında yapılacak. Dac olarak R-2R bile kullanılabilir.
her bacağa Vpp verilmeyebilir ama her bacak giriş/çıkış/vcc/gnd olabilmeli.
  • Profesyonel Üye
  • İleti: 1125
« Yanıtla #36 : 02 Ağustos 2006, 05:14:31 »
röle kullanmadan zif soket bacakları için örnek in/out devresi aşağıda;
edit:
ise ve Ziya arkadaşların hatırlatması ile üsteki devredeki npn/pnp hatası değiştirildi
Çevrimdışı Ziya
  • Profesyonel Üye
  • İleti: 1423
« Yanıtla #37 : 02 Ağustos 2006, 07:08:04 »
Her bacağı giriş yada çıkış yapabiliriz. Bunun için çok bacaklı işlemci kullanmak gerekir. Fakat her bacağa Vcc vermek yine röle kullanımı gerektirir. Zira Vcc için gerekli 5 Volt, 6.5 volt gibi değerleri işlemcilerle sürmek zor.
Alıntı
Altta görünen devreyi anlamadım. Üsttekinde de transistör pnp olmayacak mı? Sanki ters olmuş gibi. Ben daha önce bir eprom programlayıcı yapmıştım (Avustralyadan Andrew isminde birinin geliştirdiği programlayıcı). Orada Vpp ve Vcc aynı bacağa nasıl uygulandığı gayet güzel denendi. Sorun Vpp ya da Vcc nin bağlandığı bacak output olarak kullanılacağı zaman arada izolasyon yapmak gerekecek. Ya da çıkışı en fazla 5 volt ile sınırlayacak bir düzenekle mcu ya bağlamak gerekecek. Tabi bu işlemler için mcu dan Vpp tetiklemek için bir, Vcc tetiklemek için bir, Vpp/2 tetiklemek için bir ve input için bir bacak kullanmak gerekir. Topraklama için de bir npn transistörle mcu dan çıkış alacak olursak her Vpp nin bağlanacağı bacak için en az 5 mcu GPIO pini kullanılacak demektir. Yüzey montaj transistörlerle belki bu sorun aşılabilir. MCU GPIO dan çıkış olarak kullanılacak pinlerin yerine de 74hc595ler kullanılabilir.
Tasarımı çok iyi optimize etmek gerekir. Birkaç değişik yöntem üzerinde çalışıp artılarını ve eksilerini değerlendirelim derim. Vpp ve Vcc her bacak için düşünülmeyebilir.
ARM7 kullanma konusunda bahsettiğiniz gerekçeler çok gerçekçi görünmedi bana. Yazılımda assemblera neden gerek duyduğunuzu anlayamadım. 50 MHzlik işlemcide işlemler 20 ns sürede gerşekleşecek. Programlama için gerekli olabilecek 120 us gibi süreler timerlar ile elde edilecek. İnterrupta geçiş süreleri o kadar fazla değil ki assemblera ihtiyaç duyulsun. Üstelik interrupta geçişte ARM7 context saving işlemi yapmıyor, sadece interruptlarda (herbirinde farklı) yeni working registerler kullanıyor. Yani hız kaybı falan yok.
ARM tecrübesi az olması o işlemciyi kullanmayacağımız anlamına gelmez. Zaten sorun peripherallerin kullanımından kaynaklanabilir ki o da bence sorun değil. Derleyicinin simulatörü ve ISIS varken bence ARM7 kullanmakta bir problem yok.
ARM7 USB windows driverları sanıyorum üretici firma tarafından web sitelerinde bulunuyor. Kaldı ki lpc2000 yazışma forumunda ve lpc örnek kodlarında usb kullanımı konusunda örnekler de mevcut. Bence güzel bir çalışma olurdu bu.
  • Profesyonel Üye
  • İleti: 1125
« Yanıtla #38 : 02 Ağustos 2006, 07:47:54 »
Alıntı
benim ARM için 1 beden büyük dememin sebebi bu idi. Birde bunalmiş hocamın önerdiği gibi algoritmalar PC tarafında durursa çok bacaklı olması haricinde bir avantajı kalmaz oda f452 için.
Ama madem ARM ısrarı var benim için farketmez. Hiç değilse ARM öğrenmiş oluruz. Resimde altta görünen mosfetlerin amacı vcc/gnd/in işlemi; hem 1/0 data hemde vcc/gnd bir arada tristate'in yüksek akım basabilmesi için. Bu devrenin önüne 74hc573 gibi bir latch bağlandığında tris registeri gibi in/out olarak pinler programlanabilir.
Epromlarda VCC bacağı %99,99 sağ üstte (ZIF 40. bacak) buda 5/6.5 v. işini kolaylaştırıyor.
İşlemci LPC 21xx olursa seri porttan programlama avantajı var. ama o zaman fazladan bir rs232 portu koymak gerekecek. Veya dönüp dolaşıp  ft232 kullanmak gerekecek.
mosfetler için bs170/bs250 kolay bulunabilen seçenekler. daha düşük RDSon direncine sahip ve smd mosfet seçenekleri düşünülebilir.
geriye birtek Vpp ile zif soketten okuma çakışması problemi kalıyor.
  • Profesyonel Üye
  • İleti: 1125
« Yanıtla #39 : 02 Ağustos 2006, 08:14:10 »
başlangıç algoritması şöyle olabilir;
1- Programlayıcı PC ile iletişimi kontrol eder,
2- PC programından hangi çipin seçildiğine bakar,
3. Seçilen çipe ve işleme göre in/out/Vpp/Vcc/Gnd pinlerini ayarlar.
3- ZIF soketin boş olup olmadığına bakar (Icc = 0) boş ise xxx'i yerleştirin der.
4- Çipin doğru olup olmadığına bakar (Icc akımı kontrol eder hatta Vcc yi kademeli arttırır)
5- Vpp yi 5 volttan başlayarak kademeli olarak arttırır ve çektiği akıma bakar eğer akım aniden yükseliyorsa hata mesajı verir.
6. Her şey yolunda ise programlamaya başlar aradaki işlemleri LCD ve PC de ekrana basar.
  • Profesyonel Üye
  • İleti: 1125
« Yanıtla #40 : 02 Ağustos 2006, 08:25:38 »
power supply;
mantık elemanları ve işlemci için 5 ve 3,3 volt (ARM olacaksa) sabit
Vcc için 3...7 volt arası 0,25 volt adımla değiştirilebilen
Vpp için 3...26 volt arası 0,25 volt adımla değiştirilebilen.
Çevrimdışı Ziya
  • Profesyonel Üye
  • İleti: 1423
« Yanıtla #41 : 02 Ağustos 2006, 08:34:34 »
ARM7 timerlarını kullanmakta bir sorunumuz yok o nedenle assemblera geçmeye ihtiyaç yok. zaten ARM7 lerde 32 bitlik timerlar var. istenilen zaman gecikmesini üretmede bir problem yok.
Kabaca bir taslak çizip üzerinde konuşmak daha iyi olacak. Epromlar için mantığı oturttuktan sonra diğer çipler için detaylandırırız.
LPC2148 de USB üzerinde ve 512 kb gibi bir hafıza var. 4.5 dolarlık ft232 ye gerek kalmıyor. Bence PC tarafında script language benzeri basit ama herhangi bir çipin programlama algoritmasını tarif edebilecek bir dil geliştirmek gerek.  Böylece PC programlayıcıya algoritmayı ve verileri gönderir, gerisi mcu tarafından halledilir.
Başlangıç algoritmasında
2. adımdaki işlem yapılmadan da hangi çipin zif sokete yerleştirildiği test edilerek bulunabilir. Bu konuda detaylı bir işlem sırası tablo haline getirilmeli derim.
  • Profesyonel Üye
  • İleti: 1125
« Yanıtla #42 : 02 Ağustos 2006, 08:39:36 »
LPC2148 nerden bulcaz şu an benim en büyük problemim bu oldu!
Çevrimdışı Allegro
  • Global Moderator
  • Profesyonel Üye
  • İleti: 5202
« Yanıtla #43 : 02 Ağustos 2006, 09:15:37 »
ELNEC JETPROG tan kesitler... altta da bir pcb göz kırpıyor... :D
http://img311.imageshack.us/img311/3622/img0007ao9.jpg
Çevrimdışı Ziya
  • Profesyonel Üye
  • İleti: 1423
« Yanıtla #44 : 02 Ağustos 2006, 11:12:50 »
Galiba bu işlemci bize io pin bakımından yeterli olmayacak.
Erol hocam, öyle fotolar gösterip moralimizi bozmasan :D
Yanlış hatırlamıyorsam Aster hocamın fiyat performans açısından tavsiye ettiği ve yine üzerinde usb bulunan işlemciler sanki daha çok io portuna sahiptiler diye hatırlıyorum.
İşlemci konusu daha sonraya kalabilir. Bir 40 pin zif sokete Vpp, Vcc-1, Vcc-2, GND, ... vs nasıl sürebileceğimizi bir kararlaştıralım. İşlemci sorunu nasıl olsa halledilir.
Bu konuda katkı sağlayabilecek başka arkadaş varmı? Değişik fikirler doğruyu bulmamızda yardımcı olacaktır.
