.dll dosyası açma ve değişiklik yapma
Başlatan ilker_32, 03 Eylül 2007, 01:18:38
aslan_korhan
Birde şöyle bir şey var :
SiComponents Resource Builder ver.2.6.20
Tired of editing resource files? Keen to speed-up and improve the editing of resources scripts or files?
Nowadays, resource files are used in almost all applications development, but resource editing has always been a difficult and non-trivial task. Using our Resource Builder, the resource editing becomes the easiest and fastest task in your programming cycle. Our resource editor will provide you with a lot of easy-to-use and user-friendly What You See Is What You Get (WYSIWYG) editors for each type of resource, and you will produce software even quicker than before.
Do you need to modify resources in EXE or create Resource DLL?
Resource Builder's integrated resource linker will modify resources directly in executables (EXE, DLL and others) without recompiling them. Resource Only DLLs (used for software localization and customization) are created with just two clicks of the mouse.
Do you need to support Unicode?
Resource Builder is a unique resource editor, which provides full support for Unicode. You can use Unicode resource scripts and Unicode data your resources, and you will be able to edit them as easily as usual scripts.
Vista icons support! Resource Builder supports now Vista PNG icons. You can create, edit them directly in Resource Builder as well as link to compiled executables to add them Vista icons.
Vista-ready! Resource Builder completely tested and adopted for Windows Vista.
Command line interface extended. Command-line interface of Resource Builder extended by adding update resource functionality.
Preview panel in Image Editor. Resource Builder allows to see real-time preview for editing graphical resources in the Image Editor.
Icon selector. It is possible to select which icon or cursor image to load while loading or inserting icons into Image Editor or resources.
Align center horizontally and vertically in Dialog Editor. New commands added to Dialog Editor to align selected controls center in window horizontally or vertically.
Resource Linker allows to select linking method. You can choose between internal linking method and Windows API.
A lot of improvements made in resource compiler and other modules.
http://rapidshare.com/files/53290089/rebuil_home.rar.html
Boyut : 8.3mb
ilker_32
Hocam program .dll uzantısını açmıyor yada desteklemiyor. Örnek olarak diyalog kutusu yapıp kaydettim uzantısı .rc oldu. Farklı bir uzantı ile kaydetmek istesem .dll yok.
