Bu Kodları Nasıl HEX'e Çevirebilirim
Başlatan sozkarabacak, 12 Mart 2014, 18:15:30
sozkarabacak
Aşağıdaki kodları nasıl HEX e çevirebilirim?
$regfile = "m88def.dat"
$crystal = 22118400                                         '$baud = 19200
Config Lcdpin = Pin , Rs = Portb.0 , E = Portd.0 , Db4 = Portc.0 , Db5 = Portc.1 , Db6 = Portc.2 , Db7 = Portc.3
Config Lcd = 16 * 2
Config Adc = Single , Prescaler = Auto , Reference = Avcc : Start Adc
Config Portb.1 = Output , Portd.3 = Output , Portd.7 = Output       'b1=256/64 div., d7=pre+div power off
Config Timer0 = Timer , Prescale = 1024
Config Timer1 = Counter , Edge = Rising
'Config Timer2 = Timer , Prescale = 1024
Set Portd.3                                                 'power on
Set Portd.4                                                 'pullup taste
Set Portb.1                                                 'div 64
Config Int0 = Change : Enable Int0 : On Int0 Inte0:
Enable Timer1 : On Timer1 Count1int:
Enable Timer0 : On Timer0 Tim0ov:
'Enable Timer2 : On Timer2 Tim2:
Enable Interrupts
Dim C As Long , Ci As Long , Z As Long , A As Word , I As Integer , H As Long , T As Long
Do
 Cls
 C = Counter1
 Ci = Ci + C
 'Ci = Ci / Z
 Lcd Ci
 H = H * 11
 H = H / Z
 'Lcd Z ; " " ; H
 Locate 2 , 1
 A = Getadc(4) : I = -1
 Do                                                         'S-Wert berechnen
  A = A / 2 : I = I + 1
 Loop Until A = 0
 Lcd "S" ; I
 A = Getadc(5)                                              ' U Batt.
 Locate 2 , 5
 Lcd A ; "V"
 A = A / 100
 Locate 2 , 4
 Lcd A ; "," : Locate 2 , 9
 H = 0 : Z = 0 : Ci = 0 : Counter1 = 0
 'Tccr1b = 7
 Enable Int0
 Timer0 = 0
 Do
 Loop Until H > 13400 And Timer0 > 140
 Disable Int0
 'Tccr1b = 0
 Portd.3 = Pind.4                                           'power off
Loop
Inte0:
 Disable Int0
 If Pind.2 = 1 Then
  Tccr1b = 7
  Timer0 = 0
  Z = Z + 1
 Else
  Tccr1b = 0
  T = Timer0
  H = H + T
 End If
 Enable Int0
Return
Count1int:
 Ci = Ci + 65536                                            'zählt die überläufe von counter1
Return
Tim0ov:
 H = H + 256
Return
End
http://picasaweb.google.com/33elektronik http://www.33elektronik.tr.cx MSN: [email]sukruozkarabacak@hotmail.com[/email]
