02 Haziran 2020, 08:10:53
twi veri alma problemi
Başlatan berkay_91, 18 Eylül 2014, 14:31:19
berkay_91
mrb, aşağıdaki master ve slave için koyduğum programlar twi ile iki microişlemcinin birbirine veri göndermesi için ancak ilk veri, master transmitter olduğunda gönderildikten sonra birdaha slave tarafından master 'a veri gelmiyor her ikisinede LCD bağlayıp denedim olmadı yardımcı olur musunuz?
MASTER
 * twi_master.c
 * Created: 16.09.2014 12:51:27
 *  Author: BERKAY
#define F_CPU 1000000
#include <stdio.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <util/delay.h>
#include <inttypes.h>
#include "lcd.h"
void TWI_start(void);
void TWI_repeated_start(void);
void TWI_init_master(void);
void TWI_write_address(unsigned char);
void TWI_read_address(unsigned char);
void TWI_write_data(unsigned char);
void TWI_read_data(void);
void TWI_stop(void);
volatile unsigned char address=0x20read=1write=0;
volatile unsigned char write_data=0x03recv_data;
FILE lcd_str FDEV_SETUP_STREAM(lcd_putcNULL_FDEV_SETUP_WRITE);
int main(void){
DDRD=0XFF;
lcd_init(LCD_DISP_ON);
stdout stdin = &lcd_str;
_delay_ms(10);
TWI_init_master();  // Function to initialize TWI
lcd_clrscr();
lcd_gotoxy(2,0);
lcd_puts("TWI MASTER");
while(
1)
TWI_start(); // Function to send start condition
TWI_write_address(address+write); // Function to write address and data direction bit(write) on SDA
TWI_write_data(write_data);      // Function to write data in slave
TWI_stop(); // Function to send stop condition
_delay_ms(10); // Delay of 10 mili second
TWI_start();
TWI_read_address(address+read); // Function to write address and data direction bit(read) on SDA
TWI_read_data(); // Function to read data from slave
TWI_stop();
_delay_ms(10);
write_data write_data 2;
void TWI_init_master(void// Function to initialize master
TWBR=0x01// Bit rate
TWSR=(0<<TWPS1)|(0<<TWPS0); // Setting prescalar bits
// SCL freq= F_CPU/(16+2(TWBR).4^TWPS)
// Clear TWI interrupt flag, Put start condition on SDA, Enable TWI
TWCR= (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
while(!(
TWCR & (1<<TWINT))); // Wait till start condition is transmitted
while((
TWSR 0xF8)!= 0x08); // Check for the acknowledgement
while(!(
TWCR & (1<<TWINT))); // wait till restart condition is transmitted
while((
TWSR 0xF8)!= 0x10); // Check for the acknoledgement
void TWI_write_address(unsigned char data)
TWDR=data// Address and write instruction
TWCR=(1<<TWINT)|(1<<TWEN);    // Clear TWI interrupt flag,Enable TWI
while (!(
TWCR & (1<<TWINT))); // Wait till complete TWDR byte transmitted
while((
TWSR 0xF8)!= 0x18);  // Check for the acknoledgement
void TWI_read_address(unsigned char data)
TWDR=data// Address and read instruction
while (!(
TWCR & (1<<TWINT))); // Wait till complete TWDR byte received
while((
TWSR 0xF8)!= 0x40);  // Check for the acknoledgement
void TWI_write_data(unsigned char data)
TWDR=data// put data in TWDR
while (!(
while((
TWSR 0xF8) != 0x28); // Check for the acknoledgement
while (!(
while((
TWSR 0xF8) != 0x58); // Check for the acknoledgement
recv_data=TWDR;
lcd_gotoxy(0,1);
printf("%d",recv_data);
void TWI_stop(void)
// Clear TWI interrupt flag, Put stop condition on SDA, Enable TWI
TWCR= (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
while(!(
TWCR & (1<<TWSTO)));  // Wait till stop condition is transmitted
SLAVE
 * twi_slave.c
 * Created: 16.09.2014 13:06:27
 *  Author: BERKAY
#include <stdio.h>
#include <avr/io.h>
#include "lcd.h"
void TWI_init_slave(void);
void TWI_match_read_slave(void);
void TWI_read_slave(void);
void TWI_match_write_slave(void);
void TWI_write_slave(void);
volatile unsigned char write_data,recv_data;
int main(void){
DDRD=0XFF;
TWI_init_slave(); // Function to initilaize slave
lcd_clrscr();
lcd_gotoxy(3,0);
lcd_puts("TWI SLAVE");
while(
1)
TWI_match_read_slave(); //Function to match the slave address and slave direction bit(read)
TWI_read_slave(); // Function to read data
write_data=recv_data// Toggle the receive data
TWI_match_write_slave(); //Function to match the slave address and slave dirction bit(write)
TWI_write_slave();       // Function to write data
void TWI_init_slave(void// Function to initilaize slave
TWAR=0x20// Fill slave address to TWAR
void TWI_write_slave(void// Function to write data
TWDRwrite_data;           // Fill TWDR register whith the data to be sent
TWCR= (1<<TWEN)|(1<<TWINT);   // Enable TWI, Clear TWI interrupt flag
while((
TWSR 0xF8) != 0xC0); // Wait for the acknowledgement
void TWI_match_write_slave(void//Function to match the slave address and slave dirction bit(write)
while((
TWSR 0xF8)!= 0xA8// Loop till correct acknoledgement have been received
// Get acknowlegement, Enable TWI, Clear TWI interrupt flag
TWCR=(1<<TWEA)|(1<<TWEN)|(1<<TWINT);
while (!(
TWCR & (1<<TWINT)));  // Wait for TWINT flag
// Clear TWI interrupt flag,Get acknowlegement, Enable TWI
TWCR= (1<<TWINT)|(1<<TWEA)|(1<<TWEN);
while (!(
while((
TWSR 0xF8)!=0x80); // Wait for acknowledgement
recv_data=TWDR// Get value from TWDR
lcd_gotoxy(0,1);
void TWI_match_read_slave(void//Function to match the slave address and slave dirction bit(read)
while((
TWSR 0xF8)!= 0x60)  // Loop till correct acknoledgement have been received
while (!(
