Atmel Cortex-M7 300 Mhz
Başlatan engerex, 01 Nisan 2015, 19:59:17
engerex
 Atmel ARM tarafında rakiplerine göre daha atak davranmaya başladı. 300Mhz saat hızında ARM Cortex M7. Üstelik deneme kiti dahil ürünler satışta. Rakiplerinin bir kaçı sadece duyurup sitelerine bir kaç döküman eklemekle yetindi.
E70/S70
V70/V71
SAM V71
Description
ARM Cortex-M7 based MCU running up to 300MHz with 16kB Instruction and 16kB Data Cache
Up to 2MB embedded Flash and 384kB Multiport SRAM
Up to 128kB Instruction Tightly Coupled Memory (TCM) and 128kB Data TCM
Quad SPI with execute-in-place
USB High-Speed controller with integrated PHY
Ethernet-AVB with hardware traffic shaping
MediaLB 3-wire interface
CAN-FD Controllers
SSC module for TDM / I2S connectivity
High-Speed Multimedia Card Interface
CMOS Camera Interface
True Random Number Generator, SHA-256 and AES-256 cryptographic engines
12-bit ADC and DAC
Low power backup with 1KB SRAM with wake-up on CAN < 85uA @ 85C
QFP, BGA and QFN wet-able flanks package options (SAM V71J: 64 pins; SAM V71N: 100 pins; SAM V71Q: 144 pins)
http://www.atmel.com/products/automotive/automotive_microcontrollers/smart-arm-based-automotive-mcus.aspx
