16F127 lcd çalışmıyor..
Başlatan creastfallen, 24 Ocak 2016, 20:58:42
creastfallen
Merhaba arkadaşlar. 16F1827 entegre ile lcd'yi çalıştıramadım. Aşşağıda main, lcd.c ve lcd.h dosyalarını paylaştım.Yardım edermisiniz..
[main]
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <xc.h>
#include "lcd.h"
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable (PWRT enabled)
#pragma config MCLRE = OFF      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = ON          // Flash Program Memory Code Protection (Program memory code protection is enabled)
#pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable (Brown-out Reset enabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = ON        // Internal/External Switchover (Internal/External Switchover mode is enabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config PLLEN = OFF      // PLL Enable (4x PLL disabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LVP = OFF        // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
#define _XTAL_FREQ 8000000L
void main(void)
      CM1CON0 = 0x00;
      CM2CON0 = 0x00;
      CM2CON1 = 0x00;
      ANSELA = 0x00;
      ANSELB = 0x00;
      OSCCONbits.SPLLEN  = 0b0;
      OSCCONbits.IRCF3   = 0b1;
      OSCCONbits.IRCF2   = 0b1;
      OSCCONbits.IRCF1   = 0b1;
      OSCCONbits.IRCF0   = 0b0;
      OSCCONbits.SCS0    = 0b0;
      OSCCONbits.SCS1    = 0b0;
      PORTA = 0x00;
      TRISA = 0x00;
      PORTB = 0x00;
      TRISB = 0x00;
    unsigned int sayi=12345;
    unsigned char text[6];
    lcd_init();
	lcd_goto(0);	// select first line
	lcd_puts("LCD SAYI DENEME");
	sprintf(text,"sayi= %u",sayi);
	lcd_goto(0x40);	// Select second line
    lcd_puts(text);
      while(1)
         LATAbits.LATA6 = 0b1;
         __delay_ms(500);
         LATAbits.LATA6 = 0b0;
         __delay_ms(500);
[code][lcd.c]
#include <p18cxxx.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <xc.h>
#include "lcd.h"
#define	LCD_RS RB1
#define LCD_EN RB0
#define LCD_DATA4 RB4
#define LCD_DATA5 RB5
#define LCD_DATA6 RB6
#define LCD_DATA7 RB7
#define	LCD_STROBE()	((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void lcd_write(unsigned char c)
	__delay_us(40);
        unsigned char cv = (c>>4);
        LCD_DATA4 = (cv >> 0) & 0x01;
        LCD_DATA5 = (cv >> 1) & 0x01;
        LCD_DATA6 = (cv >> 2) & 0x01;
        LCD_DATA7 = (cv >> 3) & 0x01;
	LCD_STROBE();
        LCD_DATA4 = (c >> 0) & 0x01;
        LCD_DATA5 = (c >> 1) & 0x01;
        LCD_DATA6 = (c >> 2) & 0x01;
        LCD_DATA7 = (c >> 3) & 0x01;
	LCD_STROBE();
 * 	Clear and home the LCD
void lcd_clear(void)
	LCD_RS = 0;
	lcd_write(0x1);
	__delay_ms(2);
/* write a string of chars to the LCD */
void lcd_puts(const char * s)
	LCD_RS = 1;	// write characters
	while(*s)
		lcd_write(*s++);
/* write one character to the LCD */
void lcd_putch(char c)
	lcd_write( c );
 * Go to the specified position
void lcd_goto(unsigned char pos)
	LCD_RS = 0;
	lcd_write(0x80+pos);
/* initialise the LCD - put into 4 bit mode */
void lcd_init()
	char init_value;
	init_value = 0x3;
	LCD_RS = 0;
	LCD_EN = 0;
	__delay_ms(15);	// wait 15mSec after power applied,
        LCD_DATA4 = (init_value >> 0) & 0x01;
        LCD_DATA5 = (init_value >> 1) & 0x01;
        LCD_DATA6 = (init_value >> 2) & 0x01;
        LCD_DATA7 = (init_value >> 3) & 0x01;
	LCD_STROBE();
	__delay_ms(5);
	LCD_STROBE();
	__delay_us(200);
	LCD_STROBE();
	__delay_us(200);
        LCD_DATA4 = 0;
        LCD_DATA5 = 1;
        LCD_DATA6 = 0;
        LCD_DATA7 = 0;
	LCD_STROBE();
	lcd_write(0x28); // Set interface length
	lcd_write(0x0C); // Display On, Cursor Off, Cursor Blink
	lcd_clear();	// Clear screen
	lcd_write(0x6); // Set entry Mode
[code][lcd.h]
extern void lcd_write(unsigned char);
/* Clear and home the LCD */
extern void lcd_clear(void);
/* write a string of characters to the LCD */
extern void lcd_puts(const char * s);
/* Go to the specified position */
extern void lcd_goto(unsigned char pos);
/* intialize the LCD - call before anything else */
extern void lcd_init(void);
extern void lcd_putch(char);
/*	Set the cursor position */
#define	lcd_cursor(x)	lcd_write(((x)&0x7F)|0x80)
dursuncemal
lcd nin rw ucunu kullanmiyor isen ( - ) ye vermelisin.bosta olmaz!!
creastfallen
Dursun bey devreyi elektronik bord üzerine kurdum ve rw ucunu (-) katota bağladım ama devre çalışmıyor. Kod yukarıda ki gibi...
dursuncemal
lcd init ten once uzun bir delay koy   lcd nin ust satirindaki kareler kayboluyomu diye bir gozle ? hangi derleyici ile calisiyorsun ona gore bi bakalim
creastfallen
uzun bir delay yapalim olacakmış.  derleyici mplabx xc8
dursuncemal
uzun delay calismasi icin degil  ilk satirdaki karecikler  kayboluyorsa gorebilmen icin  once onlarin kaybolmasi lazim.
mesaj birleştirme:: 25 Ocak 2016, 14:21:02
A6 yı da konrol et fonksiyonun calisiyomu?
creastfallen
A6 çalışıyor .Ekranda ilk satırda siyah kareler yok. Rwyi katota (-) ye bağladığımda similasyonda çalıştı ama bordun üzerinde çalışmıyor.
dursuncemal
siyah kareler once gelip sonra kayboluyomu? yoksa hic yok mu?
creastfallen
Siyah kare hiç yok. Simülasyon da çalışıyor bordun üzerinde çalışmıyor.
dursuncemal
bordun ustunden islemciyi cıkart  sadece lcd kalsın. beslemeyi verince kontrast ayari yptıgın potansi cevirince ust satir komle karelerle dolmali. eger olmuyorsa kontrast potanisina bak yada lcd bozuk olabilir. semada pot dogru
ikinci asama islemciyi calistıtınca ilk etapta  kareler kaybolmali. kareler hala yerinde duruyorsa ya baglantintilarinda  yada  lcd_init fonksiyonunda bir sikinti vardir.  rw ucun - olacak.
