Keil #ifdef tanimlamasi
Başlatan M_B, 27 Aralık 2016, 16:26:49
M_B
Merhabalar;
STM32F407 Discovery Ethernet uygulamasının kodlarını inceliyorum.
main icerisinde  olan #ifdef USE_LCD  main başında #define USE_LCD veya keilin  Options C/C++ yerinde göremedim.
Tek bu main icin değil bir takım yerlerde #ifdef xxxx tanımlı farklı isimler de var. Bunların aktif olması için nerde tanımlamalar yapılıyor.
Belkide tam ifade edemedim. Sormal istediğimi :(
  * @file    main.c
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    31-October-2011
  * @brief   Main program body
#include "stm32f4x7_eth.h"
#include "netconf.h"
#include "main.h"
#include "httpd.h"
#include "serial_debug.h"
#define SYSTEMTICK_PERIOD_MS  10
/*--------------- LCD Messages ---------------*/
#define MESSAGE1   "     STM32F4x7      "
#define MESSAGE2   "  STM32F-4 Series   "
#define MESSAGE3   "   Webserver Demo   "
#define MESSAGE4   "                    "
__IO uint32_t LocalTime = 0; 		/* this variable is used to create a time reference incremented by 10ms */
uint32_t timingdelay;
/* Private function prototypes -----------------------------------------------*/
void LCD_LED_Init(void);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured to
       144 MHz, this is done through SystemInit() function which is called from
       startup file (startup_stm32f4xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f4xx.c file
  LCD_LED_Init(); 	/*Initialize LCD and Leds */
  ETH_BSP_Config(); /* configure ethernet (GPIOs, clocks, MAC, DMA) */
  LwIP_Init();  		/* Initilaize the LwIP stack */
  httpd_init();  		/* Http webserver Init */
  while (1)   			/* Infinite loop */
    /* check if any packet received */
    if (ETH_CheckFrameReceived())
					LwIP_Pkt_Handle();  /* process received ethernet packet */
    LwIP_Periodic_Handle(LocalTime); /* handle periodic timers for LwIP */
  * @brief  Inserts a delay time.
  * @param  nCount: number of 10ms periods to wait for.
  * @retval None
void Delay(uint32_t nCount)
   timingdelay = LocalTime + nCount;  /* Capture the current local time */
   while (timingdelay > LocalTime); /* wait until the desired delay finish */
  * @brief  Updates the system local time
  * @param  None
  * @retval None
void Time_Update(void)
  LocalTime += SYSTEMTICK_PERIOD_MS;
  * @brief  Initializes the STM324xG-EVAL's LCD and LEDs resources.
  * @param  None
  * @retval None
#ifdef USE_LCD
  /* Initialize the STM324xG-EVAL's LCD */
  STM32f4_Discovery_LCD_Init();
#endif
  STM_EVAL_LEDInit(LED4);
#ifdef USE_LCD
  /* Clear the LCD */
  LCD_Clear(Black);
  /* Set the LCD Back Color */
  LCD_SetBackColor(Black);
  /* Set the LCD Text Color */
  LCD_SetTextColor(White);
  /* Display message on the LCD*/
  LCD_DisplayStringLine(Line0, (uint8_t*)MESSAGE1);
  LCD_DisplayStringLine(Line1, (uint8_t*)MESSAGE2);
  LCD_DisplayStringLine(Line2, (uint8_t*)MESSAGE3);
  LCD_DisplayStringLine(Line3, (uint8_t*)MESSAGE4);
#endif
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/*********** Portions COPYRIGHT 2012 Embest Tech. Co., Ltd.*****END OF FILE****/
keil bilmiyorum ama ilk zamanlarda genel tanımlamaları burada yapıyordum
M_B
@muhittin_kaplan  hocam;
Hazır projede o kısma da baktım orda tanımlı değildi. O yüzden sorma ihtiyacı duydum.
Diyelim ki hiç bir yerde tanımlı olmazsa ne oluyor.
not: Tek bu örnek için değil elime bir başka kit daha var onun programlarında da
bir takım yerlerde #ifdef tanımı var.  Kodları incelerken zorlanıyorum.
preprocessor deyimi hocam, basitce programın "derlenirken dallanmasını" sağlıyor ifdef ler
ifdef HSE_VALUE //eğer define HSE_VALUE=8000000 gibi bir tanımlama varsa
     MCU yu HSE ye göre CLK ayarlaması yap.
     MCU yu HSI ye göre CLK ayarlaması yap
gibi çalışıyor. bildiğiniz if, farkı derlenme aşamasında programın farklı yerlerinin derlenmesini sağlamak, mcu seçimi, clk ayarı felan gibi.
M_B
Hocam
Demek istediğinizi anladım. Yalnız derleme esnasında diyorsunuz ya tanimliysa o kısmı derler yoksa derlemez. Peki USE_LCD kısmı nerde tanımlıki derleme esnasında fonksiyon içinde kontrol ediliyor.
Void LCD_LED_lnit();
Fonksiyonun en başında #ifdef USE_LCD tanımlı. Yukarılarda veya bir yerde tanımlıki fonksiyon içinde kontrol ediliyor. Tanımlı değilse diğer kismi derliyor.
eğer biryerlerde USE_LCD tanımlıysa Void LCD_LED_lnit(); i derler. Tanımlı olmayabilir.
Tanımlı değilse Kütüphaneyi kullanacak arkadaş bu lcd yi kullanmayacak anlamına gelir. Boşuna derlenmesin.
#ifdef USE_LCD
  /* Clear the LCD */
  LCD_Clear(Black);
#endif
eğer biryerlede tanımlı değilse, yukardaki kodların hiçbiri çalışmaz. (Muhtemelen boar la berebar bir kütüphane geldi. eğer lcd yi kullanmak istiyorsan tanımlama yapmalısın diyor.)
eğer bu kodlar işletiliyorsa debugda görüyorsanız Kütüphanenin *.h içeriğine bakın #define USE_LCD var mı ?
M_B
aramış olduğum
main.h icinde
#define USE_LCD        /* enable LCD  */
tanımlı.
Bilgilendirme icin teşekkürler.
