12F675 Servo Motor
Başlatan ipek, 16 Ocak 2017, 22:41:32
ipek
netten buldum derlerken tek bir uyarı verdi,GPIO.4 'de hiç çıkış gözlemleyemedim,yazılımın init parametreleri hatalı olabilirmi ?
#include <12F675.H>
#fuses INTRC_IO,NOWDT,NOPUT //,NOBROWNOUT
#use delay(clock=4000000)
#use fast_io(a)
#use rs232(baud=9600, xmit=PIN_A2)
//analog implementation
//AN0=target
//AN1=potentiomenter
//driver type:
//type 0: ch0-left, ch1-right,
//type 1: ch0-on/off, ch1-direction
#define driver_type 0
//output (type=0)
#define motorL    PIN_A4
#define motorR 	PIN_A5
//output (type=1)
#define motorON   PIN_A4
#define motorDIR	PIN_A5
//PID
#define Kp 0.2 * 16
#define Ki 0.0 * 16
#define Kd 0.0 * 16
#define dead_band   1
#define offset     30
#define max_pwm    240
#define max_integration 20000
#define derivate_dead_band 10
#byte ADRESH=0x1e
#byte ADRESL=0x9e
#byte ADCON0=0x1f
#byte ANSEL=0x9f
#define get_analog(var) #asm \
	movf	ADRESL,w \
	movwf	&var \
	movf	ADRESH,w \
	movwf	&var+1 \
   #endasm
#define neg16(a) #asm \
  COMF   a,F \
  COMF   &a+1,F \
  INCF   a,F \
  BTFSC  03,2 \
  INCF   &a+1,F \
  #endasm
#define txd16(dato) putc((int)dato); putc((int)(dato>>8))
//long BARG;
#define sgn16(i) (bit_test(i,15))
int sign;
int16 target,pot,e,pwm,tmp,prev_e=0,derivate,integration=0;
void main()
int cont;
 set_tris_a(0b00001011);
 ANSEL=0b00010011;  //0:nc, 001:fosc/8, 0011:DDAA
 #if driver_type==0
 output_low(motorL); output_low(motorR);
 #else
 output_low(motorON);
 #endif
 while(true) //bucle
   //Get analog channels
   //TARGET
   ADCON0=0b10000001; //1: Right, 0: vref=5v, 00:NC, 00: ch=0, 1: start, 1: AD_ON
   delay_us(100);
   bit_set(ADCON0,1); //start
   while(bit_test(ADCON0,1));
   get_analog(target);
   //POTENTIOMETER
   ADCON0=0b10000101; //1: Right, 0: vref=5v, 00:NC, 01: ch=1, 1: start, 1: AD_ON
   delay_us(100);
   get_analog(pot);
//** IMPLEMENTS PID *******
   pwm=0;
   e=target-pot; //error
   derivate=e-prev_e; prev_e=e; //derivate
   if((e>dead_band) || (e+dead_band<0))
      //integrative
      integration=integration+e;
      //Kp
      sign=false;
      if (sgn16(e)) { sign=true; neg16(e); }
      pwm=e*Kp; pwm=pwm>>4;
      if (sign) neg16(pwm);
      //Kd
      sign=false;
      if (sgn16(derivate)) { sign=true; neg16(derivate); }
      if(derivate>derivate_dead_band)
        tmp=derivate*Kd; //tmp=tmp>>4;
        if (sign) neg16(tmp);
        pwm=pwm+tmp;
   //Ki
   sign=false;
   if (sgn16(integration)) { sign=true; neg16(integration); }
   if (integration>max_integration) integration=max_integration;    //check limits
   tmp=integration; tmp=tmp>>4;
   tmp=tmp*Ki; tmp=tmp>>4;
   if (sign) {neg16(tmp); neg16(integration) }
   pwm=pwm+tmp;
   tmp=pwm;
   if(pwm)
      if(sgn16(tmp))
         //negative
         #if driver_type==0
         output_high(motorL);
         #else
         output_high(motorON);
         output_high(motorDIR);
         #endif
         neg16(tmp);
         //positive
         #if driver_type==0
         output_high(motorR);
         #else
         output_low(motorDIR);
         #endif
      tmp+=offset;
      if(tmp>max_pwm) tmp=max_pwm;
   //implements PWM
   for(cont=0;cont<255;cont++)
     delay_us(50);
     if ((int)tmp==cont)
       #if driver_type==0
       #else
       #endif
   #if driver_type==0
   #else
   #endif
/*     //monitor
     putc('0');  txd16(POT);
     putc(0x3c); txd16(TARGET);
     putc(0x3d); txd16(PWM);
  } //while(1)
sifirzero
sifirzero.blogspot.com [email]sifirrzero@gmail.com[/email] iman hem nurdur hem kuvvettir
ipek
CCSC 4.093 ile bu header'i görünce bunun olacağını düşündüm,
[img][http://i.hizliresim.com/Anv7QB.jpg/img]
#include <12F675.H>
#use fast_io(a)
sifirzero
Ccs c ile mikro c karışımı kodlar olmuş.resim gorunmuyor
sifirzero
Derlemiş hiç bir sorun yok sadece while (1)
Olan yeri while (true) yap
ipek
elektronik
//output (type=0)
//output (type=1)
aynı pinler iki defa tanımlanmış.
sadogan
Hocam, #define driver_type 0  ile sürücü tipi belirlemiş
sizin sürücü hangisine uygun bilmiyorum ama type 1 yaparak yeniden derleyip test edebilirsiniz.
sifirzero
Eve gidince bakayım hocam
ilyas KAYA
Ayrıca gp4 analog olarak belirtilmiş. Otomatik olarak giriş oluyor olabilir.
Ansel ı kontrol ediniz. Analog giriş yok ise Ansel ı sıfır yapın
pwm.c
ipek abi kodları bahsettiğin siteden indirip derledim. sanırım burası:
http://www.sportdevices.com/servo/servo.c
proteusta gp4 çıkışını alabildim burada sıkıntı yok gibi. derleyicinin verdiği uyarı ise şu kodlara:
buradaki "e" isimli değişken unsigned olduğu için negatif değer alamaz ancak yukarıdaki if koşulunda sıfırdan küşük mü diye bakılmış. mantık hatası var diye bildirilmiş.
kodlarda belki başka hatalarda olabilir. uzun ve karmaşık olduğu için bulmakta zorlanıyorum. neyse, istersen benim hex dosyasını vereyim belki çalışır:
:1000000000308A0004280000FF238316900000308F
:100010008A00BB288E30A0003708A1003608A20055
:10002000A301A108031D1E282208A100A201083077
:10003000A002A108031D1E28A00126280310A11B51
:100040002528A20DA10DA0031E28A11308003A081F
:1000500003199728C2003E0803199728C2070318FE
:1000600038287F30C202031C9728031997283C28A0
:100070008130C207031897284208A000A101A201FD
:10008000A3013B08C600C6173C08C5003D08C400D4
:100090001830C200C301441C65284108A307031C93
:1000A0005728A20A031D5728A10A0319C31740089D
:1000B000A207031C5E28A10A0319C3173F08BC004E
:1000C000BC173C08A1070318C317C30DA10CA20C51
:1000D000A30CC60CC50CC40C0310C20B4A2801307B
:1000E000A00703189728A11B7C28C60DA30DA20DFD
:1000F000A10DA00303199728C61F8D28A30A031D6D
:100100008D28A20A031D8D28A10A031D8D28A10C8C
:10011000A20CA30CA00A031997283B08C3003F08B0
:10012000C306C31F9528A1179B28A1139B28A001D4
:10013000A101A201A30108008E30A0003608A00290
:100140003708A2003808A100A217A0080319B32895
:100150000310A208031DAF28A1080319B328A20C9D
:10016000A10CA00BA828B71FBA28A109A209A10AAF
:100170000319A20A080003081F3983000515B001FE
:10018000AF01B401B3011F1383161F109F101F117D
:100190009F110730831299000B30831685001330AE
:1001A0009F0083120512851281309F002130A0002C
:1001B000A00BD8289F149F18DB2883161E088312D3
:1001C000A5001E08A60085309F002130A000A00BCE
:1001D000E7289F149F18EA2883161E088312A70099
:1001E0001E08A800AC01AB0127082502A9002608BB
:1001F000AA002808031C280FAA022F082902B10010
:100200002A08B2003008031C300FB2022A08B000DE
:100210002908AF00AA08031D1B292908013C03185F
:10022000CA291B2901302907B6002A08B70003187C
:10023000B70A001CCA292908B3072A0803182A0F7D
:10024000B407A401AA1F2B290130A400A909AA09F7
:10025000A90A0319AA0A2A08B7002908B6000A2021
:100260002308BD002208BC002108BB002008BA00FA
:10027000CD30C100CC30C0004C30BF007C30BE005F
:1002800027202308B9002208B8002108B700200859
:10029000B6002308BD002208BC002108BB002008CE
:1002A000BA00C101C001BF018330BE00272023086E
:1002B000B9002208B8002108B7002008B6009C2029
:1002C0002208AC002108AB00AC0CAB0CAC0CAB0CA6
:1002D000AC0CAB0CAC0CAB0C0F30AC05A408031988
:1002E0007629AB09AC09AB0A0319AC0AA401B21F09
:1002F00080290130A400B109B209B10A0319B20A78
:10030000B208031D872931080A3C0318CA2932089C
:10031000B7003108B6000A202308BD002208BC003F
:100320002108BB002008BA00C101C001BF01BE0105
:1003300027202308B9002208B8002108B7002008A8
:10034000B6002308BD002208BC002108BB0020081D
:10035000BA00C101C001BF018330BE0027202308BD
:10036000B9002208B8002108B7002008B6009C2078
:100370002208AE002108AD00A4080319C429AD0964
:10038000AE09AD0A0319AE0A2D08AB072E080318F3
:100390002E0FAC07A401B41FD4290130A400B30967
:1003A000B409B30A0319B40A34084D3C0318E3290D
:1003B000FF3A031DDF293308203C0318E3294E30A0
:1003C000B4002030B3003408AE003308AD00AE0CEA
:1003D000AD0CAE0CAD0CAE0CAD0CAE0CAD0C0F30CC
:1003E000AE052E08B7002D08B6000A202308BD0070
:1003F0002208BC002108BB002008BA00C101C001CE
:10040000BF01BE0127202308B9002208B800210837
:10041000B7002008B6002308BD002208BC00210850
:10042000BB002008BA00C101C001BF018330BE007B
:1004300027202308B9002208B8002108B7002008A7
:10044000B6009C202208AE002108AD00AE0CAD0C19
:10045000AE0CAD0CAE0CAD0CAE0CAD0C0F30AE0551
:10046000A40803193D2AAD09AE09AD0A0319AE0A65
:10047000B309B409B30A0319B40A2D08AB072E084F
:1004800003182E0FAC072C08AE002B08AD002B086C
:100490002C040319632AAE1F542A0516AD09AE09B0
:1004A000AD0A0319AE0A552A85161E30AD0703188A
:1004B000AE0AAE08031D602A2D08F03C0318632A1B
:1004C000AE01F030AD00B501350F672A742A103047
:1004D000A000A00B692A000035082D02031D722A16
:1004E00005128512B50A642A05128512D428630004
:02400E00F411AB
:00000001FF
ipek
@pwm.c
enteresan senin Hex dosyasını kopyala yapıştır yaptım GPIO.4'den çıkış alabildim.
şimdi bizim derleyicimi hatalı derliyor,yoksa kod'da bir değişiklikmi yaptın sorusu kemirdi beni ,evet o sitede bulmuştum..
ikinci şık ise CCSC PCW derlediği Hex dosyasın Footer'ine günün tarihini ve seçilmiş işlemcinin adını verir acaba sen bunu XC8'demi derledin ?
pwm.c
Alıntı yapılan: ipek - 17 Ocak 2017, 16:55:51
@pwm.c
kodları CCS C 5.065 ile derledim.
pic numarası ve tarih bilgilerini buraya eklerken kendim silmiştim (karışıklık olmasın diye). bilgisayardaki hex dosyasında hepsi duruyor.
bu derleyicilerde eski ve yeni versiyon çok farkeder. forumda benim kullandığım versiyonun linki mevcut oradan indirip deneyebilirsiniz.
ayrıca CCS C kodlarını XC8 derleyemez. aynı picbasicpro ve proton gibi basic yapılı olmasına rağmen çok farklı derleyicilerdir. proton'un bazı komutları karşılığı picbasicpro'da olmuyor. CCS de aynı böyle.
ipek
@pwm.c
sağolasın linkten indirdim sonuç mükemmel..
omereliusuk
Pina4 opencollector pullup yapmadan logic 1 olmaz.
