NASA uzay fotoğrafları
Başlatan CoşkuN, 31 Ekim 2005, 20:19:05
CoşkuN
Aşağıdaki adreste NASA hergün bir uzay fotoğrafını açıklaması ile yayınlıyor:
http://antwrp.gsfc.nasa.gov/apod/archivepix.html
ground
http://prdownloads.sourceforge.net/n/na/nasa-exp
World Wind 1.3.3.1
2005-10-25
Alıntı YapLatest changes:
· NASA Blue Marble Next Generation integrated (Issue WW-443)
· NRL Realtime weather integrated (Issue ADD-29)
· Startup Wizard enabled (WW-380)
· World changing support through menu system (Issue WW-444)
· Moon atmosphere disabled (Issue WW-445)
· Single VS.NET solution (Issue WW-361)
· Blue Marble uses terrain (Issue WW-239)
· Added transparent color for textures (Issue WW-442)
· Opacity Control for showing index of ThemeLayers (Issue WW-25)
· Added distance measuring tool (Issue WW-131)
· Configuration Wizard addresses all settings (Issue WW-301)
· Removed unused DLLs (Issue WW-333)
· Removed obsolete projects (Issue WW-347)
· Renamed Startup Wizard to Configuration Wizard (Issue WW-360)
· Seperate XML settings file for different versions (Issue WW-368)
· Plugin unloading when quiting (Issue WW-393)
· Terrain data won't download and build a mesh when terrain is disabled (Issue WW-394)
· Menu bar can remove buttons (Issue WW-399)
· Network path support (Issue WW-402)
· Bathymetry rendering (Issue WW-398)
· Tiny icon text fixed (Issue WW-400)
· Redundant rescaling icons fixed (Issue WW-423)
· SVS loads layer list fixed (Issue WW-422)
· configuration Wizard runs first (Issue WW-416)
· Mouseover text appears first (Issue WW-252)
· Improved error window during crash (Issue WW-351)
· Dynamic custom terrain loaders (Issue WW-397)
· Alpha transparency for tool bar icons (Issue WW-405)
· World Wind version number based on .exe (Issue WW-413)
· Fullscreen command from an extra running copy ignored (Issue WW-414)
· Removed non existant settings stored in app.config (Issue WW-424)
· Removed OEMPipe and Enter as zoom controls (Issue WW-420)
· Removed unused code (Issue WW-16)
· Removed unused assembly references (Issue WW-410)
· Terrain mesh code updated (Issue WW-404)
· logfile HTTP error messages formatted (Issue WW-415)
· Vsync setting added (Issue WW-409)
| 田︱田田|
Picproje - Sözde değil özde paylaşım..
mhk
Sevgili arkadaşlar, gerçek zamanlı uydu foroğrafları varmı bildiğiniz? Yani Türkiye yada başka ülkeler üzerinden geçerken çekilen yada canlı yayınla gösterilen vs. Şu anda Türiyeyi üstten görmek hoş olurdu.
DumrulBey
Bu konu Bilim Teknik Dergisi'nin Kasım sayısında (-bkz. BİR "TIK"LA DÜNYA TURU, sayfa 72-74) işlenmiş. Gerçi konu Google Earth ile ilgili ama gerçek zamanlı olmadığından yakınılmış. Mesela yakın zamandaki inşaa edilmiş evinizin olduğu yerde yeller esmesi dramatize edilmiş...:)
Aslında böyle bir şeyin olması güvenlik tehditlerini doğuracağından olmasa gerek. En azında belli olanaklara sahip bir ajan değilseniz. Hele hele terörün tırmandığı şu devirde. Ancak NASA'nın sitesinde yakın zamanlarda uluslararası uzay istasyonundan çekilmiş resimler var. Adresini bulursam bir ara naklederim.
Sevgiler, saygılar...
DumrulBey
Ancak http://eol.jsc.nasa.gov/sseop/clickmap adresini bulabildim. Bir kaç ay ara verince ne nedir, nerededir bulmak zor oluyor...:(
mhk
Teşekkür ederim sevgili Dumrulbey, başka bulursan gönder tamam mı?  ;)
