STM32F7 Discovery GPIO setlenmiyor
Başlatan unknownperson, 16 Mart 2017, 16:06:30
unknownperson
STM32F7 Discovery kullanıyorum, çok saçma bir durumla karşı karşıyayım.
STM32CUBEMx 'de GPIO bacağını PI2(MCU pin'i olarak) yani D8(kit üzerinde) belirliyorum.(PI2 sağ tıklayıp Output olarak seçiyorum.)
HAL_GPIO_WritePin() fonksiyonu ile setlemek istiyorum fakat programı load edince kitte o pinde 5V okumayı beklerken 0V okuyorum.
Koddaki main.c şöyle:
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2017 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f7xx_hal.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
	HAL_GPIO_WritePin(GPIOI, GPIO_PIN_2, GPIO_PIN_SET);
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 10;
  RCC_OscInitStruct.PLL.PLLN = 210;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOI_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOI, GPIO_PIN_2, GPIO_PIN_RESET);
  /*Configure GPIO pin : PI2 */
  GPIO_InitStruct.Pin = GPIO_PIN_2;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOI, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
skara1214
__HAL_RCC_GPIOB_CLK_ENABLE(); // bu satırda gpiob nin clockunu aktif ediyor. oysaki siz I nin pinini kullanıyorsunuz[/size]
unknownperson
Hocam ufak denemeler yapmıştım ondan kodu buraya yapıştırırken değiştirmeyi unutmuşum, şimdi kodu tekrar üretip iletimi düzenledim tekrar bi bakabilir misiniz bu şekilde çalıştırdım gene 0V gördüm.
skara1214
hocam debug yapamadan göremessin bence yüksek ihtimal bir yerde hard faulta düşüyordur.zira bende dma yı hal libraryinin kodlarıyla kullanmaya kalkınca hard faulta düştüğünü gördüm. Sonra kendim düzenledim sıknıtı kalmadı.
Sizdede böyle bir sıkıntı varsa sizde registerler üzerinden ayarlama yapabilirsiniz.
unknownperson
Hocam o zaman şöyle diyeyim şimdi bu Cubemx dediğimiz program bizim init ve config işlerimizi main.c içinde tanımlıyor bir de kütüphaneleri gönderiyor. Ben bu projede LCD, GPIO ve DAC kullanıyorum. Ben LCD işini STemWin example'ı ile hallettim. Bu example üzerinden Keil'da Manage Run time environment'ı açarak gerekli şeyleri seçsem. Sonrasında init ve config işlemlerini el ile main.c içine yazsam olur mu ?
skara1214
olur tabi ama neden debug yapmayı reddediyorsunuz onu anlamadım
unknownperson
Aslında şu yüzden elimde çalışan cubemx ile oluşturulmamış bir yazılım var,
Öte yandan cubemx ile olusturduğum gpio, dac yazılımı var ama doğru çalışmıyor.
Amacım çalışan yazılımı bozmadan yazılımları birleştirme.
Öte yandan hard fault ile ilgili bilgim yok. Sanırım breakpoint koyup debugda adım adım yazılım bir yerde takılıyor mu diyee bakıcam writepin'e geliyor mu diye kontrol edicem .
projeyi biryere atarsan (CubeMx) deneyebilirim.
unknownperson
Hocam sanırım sadece GPIO olan projeyi atmamı istediniz, buyrun :
http://www.dosyaupload.com/1Foz
Bu arada stm32f7 discovery pinlerini çok saçma yapmışlar, belki yanlış pine bakıyorumdur o yüzden tekrar bi tüm pinleri ölçeyim.
unknownperson
Hocam sorunu çözdüm, sıkıntı şuymuş flash download kısmında reset and run seçili değilmiş butona basınca tekrar ölçüm yaptım o şekilde anladım.
skara1214
bende o hatayı çok yapıyorum :D alışıyor insan
unknownperson
#11
Ben aslında düzeltmiştim de yeni proje açınca sıfırlanıyormuş ben keil otomatik tutuyor sandım, neyse tecrübe oldu bu da ilk oraya bakıcam artık  ;D
O bitti şu başladı hocam basit bir DAC oluşturmak istedim sadece 2V civarı bir değer görsem yeterli sonrasında kendim bir fonksiyon yazıcam göndermek istediğim değer için.
Hesabı şu şekilde verilmiş :
*** DAC data value to voltage correspondence ***
       The analog output voltage on each DAC channel pin is determined
       by the following equation:
       DAC_OUTx = VREF+ * DOR / 4095
       with  DOR is the Data Output Register
          VEF+ is the input voltage reference (refer to the device datasheet)
        e.g. To set DAC_OUT1 to 0.7V, use
          Assuming that VREF+ = 3.3V, DAC_OUT1 = (3.3 * 868) / 4095 = 0.7V
Şuan aşağıdaki kodu yazdım 0V görüyorum :
#include "main.h"
DAC_HandleTypeDef hdac;
static void MX_DAC_Init(void);
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_DAC_Init();
   HAL_DAC_Start(&hdac, DAC_CHANNEL_1);
  /* Infinite loop */
  while (1)
   HAL_DAC_SetValue(&hdac, DAC_CHANNEL_1, DAC_ALIGN_12B_R, 0x7D0);
    Error_Handler();
    Error_Handler();
/* DAC init function */
  DAC_ChannelConfTypeDef sConfig;
    /**DAC Initialization
  hdac.Instance = DAC;
  if (HAL_DAC_Init(&hdac) != HAL_OK)
    Error_Handler();
    /**DAC channel OUT1 config
  sConfig.DAC_Trigger = DAC_TRIGGER_NONE;
  sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
  if (HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_1) != HAL_OK)
    Error_Handler();
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOG_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  HAL_GPIO_WritePin(GPIOI, GPIO_PIN_0, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_7|GPIO_PIN_6, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOG, GPIO_PIN_7, GPIO_PIN_RESET);
  /*Configure GPIO pins : PI3 PI2 PI11 */
  GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_2|GPIO_PIN_11;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  /*Configure GPIO pin : PI0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  /*Configure GPIO pins : PC7 PC6 */
  GPIO_InitStruct.Pin = GPIO_PIN_7|GPIO_PIN_6;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pin : PG7 */
  GPIO_InitStruct.Pin = GPIO_PIN_7;
  HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  /*Configure GPIO pin : PG6 */
  GPIO_InitStruct.Pin = GPIO_PIN_6;
  /*Configure GPIO pin : PH6 */
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
  HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
  /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI9_5_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI9_5_IRQn);
  * @param  None
  * @retval None
  while(1)
   * @retval None
#endif
