Dsp Programlamak
Başlatan rayman, 19 Mart 2017, 12:00:06
rayman
Buradaki kaynakta Dsp nin Power Supply vede geneş özellikleri verilmiş. Ancak böyle bir Dsp ile çalışmaya kalksak bunu nasıl programlayacaz ? Arayüz programlayıcısı olması gerekmiyor mu ?
XM14
The XM14 DSP module is a very high quality 1-input, 4-output DSP processor with all necessary features for an active 4-way loudspeaker system. The board features 1 XLR input connector and an XLR link connector, two 26- pin output headers which carry all needed signals, 5 LEDs and a push button for preset selection, one LED with push button for Low Cut or Standby (configurable in custom software), a volume pot, and a signal and peak LED. The XM series of products match the Pascal Audio S-Pro Series class D modules for active loudspeakers. The combination of these products provides a plug-and-play solution without the need for additional PCBs. ATTENTION: By default, this board is sold as SMD only module. The THT components (connectors, LEDs, buttons) need to be added in the customer's production facility. Completed products are available as samples; mass production of completed products can be organized on request.
Features:
48kHz sample rate
Ethernet or USB interface (optional)
114dB(A) dynamic range (inputs) / 114dB(A) dynamic range (outputs)
Frequency range 10Hz....22kHz
10 parametric filters on each input and each output
10ms delay on each output
Butterworth, Bessel, Linkwitz-Riley filters up to 24dB / oct.
Limiter on each input and each output
180° phase
Nominal input level: +6dBu
Maximum input level: +21dBu
Nominal output level: +11dBu
Maximum output level: +12dBu
Full configuration and real-time monitoring via PC (Software Included)
Grouping functions available
80 Presets
Mixed-mode 64 bits digital processing
Power supply: Accepts +7V and +/- 15V (regulated)
Power consumption: 150mA (+/-15V) and 400mA (+7V)
