FPGA ve PLL
Başlatan MC_Skywalker, 24 Mayıs 2017, 22:18:00
FPGA içindeki PLL leri kullanmak için aşağıdaki örneği denedim.
1280x800@60Hz çıkış  ve Pixel clock frekansı olan 83.46Mhz elde etmek için FPGA üzerinde ki PLL brimini kullanamak.
Neden bu çözünürlüğü seçtiğime gelince 83.46Mhz gibi küsüratlı bir frekans değeri var.
VGA_Top_Level.vhd
-- Create Date: 20.05.2017 21:14:07
-- Design Name:
-- Module Name: VGA_Top_Level - Behavioral
-- scpecialist@yahoo.com
-- 1280x800@60Hz için VGA
--Pixel Clock Fr: 83.46Mhz
--HOR
----1280 pixel görünür
----  64 Front porch
---- 136 Senkron
---- 200 Back Porch
----1680 Toplam pixel
--VER
----800 Pizel Görünür
----  1 Front Proch
----  3 Senkron
---- 24 Back Porch
----828 Toplam Pixel
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity VGA_Top_Level is
Port (
        Clock_100: IN STD_LOGIC; --VECTOR (1 downto 0);
        VGA_HS,VGA_VS: OUT STD_LOGIC;
        VGA_R,VGA_G,VGA_B: OUT STD_LOGIC_VECTOR (3 downto 0)
end VGA_Top_Level;
architecture MAIN of VGA_Top_Level is
signal VGACLK: std_logic;
component PLL83Mhz is
port (
        clk_in1: in std_logic;
        clk_out: out std_logic
end component PLL83Mhz;
component SYNC is
 port (
       CLK : IN STD_LOGIC;
       HSYNC,VSYNC: OUT std_logic;
       R,G,B: OUT STD_LOGIC_VECTOR (3 downto 0)
end component SYNC;
begin
C1: SYNC port map (VGACLK,VGA_HS,VGA_VS,VGA_R,VGA_G,VGA_B);
C2: PLL83Mhz port map(Clock_100, VGACLK);
end MAIN;
SYNC.vhd
library IEEE;
Entity SYNC is
port (
        CLK : IN STD_LOGIC;
end SYNC;
architecture MAIN of SYNC is
        signal HPOS: integer range 0 to 1680:=0;
        signal VPOS: integer range 0 to 828:=0;
    begin
        process (CLK)
          begin
            if(CLK'EVENT and CLK='1')then
             if(HPOS=1040 or VPOS=428) then
               R<=(others=>'1');
               G<=(others=>'1');
               B<=(others=>'1');
               R<=(others=>'0');
               G<=(others=>'0');
               B<=(others=>'0');
             end if;
               if (HPOS<1680) then
                HPOS<=HPOS+1;
                HPOS<=0;
               if (VPOS<828) then
               VPOS<=VPOS+1;
               VPOS<=0;
               end if;
               end if;
               if (HPOS>64 and HPOS <200) then
                 HSYNC <='0';
                 HSYNC <='1';
               end if;
               if (VPOS>1 and VPOS <4) then
                 VSYNC <='0';
                 VSYNC <='1';
               end if;
               if ((HPOS >0 and HPOS<400) or (VPOS>0 and VPOS<28))then
                 R<=(others=>'0');
                 G<=(others=>'0');
                 B<=(others=>'0');
               end if;
            end if;
        end process;
end  MAIN;
pinler.xcd
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_G[3]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_G[2]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_G[1]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_G[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_R[3]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_R[2]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_R[1]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_R[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_B[3]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_B[2]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_B[1]}]
set_property IOSTANDARD LVCMOS33 [get_ports {VGA_B[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports Clock_100]
set_property IOSTANDARD LVCMOS33 [get_ports VGA_HS]
set_property IOSTANDARD LVCMOS33 [get_ports VGA_VS]
set_property PACKAGE_PIN P19 [get_ports VGA_HS]
set_property PACKAGE_PIN R19 [get_ports VGA_VS]
set_property PACKAGE_PIN W5 [get_ports Clock_100]
set_property PACKAGE_PIN H19 [get_ports {VGA_R[1]}]
set_property PACKAGE_PIN N19 [get_ports {VGA_R[3]}]
set_property PACKAGE_PIN J19 [get_ports {VGA_R[2]}]
set_property PACKAGE_PIN G19 [get_ports {VGA_R[0]}]
set_property PACKAGE_PIN J17 [get_ports {VGA_G[0]}]
set_property PACKAGE_PIN H17 [get_ports {VGA_G[1]}]
set_property PACKAGE_PIN G17 [get_ports {VGA_G[2]}]
set_property PACKAGE_PIN D17 [get_ports {VGA_G[3]}]
set_property PACKAGE_PIN N18 [get_ports {VGA_B[0]}]
set_property PACKAGE_PIN K18 [get_ports {VGA_B[1]}]
set_property PACKAGE_PIN L18 [get_ports {VGA_B[2]}]
set_property PACKAGE_PIN J18 [get_ports {VGA_B[3]}]
