ADC okuma olmuyor
Başlatan yunus58, 01 Şubat 2018, 17:44:17
yunus58
Ben stm32f103c8t6 kullanıyorum,yapmaya çalıştığım bir adc versini arayüz ile göstermek usart ile.Yazdığım kodda bilgisiyar üzerinden hep 1 değerini okuyorum.Hatam nerede olabilir.Teşekkürler, iyi çalışmlar
#include "stm32f10x.h"                  // Device header
#include <stdio.h>
#include <stdlib.h>
char str[50];
uint32_t i;
uint16_t Read_ADC(void)
ADC_RegularChannelConfig(ADC1,ADC_Channel_0,1,ADC_SampleTime_55Cycles5);
	ADC_SoftwareStartConvCmd(ADC1,ENABLE);
	while(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)==RESET)
	return ADC_GetConversionValue(ADC1);
void USART_Puts(USART_TypeDef*USARTx,volatile char*s)
while(*s)
   while(!(USARTx->SR & 0x00000040));
	 USART_SendData(USARTx,*s);
	*s++;
int main()
  uint16_t ADC_Data;
	ADC_InitTypeDef  ADC_InitStructure;
	USART_InitTypeDef USART_InitStructure;
	RCC_ADCCLKConfig(RCC_PCLK2_Div4);
	ADC_DeInit(ADC1);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
	GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;
	GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3;
	GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz;
	GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
	GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2;
	GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
   GPIO_Init(GPIOA, &GPIO_InitStructure);
	USART_InitStructure.USART_BaudRate=9600;
	USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
	USART_InitStructure.USART_Mode=USART_Mode_Tx;
	USART_InitStructure.USART_Parity=USART_Parity_No;
	USART_InitStructure.USART_StopBits=USART_StopBits_1;
	USART_InitStructure.USART_WordLength=USART_WordLength_8b;
	USART_Init(USART2,&USART_InitStructure);
	USART_Cmd(USART2,ENABLE);
	//USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
	ADC_InitStructure.ADC_ContinuousConvMode=ENABLE;
	ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right;
	ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;
	ADC_InitStructure.ADC_Mode=ADC_Mode_Independent;
	ADC_InitStructure.ADC_NbrOfChannel=1;
	ADC_InitStructure.ADC_ScanConvMode=DISABLE;
	ADC_Cmd(ADC1,ENABLE);
	ADC_Init(ADC1,&ADC_InitStructure);
	ADC_ResetCalibration(ADC1);
	 while(ADC_GetResetCalibrationStatus(ADC1));
	ADC_StartCalibration(ADC1);
   while(ADC_GetCalibrationStatus(ADC1));
while(1)
ADC_Data=Read_ADC();
	sprintf(str,"%d\n",ADC_Data);
	USART_Puts(USART2,str);
	i=600000;
	while(i)
		i--;
devrecii
        buraları while dönğüsünden önceye al
   while(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)==RESET);   <--buradaki noktalı virgülü unutmuşsun
Usart doğru çalışıyormu diye bir text yada harf göndrip test etmelisin ilk önce
yunus58
dediğinizi yaptım.Şimdi de 1990 ile2100 arasında kafasına göre kendisi değer değiştiriyor.Acaba dediğinizi yanlış mı yaptım?
#include <stdio.h>
#include <stdlib.h>
char str[50];
uint32_t i;
while(*s)
	*s++;
int main()
  uint16_t ADC_Data;
	ADC_DeInit(ADC1);
while(1)
	i=600000;
	while(i)
		i--;
yunus58
aşadaki kod çalışıyor.Ekranda Hello world yazısını çıkıyor.Ama ADC değeri üstte belirttiğim gibi yanlış okuyor.Şimdiden teşekkürler.
while(1)
	sprintf(str,"Hello world\n");
	i=600000;
	while(i)
		i--;
MCU'nun ADC Ref ayağındaki voltajı kontrol edin.  Çin işi stm kartlarında bu durumla karşılaştım.
http://www.st.com/content/ccc/resource/technical/document/application_note/group0/3f/4c/a4/82/bd/63/4e/92/CD00211314/files/CD00211314.pdf/jcr:content/translations/en.CD00211314.pdf
Ayrıca değişkenini tanımlarken 0'a eşitlemeyi unutma.
float ADCRaw=0;
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
	if (__HAL_ADC_GET_FLAG(hadc, ADC_FLAG_EOC))
			ADCRaw = HAL_ADC_GetValue(hadc);
				Vin = 3.31 * (ADCRaw/4095);			//VRef * (ADC Data/2^ADCbit)
/* USER CODE END 0 */
SPI LCD ekrana aşağıda ki gibi gönderiyorum fakat Çin işi STM kitin ADCRef ayağındaki voltaj problemi beni çok uğraştırmıştı.
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
		HAL_ADC_Start_IT(&hadc);
		float X[100], ToplamX=0;
			int j;
			X[0] = Vin;										   //okudugumuz degeri dizinin ilk elemanina
				for (int i=0;i<99;i++) 				//99 kere döngü döner
						j = 98 - i; 							//98 den 0 e dogru geriye saydiralim
						X[j+1] = X[j] ; 					// Her seferinde eski X[j] degerini bir eskisinin yerine tasiyalim
				for (int y=0;y<99;y++)
						ToplamX += X[y];					// tüm X degerlerini toplayip 10 a bölüyoruz.
				OrtalamaX = ToplamX/100;
		sprintf(lcd_buff,"%.3f V", OrtalamaX);
		ssd1306_SetCursor(10,15);
		ssd1306_WriteString(lcd_buff,Font_11x18,White);
		sprintf(lcd_buff,"ADC RAW: %.2f",ADCRaw);
		ssd1306_SetCursor(0,45);
		ssd1306_WriteString(lcd_buff,Font_7x10,White);
		ssd1306_UpdateScreen();
		HAL_Delay(10);
  /* USER CODE END 3 */
devrecii
Yada arkadaş yanlış yerden giriş yapıyor  ;D
yunus58
Aynı sorun bende de var nasıl düzeltiniz peki?
Alıntı yapılan: MC_Skywalker - 02 Şubat 2018, 15:39:02
float ADCRaw=0;
  while (1)
			int j;
		HAL_Delay(10);
Analog
Herkese merhaba. Bende bir adc uygulaması geliştirmeye çalışıyorum ve 32-bit işlemcilerde yeniyim. Elimdeki 32f429 kartı ile basit bir adc yapmaya çalıştım ama kod da herhangi bir hata olmasa da çıkışta hiçbirşey görmüyorum. Sizce hatam nerede olabilir ?
#include "stm32f4xx.h"                  // Device header
/*long map( long x, long in_min, long in_max, long out_min, long out_max)
return (x-in_min)*(out_max-out_min)/(in_max-in_min)+out_min;
int main(void)
	uint16_t								adc_data;
	ADC_CommonInitTypeDef		ADC_CommonInitStructure;
	DAC_InitTypeDef					DAC_InitStructure;
			RCC_AHB1PeriphClockCmd (RCC_AHB1Periph_GPIOA, ENABLE); //to use DAC
	RCC_AHB1PeriphClockCmd (RCC_AHB1Periph_GPIOD, ENABLE); //LEDLER
			RCC_AHB2PeriphClockCmd (RCC_APB2Periph_ADC1, ENABLE); //ADC
	RCC_AHB1PeriphClockCmd (RCC_APB1Periph_DAC, ENABLE); //DAC
	//DAC CHANNEL 1
	GPIO_InitStructure.GPIO_Pin								= GPIO_Pin_4;
	GPIO_InitStructure.GPIO_Mode							= GPIO_Mode_AN;
	GPIO_InitStructure.GPIO_PuPd							= GPIO_PuPd_NOPULL;
	//LEDLER
	GPIO_InitStructure.GPIO_Mode 							= GPIO_Mode_OUT;
	GPIO_InitStructure.GPIO_Pin								= GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14;
	GPIO_InitStructure.GPIO_OType							= GPIO_OType_PP;
	GPIO_Init(GPIOD,&GPIO_InitStructure);
	//ADC CHANNEL
	GPIO_InitStructure.GPIO_Mode							= GPIO_Mode_AIN;
	GPIO_InitStructure.GPIO_Pin								= GPIO_Pin_0;
	//ADC CONFIGURATIONS
	ADC_CommonInitStructure.ADC_Mode					= ADC_Mode_Independent;
	ADC_CommonInitStructure.ADC_Prescaler			= ADC_Prescaler_Div4;
	ADC_CommonInitStructure.ADC_DMAAccessMode= ADC_DMAAccessMode_Disabled;
	ADC_CommonInitStructure.ADC_TwoSamplingDelay=ADC_TwoSamplingDelay_5Cycles;
	ADC_CommonInit(&ADC_CommonInitStructure);
	ADC_InitStructure.ADC_Resolution					= ADC_Resolution_8b;
	ADC_InitStructure.ADC_ExternalTrigConvEdge=ADC_ExternalTrigConvEdge_None;
	ADC_InitStructure.ADC_NbrOfConversion=1;
	ADC_RegularChannelConfig(ADC1,ADC_Channel_0,1,ADC_SampleTime_56Cycles);
	ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
	ADC_DMACmd(ADC1, ENABLE);
	ADC_SoftwareStartConv(ADC1);
	//DAC CONFIGURATIONS
	DAC_InitStructure.DAC_Trigger 						= DAC_Trigger_None;
	DAC_InitStructure.DAC_WaveGeneration			= DAC_WaveGeneration_None;
	DAC_InitStructure.DAC_OutputBuffer				= DAC_OutputBuffer_Enable;
	DAC_Init(DAC_Channel_1, &DAC_InitStructure);
	DAC_Cmd(DAC_Channel_1, ENABLE);
	while(1)
  	adc_data=Read_ADC();
	//	adc_data=map(adc_data,0,255,0,4095);
		DAC_SetChannel1Data(DAC_Align_12b_R, adc_data);
		if(adc_data<51)
		GPIO_ResetBits(GPIOD, GPIO_Pin_12);
		GPIO_ResetBits(GPIOD, GPIO_Pin_13);
    GPIO_ResetBits(GPIOD, GPIO_Pin_14);
		if(50<adc_data &&adc_data<101)
		GPIO_SetBits(GPIOD, GPIO_Pin_12);
		if(100<adc_data &&adc_data<151)
		GPIO_SetBits(GPIOD, GPIO_Pin_13);
		if(150<adc_data &&adc_data<255)
    GPIO_SetBits(GPIOD, GPIO_Pin_14);
