Arduino 5110 LCD Kullanım Sorunu
Başlatan mas, 27 Mart 2018, 02:59:33
mas
Merhaba arkadaşlar, şu sitedeki pil test cihazını güncel donanımlarla yeniden tasarlamak istiyorum.
http://www.vwlowen.co.uk/arduino/battery-tester/battery-tester.htm
Orjinal projede 4X20 lcd kullanılmış günümüzde 5110 lcd hatta çeşitli boyutlarda oled ekranlar varken biraz gereksiz bence. Atmega 328 ve seri port dönüştürücü yerine Arduino nano kullanmayı düşünüyorum. Kalan parçalar standart zaten.
orjinal yazılım aşığadaki gib
/*  Lithium Battery Tester - works with hardware shown at vwlowen.co.uk/arduino/battery-tester/batery-tester.htm */
#include <TimerOne.h>                         //https://github.com/PaulStoffregen/TimerOne
#include <Wire.h>
#include <Adafruit_INA219.h>                  //https://github.com/adafruit/Adafruit_INA219
#include <LiquidCrystal.h>
int end_sounder = A2;                        // Digital output for sounder
boolean sounded = false;
int end_pin = 11;                            // Output pin for end of test LED
int manual_pin = 12;                         // Manual/Run switch. Grounded in Manual.
int manual_value = A3;                       // Set target discharge current with potentiometer
int lcdRS = 2;                               // Define output pins for LCD
int lcdE = 4;
int lcdD4 = 5;
int lcdD5 = 6;
int lcdD6 = 7;
int lcdD7 = 8;
LiquidCrystal lcd(lcdRS, lcdE, lcdD4, lcdD5, lcdD6, lcdD7);
byte bell[8] = {0, 4, 14, 14, 14, 31, 4, 0};  // Data for 'bell' character for LCD.
const byte pwm_pin = 9;                       // PWM DAC, only pins 9 and 10 are allowed
const byte period = 128;                      // for 10 bit DAC
unsigned long  startMillisec;                 // Variables for discharge timer.
unsigned long  sampleTime = 10000;            // Default samples to PC time (ms)
unsigned long millis_PC_wait;                 // Timer for samples to PC
unsigned long millisCalc_mAh;                 // Timer for nexr mAh calc. and LCD write.
float hours;                                  // Working variables for time and mAh
float last_hours = 0.0;
int mins, secs, tMins;
float mAh_soFar = 0.0;
Adafruit_INA219 ina219;                       // Create instance for INA219 sensor library
int current_mA = 0;                       // Variables for INA219 readings
float busvoltage = 0.0;
float shuntvoltage = 0.0;
float loadvoltage = 0.0;
float battery_volts = 0.0;
float vR;                                     // Volt drop in circuit
int target_mA = 0;                            // Default 'set point' variables
float cutoff_voltage = 3.0;
int time_limit = 180;
float offset = 0.0;
float error;
int cancel = 0;                               // Variables and flags to terminate test
boolean timed_out = false;
boolean high_current = false;
boolean cutoff_voltage_reached = false;
boolean manual = false;
int pwm = 0;                                     // Starting PWM value for 10-bit DAC
float kP = 30;                                   // Simple 'Proportional' control term
int tolerance = 1;                               // Deadband to stop 'hunting' around target value
int beep = 1;                                    // Sounder on/off  (0 = off, 1 = on)
/* === Set up - normal setup parameters and initialises values for the contol loop ===== */
void setup() {
  lcd.createChar(1, bell);                       // Bell char for LCD. Displayed when sounder is enabled.
  pinMode(manual_pin, INPUT);                    // MAN/RUN switch. Grounded in MAN position.
  digitalWrite(manual_pin, HIGH);                // Enable internal pullup resistor.
  pinMode(end_pin, OUTPUT);                      // Output to LD to signal end of test.
  digitalWrite(end_pin, LOW);
  pinMode(end_sounder, OUTPUT);                  // Output to sounder.
  digitalWrite(end_sounder, LOW);
  pinMode(pwm_pin, OUTPUT);                      // Set up 10-bit DAC pin as output
  Timer1.initialize(period);                     //
  Timer1.pwm(pwm_pin, pwm);                      // and set zero PWM out
  ina219.begin();                                // Initialise INA219 Current Sensor
  Serial.begin(9600);                           // Initialise Arduino to PC Com Port
  lcd.begin(20, 4);                              // Initialize the LCD.
  lcd.clear();
  delay(100);
  lcd.setCursor(0, 1);
  lcd.print("Initialising...");                  // Print something on the display to show
  delay(1000);                                   // it's working.
  lcd.clear();                                   // Clear display
  delay(100);
  while (digitalRead(manual_pin) == LOW) {          // Loop here to adjust desired load mA manually
     lcd.print("Set mA: ");
     manual = true;
     target_mA = map(analogRead(manual_value), 0, 1023, 0, 1500);
     lcd.setCursor(10, 1);
     lcd.print("      ");
     lcd.print(target_mA);
     time_limit = 480;                               // 8 hours. Test relies on the..
     cutoff_voltage = 3.0;                           // 3.0 volts cutoff voltage.
     kP = 30;                                        // Default values are used in Manual Mode.
     offset = 0;
     tolerance = 1;
     beep = 1;
     cancel = 0;
     delay(200);
  if (!manual) {                                     // If not manual, must be under PC control.
    lcd.print("Waiting for settings");               // Prompt that we're waiting to receive
    lcd.setCursor(6, 2);                             // the load settings from the application
    lcd.print("from PC...");                         // that's running on the PC.
    while (Serial.available() == 0 ) ;              // Wait for settings params from PC
    if (Serial.available() > 0) {                   // Data available on serial port from PC
      target_mA = Serial.parseInt();                // so read each one in turn into variables.
      cutoff_voltage = Serial.parseFloat();         // Minimum battery voltage to end test
      time_limit = Serial.parseInt();               // maximum time allowed for the test
      sampleTime = Serial.parseInt() * 1000;        // Interval to send data to PC
      kP = Serial.parseInt();                       // kP - control loop Proportional value
      offset = Serial.parseFloat();                 // To reduce offset between target and actual mA
      tolerance = Serial.parseInt();
      beep = Serial.parseInt();                     // Sounder on/off   (0=off, 1=on)
      cancel = Serial.parseInt();                   // Will = 0. Clear Cancel flag
    Serial.flush();                                 // Make sure the serial port is empty to avoid
                                                     // false 'Cancel' messages in the control loop.
  /* These lines echo the received values to the LCD and display for 5 seconds  */
  lcd.clear();
  delay(200);
  lcd.print("Target mA   "); lcd.print(target_mA);
  lcd.print("Cutoff v    "); lcd.print(cutoff_voltage);
  if (beep == 1) {
    lcd.setCursor(19, 0);
    lcd.write(1);
  lcd.setCursor(0, 2);
  lcd.print("Time (min)  "); lcd.print(time_limit);
  lcd.setCursor(0, 3); lcd.print("S="); lcd.print(sampleTime/1000);
  lcd.print(" t="); lcd.print(tolerance); lcd.print(" kP="); lcd.print((int)kP);
  lcd.print(" i="); lcd.print(offset, 1);
  delay(8000);
  lcd.clear();
  startMillisec = millis();                        // get millisec time at start
  if (beep == 1) {
    digitalWrite(end_sounder, HIGH);               // Bleep once to indicate test starting.
    delay(50);
/* =========== Get Current and Voltage from Adafruin INA219 breakout board ============ */
void readINA219() {                                 // Function to read curent and voltage from INA219.
  float R = 0.12;                                   // "Tweaking" value to compensate for circuit resistance.
  float temp_mA = 0.0;
  float temp_V = 0.0;
  shuntvoltage = ina219.getShuntVoltage_mV();       // Get values for the INA219 sensor.
  for (int i = 0; i< 10; i++) {
    temp_V = temp_V + ina219.getBusVoltage_V();     // Take average of 10 readings for
    delayMicroseconds(600);                                      // Bus Voltage.......
  busvoltage = temp_V / 10;
  for (int i = 0; i< 20; i++) {
    temp_mA = temp_mA + ina219.getCurrent_mA();     //...... and 20 reading for current.
 current_mA = temp_mA / 20;
  vR = R * current_mA / 1000;                            // Total load voltage has to factor in the
  loadvoltage = busvoltage  + (shuntvoltage/1000) + vR;  // volt drop across the 0.1R shunt & circuit resistance.
/* ========== Main Loop ============================================================= */
void loop() {
  readINA219();                                              // Get current and voltage values.
  /* Calculate error between target_mA and actual mA and apply to PWM value */
  error = abs(target_mA - current_mA);
  error = (error / target_mA) * 100;
  if ((error > tolerance)  ) {                              // If out of tolerance (deadband to stop 'hunting')
    error = error - offset;                                 // Bias (long term error compensation)
    error = (error * kP) / 100;                             // 'proportional' factor reduces impact of 'raw' error.
    error = constrain(error, 0.0, 50.0); // 25
    if (current_mA > target_mA) error = -error;             // Determine if it's a pos or neg error.
    pwm =  abs(pwm + round(error));
    pwm = constrain(pwm, 0, 1023);
  if (current_mA > (target_mA * 2.0) ) {                     // Check if measured current has
     pwm = 0;                                                // overshot the target value by more than
     Timer1.pwm(pwm_pin, pwm);                               // 100% and abort if it has.
     high_current = true;
     target_mA = 0;
     lcd.setCursor(3, 1);
     lcd.print("ERROR - Hi mA");
     Serial.print("MSGSTError - High mAMSGEND");
  if (loadvoltage < cutoff_voltage) {                        // Monitor battery voltage and finish
    delay(3000);                                             // the load test when it reaches the
    readINA219();                                            // target value.  Allow 3 seconds for
    if (loadvoltage < cutoff_voltage) {                     // short dip in battery voltage when
      pwm = 0;                                                 // load comes on.
      cutoff_voltage_reached = true;
      target_mA = 0;
      lcd.setCursor(5, 1);
      lcd.print("FINISHED");
      Serial.print("MSGSTTest FinishedMSGEND");
  if ((!cutoff_voltage_reached) && (tMins > time_limit)) {    // A time limit can also be set to
    pwm = 0;                                                 // abort the test if it appears to
    Timer1.pwm(pwm_pin, pwm);                                // be taking too long.
    timed_out = true;
    target_mA = 0;
    lcd.setCursor(2, 1);
    lcd.print("TIMED OUT");
    Serial.print("MSGSTTime ExceededMSGEND");
      cancel = Serial.parseInt();                   // 999 will calcel the test. 0 will clear Cancel flag
      if (cancel == 999) {                          // 999 from the PC means 'Cancel' the test.
        pwm = 0;
        target_mA = 0;
        lcd.print("CANCELLED");
        Serial.print("MSGSTUser cancelledMSGEND");
    Serial.flush();
  /* If all is ok, outout the PWM value to adjust the current.  */
  if   ((cancel == 0) && (!timed_out) && (!high_current) && (!cutoff_voltage_reached)) {
     Timer1.pwm(pwm_pin, pwm);                               // Adjust PWM to calculated value.
  else {                                                     // otherwise sound the beep and light the
    digitalWrite(end_pin, HIGH);                             // End LED.
    if ((!sounded) && (beep == 1)) {
      sounded = true;
        delay(50);
        delay(50);
  /* Calculate the elapsed time and the mA / hr used each second round the loop. Send to LCD and PC */
  getTime();
  if (millis() > millisCalc_mAh + 1000) {
    float this_hours = (millis() - startMillisec) / (1000.0 * 3600.0);    // Calculate mA used in this time sample
    mAh_soFar = mAh_soFar + ((this_hours - last_hours) * current_mA);     //
    last_hours = this_hours;
    write_to_lcd();                                                       // Write data to LCD
    millisCalc_mAh = millis();
  if (millis() > millis_PC_wait + sampleTime) {               // If the Sample-to-PC time has
      write_to_pc();                                          // elapsed, send data to the PC
      millis_PC_wait = millis();                              // and reset the elapsed time
  }                                                           // counter.
/* ==============  Write values to LCD ========================================== */
void write_to_lcd() {
    lcd.setCursor(0, 0);
    if (current_mA < 1000) lcd.print(" "); if (current_mA < 100) lcd.print(" ");
    if (current_mA < 10) lcd.print(" ");
    lcd.print(current_mA); lcd.print(" mA");
    lcd.setCursor(9, 0);                              //
    lcd.print(loadvoltage); lcd.print(" v  ");
    if (beep == 1) {
      lcd.write(1);
      lcd.print("Time: ");
      lcd.print((int)hours); lcd.print(":");
      if (mins < 10) lcd.print("0"); lcd.print(mins); lcd.print(":");
      if (secs < 10) lcd.print("0");
      lcd.print(secs);
      lcd.print("Used: "); lcd.print(mAh_soFar); lcd.print(" mAh");
/* =================== Send values to PC =================================== */
void write_to_pc() {
  Serial.print("STARTC");  Serial.print(current_mA); Serial.println(" mAENDC");
  /* Send time elapsed to PC. Formatting is done this end as it's easier than
     having to parse/unparse the string twice at the other end.  */
  Serial.print("STARTT"); Serial.print((int) hours); Serial.print(":");
  if (mins < 10) Serial.print("0"); Serial.print(mins); Serial.print(":");
  if (secs < 10) Serial.print("0"); Serial.print(secs); Serial.println("ENDT");
  /* Send mAh used so far, this sample's current and voltage to PC */
  Serial.print("STARTMAH"); Serial.print(mAh_soFar); Serial.println("ENDMAH");
  Serial.print("GRAPHCS"); Serial.print(current_mA); Serial.println("GRAPHCEND");
  Serial.print("GRAPHVS");  Serial.print(loadvoltage); Serial.println("GRAPHVEND");
  Serial.flush();        // Flush serial port before it returns to the main loop.
/* === Generic routine for hours, minutes and seconds between two millis() values.===*/
void getTime() {
  char buffer[20];
  unsigned long nTime;
  unsigned long milli =  millis() - startMillisec;
  nTime = milli / 1000;
  tMins = nTime / 60;
  nTime = nTime % (24*3600);
  hours = nTime / 3600;
  nTime = nTime % 3600;
  mins  = nTime / 60;
  secs  = nTime % 60;
buda benim 5110 için yeniden derlediğim program. şu haliyle ekranda normal yazılar görünüyor, program kısmen çalışıyor ancak değişkenlerin olduğu bölümlerde garip şekiller çıkıyor.
#include <Wire.h>
#include <LCD5110_Basic.h>
LCD5110 myGLCD(4,5,6,7,8);
extern uint8_t SmallFont[];
float offset = 0.0;
float error;
void setup() {
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  delay(100);
  myGLCD.print("Initialising...", CENTER, 8);                  // Print something on the display to show
  myGLCD.clrScr();                                   // Clear display
  delay(100);
     myGLCD.print("Set mA: ", LEFT, 8);
     manual = true;
     myGLCD.print(target_mA,RIGHT, 8);
     offset = 0;
     tolerance = 1;
     beep = 1;
     cancel = 0;
     delay(200);
    myGLCD.print("Waiting for ", CENTER, 0);
    myGLCD.print("settings", CENTER, 8);              // Prompt that we're waiting to receive
    myGLCD.print("from PC...", CENTER, 16);                         // that's running on the PC.
  myGLCD.clrScr();
  delay(200);
  myGLCD.print("Target mA   ", LEFT, 0); myGLCD.printNumI(target_mA, RIGHT, 0);
  myGLCD.print("Cutoff v    ", LEFT, 8); myGLCD.printNumI(cutoff_voltage, RIGHT, 8);
   myGLCD.print("Time (min)  ", LEFT, 16); myGLCD.print(time_limit, RIGHT, 16);
 myGLCD.print("S=", LEFT, 24); myGLCD.print(sampleTime/1000, RIGHT, 24);
  myGLCD.print(" t=", LEFT, 32); myGLCD.print(tolerance, CENTER, 32); myGLCD.print(" kP=", LEFT, 40); myGLCD.print((int)kP, LEFT, 48);
  myGLCD.print(" i=", CENTER, 48); myGLCD.printNumI(offset, 1, RIGHT, 48);
  delay(8000);
  myGLCD.clrScr();
  if (beep == 1) {
    delay(50);
  float temp_V = 0.0;
void loop() {
     target_mA = 0;
     myGLCD.print("ERROR - Hi mA", LEFT, 16);
      target_mA = 0;
      myGLCD.print("FINISHED", LEFT, 32);
    timed_out = true;
    target_mA = 0;
    myGLCD.print("TIMED OUT", LEFT, 16);
        pwm = 0;
        target_mA = 0;
        myGLCD.print("CANCELLED", LEFT, 24);
    Serial.flush();
      sounded = true;
        delay(50);
        delay(50);
  getTime();
  }                                                           // counter.
    if (current_mA < 1000) myGLCD.print(" ", LEFT, 0); if (current_mA < 100) myGLCD.print(" ", LEFT, 8);
    if (current_mA < 10) myGLCD.print(" ", LEFT, 8);
    myGLCD.printNumI(current_mA, LEFT, 16); myGLCD.print(" mA", RIGHT, 16);                          //
    myGLCD.printNumI(loadvoltage, LEFT, 24); myGLCD.print(" v  ", RIGHT, 24);
    if (beep == 1) {
    myGLCD.print("1", LEFT, 32);
      myGLCD.print("Time: ", LEFT, 8);
 myGLCD.printNumI((int)hours, LEFT, 16); myGLCD.print(":", CENTER, 16);
      if (mins < 10) myGLCD.print("0", LEFT, 16); myGLCD.printNumI(mins, LEFT, 16); myGLCD.print(":", LEFT, 16);
      if (secs < 10) myGLCD.print("0", LEFT, 16);
     myGLCD.printNumI(secs, LEFT, 24);
void getTime() {
  char buffer[20];
  tMins = nTime / 60;
  mins  = nTime / 60;
  secs  = nTime % 60;
yaklaşık 3 saattir uğraşıyorum işin içinden çıkamadım. yardımınız için şimdiden teşekkürler.
Murat Mert
S.A.
değişkenler için
float float_val = 123.45;
int int_val = 12345;
myGLCD.printNumI(int_val,0,5,5,"  ");
myGLCD.printNumI(değişken, x balangıç pixel, y başlangıç pixel, ekranda kaç karekter görüneceği, görünecek karakterden az olursa ne gösterileceği)
myGLCD.printNumI(int_val,0,5,5,'  '); şimdi bu komutta ekranda
"12345 "görünür eğer
int_val = 123; olursa ekranda
myGLCD.printNumI(int_val,0,5,5,'  '); olursa ekranda "  123" görünür
myGLCD.printNumI(int_val,0,5,5,'0'); olursa ekranda "00123" görünür
myGLCD.printNumF(float_val,2,0,5, '.' ,3,'  '); şimdi bu komutta ekranda
"123.45" görünü
myGLCD.printNumF( float değişken, ayıraçtan sonra kaç rakan olacağı, x başlangıç, y başlangıç, '.' ayıraç işareti(',' de olabilir), ayıraçtan önce görünen sayı basamağı, görünecek basamak karakterden az olursa ne gösterileceği)
float_val = 12,45;
" 12.45"
myGLCD.printNumF(float_val,2,0,5, '.' ,3,'0');
"012.45"
myGLCD.printNumF(float_val,1,0,5, '.' ,3,'  ');
"12.4" görünür.
hatalar atlamalar zıplamalar olduysa affola. Kolay gelsin.
mert07
