Yeni PIC18 Q10 Product Family
Başlatan OG, 31 Mayıs 2018, 15:44:42
http://www.microchip.com/promo/pic18f-q10-product-family
PIC® MCUs for Closed-loop Control:
From pool pumps to air handling units, closed-loop control is one of the most fundamental tasks performed by embedded systems. Advancements in the architecture of PIC® 8-bit microcontrollers (MCUs) have optimized the devices for implementing closed-loop control, enabling systems to offload the Central Processing Unit (CPU) to manage more tasks and save power. To help designers maximize performance and efficiency in these systems, Microchip Technology Inc. (NASDAQ: MCHP) has introduced the new PIC18 Q10 family, featuring multiple intelligent Core Independent Peripherals (CIPs) that simplify development and enable quick response time to system events.
PIC18 Q10 Key Attributes
    64 MHz internal oscillator
    Up to 128 KB Flash program memory
    Up to 1 KB data EEPROM
    Up to 3615 B data SRAM
    10-bit ADC2 (ADC with Computation), up to 35 channels
    Four 16-bit timers
    Complementary Waveform Generator (CWG)
    Two comparators
    Zero Cross Detect (ZCD)
    Windowed Watch Dog Timer (WWDT)
    Peripheral Pin Select (PPS)
    Data Signal Modulator (DSM)
    Up to 8 Configurable Logic Cells (CLC)
    5-bit DAC
    EUSART, SPI and I2C
    Available in 28-, 40- and 44-pins
exmachine
Microchip son zamanlarda iyi depara kalktı. Bu seri dijital kontrol uygulamaları için bulunmaz nimet.
Firzen
Beya sağlam bir seri olmuş aslında
Kararsız...
bulut_01
birde 24 bit dac olsa dadından yenmez.
YENİLMEZ..
