22 Nisan 2019, 20:57:20
assembly 16f628a derleme sorunu
Başlatan ahmetguvenn, 01 Temmuz 2018, 20:51:06
ahmetguvenn
01 Temmuz 2018, 20:51:06 Son düzenlenme: 03 Temmuz 2018, 02:57:00 ahmetguvenn
iyi günler
assembly diliyle 16f628a programlamayı öğrenmeye çalışıyorum.
aşağıdaki kodları yazıyor ve derliyorum.
Kod Seç
LIST P=16F628A
INCLUDE "P16F628A.INC"
__CONFIG _XT_OSC _WDT_OFF _PWRTE_ON _MCLRE_ON _BODEN_OFF _LVP_OFF _CPD_OFF _CP_OFF
ORG h
'0000'
CLRF PORTB
BANKSEL TRISB
CLRF TRISB
BANKSEL PORTB
BASLA
MOVLW h
'55'
MOVWF PORTB
DONGU
GOTO DONGU
END
derleme sonucunda şu sonuç çıkıyor.
__________________________________________________________________________________
Kod Seç
Debug build of project `C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.mcp' started.
Language tool versions: MPASMWIN.exe v5.50, mplink.exe v4.48, mplib.exe v4.48
Preprocessor symbol
`__DEBUG' is defined.
Sun Jul 01 17:42:39 2018
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.o".
Clean: Deleted file "C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.err".
Clean: Deleted file "C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.lst".
Clean: Deleted file "C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.cof".
Clean: Deleted file "C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.hex".
Clean: Deleted file "C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.mcs".
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "sss.asm" /l"sss.lst" /e"sss.err" /o"sss.o" /d__DEBUG=1
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 1 : Found directive in column 1. (LIST)
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 2 : Found directive in column 1. (INCLUDE)
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 3 : Found directive in column 1. (__CONFIG)
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 6 : Found directive in column 1. (ORG)
Warning[203] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 7 : Found opcode in column 1. (CLRF)
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 8 : Found directive in column 1. (BANKSEL)
Warning[203] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 9 : Found opcode in column 1. (CLRF)
Message[302] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 9 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 10 : Found directive in column 1. (BANKSEL)
Warning[203] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 12 : Found opcode in column 1. (MOVLW)
Warning[203] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 13 : Found opcode in column 1. (MOVWF)
Warning[203] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 15 : Found opcode in column 1. (GOTO)
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\YENI KLASöR\SSS.ASM 16 : Found directive in column 1. (END)
Executing: "C:\Program Files (x86)\Microchip\MPASM Suite\mplink.exe" /p16F628A "sss.o" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"sss.cof" /M"sss.map" /W
MPLINK 4.48, Linker
Device Database Version 1.12
Copyright (c) 1998-2011 Microchip Technology Inc.
Errors    : 0
MP2HEX 4.48, COFF to HEX File Converter
Errors    : 0
Loaded C:\Users\asus\Desktop\pic uygulama\Yeni klasör\sss.cof.
succeeded.
Language tool versionsMPASMWIN.exe v5.50mplink.exe v4.48mplib.exe v4.48
Preprocessor symbol
Sun Jul 01 17:42:41 2018
BUILD SUCCEEDED
bu derleme sonucunda hex dosyasını proteusta simule ettiğimde uygulama çalışmıyor.Aşağıda eklediğim hatayı veriyor. Yardımcı olursanız sevinirim.
ahmetguvenn
iyi günler
Kod Seç
;======PROG6.ASM====BOLUM7===SYF:116
LIST P=16F628A
INCLUDE
"P16F628A.INC"
SAYAC1
EQU
h'20'
SAYAC2
EQU
h'21'
BANKSEL
TRISB
CLRF
TRISB
MOVLW
h'FF'
MOVWF
TRISA
BANKSEL
PORTB
MOVLW
h'07'
MOVWF
CMCON
CLRF
PORTB
BASLA
MOVLW
h'0A'
MOVWF
SAYAC1
TEST
BTFSC
PORTA,0
GOTO
TEST
MOVLW
h'FF'
MOVWF
SAYAC2
GECIKME
NOP
NOP
NOP
DECFSZ
SAYAC2,F
GOTO
GECIKME
AZALT
DECFSZ
SAYAC1,F
GOTO
YAK
GOTO
BASLA
YAK
MOVF
SAYAC1,W
MOVWF
PORTB
GOTO
TEST
END
derleme sonucuda aşağıdaki hatayı veriyor.
Kod Seç
Debug build of project `C:\Users\asus\Desktop\pic uygulama\KitapProgramlar1\prog6.mcp' started.
Preprocessor symbol
Mon Jul 09 14:39:28 2018
Make: The target "C:\Users\asus\Desktop\pic uygulama\KitapProgramlar1\prog6.o" is out of date.
Executing: "C:\Program Files (x86)\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "prog6.asm" /l"prog6.lst" /e"prog6.err" /o"prog6.o" /d__DEBUG=1
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 2 : Found directive in column 1. (LIST)
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 3 : Found directive in column 1. (INCLUDE)
Warning[205] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 4 : Found directive in column 1. (__CONFIG)
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 8 : Executable code and data must be defined in an appropriate section
Message[302] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 9 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 9 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 10 : Executable code and data must be defined in an appropriate section
Message[302] C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 11 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 11 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 12 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 13 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 14 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 15 : Executable code and data must be defined in an appropriate section
Error[150]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 17 : Labels must be defined in a code or data section when making an object file
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 18 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 19 : Executable code and data must be defined in an appropriate section
Error[150]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 20 : Labels must be defined in a code or data section when making an object file
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 21 : Executable code and data must be defined in an appropriate section
Error[151]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 22 : Operand contains unresolvable labels or is too complex
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 22 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 23 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 24 : Executable code and data must be defined in an appropriate section
Error[150]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 25 : Labels must be defined in a code or data section when making an object file
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 26 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 27 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 28 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 29 : Executable code and data must be defined in an appropriate section
Error[151]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 30 : Operand contains unresolvable labels or is too complex
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 30 : Executable code and data must be defined in an appropriate section
Error[150]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 31 : Labels must be defined in a code or data section when making an object file
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 32 : Executable code and data must be defined in an appropriate section
Error[151]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 33 : Operand contains unresolvable labels or is too complex
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 33 : Executable code and data must be defined in an appropriate section
Error[151]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 34 : Operand contains unresolvable labels or is too complex
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 34 : Executable code and data must be defined in an appropriate section
Error[150]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 35 : Labels must be defined in a code or data section when making an object file
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 36 : Executable code and data must be defined in an appropriate section
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 37 : Executable code and data must be defined in an appropriate section
Error[151]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 38 : Operand contains unresolvable labels or is too complex
Error[152]   C:\USERS\ASUS\DESKTOP\PIC UYGULAMA\KITAPPROGRAMLAR1\PROG6.ASM 38 : Executable code and data must be defined in an appropriate section
Halting build on first failure as requested.
failed.
Preprocessor symbol
Mon Jul 09 14:39:29 2018
BUILD FAILED
yardımcı olursanız sevinirim
Kod başlangıç adresini "org" ile işaretlememişsin, o yüzden hata veriyor. İlk mesajındaki kodda doğru bir şekilde yapılmış bu.
MPLAB'in kurulum klasörünün içinde her işlemci için hazır kod şablonu bulunur. Bunları incelemen fikir verecektir.
PIC16F628A için olanı aşağıda:
Kod Seç
This file is a basic code template for assembly code generation  *
on the PIC16F628AThis file contains the basic code              *
building blocks to build upon.                                    *
Refer to the MPASM User's Guide for additional information on    *
;  features of the assembler (Document DS33014).                    *
;  Refer to the respective PIC data sheet for additional            *
;  information on the instruction set.                              *
;    Filename:     xxx.asm                                          *
;    Date:                                                            *
;    File Version:                                                    *
;    Author:                                                          *
;    Company:                                                        *
;    Files Required: P16F628A.INC                                    *
;    Notes:                                                          *
 list      p=16f628A          ; list directive to define processor
 #include <p16F628A.inc>      ; processor specific variable definitions
 errorlevel  -302              ; suppress message 302 from list file
 __CONFIG  _CP_OFF & _DATA_CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTOSC_OSC_NOCLKOUT
__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
;***** VARIABLE DEFINITIONS
w_temp        EQU    0x7E        ; variable used for context saving
status_temp  EQU    0x7F        ; variable used for context saving
 ORG    0x000            ; processor reset vector
 goto    main              ; go to beginning of program
 ORG    0x004            ; interrupt vector location
 movwf  w_temp            ; save off current W register contents
 movf STATUS,w          ; move status register into W register
 movwf status_temp      ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
 movf    status_temp,w    ; retrieve copy of STATUS register
 movwf STATUS            ; restore pre-isr STATUS register contents
 swapf  w_temp,f
 swapf  w_temp,w          ; restore pre-isr W register contents
 retfie                    ; return from interrupt
main
; remaining code goes here
 goto main   ;loop forever, remove this instruction, for test only
; initialize eeprom locations
 ORG 0x2100
 DE 0x00, 0x01, 0x02, 0x03
 END                      ; directive '
end of program'
bigbey
LIST P=16F628A
__CONFIG    satırlarını tab ile satır başından ileri öteledim ve derledim hata görünmedi
TA6R
kudretuzuner
Amatör
