18F24K22 için konfig ayarları ?
Başlatan mustafa_cmbz, 06 Şubat 2019, 13:26:33
mustafa_cmbz
Merhabalar..
  Config_Start
OSC      = HS     ' High speed Oscillator (16 MHz)
IESO     = OFF    ' Int/Ext Oscillator Switch Over Disabled
PWRT     = On     ' Power Up Timer Enabled
BOREN    = OFF    ' Brownout Reset Disabled
WDT      = OFF    ' Watchdog Timer Disabled
WDTPS    = 256    ' Watchdog Postscaler: 1:256
MCLRE    = On     ' External MCLR enabled
STVREN   = On     ' Stack Overflow Reset Enabled
LVP      = OFF    ' Low Voltage ICSP Disabled
Debug    = OFF    ' Background Debugger Disabled
PBADEN   = OFF    ' Port B ADC functions Disabled
CP0      = OFF    ' Code Protection Block 0 Disabled
CP1      = OFF    ' Code Protection Block 1 Disabled
CPB      = OFF    ' Boot Block Code Protection Disabled
CPD      = OFF    ' Data EEPROM Code Protection Disabled
WRT0     = OFF    ' Write Protection Block 0 Disabled
WRT1     = OFF    ' Write Protection Block 1Disabled
WRTB     = OFF    ' Boot Block Write Protection Disabled
WRTC     = OFF    ' Configuration Register Write Protection Disabled
WRTD     = OFF    ' Data EEPROM Write Protection Disabled
EBTR0    = OFF    ' Table Read Protection Block 0 Disabled
EBTR1    = OFF    ' Table Read Protection Block 1 Disabled
EBTRB    = OFF    ' Boot Block Table Read Protection Disabled
Config_End
en basitinden bu şekilde bir konfig girdiğimde hata alıyorum.Sorun nedir neresini eksik yapıyorum ?
Maxim
18F25K22 çalışan config ayarı
(int osc 16mhz)
Device 18F25K22
Declare Xtal=16
OSCCON.6=1
OSCCON.5=1
OSCCON.4=1
OSCCON.1=1
OSCCON.0=1
Config_Start
  FOSC = INTIO67	;Internal oscillator block
  PLLCFG = OFF	;Oscillator used directly
  PRICLKEN = On	;Primary clock enabled
  FCMEN = OFF	;Fail-Safe Clock Monitor disabled
  IESO = OFF	;Oscillator Switchover mode disabled
  PWRTEN = On	;Power up timer enabled
  BOREN = SBORDIS ;Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
  BORV = 190	;VBOR set to 2.50 V nominal
  WDTEN = OFF	;Watch dog timer is always disabled. SWDTEN has no effect.
  WDTPS = 32768	;1:32768
  CCP2MX = PORTC1	;CCP2 input/output is multiplexed with RC1
  PBADEN = OFF
  CCP3MX = PORTC6	;P3A/CCP3 input/output is mulitplexed with RC6
  HFOFST = OFF	;HFINTOSC output and ready status are not delayed by the oscillator stable status
  T3CMX = PORTC0	;T3CKI is on RC0
  P2BMX = PORTC0	;P2B is on RC0
  MCLRE = INTMCLR	;RE3 input pin enabled; MCLR disabled
  STVREN = OFF	;Stack full/underflow will not cause Reset
  LVP = OFF	;Single-Supply ICSP disabled
  XINST = OFF	;Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
  Debug = OFF	;Disabled
  Cp0 = On	;Block 0 (000800-001FFFh) code-protected
  CP1 = On	;Block 1 (002000-003FFFh) code-protected
  CP2 = On	;Block 2 (004000-005FFFh) code-protected
  CP3 = On	;Block 3 (006000-007FFFh) code-protected
  CPB = On	;Boot block (000000-0007FFh) code-protected
  CPD = OFF	;Data EEPROM not code-protected
  WRT0 = OFF	;Block 0 (000800-001FFFh) not write-protected
  WRT1 = OFF	;Block 1 (002000-003FFFh) not write-protected
  WRT2 = OFF	;Block 2 (004000-005FFFh) not write-protected
  WRT3 = OFF	;Block 3 (006000-007FFFh) not write-protected
  WRTC = OFF	;Configuration registers (300000-3000FFh) not write-protected
  WRTB = OFF	;Boot Block (000000-0007FFh) not write-protected
  WRTD = OFF	;Data EEPROM not write-protected
  EBTR0 = OFF	;Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
  EBTR1 = OFF	;Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
  EBTR2 = OFF	;Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
  EBTR3 = OFF	;Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
  EBTRB = OFF	;Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
Config_End
mustafa_cmbz
Hocam geçen soracaktım kaldı.
xtal=16 demişsiniz oscon lar ile de 16 ya göre ayarlamışsınız osilatörü datasheet öyle diyor fakat devrede 20mhz kristal bağlı benim..
karta 16mhz kristal mı takmam gerekiyor yoksa 20mhz kristali 16mhz gibi mi bölüp çalıştırıyor osilatörü içeride ?
nihayetinde 20mhz kristal ile sizin osilatör ayarları ile gayet iyi çalışıyor niyahetinde usart haberleşmem var sorun yaratacak olsa en başta o çalışmazdı diye düşünüyorum..
Birde diğer config ayarlarının türkçe açıklamaları olsa çok güzel olurmuş..
@mustafa_cmbz hocam hata vermesinin nedeni yazım hatasından kaynaklanıyor. "P18F24K22.PPI" içeriğini inceleyip Config i tanımlarken buradaki yazımları referans alabilirsiniz. Bu MCU için "HS" hatalı bir tanımlama siz harici olarak 16MHZ üzerinde crystal kullanacaksınız "OSC = HSHP" şeklinde kullanmalısınız.
fofo
Device = 18F25K22
Config_Start
     FOSC = INTIO67			     ;interne oscillator A6, A7 poortfuntie
     IESO = OFF			             ;internal external switchover mode
     PWRTEN = On			     ;power-up timer  (18F25K22)
     BOREN = On			             ;brown-out reset
     BORV = 285			             ;brown-out reset value (2,85V) (18F25K22)
     WDTEN = OFF			     ;watchdog timer
     WDTPS = 128			     ;1:128 WDT prescalar
     PBADEN = OFF			     ;analog port B<4:0>
     STVREN = On			     ;;stack overflow reset
     LVP = OFF			             ;low voltage programming
     Debug = OFF			     ;no debug
  CP1 = On	;Block 1 (002000-003FFFh) not code-protected
  CP3 = On	;Block 3 (006000-007FFFh) not code-protected
  CPB = On	;Boot block (000000-0007FFh) not code-protected
  CPD = On	;Data EEPROM not code-protected
  WRT0 = On	;Block 0 (000800-001FFFh) not write-protected
  WRT1 = On	;Block 1 (002000-003FFFh) not write-protected
  WRT2 = On	;Block 2 (004000-005FFFh) not write-protected
  WRT3 = On	;Block 3 (006000-007FFFh) not write-protected
  EBTR0 = On	;Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
  EBTR1 = On	;Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
Config_End
Declare  Xtal = 8
;OSCCON = %01010000 ' 4MHz
OSCCON =%01100010    '// 8 MHz - 18F25K22
