TM1627 CCS C
Başlatan yakup1890, 09 Ağustos 2020, 00:38:58
yakup1890
Merhaba Arkadaşlar
TM1627 ile saat termometre yapmak istiyorum bir türlü süremedim
c ile yazılmış bir kod buldum düzenledim olmadı
yardımcı olurmusunuz
#include <tm1637_pic.h>
#include "DS1302.C"
#include "DHT11.C"
#include  "TM1637-BOLT.h"
#define bright MAX_BRIGHT
byte saniye,dakika,saat,gun,ay,yil,haftanin_gunu;
unsigned int  i=0;
char birler=0, onlar=0,yuzler=0,binler=0,sayi=0;
float sicaklik,nem;
long a=0;
unsigned char digits[]={0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f};
void main()
   //port_a_pullups(0x0C);
   rtc_init();
 InitTM1637();
//displayValues(0,0,0,0);
output_high(pin_a3);
delay_ms(500);
output_low(pin_a3);
   while(TRUE)
for(a=1;a<9999;a++)
displayValues(digits[(a/1000)%10], digits[(a/100)%10], digits[(a/10)%10],
            digits[a%10]);
delay_ms(250);
displayValues(digits[(saat/10)%10], digits[saat%10] | 0x80, digits[(dakika/10)%10],
                 digits[dakika%10]);
      delay_ms(500);
     writeRawDigit(digits[saat%10],1);
//TM1637.H
#define CLK pin_a0
#define DIO pin_a1
//#define CLK_HIGH  pin_a1
//#define DIO_HIGH TRISCbits.TRISC1 = 1
#define LOW_BRIGHT 0X00
#define MID_BRIGHT 0X02
#define MAX_BRIGHT 0X07
void InitTM1637(unsigned char BRIGHT);
void Delay_us(unsigned int useconds);
void start(void);
void ask(void);
void stop(void);
void writeByte(unsigned char oneByte);
void writeRawDigit(unsigned char segment, unsigned char nDigit);
void displayValues(unsigned char segment0, unsigned char segment1, unsigned char segment2, unsigned char segment3);
//   Inicializa y ajusta el brillo del display TM1637
void InitTM1637()
   start();
   writeByte(0x88 | 0X07);
   ask();
   stop();
//   Función de retardos ajustada a los requerimientos de la comunicación con el display TM1637
   unsigned int i;
   for(i=0; i < useconds; i++)
      Delay_us(20);
//   Función que inicia la comunicación en el display TM1637
void start(void)
   output_high(clk);
   output_high(dio);
   Delay_us(2);
   output_low(dio);
//   Función que permite saber si el dato o comando enviado al display TM1637 ha sido recibido y
//   procesado correctamente
void ask(void)
    output_high(dio);
    output_low(clk);
   Delay_us(5);
   while(dio==0);
   output_high(dio);
   Delay_us(2);
  output_low(dio);
   output_low(clk);
//   Secuencia de paro, necesaria para el correcto funcionamiento del protocolo de comunicación
//   con el display TM1637
void stop(void)
     output_low(clk);
   Delay_us(2);
  output_low(dio);
   Delay_us(2);
   output_high(clk);
   Delay_us(2);
   output_high(dio);
//   Envia por el pin DIO los bits de un byte, envia serialmente los datos
   unsigned char i;
   for(i=0; i<8; i++)
     output_low(clk);
      if(oneByte & 0x01)
         output_high(dio);
         output_low(dio);
      Delay_us(3);
      oneByte = oneByte >> 1;
      output_high(clk);
      Delay_us(3);
//   Esta función envía al módulo TM1637 un byte con la representación en 7 segmentos en la
//   posción nDigit
   start();
   writeByte(0x44);
   ask();
   stop();
   start();
   writeByte(0xC0 | (nDigit & 0x07));
   ask();
   writeByte(segment);
   ask();
   stop();
//   Envía 4 caracteres al módulo TM1637 desde la posición 0 hasta la 4 de los segmentos
   start();
   writeByte(0x40);
   ask();
   stop();
   start();
   writeByte(0xC0);
   ask();
   writeByte(segment0);
   ask();
   writeByte(segment1);
   ask();
   writeByte(segment2);
   ask();
   writeByte(segment3);
   ask();
   stop();
isa_olcer
TM1629A için bende uğraşıyorum çözersem paylaşırım.
