magnetik kart okuyucu
Başlatan koordinat, 11 Ekim 2003, 01:39:23
koordinat
arkadaşlar magnetik kart okuyucu ve pic leri kullanarak yapılan bir proje war mı?
mmengi
dostum aşağıda pb pro ile yazılmış bir kod var belki işene yarayabilir.
iyi çalışmalar.
   '   Project MagCard
   '   Embedded Software Version 1.00
   '   Target Processor PIC16F628-04/SP
   '   Target PCB - BB-01
   '   Created 15/06/02
   '   Last Updated 15/06/02
   '   Written by Melanie Newman
   '   Magnetic Card Reader Program
   '      Designed for Mag-Card Track 2
   '      This track contains the numeric information that
   '      is usually printed on the face of your Credit Card
   '      ie Card Number, Start and Expiry Dates etc.
   '   This is a PICBASIC variation on MicroChip application
   '   note AN727 and I refer you to this App Note for details
   '   of how the track is organised.
   '   Written for one LED
   '      LED On=Ready
   '      LED Off=Card Inserted
   '      LED Slow single Blink=Good Read
   '      LED multiple Rapid Blink=Bad Read
   '   MagData is a 40 byte array buffer containing all of Track 2
   '      the first byte (SS) is in MagData(0)
   '   MagError contains any Error Flags
   '   Device Programming Options
   @ DEVICE pic16F628, XT_OSC
         ' System Clock Options
   @ DEVICE pic16F628, WDT_ON
         ' Watchdog Timer
   @ DEVICE pic16F628, PWRT_ON
         ' Power-On Timer
   @ DEVICE pic16F628, BOD_ON
         ' Brown-Out Detect
   @ DEVICE pic16F628, MCLR_ON
         ' Master Clear Options (External)
   @ DEVICE pic16F628, LVP_OFF
         ' Low-Voltage Programming
   @ DEVICE pic16F628, CPD_OFF
         ' Data Memory Code Protect
   @ DEVICE pic16F628, PROTECT_OFF
         ' Program Code Protection
   '   Hardware Assignments
      '   Mag Reader Connections
      '   No Resistors required - relies on Weak Pull-Up's
   MagRDA var PORTB.5   ' Mag-Reader Data Pin
   MagCLK var PORTB.6   ' Mag-Reader Clock Pin
   MagCIN var PORTB.7   ' Mag-Reader Card Loaded & Running Signal
      '   LED Connections
   GreenLED var PORTA.4   ' 330R Resistor from Vdd via LED
            ' Port goes LOW for LED=ON
      '   Unused Ports
      ' RA0, RA1, RA2, RA3, RA5, RA6, RA7
      ' RB0, RB1, RB2, RB3, RB4
   '   EEPROM Locations
      ' None used
   '   RAM Assignments and Variables
   CounterA var byte   ' General purpose Variable
            '   Used as incomming Card-Data bit counter
   CounterB var byte   ' General purpose Variable
            '   Used as byte pointer into Data Buffer
   CounterC var byte   ' General purpose Variable
            '   Used as LRC Summing character
   CounterD var byte   ' General purpose Variable
            '   Used to temporarily store incomming Card-Data bits
            '   and form byte ready for transfer out
   '   The four Counter variables above can be reused.  Once the
   '   Mag-Reader program completes, they are no longer required
   '   However CounterB on exit holds the number of bytes in the Data buffer
   MagData var byte [40]   ' Data Array for Mag-Strip Track
            ' Increase this number for larger buffer size (subject
            '   to the maximum allowed by the PIC and PBP), but
            '   don't forget to also change the constant MagMax
            '   (below) to reflect the new buffer size.
   MagError var byte   ' Error Flags
            '  bit 7 - Used as Temporary Storage for Parity Toggle
            '             it is set to Zero on exit
            '  bit 6 - Unused
            '  bit 5 - Unused
            '  bit 4 - ES (End Sentinel) Not Found
            '  bit 3 - SS (Start Sentinel) Not Found
            '  bit 2 - Buffer Over-Run, Card Data exceeded Buffer space
            '  bit 1 - Parity Error
            '  bit 0 - LRC Error
   '   Program Constants
   MagMax con 40      ' Max Buffer Size
   '   Start Program
   '   This goto below is unnescessary if you are never going to have
   '   any subroutines, so remove it if you wish.
   goto JumpStart
   '   Subroutine Nest Area
   '   There are no subroutines in this program
   '   but if there were any, put them here.
   '   End of Subroutine Nest Area
   '   Actual Start of Real Program
JumpStart:
   '   Set Hardware Directions
   CMCON=%00000111      ' Disable Comparators
   TRISA=%00000000      ' PORTA all set to Output
   TRISB=%11111111      ' PORTB all set to Input
   OPTION_REG.7=0      ' Enable Weak Pull-Ups
   '   Reset Hardware
   Pause 250      ' Timeout for Hardware to settle
   '   Zero variables ready for Card Read
ReadReadyLoop:
   For CounterA=0 to MagMax-1
            ' Clear Data Buffer
      MagData(CounterA)=0
      Next CounterA
   '   Ready to Read
   Low GreenLED      ' Switch-On LED to indicate Ready to Read
   While MagCIN=1:Wend   ' Wait for Card to be inserted
   '   Read Card
   High GreenLED      ' LED Off to indicate Card inserted
   CounterB=0      ' Point to first byte in Data buffer
   CounterC=0      ' Reset LRC Check byte
   MagError=%00011000   ' Reset Read Error Flags
            ' Preset SS and ES errors (to be cleared later)
MagReadByteLoop:
   CounterA=0      ' Reset for first bit of Data
   CounterD=0      ' Reset holding buffer
   MagError.7=0      ' Reset Temporary byte Parity Error Flag
      '   Loop for incomming Data bit
MagReadBitLoop:
   If MagCIN=1 then goto MagReadErrorCheck
            ' Card Removed or movement stopped
   If MagCLK=1 then goto MagReadBitLoop
            ' Loop waiting for Clock Pulse to go Low
   CounterD.4=MagRDA^1   ' Read-in inverting One Card-Data Bit as we go
   MagError.7=MagError.7^CounterD.4
            ' Toggle bit Parity for later byte Parity chaeck
   CounterA=CounterA+1   ' Increment bit Counter
   If CounterA<5 then
            ' There a 5-bits to a byte from the Card... execute
            ' this section if insufficient bits have been received
      CounterD=CounterD>>1
            ' Shift bit Right one place
      While MagCLK=0:Wend
            ' Wait for Clock to go High
      Goto MagReadBitLoop
            ' Loop for next data bit
      endif
      '   Start Bit Synchronisation
            ' Synchonise incomming bits on Start Sentinel
            ' otherwise trash all incomming bits.
            ' Explanation:  Until the SS byte, there could be
            ' an uneven and unpredictable number of bits
            ' in the run-up.  Until the SS is recognised, all such
            ' bits are trashed
   If MagError.3=1 then
            ' This section is only executed if SS has not
            ' yet been detected...
      If CounterD=$0B then
         MagError.3=0
            ' Reset SS Error Flag if SS Received
         CounterA=CounterA-1
            ' Shift Bits Right one place and trash one on the end
         While MagCLK=0:Wend
         Goto MagReadBitLoop
         endif
      endif
      '    5th Data Bit Parity Check on received byte
   If MagError.7<>1 then
            ' Parity must be odd, otherwise there's an error
      MagError.1=1   ' Set Parity Error Flag
      endif
      '   Save byte to main buffer and increment pointer
   MagData(CounterB)=CounterD
            ' Good or Bad, Save the data byte to buffer
   ' If you want to automatically strip-out the parity from the data,
   ' replace the above line with... MagData(CounterB)=CounterD&$0F
   CounterC=CounterC^CounterD
            ' Add received byte for LRC Check at end
   CounterB=CounterB+1   ' Increment to next byte in Data buffer
      '   Deal with LRC
   If MagError.4=0 then
            ' This section is executed only for the LRC
            ' byte following the ES...
      If (CounterC&$0F)<>0 then MagError.0=1
            ' Test for LRC bit error
            ' This is the very last valid byte, so Exit now
      endif
      '   Check for End Sentinel
            ' The ES (End Sentinel) signifies the end of data.
            ' Note that different Cards have different lengths of
            ' data so the ES can be anywhere in the incomming block
            ' of data read from the Card.  Only ONE byte following
            ' the ES (the LRC byte) is valid.  Anything following
            ' the LRC is considered junk and not bothered with.
   If CounterD=$1F then MagError.4=0
            ' Reset ES Error Flag
            ' only one more time thru the loop left once flag Reset
            ' in order to pick up the LRC byte
      '   Check for Buffer Full
   If CounterB=>MagMax then
      MagError.2=1   ' You should never exit here unless the Card contains
            ' more data than is expected (ie this is Buffer over-run)
      endif
      '   Loop around for next incomming byte
   While MagCLK=0:Wend   ' Wait for Clock to go High
   Goto MagReadByteLoop   ' Loop for Next Data Byte
   '   Card Read Complete - Process Exit Proceedure
   '   Check if Good or Bad Card Read
MagReadErrorCheck:
   MagError.7=0      ' Reset Temporary Parity-Count bit
   If MagError<>0 then
      '   Blink LED ten times rapidly to indicate Bad Read
      For CounterA=1 to 10
         Low GreenLED:Pause 50
         High GreenLED:Pause 50
         Next CounterA
      '    Blink LED slowly to indicate Good Read
      Pause 500:Low GreenLED:Pause 500:High GreenLED
      endif
   ' At this point we have one of two possible scenario's...
   ' (1) MagError=0, There are No Errors and MagData is full of Good Data
   '       additionally, CounterB contains the number of data bytes held
   '       in MagData (these bytes include SS, ES and LRC).  Also the
   '       Parity bit (bit 5) has NOT been stripped out in case you wanted
   '       the whole byte intact for your programming... see in the section
   '       "Save byte to buffer..." you'll find a comment indicating what to
   '       change if you want the parity bit removed for you.
   ' (2) MagError<>0.  There's a problem...
   '       Check the flags within MagError to indicate what kind of error
   '       happened, and remember that MagData is probably incomplete or may
   '       contain corrupt or erroneous bytes.
   ' For the purposes of demonstration, all I'm going to do here is pause
   ' a second and then loop back to the start for another Card read.
   ' So you either had a single slow blink on the LED for a Good card-swipe, or
   ' a bunch of rapid blinks on the LED for a Bad card-swipe.
   Pause 1000
   Goto ReadReadyLoop
   End
koordinat
bu kod zaten picbasicpro.com sitesinde var  :lol:
mmengi
dostum benim bulabildiğim buydu belki yardımı olur diye yazmıştım.
koordinat
