TRAFO SİPİR SAYACI
Başlatan salihtolu, 03 Temmuz 2008, 17:05:11
salihtolu
[si
Arkadaşlar yukarıdaki sayactaki 4 haneyi milyona yani 7 haneye nasıl cıkarta biliriz bana
  Yardım  edebilecek arkadaşlardan yardım istiyorum aşagıdaki ASM dosyası fakat
   Neresinden bu haneleri cogalta bilecegimi bulamadım bu devreyi trafo spir sayacı olarak kullanmak istiyorum yardım ederseniz minnettar olurum saygılar
; Source created with Parsic Version 3.x
; at              : 25.05.2008 01:00:29
; Project File    : D:\PARSİC\trafo spir sayıcı\spirsay.PIC
; Project Version : 1.0.17
; Created         : 20.05.2008 23:37:00
; Last change     : 25.05.2008 01:00:27
   PROCESSOR 16F628
   INCLUDE P16F628.INC
   RADIX DEC
   __IDLOCS H'0100'
   __CONFIG _CP_OFF & _PWRTE_OFF & _WDT_OFF & _BODEN_OFF & _XT_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO   EQU Z   ; ZERO-Flag
CARRY    EQU C   ; CARRY-Flag
; Variable
ZV1   = 32   ; located in Bank 0
ZV1_HI   = 33   ; located in Bank 0
ZV1_FD   = 34   ; located in Bank 0
MF1   = 35   ; located in Bank 0
MF1_HI   = 36   ; located in Bank 0
MF1_FD   = 37   ; located in Bank 0
S2   = 38   ; located in Bank 0
S0   = 39   ; located in Bank 0
MF2   = 40   ; located in Bank 0
MF2_HI   = 41   ; located in Bank 0
TR1   = 42   ; located in Bank 0
TR1_HI   = 43   ; located in Bank 0
MF3   = 44   ; located in Bank 0
MF3_HI   = 45   ; located in Bank 0
MF3_FD   = 46   ; located in Bank 0
ZV2   = 47   ; located in Bank 0
ZV2_HI   = 48   ; located in Bank 0
ZV2_FD   = 49   ; located in Bank 0
S1   = 50   ; located in Bank 0
OS1_FD   = 51   ; located in Bank 0
MF4   = 52   ; located in Bank 0
MF4_HI   = 53   ; located in Bank 0
MF4_FD   = 54   ; located in Bank 0
MF5   = 55   ; located in Bank 0
MF5_HI   = 56   ; located in Bank 0
MF5_FD   = 57   ; located in Bank 0
MF6   = 58   ; located in Bank 0
MF6_HI   = 59   ; located in Bank 0
MF6_FD   = 60   ; located in Bank 0
LT1_FD   = 61   ; located in Bank 0
LT2_FD   = 62   ; located in Bank 0
TR2   = 63   ; located in Bank 0
TR2_HI   = 64   ; located in Bank 0
LT3_FD   = 65   ; located in Bank 0
LT4_FD   = 66   ; located in Bank 0
SR1   = 67   ; located in Bank 0
SR1_FD   = 68   ; located in Bank 0
MF7   = 69   ; located in Bank 0
MF7_HI   = 70   ; located in Bank 0
MF7_FD   = 71   ; located in Bank 0
TR3   = 72   ; located in Bank 0
TR3_HI   = 73   ; located in Bank 0
LT5_FD   = 74   ; located in Bank 0
LT6_FD   = 75   ; located in Bank 0
RAM   = 76   ; located in Bank 0
SYS_WSAV   = 112   ; located in Bank 0, 1, 2, 3
SYS_SSAV   = 113   ; located in Bank 0, 1, 2, 3
SYS_TMP1   = 114   ; located in Bank 0, 1, 2, 3
SYS_TMP2   = 115   ; located in Bank 0, 1, 2, 3
SYS_TMP3   = 116   ; located in Bank 0, 1, 2, 3
SYS_TMP4   = 117   ; located in Bank 0, 1, 2, 3
SYS_TMP5   = 118   ; located in Bank 0, 1, 2, 3
SYS_TMP6   = 119   ; located in Bank 0, 1, 2, 3
SYS_TMP9   = 120   ; located in Bank 0, 1, 2, 3
SYS_TMP10   = 121   ; located in Bank 0, 1, 2, 3
   ERRORLEVEL -302   ; disable warning (Bankswitching)
   ERRORLEVEL -306   ; disable warning (Pageswitching)
;Programmanfang
   ORG 0
   CLRF STATUS   ; switch to RAM-Bank 0
   GOTO SYS_INIT
   NOP
   NOP
;Interrupt-Adress
   MOVWF SYS_WSAV   ; save register
   SWAPF STATUS,W
   CLRF STATUS   ; bank 0
   MOVWF SYS_SSAV
   BCF INTCON,T0IF   ; Interrupt quitieren
   BCF STATUS,RP0   ; Bank 0
   BCF STATUS,RP1   ; Bank 0
   INCFSZ MF1,F
   GOTO SYS_INT_LABEL_0
   INCF MF1_HI,F
SYS_INT_LABEL_0
   INCFSZ MF2,F
   GOTO SYS_INT_LABEL_1
   INCF MF2_HI,F
SYS_INT_LABEL_1
   INCFSZ TR1,F
   GOTO SYS_INT_LABEL_2
   INCF TR1_HI,F
SYS_INT_LABEL_2
   INCFSZ MF3,F
   GOTO SYS_INT_LABEL_3
   INCF MF3_HI,F
SYS_INT_LABEL_3
   INCFSZ MF4,F
   GOTO SYS_INT_LABEL_4
   INCF MF4_HI,F
SYS_INT_LABEL_4
   INCFSZ MF5,F
   GOTO SYS_INT_LABEL_5
   INCF MF5_HI,F
SYS_INT_LABEL_5
   INCFSZ MF6,F
   GOTO SYS_INT_LABEL_6
   INCF MF6_HI,F
SYS_INT_LABEL_6
   INCFSZ TR2,F
   GOTO SYS_INT_LABEL_7
   INCF TR2_HI,F
SYS_INT_LABEL_7
   INCFSZ MF7,F
   GOTO SYS_INT_LABEL_8
   INCF MF7_HI,F
SYS_INT_LABEL_8
   INCFSZ TR3,F
   GOTO SYS_INT_LABEL_9
   INCF TR3_HI,F
SYS_INT_LABEL_9
EXITINT
   SWAPF SYS_SSAV,W   ; Register zurück
   MOVWF STATUS
   SWAPF SYS_WSAV,F
   SWAPF SYS_WSAV,W
   RETFIE   ; RETurn From Interrupt and Enable GIE
; Subroutines
; Subroutines for LB1
LCD_LB1_INIT
   BCF PORTB,4   ; ir-register
LCD_LB1_L1
   CALL LCD_LB1_OUT4
   DECFSZ SYS_TMP1,F
   GOTO LCD_LB1_L1
   MOVFW PORTB
   ANDLW H'F0'
   IORLW B'0011'   ; Function Set
   MOVWF PORTB
   BSF PORTB,5   ; write
   BCF PORTB,5
   BSF SYS_TMP1,5   ; wait
LCD_LB1_L2
   CALL LCD_LB1_OUT4
   DECFSZ SYS_TMP1,F
   GOTO LCD_LB1_L2
   BSF PORTB,5   ; write
   BCF PORTB,5
   CALL LCD_LB1_OUT4
   BSF PORTB,5   ; write
   BCF PORTB,5
   CALL LCD_LB1_OUT4
   BCF PORTB,0   ; 4-Bit Interface
   BSF PORTB,5   ; write
   BCF PORTB,5
   CALL LCD_LB1_OUT4
   MOVLW B'00101000'   ; Function Set 4-Bit,2-Lines
   CALL LCD_LB1_OUT
   MOVLW B'00001100'   ; Display on, Cursor off, Blink off
   CALL LCD_LB1_OUT
   MOVLW B'00000110'   ; Entrymode set
   CALL LCD_LB1_OUT
LCD_LB1_CLR
   MOVLW B'00000001'   ; Display clear
   CALL LCD_LB1_OUT
LCD_LB1_L3
   CALL LCD_LB1_OUT4
   DECFSZ SYS_TMP1,F
   GOTO LCD_LB1_L3
   GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
   MOVLW H'40'
   BTFSC SYS_TMP2,0   ; Ypos
   ADDWF SYS_TMP1,F
   BSF SYS_TMP1,7   ; select dd-ram
   GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
   BSF PORTB,4   ; dd-ram
LCD_LB1_WRITESTR1
   CALL LCD_LB1_CHAROUT
   BSF INTCON,GIE
   ANDLW H'FF'   ; last is zero
   BTFSC STATUS,ZERO
   RETURN
   MOVWF SYS_TMP1
   CALL LCD_LB1_OUT1
   INCFSZ SYS_TMP4,F   ; next char
   GOTO LCD_LB1_WRITESTR1
   INCF SYS_TMP5,F   ; next page
LCD_LB1_CHAROUT
   BCF INTCON,GIE
   MOVFW SYS_TMP5
   MOVWF PCLATH
   MOVFW SYS_TMP4
   MOVWF PCL
LCD_LB1_DEZO10000
   MOVLW LOW 10000
   MOVWF SYS_TMP1
   MOVLW HIGH 10000
   MOVWF SYS_TMP2
   CALL LCD_LB1_CONVERTDEZ
   MOVF SYS_TMP9,F
   BTFSS STATUS,ZERO
   GOTO LCD_LB1_DEZO1000
   CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
   MOVLW LOW 1000
   MOVWF SYS_TMP1
   MOVLW HIGH 1000
   MOVWF SYS_TMP2
   MOVF SYS_TMP9,F
   BTFSS STATUS,ZERO
LCD_LB1_DEZO100
   MOVLW LOW 100
   MOVWF SYS_TMP1
   CLRF SYS_TMP2
   MOVF SYS_TMP9,F
   BTFSS STATUS,ZERO
   GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
   MOVLW LOW 10
   MOVWF SYS_TMP1
   CLRF SYS_TMP2
   MOVF SYS_TMP9,F
   BTFSS STATUS,ZERO
   GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
   MOVLW 48
   ADDWF SYS_TMP4,W
   GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
   MOVF SYS_TMP9,F
   BTFSS STATUS,ZERO
   DECF SYS_TMP9,F
   CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
   INCF SYS_TMP6,F
   MOVFW SYS_TMP1
   SUBWF SYS_TMP4,F
   MOVFW SYS_TMP2
   BTFSS STATUS,CARRY
   INCFSZ SYS_TMP2,W
   SUBWF SYS_TMP5,F
   BTFSC STATUS,CARRY
   GOTO LCD_LB1_CONVERTDEZ2
   MOVFW SYS_TMP2
   ADDWF SYS_TMP5,F
   MOVFW SYS_TMP1
   ADDWF SYS_TMP4,F
   BTFSC STATUS,CARRY
   INCF SYS_TMP5,F
   DECF SYS_TMP6,W
   BTFSS STATUS,ZERO
   BSF SYS_TMP10,0
   RETURN
LCD_LB1_CONVERTHEX
   ANDLW 15
   MOVWF SYS_TMP1
   MOVLW 48
   ADDWF SYS_TMP1,F
   MOVLW 58
   SUBWF SYS_TMP1,W
   BTFSS STATUS,CARRY
   GOTO $+3
   MOVLW 7
   ADDWF SYS_TMP1,F
   MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
   MOVWF SYS_TMP1   ; store
LCD_LB1_OUT1
   CLRF SYS_TMP3   ; LCDWriteStr (first nibble)
LCD_LB1_OUT2
   SWAPF SYS_TMP1,W   ;high nibble
LCD_LB1_OUT3
   ANDLW H'0F'   ; mask
   MOVWF SYS_TMP2   ; store
   MOVFW PORTB   ; load port
   ANDLW H'F0'   ; mask
   IORWF SYS_TMP2,W   ; add cmd
   MOVWF PORTB   ; out
   BSF PORTB,5   ; E high
   BCF PORTB,5   ; E low
   BTFSC SYS_TMP3,3   ; ready ?
   GOTO LCD_LB1_OUT4   ; yes
   BSF SYS_TMP3,3   ; second nibble
   MOVFW SYS_TMP1
   GOTO LCD_LB1_OUT3   ; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
   DECFSZ SYS_TMP3,F
   GOTO LCD_LB1_OUTV
   RETURN
LCD_LB1_CHECKNULL
   BTFSS STATUS,ZERO
   DECF SYS_TMP9,F
   MOVWF SYS_TMP1
   BTFSS STATUS,ZERO
   BSF SYS_TMP10,0
   MOVLW 48
   BTFSC SYS_TMP10,0
   ADDWF SYS_TMP1,f
   MOVLW 32
   BTFSS SYS_TMP10,0
   ADDWF SYS_TMP1,F
   MOVFW SYS_TMP1
; 016B
;Initialisierung
SYS_INIT
   MOVLW B'00100000'
   MOVWF INTCON
; Ausgangs-Pegel setzen, bevor die Richtung gesetzt wird
   MOVLW B'00000000'
   MOVWF PORTA
   MOVLW B'00000000'
   MOVWF PORTB
   MOVLW 143
   BSF STATUS,RP0   ; Bank 1
   BCF STATUS,RP1   ; Bank 1
   MOVWF OPTION_REG
; Richtung setzen
   MOVLW B'11111111'
   MOVWF TRISA
   MOVLW B'01000000'
   MOVWF TRISB
   MOVLW 7   ; Comparators off
   MOVWF CMCON
; init vars
; Clear RAM
   BCF STATUS,IRP
   MOVLW 32
   MOVWF FSR
CR1
   CLRF INDF
   INCF FSR,F
   BTFSS FSR,7
   GOTO CR1
   BSF FSR,5
CR2
   CLRF INDF
   INCF FSR,F
   MOVLW H'F0'
   SUBWF FSR,W
   BTFSS STATUS,ZERO
   GOTO CR2
   BSF STATUS,IRP
   MOVLW 32
   MOVWF FSR
CR3
   CLRF INDF
   INCF FSR,F
   MOVLW H'50'
   SUBWF FSR,W
   BTFSS STATUS,ZERO
   GOTO CR3
; Init LCD -> LB1
   CALL LCD_LB1_INIT
   CLRF TMR0
   BCF INTCON,T0IF
   BSF INTCON,GIE   ; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
   BTFSS S0,7   ; Reset ?
   GOTO LABEL_ZV1_COUNT
   CLRF ZV1
   CLRF ZV1_HI
   GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
   BTFSS S0,3
   GOTO LABEL_ZV1_SETFD
   BTFSC ZV1_FD,0
   BSF ZV1_FD,0
   BTFSC S0,4   ; Vorwärts oder Rückwärts ?
   GOTO LABEL_ZV1_BACKWARD
   INCFSZ ZV1,F
   INCF ZV1_HI,F
LABEL_ZV1_BACKWARD
   DECF ZV1,F
   INCFSZ ZV1,W
   DECF ZV1_HI,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
   BTFSC S0,3
   GOTO LABEL_ZV1_EXIT
   BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Mono-Flop -> MF1
; Läuft der Impuls ?
   BTFSC MF1_FD,1
   GOTO LABEL_MF1_CHKTIME
   BTFSC MF1_FD,0
   GOTO LABEL_MF1_SETFD
   BTFSS PORTA,3
LABEL_MF1_RESET
   CLRF MF1
   CLRF MF1_HI
   BSF MF1_FD,1
   BSF S2,3
LABEL_MF1_CHKTIME
   MOVLW 0
   SUBWF MF1_HI,W
   BTFSS STATUS,ZERO
   GOTO LABEL_MF1_CHECK
   MOVLW 78
   SUBWF MF1,W
LABEL_MF1_CHECK
   BTFSS STATUS,CARRY
LABEL_MF1_TO
   BCF MF1_FD,1
   BCF S2,3
LABEL_MF1_SETFD
   BTFSS PORTA,3
   GOTO LABEL_MF1_CLR
   BSF MF1_FD,0
   GOTO LABEL_MF1_ENDE
LABEL_MF1_CLR
   BCF MF1_FD,0
LABEL_MF1_ENDE
; ODER - Gatter -> LG1
LABEL_LG1_1
   BTFSC S2,3
   GOTO LABEL_LG1_TRUE
LABEL_LG1_2
   BTFSC S0,2
   GOTO LABEL_LG1_TRUE
LABEL_LG1_3
   BTFSC S0,4
   GOTO LABEL_LG1_TRUE
LABEL_LG1_FALSE
   BCF S0,3
   GOTO LABEL_LG1_ENDE
LABEL_LG1_TRUE
   BSF S0,3
LABEL_LG1_ENDE
; Anzug-Verzögerung -> MF2
   BTFSC PORTA,3   ; Eingang auf High ?
   GOTO LABEL_MF2_CHKTIME   ; Ja
; RESET
   CLRF MF2
   CLRF MF2_HI
   BCF S0,0
   GOTO LABEL_MF2_EXIT   ; raus
LABEL_MF2_CHKTIME
   BTFSC S0,0   ; Ausgang schon auf High ?
   GOTO LABEL_MF2_EXIT   ; Ja
   MOVLW 30
   SUBWF MF2_HI,W
   BTFSS STATUS,CARRY
   GOTO LABEL_MF2_EXIT
   MOVLW 132
   SUBWF MF2,W
   BTFSS STATUS,CARRY
   GOTO LABEL_MF2_EXIT
   BSF S0,0
LABEL_MF2_EXIT
; UND - Gatter -> LG2
LABEL_LG2_1
   BTFSS S0,0
   GOTO LABEL_LG2_FALSE
LABEL_LG2_2
   BTFSS S0,1
LABEL_LG2_TRUE
   BSF S0,2
   GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
   BCF S0,2
LABEL_LG2_ENDE
; Timer -> TR1
   MOVLW 0   ; Test auf >=
   SUBWF TR1_HI,W   ;F-W -> W
   BTFSS STATUS,ZERO
   GOTO LABEL_TR1_CHECK
   MOVLW 20
   SUBWF TR1,W   ;F-W -> W
LABEL_TR1_CHECK
   BTFSS STATUS,CARRY
   GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
   SUBWF TR1_HI,F   ;F-W -> F
   MOVLW 20
   SUBWF TR1,F   ;F-W -> F
   BTFSS STATUS,CARRY
   DECF TR1_HI,F
LABEL_TR1_SET   ; toggel output
   BTFSC S0,1
   GOTO LABEL_TR1_CLR
   BSF S0,1
   GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
   BCF S0,1
LABEL_TR1_ENDE
; Mono-Flop -> MF3
   BTFSC MF3_FD,1
   GOTO LABEL_MF3_CHKTIME
   BTFSC MF3_FD,0
   GOTO LABEL_MF3_SETFD
   BTFSS PORTA,2
LABEL_MF3_RESET
   CLRF MF3
   CLRF MF3_HI
   BSF MF3_FD,1
   BSF S2,4
LABEL_MF3_CHKTIME
   MOVLW 1
   SUBWF MF3_HI,W
   BTFSS STATUS,ZERO
   GOTO LABEL_MF3_CHECK
   MOVLW 135
   SUBWF MF3,W
LABEL_MF3_CHECK
   BTFSS STATUS,CARRY
LABEL_MF3_TO
   BCF MF3_FD,1
   BCF S2,4
LABEL_MF3_SETFD
   BTFSS PORTA,2
   GOTO LABEL_MF3_CLR
   BSF MF3_FD,0
   GOTO LABEL_MF3_ENDE
LABEL_MF3_CLR
   BCF MF3_FD,0
LABEL_MF3_ENDE
; Zähler -> ZV2
   GOTO LABEL_ZV2_COUNT
   CLRF ZV2
   CLRF ZV2_HI
   GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
   BTFSS S1,4
   GOTO LABEL_ZV2_SETFD
   BTFSC ZV2_FD,0
   BSF ZV2_FD,0
   BTFSC S1,6   ; Vorwärts oder Rückwärts ?
   GOTO LABEL_ZV2_BACKWARD
   INCFSZ ZV2,F
   INCF ZV2_HI,F
LABEL_ZV2_BACKWARD
   DECF ZV2,F
   INCFSZ ZV2,W
   DECF ZV2_HI,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
   BTFSC S1,4
   GOTO LABEL_ZV2_EXIT
   BCF ZV2_FD,0
LABEL_ZV2_EXIT
; One Shot -> OS1
   BTFSS PORTA,4
   GOTO LABEL_OS1_1
   BTFSC OS1_FD,0
   GOTO LABEL_OS1_1
   BSF OS1_FD,0
   BSF S1,5
   GOTO LABEL_OS1_2
LABEL_OS1_1
   BCF S1,5
   BTFSC PORTA,4
   GOTO LABEL_OS1_2
   BCF OS1_FD,0
LABEL_OS1_2
; Vergleich -> IF1
   MOVFW ZV2_HI
   SUBWF ZV1_HI,W   ; F - W -> W
   BTFSS STATUS,ZERO   ; Wenn ZERO gesetzt LOW-Byte testen
   GOTO LABEL_IF1_CHECK
   MOVFW ZV2
   SUBWF ZV1,W   ; F - W -> W
LABEL_IF1_CHECK
   BTFSS STATUS,ZERO   ; Test auf -> =
   GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
   BSF S0,5
   GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
   BCF S0,5
LABEL_IF1_EXIT
; RS-FLIP-FLOP -> RS1
   BTFSC S1,0
   GOTO LABEL_RS1_RESET
   BTFSS S0,6
   GOTO LABEL_RS1_ENDE
   BSF S1,2   ; Ausgang setzen
   GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
   BCF S1,2   ; Ausgang zurücksetzen
LABEL_RS1_ENDE
; Mono-Flop -> MF4
   BTFSC MF4_FD,1
   GOTO LABEL_MF4_CHKTIME
   BTFSC MF4_FD,0
   GOTO LABEL_MF4_SETFD
   BTFSS PORTA,0
LABEL_MF4_RESET
   CLRF MF4
   CLRF MF4_HI
   BSF MF4_FD,1
   BSF S0,7
LABEL_MF4_CHKTIME
   MOVLW 0
   SUBWF MF4_HI,W
   BTFSS STATUS,ZERO
   GOTO LABEL_MF4_CHECK
   MOVLW 78
   SUBWF MF4,W
LABEL_MF4_CHECK
   BTFSS STATUS,CARRY
LABEL_MF4_TO
   BCF MF4_FD,1
   BCF S0,7
LABEL_MF4_SETFD
   BTFSS PORTA,0
   GOTO LABEL_MF4_CLR
   BSF MF4_FD,0
   GOTO LABEL_MF4_ENDE
LABEL_MF4_CLR
   BCF MF4_FD,0
LABEL_MF4_ENDE
; Mono-Flop -> MF5
   BTFSC MF5_FD,1
   GOTO LABEL_MF5_CHKTIME
   BTFSC MF5_FD,0
   GOTO LABEL_MF5_SETFD
   BTFSS PORTA,1
LABEL_MF5_RESET
   CLRF MF5
   CLRF MF5_HI
   BSF MF5_FD,1
   BSF S0,6
LABEL_MF5_CHKTIME
   MOVLW 0
   SUBWF MF5_HI,W
   BTFSS STATUS,ZERO
   GOTO LABEL_MF5_CHECK
   MOVLW 78
   SUBWF MF5,W
LABEL_MF5_CHECK
   BTFSS STATUS,CARRY
LABEL_MF5_TO
   BCF MF5_FD,1
   BCF S0,6
LABEL_MF5_SETFD
   BTFSS PORTA,1
   GOTO LABEL_MF5_CLR
   BSF MF5_FD,0
   GOTO LABEL_MF5_ENDE
LABEL_MF5_CLR
   BCF MF5_FD,0
LABEL_MF5_ENDE
; ODER - Gatter -> LG3
LABEL_LG3_1
   BTFSC S1,1
   GOTO LABEL_LG3_TRUE
LABEL_LG3_2
   BTFSC S0,7
   GOTO LABEL_LG3_TRUE
LABEL_LG3_FALSE
   BCF S1,0
   GOTO LABEL_LG3_ENDE
LABEL_LG3_TRUE
   BSF S1,0
LABEL_LG3_ENDE
; Mono-Flop -> MF6
   BTFSC MF6_FD,1
   GOTO LABEL_MF6_CHKTIME
   BTFSC MF6_FD,0
   GOTO LABEL_MF6_SETFD
   BTFSS S0,5
LABEL_MF6_RESET
   CLRF MF6
   CLRF MF6_HI
   BSF MF6_FD,1
   BSF S1,1
LABEL_MF6_CHKTIME
   MOVLW 0
   SUBWF MF6_HI,W
   BTFSS STATUS,ZERO
   GOTO LABEL_MF6_CHECK
   MOVLW 78
   SUBWF MF6,W
LABEL_MF6_CHECK
   BTFSS STATUS,CARRY
LABEL_MF6_TO
   BCF MF6_FD,1
   BCF S1,1
LABEL_MF6_SETFD
   BTFSS S0,5
   GOTO LABEL_MF6_CLR
   BSF MF6_FD,0
   GOTO LABEL_MF6_ENDE
LABEL_MF6_CLR
   BCF MF6_FD,0
LABEL_MF6_ENDE
; LCD -> LT1
; test of positiv edge
   BTFSC LT1_FD,0
   GOTO LABEL_LT1_SETFD
   BTFSS S1,3
   MOVLW 0
   MOVWF SYS_TMP1
   MOVLW 0
   MOVWF SYS_TMP2
   CALL LCD_LB1_GOTOXY
   MOVLW LOW TAB_LT1
   MOVWF SYS_TMP4
   MOVLW HIGH TAB_LT1
   MOVWF SYS_TMP5
   CALL LCD_LB1_WRITESTR
LABEL_LT1_SETFD
   BTFSS S1,3
   GOTO LABEL_LT1_SETFD2
   BSF LT1_FD,0
   GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
   BCF LT1_FD,0
LABEL_LT1_END
; LCD -> LT2
   BTFSC LT2_FD,0
   GOTO LABEL_LT2_SETFD
   BTFSS S1,3
   MOVLW 0
   MOVWF SYS_TMP1
   MOVLW 1
   MOVWF SYS_TMP2
   CALL LCD_LB1_GOTOXY
   MOVLW LOW TAB_LT2
   MOVWF SYS_TMP4
   MOVLW HIGH TAB_LT2
   MOVWF SYS_TMP5
LABEL_LT2_SETFD
   BTFSS S1,3
   GOTO LABEL_LT2_SETFD2
   BSF LT2_FD,0
   GOTO LABEL_LT2_END
LABEL_LT2_SETFD2
   BCF LT2_FD,0
LABEL_LT2_END
; Timer -> TR2
   SUBWF TR2_HI,W   ;F-W -> W
   BTFSS STATUS,ZERO
   GOTO LABEL_TR2_CHECK
   MOVLW 39
   SUBWF TR2,W   ;F-W -> W
LABEL_TR2_CHECK
   BTFSS STATUS,CARRY
   GOTO LABEL_TR2_ENDE
LABEL_TR2_RESET
   SUBWF TR2_HI,F   ;F-W -> F
   MOVLW 39
   SUBWF TR2,F   ;F-W -> F
   BTFSS STATUS,CARRY
   DECF TR2_HI,F
LABEL_TR2_SET   ; toggel output
   BTFSC S1,3
   GOTO LABEL_TR2_CLR
   BSF S1,3
   GOTO LABEL_TR2_ENDE
LABEL_TR2_CLR
   BCF S1,3
LABEL_TR2_ENDE
; LCD -> LT3
   BTFSC LT3_FD,0
   GOTO LABEL_LT3_SETFD
   BTFSS S1,3
   MOVLW 7
   MOVWF SYS_TMP1
   MOVLW 0
   MOVWF SYS_TMP2
   CALL LCD_LB1_GOTOXY
   MOVFW ZV1
   MOVWF SYS_TMP4
   MOVFW ZV1_HI
   MOVWF SYS_TMP5
   BSF SYS_TMP10,0
   MOVLW 2
   MOVWF SYS_TMP9
   CALL LCD_LB1_DEZO10000
LABEL_LT3_SETFD
   BTFSS S1,3
   GOTO LABEL_LT3_SETFD2
   BSF LT3_FD,0
   GOTO LABEL_LT3_END
LABEL_LT3_SETFD2
   BCF LT3_FD,0
LABEL_LT3_END
; LCD -> LT4
   BTFSC LT4_FD,0
   GOTO LABEL_LT4_SETFD
   BTFSS S1,3
   MOVLW 7
   MOVWF SYS_TMP1
   MOVLW 1
   MOVWF SYS_TMP2
   CALL LCD_LB1_GOTOXY
   MOVFW ZV2
   MOVWF SYS_TMP4
   MOVFW ZV2_HI
   MOVWF SYS_TMP5
   BSF SYS_TMP10,0
   MOVLW 2
   MOVWF SYS_TMP9
LABEL_LT4_SETFD
   BTFSS S1,3
   GOTO LABEL_LT4_SETFD2
   BSF LT4_FD,0
   GOTO LABEL_LT4_END
LABEL_LT4_SETFD2
   BCF LT4_FD,0
LABEL_LT4_END
; UND - Gatter -> LG4
LABEL_LG4_1
   BTFSS S1,5
   GOTO LABEL_LG4_FALSE
LABEL_LG4_2
   BTFSS PORTB,7
LABEL_LG4_3
   BTFSC S2,1
LABEL_LG4_TRUE
   BSF S1,4
   GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
   BCF S1,4
LABEL_LG4_ENDE
; GND
   BCF S1,6   ; immer Low
; Schieberegister -> SR1
   BTFSS S2,0   ; Reset ?
   GOTO LABEL_SR1_SHIFT
   CLRF SR1
   GOTO LABEL_SR1_SETOUT
LABEL_SR1_SHIFT
   BTFSC SR1_FD,0
   GOTO LABEL_SR1_SETFD
   BTFSS S1,7
   BCF STATUS,CARRY
   BTFSC S1,7
   BSF STATUS,CARRY
   RLF SR1,F
LABEL_SR1_SETOUT
; Output Q0
   BTFSS SR1,0
   GOTO LABEL_SR1_SETOUT0
   BSF S2,1
   GOTO LABEL_SR1_SETOUT0_END
LABEL_SR1_SETOUT0
   BCF S2,1
; Output Q1
   BTFSS SR1,1
   GOTO LABEL_SR1_SETOUT1
   BSF S2,0
   GOTO LABEL_SR1_SETOUT1_END
LABEL_SR1_SETOUT1
   BCF S2,0
LABEL_SR1_SETFD
   BTFSS S1,7
   GOTO LABEL_SR1_SETFD2
   BSF SR1_FD,0
   GOTO LABEL_SR1_END
LABEL_SR1_SETFD2
   BCF SR1_FD,0
LABEL_SR1_END
; Mono-Flop -> MF7
   BTFSC MF7_FD,1
   GOTO LABEL_MF7_CHKTIME
   BTFSC MF7_FD,0
   GOTO LABEL_MF7_SETFD
   BTFSS PORTB,6
LABEL_MF7_RESET
   CLRF MF7
   CLRF MF7_HI
   BSF MF7_FD,1
   BSF S1,7
LABEL_MF7_CHKTIME
   MOVLW 0
   SUBWF MF7_HI,W
   BTFSS STATUS,ZERO
   GOTO LABEL_MF7_CHECK
   MOVLW 78
   SUBWF MF7,W
LABEL_MF7_CHECK
   BTFSS STATUS,CARRY
LABEL_MF7_TO
   BCF MF7_FD,1
   BCF S1,7
LABEL_MF7_SETFD
   BTFSS PORTB,6
   GOTO LABEL_MF7_CLR
   BSF MF7_FD,0
   GOTO LABEL_MF7_ENDE
LABEL_MF7_CLR
   BCF MF7_FD,0
LABEL_MF7_ENDE
; UND - Gatter -> LG5
LABEL_LG5_1
   BTFSC S2,1
   GOTO LABEL_LG5_FALSE
LABEL_LG5_2
   BTFSS S1,2
LABEL_LG5_TRUE
   BSF PORTB,7
   GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
   BCF PORTB,7
LABEL_LG5_ENDE
; Vergleich -> IF2
   MOVLW 0
LABEL_IF2_CHECK
   GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
   BSF S2,2
   GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
   BCF S2,2
LABEL_IF2_EXIT
; UND - Gatter -> LG6
LABEL_LG6_1
   BTFSS S2,4
   GOTO LABEL_LG6_FALSE
LABEL_LG6_2
   BTFSC S2,2
LABEL_LG6_TRUE
   BSF S0,4
   GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
   BCF S0,4
LABEL_LG6_ENDE
; Timer -> TR3
   MOVLW 7   ; Test auf >=
   SUBWF TR3_HI,W   ;F-W -> W
   BTFSS STATUS,ZERO
   GOTO LABEL_TR3_CHECK
   MOVLW 161
   SUBWF TR3,W   ;F-W -> W
LABEL_TR3_CHECK
   BTFSS STATUS,CARRY
   GOTO LABEL_TR3_ENDE
LABEL_TR3_RESET
   SUBWF TR3_HI,F   ;F-W -> F
   MOVLW 161
   SUBWF TR3,F   ;F-W -> F
   BTFSS STATUS,CARRY
   DECF TR3_HI,F
LABEL_TR3_SET   ; toggel output
   BTFSC S2,5
   GOTO LABEL_TR3_CLR
   BSF S2,5
   GOTO LABEL_TR3_ENDE
LABEL_TR3_CLR
   BCF S2,5
LABEL_TR3_ENDE
; UND - Gatter -> LG7
LABEL_LG7_1
   BTFSS S2,1
   GOTO LABEL_LG7_FALSE
LABEL_LG7_2
   BTFSS S2,5
LABEL_LG7_TRUE
   BSF S2,6
   GOTO LABEL_LG7_ENDE
LABEL_LG7_FALSE
   BCF S2,6
LABEL_LG7_ENDE
; LCD -> LT5
   BTFSC LT5_FD,0
   GOTO LABEL_LT5_SETFD
   BTFSS S2,6
   MOVLW 14
   MOVWF SYS_TMP1
   MOVLW 0
   MOVWF SYS_TMP2
   CALL LCD_LB1_GOTOXY
   MOVLW LOW TAB_LT5
   MOVWF SYS_TMP4
   MOVLW HIGH TAB_LT5
   MOVWF SYS_TMP5
LABEL_LT5_SETFD
   BTFSS S2,6
   GOTO LABEL_LT5_SETFD2
   BSF LT5_FD,0
   GOTO LABEL_LT5_END
LABEL_LT5_SETFD2
   BCF LT5_FD,0
LABEL_LT5_END
; LCD -> LT6
; test of negative edge
   BTFSS LT6_FD,0
   GOTO LABEL_LT6_SETFD
   BTFSC S2,6
   MOVLW 14
   MOVWF SYS_TMP1
   MOVLW 0
   MOVWF SYS_TMP2
   CALL LCD_LB1_GOTOXY
   MOVLW LOW TAB_LT6
   MOVWF SYS_TMP4
   MOVLW HIGH TAB_LT6
   MOVWF SYS_TMP5
LABEL_LT6_SETFD
   BTFSS S2,6
   GOTO LABEL_LT6_SETFD2
   BSF LT6_FD,0
   GOTO LABEL_LT6_END
LABEL_LT6_SETFD2
   BCF LT6_FD,0
LABEL_LT6_END
   GOTO MAIN
TAB_LT1
   RETLW 65   ; A
   RETLW 46   ; .
   RETLW 83   ; S
   RETLW 112   ; p
   RETLW 105   ; i
   RETLW 114   ; r
   RETLW 58   ; :
   RETLW 0   ; end
TAB_LT2
   RETLW 83   ; S
   RETLW 46   ; .
   RETLW 83   ; S
   RETLW 112   ; p
   RETLW 105   ; i
   RETLW 114   ; r
   RETLW 58   ; :
   RETLW 0   ; end
TAB_LT5
   RETLW 80   ; P
   RETLW 0   ; end
TAB_LT6
   RETLW 32   ;
   RETLW 0   ; end
   END
ze=12] [/size]
XX_CİHAN_XX
@salihtolu
Kimse bukadar uzun asm programını oturup çözmeye çalışmaz. Yazdığın yazıda net olmayan noktalar var. Şeman yok. Programda yapmaya çalıştıgın noktaları tam olarak yazmalısın.
ayhani
İşe bak :lol:
Arkadaşım bu programı aldığın linke sorsaydın daha iyi olurdu diye düşünüyorum.
Zira bu program ve devresi bana ait  :lol:
Bunun asmsinden kimse sana yardım edemez. Ben programı Parsic ile yazıyorum. Parsic ile bunu 2 dakikada yapabilirim. Şu an dışardayım eve gidince unutmazsam sorunu çözüp gönderirim.
Nacizane tavsiye alıntı yaptığınızda devre şemasınıda verinki insanlar neden bahsettiğinizi anlasın
