STM32F4 Discovery - Vizeler
Başlatan bunalmis, 24 Aralık 2011, 15:13:13
#include "STM32F4xx.h"
unsigned char WAdr,RAdr;
char RxBuf[128];
         CPU PLL ile 168Mhz de kosturulur
         AHB frekansy 168 Mhz
         APB1 frekansy 42 Mhz
         APB2 frekansy 84 Mhz
void SystemInit()
volatile unsigned int i;
     for (i=0;i<0x00100000;i++);     // OSC oturtma ve kurtarma rutini
     RCC->CFGR |= 0x00009400;        // AHB ve APB hizlarini max degerlere set edelim
     RCC->CR |= 0x00010000;          // HSE Xtal osc calismaya baslasin
     while (!(RCC->CR & 0x00020000));// Xtal osc stabil hale gelsin
     RCC->PLLCFGR = 0x07402A04;      // PLL katsayilarini M=4, N=168, P=2 ve Q=7 yapalim
     RCC->CR |= 0x01000000;          // PLL calismaya baslasin  (Rehber Sayfa 95)
     while(!(RCC->CR & 0x02000000)); // Pll hazir oluncaya kadar bekle
     FLASH->ACR = 0x00000605;        // Flash ROM icin 5 Wait state secelim ve ART yi aktif edelim (Rehber Sayfa 55)
     RCC->CFGR |= 0x00000002;        // Sistem Clk u PLL uzerinden besleyelim
     while ((RCC->CFGR & 0x0000000F) != 0x0000000A); // Besleninceye kadar bekle
     RCC->AHB1ENR |= 0x0000001F;     // GPIO A,B,C,D,E clock'u aktif edelim
     GPIOD->MODER  = 0x55550000;     // GPIOD nin 15, 14, 13, 12, 11, 10, 9, 8 pinleri cikis tanimlandi (LEDler icin)
     GPIOD->OSPEEDR= 0xFFFFFFFF;     // GPIOD nin tum cikislari en yuksek hizda kullanacagiz
//  GPIOA da A7, A6, A5 pinleri, LIS302DL cipiyle haberlesmek icin SPI moduna alinacak
     GPIOA->AFR[0]=0x55500000;       // SPI1 secelim (Rehber Sayfa 141), Hard Sayfa 49
     GPIOA->MODER|=0x0000A800;       // A7,A6,A5 Alternatif fonksiyon
     RCC->APB2ENR|=0x00001000;       // SPI1 clk enable   //   GPIOE3 pinini output tanimlayalim (LIS302DL SPI/I2C secimi)
     GPIOE->MODER  = 0x00000040;     // GPIOE nin 3 nolu pini cikis tanimlandi
     GPIOE->OSPEEDR= 0xFFFFFFFF;     // GPIOE nin tum cikislari en yuksek hizda kullanacagiz
     GPIOE->BSRRL=0x0008;            // GPIOE3=1; LIS302DL CS=1
     SPI1->CR1=0x00000B7F;           // SPI1 16 bit, master , fulldublex vs
     SPI1->CR2=0X0000;
//-----------------------------------------------------------------------------------------------------------USART3_IRQHandler
void USART3_IRQHandler()
volatile int Sts;
     Sts=USART3->SR;
     RxBuf[WAdr]=USART3->DR;
     WAdr=(WAdr+1)&0x7F;
//-----------------------------------------------------------------------------------------------------------SPI_CMD
signed char  SPI_CMD(short DAT)
signed char RxDat;
      GPIOE->BSRRH=0x0008;      // LIS302DL CS=0
      RxDat=SPI1->SR;           // AMAC DELAY (kalmasinda fayda var)
      SPI1->DR=DAT;             // Komutu yukle
      while(!(SPI1->SR&0x01));  // RX BUF bos ise beklemede kal
      while(SPI1->SR&0x80);     // BSY durumu varsa kalkmasini bekleyelim
      RxDat=SPI1->DR;           // Cipten gelen veriyi oku
      while(SPI1->SR!=0x02);    // CS=1 yapmadan once cipin orjinal duruma donmeyi bekleyelim
      GPIOE->BSRRL=0x0008;      // LIS302DL CS=1
      return(RxDat);
//-----------------------------------------------------------------------------------------------------------SpiWrite
signed char SpiWrite(char Adr,unsigned char Data)
      return(SPI_CMD(((Adr&0x3F)<<8 )|Data));
//-----------------------------------------------------------------------------------------------------------SpiRead
signed char SpiRead(char Adr)
      return(SPI_CMD(((Adr&0x3F)|0x80)<<8 ));
//-----------------------------------------------------------------------------------------------------------SendChar
void SendChar(int Tx)
      while(!(USART3->SR&0x80));  // TX Buffer dolu ise bekle (Rehber Sayfa 646)
      USART3->DR=Tx;
//-----------------------------------------------------------------------------------------------------------UsartInit
void UsartInit()
     WAdr=0;RAdr=0;
// USART3 MODULUNU AKTIF HALE GETIRELIM
      RCC->APB1ENR|=0x00040000;  // USART3 Clk Enable (Rehber Sayfa 113)
      RCC->APB1RSTR|=0x00040000;  // USART3 Resetlendi
      GPIOB->AFR[1]=0x07777700;  // PB10..PB14 pinleri USART3 ile alakalandirildi (Hard Sayfa 49)
      GPIOB->MODER|=0x2AA00000;  // GPIOB 10..14 icin alternatif fonksiyon tanimi (Rehber Sayfa 148)
// USART3 MODULUNU AYARLAYALIM  // 1 Start, 8 Data, 1 Stop, No parity (Default degerler)
      RCC->APB1RSTR&=~0x00040000;  // USART3 Reseti kaldiralim
//      USART3->SR&=~0X03FF;   // Status registeri silelim
      USART3->BRR=0X1112;    // 9600 Baud
      USART3->CR1|=0x0000202C;  // USART3 enable
      NVIC->ISER[1]|=0x80;         // NVIC da USART3 interrupta izin verelim
//-----------------------------------------------------------------------------------------------------------main
int main()
int i;
signed char who,xo,yo;
short x=0,y=0;
      UsartInit();
      if(SpiRead(0x0F)==0x3B)       // Who are you ?
          SpiWrite(0x20,0x47);  // Data Rate=100Hz, Full Scale=2g, Activate, x,y,z enable
          while(!(SpiRead(0x27)&1));
          xo=SpiRead(0x29);
          while(!(SpiRead(0x27)&2));
          yo=SpiRead(0x2B);
          while(1)
               who=SpiRead(0x27);   // Statusu ogrenelim. Kim hazir kim değil?
               if (who&1)
                 	x=(SpiRead(0x29));
					SendChar(x);
					//SendChar(0x0A);
//               if (who&2)
//                 y=(SpiRead(0x2B));
//                 SendChar(y);
//				 SendChar(0x0A);
      TIM7->DIER=0x0000;              // Update Int disable
      while(1)
         for(i=0;i<0x1000000;i++);
         GPIOD->ODR^=0x0000F000;
//-----------------------------------------------------------------------------------------------------------STOP
programda X den aldgım bilgiyi Usart tan göndrmee çalışıyorum. Yanlış gidn birşeyler var gibi geliyor bana
değer 0-255 arasında olmalı değilmi ?
X yönünde oynattığım değişim görmem gerek ama anlamsız bir değişim var
Klein
ADC örneğini  "Örnek temel programlar" başlışındaki  accelerometer örneği ile biraz modifiye ettim. sorun yok.
Kodlarını incelemedim sorunun nerede bilmiyorum. Bu örneğe bakarak sorunun kaynağını tespit edebilirsin.
#include "stdio.h"
char RxBuf[128];
char TxBuf[128];
unsigned char timer_update=0;
uint16_t adc_val;
 CPU frekansi 168Mhz
 AHB frekansi 84 Mhz
 APB frekansi 42 Mhz
void SystemInit()
unsigned int i;
      RCC->PLLCFGR = 0x07402A04;      // PLL katsayilarini M=4, N=168, P=2 ve Q=7 yapalim   168 Mhz
	 RCC->APB1ENR|=0x00000020;       // Timer7 CLK'u aktif edelim (84 Mhz)
     TIM7->CR1=0x0080;               // Otomatik Reload
     TIM7->PSC =839;                 // Prescaler degerimiz 839, Count frekansimiz = fCK_PSC / (Yuklenen Deger + 1) 84E6 / (840) = 100 KHz
     TIM7->ARR =5;                   // Counter, Decimal 1 olunca basa donsun. Her 20 mikrosaniye de bir timer int olusacak.
     TIM7->DIER=0x0001;              // Update Int enable
     NVIC->ISER[1] = 0X00800000;     // NVIC de Timer 7 interrupta izin verelim
     TIM7->CR1|=0x0001;              // Counter Enable
	 RCC->APB2ENR|=0x00000100;  // ADC saat kaynağını aktif ettik.
	 //PB->MODER.p0 = PORT_ANALOG; // PortB0 analog
	 GPIOB->MODER |= 0x00000003;
	 ADC1->CR1 |=0x00000100; //  ADC scan modunda çalışacak.
	 ADC1->SQR3 |= 0x00000008; // Çevrime ilk girecek kanal 8. (PB0)
	 ADC1->CR2 |=0x00000003;   // AD converter'i açtık. Sürekli çevirim yapacağımızı belirttik.
	 GPIOA->AFR[0]|=0x55500000;       // SPI1 secelim (Rehber Sayfa 141), Hard Sayfa 49
     SPI1->CR2=0X0000;
      USART3 modulunu kullanarak asenkron haberlesme (Hata kontrolu yapilmiyor)
volatile int Sts;
     Sts=USART3->SR;
     WAdr=(WAdr+1)&0x7F;
void UsartInit()
     WAdr=0;RAdr=0;
void SendChar(char Tx)
      USART3->DR=Tx;
void SendTxt(char *Adr)
      while(*Adr)
          SendChar(*Adr);
          Adr++;
char DataReady()
       return(WAdr-RAdr);
char ReadChar()
char Dat;
      Dat=RxBuf[RAdr];
      RAdr=(RAdr+1)&0x7F;
      return(Dat);
void TIM7_IRQHandler()
TIM7->SR=0;
timer_update=1;
// Rx ve TX pinlerini (GPIOB10 ve GPIOB11) birbirine baglarsaniz gonderdiginiz datalar geri gelecektir
signed char RxDat;
      return(RxDat);
signed char Write(char Adr,unsigned char Data)
signed char Read(char Adr)
int main()
unsigned int ledtime;
signed char who, b;
      UsartInit();
      SendTxt("PicProje");
			ADC1->CR2 |=0x40000000; // ADC çevrimini başlattık.
      if(Read(0x0F)==0x3B)       // Who are you ?
      while(1){
               who=Read(0x27);   // Statusu ogrenelim. Kim hazir kim değil?
               if (who&1)
      				b=Read(0x29);
	  	if(ADC1->SR & 0x0002){
		    ADC1->SR &= ~0x0002;
			adc_val = ADC1->DR;
	  	if(timer_update){
			timer_update=0;
			if(++ledtime > 5000){
	  			ledtime =0;
				GPIOD->ODR ^= 0x0000008000;
//				sprintf(TxBuf,"ADC Degeri :%u\r",adc_val);
				sprintf(TxBuf,"X = %d\r",b);
				SendTxt(TxBuf);
Verdiğiniz Program Tam Olarak ne Yapıyor Hocam ?
Klein
kartın eğimine göre X ekseni ( Y de olabilir) açısını seri porttan gönderiyor.
"sprintf" i stdio dan mı çalışıyor hocam ?
Klein
Yeri Gelmişken Sorayım Ozaman.
Bu STDIO bu chip için düzenlenmiş/yazılmış olmalı değil mi ?
Klein
Doğrudan işlemci için değil ama işlemci ailesi için düzenlenmiş olması gerekebilir. emin değilim.
Alıntı Yapsprintf fonksiyonu da, printf ve fprintf fonksiyonlarına benzer şekilde çalışmaktadır. Bu fonksiyonun diğerlerinden temel farkı ise, yazacağı ifadeleri bir dosyaya ya da ekrana değil, bir karakter katarına yazmasıdır
Klein
Şaşırmayın Hocam Dediğinizi Desteklemek için Alıntı yaptım biryerden.
