SHT75 DRİVER LÜTFEN YARDIM EDİN
Başlatan husam685, 26 Aralık 2011, 00:54:21
husam685
slm arkadaşlar sht75 ve sht11 sıcaklık ve nem sensörü driver arayıp bulamadım bulduklarım çalışmadı lütfen elinizde eger sht11.c ve sht75.c driver dosyası olan varsa paylaşırmı rica etsem.
tacettin
:::ccs c nin kendi forum sitesinden alınmıştır:::
This driver should also work for SHT11, SHT71 and SHT15 as these sensors are using the same communication protocol.
SHT75.C Driver
// Driver file for SHT75 Temperature & Humidity Sensor                       //
// ***** To initialise SHT75 sensor upon power up *****                      //
// Function : sht_init()                                                     //
// Return   : none                                                           //
// ***** To measure and caluculate SHT75 temp & real RH *****                //
// Function : sht_rd (temp, truehumid)                                       //
// Return   : temperature & true humidity in float values                    //
#define sht_data_pin   PIN_D3
#define sht_clk_pin    PIN_C4
//***** Function to alert SHT75 *****
void comstart (void)
 output_float(sht_data_pin);  //data high
 output_bit(sht_clk_pin, 0);  //clk low
 delay_us(1);
 output_bit(sht_clk_pin, 1);  //clk high
 delay_us(1);
 output_bit(sht_data_pin, 0); //data low
 delay_us(1);
 delay_us(2);
 delay_us(1);
 delay_us(1);
//***** Function to write data to SHT75 *****
int1 comwrite (int8 iobyte)
 int8 i, mask = 0x80;
 int1 ack;
 //Shift out command
 delay_us(4);
 for(i=0; i<8; i++)
   if((iobyte & mask) > 0) output_float(sht_data_pin);  //data high if MSB high
   else output_bit(sht_data_pin, 0);                    //data low if MSB low
   delay_us(1);
   delay_us(1);
   mask = mask >> 1;                                    //shift to next bit
 //Shift in ack
 delay_us(1);
 ack = input(sht_data_pin);   //get ack bit
 delay_us(1);
 return(ack);
//***** Function to read data from SHT75 *****
int16 comread (void)
 int8 i;
 int16 iobyte = 0;
 const int16 mask0 = 0x0000;
 const int16 mask1 = 0x0001;
 //shift in MSB data
 for(i=0; i<8; i++)
   iobyte = iobyte << 1;
   delay_us(1);
   if (input(sht_data_pin)) iobyte |= mask1;  //shift in data bit
   else iobyte |= mask0;
   delay_us(1);
 //send ack 0 bit
 delay_us(1);
 delay_us(2);
 delay_us(1);
 //shift in LSB data
 for(i=0; i<8; i++)
   delay_us(1);
   delay_us(1);
 //send ack 1 bit
 delay_us(1);
 delay_us(2);
 return(iobyte);
//***** Function to wait for SHT75 reading *****
void comwait (void)
 int16 sht_delay;
 delay_us(1);
 for(sht_delay=0; sht_delay<30000; sht_delay++)  // wait for max 300ms
   if (!input(sht_data_pin)) break;              //if sht_data_pin low, SHT75 ready
   delay_us(10);
//***** Function to reset SHT75 communication *****
void comreset (void)
 int8 i;
 delay_us(2);
 for(i=0; i<9; i++)
   output_bit(sht_clk_pin, 1);  //toggle clk 9 times
   delay_us(2);
   delay_us(2);
 comstart();
//***** Function to soft reset SHT75 *****
void sht_soft_reset (void)
 comreset();           //SHT75 communication reset
 comwrite(0x1e);       //send SHT75 reset command
 delay_ms(15);         //pause 15 ms
//***** Function to measure SHT75 temperature *****
int16 measuretemp (void)
 int1 ack;
 int16 iobyte;
 comstart();             //alert SHT75
 ack = comwrite(0x03);   //send measure temp command and read ack status
 if(ack == 1) return;
 comwait();              //wait for SHT75 measurement to complete
 iobyte = comread();     //read SHT75 temp data
 return(iobyte);
//***** Function to measure SHT75 RH *****
int16 measurehumid (void)
 int1 ack;
 int16 iobyte;
 ack = comwrite(0x05);  //send measure RH command and read ack status
 return(iobyte);
//***** Function to calculate SHT75 temp & RH *****
void calculate_data (int16 temp, int16 humid, float & tc, float & rhlin, float & rhtrue)
 float truehumid1, rh;
 //calculate temperature reading
 tc = ((float) temp * 0.01) - 40.0;
 //calculate Real RH reading
 rh = (float) humid;
 rhlin = (rh * 0.0405) - (rh * rh * 0.0000028) - 4.0;
 //calculate True RH reading
 rhtrue = ((tc - 25.0) * (0.01 + (0.00008 * rh))) + rhlin;
//***** Function to measure & calculate SHT75 temp & RH *****
void sht_rd (float & temp, float & truehumid)
 int16 restemp, reshumid;
 float realhumid;
 restemp = 0; truehumid = 0;
 restemp = measuretemp();    //measure temp
 reshumid = measurehumid();  //measure RH
calculate_data (restemp, reshumid, temp, realhumid, truehumid);  //calculate temp & RH
//***** Function to initialise SHT75 on power-up *****
void sht_init (void)
 comreset();    //reset SHT75
 delay_ms(20);  //delay for power-up
buda örnek::
#include <16F877A.h>
#fuses HS,NOWDT,PUT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#include<lcd.c>
#include<sht75.c>
void main()
 float restemp, truehumid;
 lcd_init();
 sht_init();
 while(1)
  sht_rd (restemp, truehumid);
  lcd_gotoxy(1,1);
  printf(lcd_putc, "Temp : %3.1f %cC   ", restemp, 223);
  printf(lcd_putc, "\nRH   : %3.1f %%   ", truehumid);
  delay_ms(500);        //delay 500 ms between reading to prevent self heating of sensor
husam685
arkadaşlar çok sagolun şimdi bununla ilgili bi sorun var devrem herşeyim hazırdı zaten simdi SHT75 driverine SHT75 baglayınca devreye +4,5 sapma var ama SHT75 yerine SHT15 baglayınca bu sapma  +2.6 oluyor ama benim SHT75 kullanmam lazım bunu nasıl çözebilirim.
