STM32F4 DMA interrupt problemi?
Başlatan Mucit23, 09 Nisan 2014, 15:49:21
Hocam dediğinizi yaptım. Yaklaşık 10 dk oldu hala çalışıyor.
Ayarlardada pek birşey yapmadım.
  /* Enable DMA2 clock */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
  /* DMA2 Stream1 Configuration */
  DMA_DeInit(DMA2_Stream1);
  DMA_InitStructure.DMA_Channel = DMA_Channel_1;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) ℑ
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) &image_array;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 19200;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Enable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream1, &DMA_InitStructure);
  /* DMA Interrupts config ***************************************************/
  DMA_ITConfig(DMA2_Stream1,DMA_IT_TC, ENABLE);
	DMA_ITConfig(DMA2_Stream1,DMA_IT_FE, ENABLE);
	DMA_ITConfig(DMA2_Stream1,DMA_IT_TE, ENABLE);
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
DCMI yine aktif durumda. Yaptığım tek şey peripheral adres bölümüne yine boyutu 19200 olan bir dizinin adresini atadım. Ayrıca DMA_PeripheralInc özelliğini aktif ettim.
DMA TC kesmesi yaklaşık 581 us aralıklarla oluşuyor.
DMA nın hata kesmelerinde oluşan yok. Yani DMA bu haliyle sıkıntısı çalışıyor diyebiliriz. Peki bundan sonra ne yapayım hocam acaba DCMI'mi problemli çalışıyor? Başka ne tür testler yapabilirim
Birde şunu sorayım. Yukarıdaki DMA ilgili ayarlarda DMA yı DCMI ye bağlayan şey nedir? Merak ettiğim nokta şu. DMA tetikleme sinyalini nereden alır bu durumdayken? DCMI dan yine alsa transfer süresi yine aynı olurdu ama DMA daha hızlı çalışıyor. DCMI Capture işlemini durduruncada DMA çalışmıyor? Bunu açıklayabilirmisiniz.
SpeedyX
#16
datasheet de DMA2 kısmında bir tablo var, kontrol etmedim ama muhtemelen DCMI enable ise DMA2 oraya bağlı olarak geliyor. PeripheralToMemory seçerek de tam olarak DCMI dan veri alınacağı belirleniyor.
İlginç olan, kodunda DMA_DIR_PeripheralToMemory seçmiş olmana rağmen hızlı bir şekilde memory to memory kopyalama yapmış olması. Burada kopyalamayı DCMI tetiklemeli yapması beklenir, bildiğim kadarıyla.
Projede başka DMA kullanan kod var mı?
DCMI init kodlarını görebilir miyim?
DCMI overflow kesmesi oluşuyor mu?
Kamera hangi boyutta resim gönderiyor? - DMA ayarlarına göre (Word), size olarak resim/4 verilmeli.
Aşağıdaki kodda sorun var sanırım, tanım char image_array[19200] şeklinde ise & işaretini kaldırmalısın yada &image_array[0] şeklinde kullanmalısın.
DMA_Mode_Circular yerine DMA_Mode_Normal deneyip tek resim almaya çalışabilirsin.
Hocam kusura bakmayın cevapta biraz geciktim.
Alıntı yapılan: SpeedyX - 12 Nisan 2014, 15:38:52
Hocam bu konuda kesinlikle haklısınız. Eğer Şuanda DMA, DCMI ile bağlantılı çalışıyorsa neden veri transferini hızlı yapsın? Eğer DCMı den tetik sinyali alıyorsa DCMI nin hızında transfer yapması gerekir
DMA nın nasıl DCMI'ye bağlandığını anladım sanırım. Dediğiniz gibi aşağıdaki tablo açıklıyor.
Biz DCMI ve DMA Stream1'i aktif ettiğimiz zaman galiba doğrudan DMA, DCMI den tetikleme sinyali alacak şekilde ayarlanıyor. Bu yüzden DCMI Capture işlemini durdurduğumda DMA çalışmıyor. Ama DCMı çalıştığında neden DMA hızlı çalışıyor bu sorunun cevabını arıyorum.  ???
Projede birde ADC3 kullanıyor ama ADC yi hiç init etmiyorum bile. Ayrıca ADC3, DMA2_Stream0'ı kullanıyor.
DCMI init kodlarım bunlar hocam.
  * @file    DCMI/OV9655_Camera/dcmi_ov9655.c
  * @author  MCD Application Team
  * @version V0.1.4
  * @date    10/15/2010
  * @brief   This file includes the driver for OV9655 Camera module mounted on
  *          STM3220F-EVAL board RevA.
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2010 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "OV9655.h"
#include "stm32f4xx.h"
#include "I2C.h"
#include "main.h"
/** @addtogroup DCMI_OV9655_Camera
/* Private typedef -----------------------------------------------------------*/
   RCC_ClocksTypeDef RCC_Clocks;
/* Private define ------------------------------------------------------------*/
   #define  TIMEOUT  2
   #define  DCMI_DR_ADDRESS     0x50050028
   #define  FSMC_LCD_ADDRESS    0x60020000
/* Bits definitions ----------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
   __IO uint16_t image_array[19200];
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/* Pin Map -------------------------------------------------------------------*/
      DCMI D0    = PC6
			DCMI D1    = PC7
			DCMI D2    = PE0
			DCMI D3    = PE1
      DCMI D4    = PE4
			DCMI D5    = PB6
			DCMI D6    = PE5
			DCMI D7    = PE6
      DCMI HSYNC = PA4
			DCMI VSYNC = PB7
			DCMI XCLK  = PC9
			DCMI PXCLK = PA6
			I2C_SCL    = PB8
			I2C_SDA    = PB9
  * @brief  Configures the OV9655 DCMI
  * @param  None
  * @retval None
uint8_t OV9655_Configuration(void){
	int i=0;
	OV9655_IDTypeDef OV9655_ID;
	/*OV9655 MCO Configuration*/
	OV9655_MCO_Configuration();
	/* I2C configuration */
  Soft_I2C_Configuration();
  for(i=0;i<10000;i++){}
  /* Reset and check the presence of the OV9655 camera module */
  if (DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x12, 0x80)==0xFF)
     return (0xFF); //Camera Failed!
	/* Camera Ok!*/
  DCMI_OV9655_ReadID(&OV9655_ID);
  /* OV9655 Camera size setup */
  #if defined (QQVGA_SIZE)
    DCMI_OV9655_QQVGASizeSetup();
  #elif defined (QVGA_SIZE)
    DCMI_OV9655_QVGASizeSetup();
  #endif
	//OV9655_config_window(272,16,320,240);
  /* Set the RGB565 mode */
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM7, 0x63);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM15, 0xd0);
  /* Invert the HRef signal*/
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM10, 0x08);
	/* OV9655 Camera DCMI setup */
  OV9655_DCMI_Configuration();
  return (0x00);
  * @brief  Configures the MCO Module
  * @param  None
  * @retval None
void OV9655_MCO_Configuration(void){
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_MCO);
  RCC_PLLI2SCmd(DISABLE);
  RCC_PLLI2SConfig(240, 5); // 192..432, 2..7, ie range of 27.429 Mhz to 192 MHz
  /* PLLI2SSCLK = 240 / 5 = 48Mhz */
	/* MCO2 Output Freq = 48 / 2 = 24Mhz*/
  RCC_MCO2Config(RCC_MCO2Source_PLLI2SCLK, RCC_MCO2Div_2); // 24 MHz with default PLL fComp
  RCC_PLLI2SCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLI2SRDY) == RESET);
  * @brief  Configures the DCMI to interface with the OV9655 camera module.
  * @param  None
  * @retval None
void OV9655_DCMI_Configuration(void)
  DCMI_InitTypeDef DCMI_InitStructure;
  DMA_InitTypeDef  DMA_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable DCMI GPIOs clocks */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOE |
                         RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOA, ENABLE);
  /* Enable DCMI clock */
  RCC_AHB2PeriphClockCmd(RCC_AHB2Periph_DCMI, ENABLE);
  /* Connect DCMI pins to AF13 ************************************************/
  /* PCLK */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_DCMI);
  /* D0-D7 */
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_DCMI);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_DCMI);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource0, GPIO_AF_DCMI);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource1, GPIO_AF_DCMI);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource4, GPIO_AF_DCMI);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_DCMI);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource5, GPIO_AF_DCMI);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource6, GPIO_AF_DCMI);
  /* VSYNC */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_DCMI);
  /* HSYNC */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_DCMI);
  /* DCMI GPIO configuration **************************************************/
  /* D0 D1(PC6/7) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  /* D2..D4(PE0/1/4) D6/D7(PE5/6) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1
	                              | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* D5(PB6), VSYNC(PB7) */
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* PCLK(PA6) HSYNC(PA4)*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_6;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* DCMI configuration *******************************************************/
  DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMode_Continuous;
  DCMI_InitStructure.DCMI_SynchroMode = DCMI_SynchroMode_Hardware;
  DCMI_InitStructure.DCMI_PCKPolarity = DCMI_PCKPolarity_Rising;
  DCMI_InitStructure.DCMI_VSPolarity = DCMI_VSPolarity_High;
  DCMI_InitStructure.DCMI_HSPolarity = DCMI_HSPolarity_High;
  DCMI_InitStructure.DCMI_CaptureRate = DCMI_CaptureRate_All_Frame;
  DCMI_InitStructure.DCMI_ExtendedDataMode = DCMI_ExtendedDataMode_8b;
  DCMI_Init(&DCMI_InitStructure);
//  /* DCMI Interrupts config ***************************************************/
//  DCMI_ITConfig(DCMI_IT_VSYNC, ENABLE);
//  DCMI_ITConfig(DCMI_IT_LINE, ENABLE);
//  DCMI_ITConfig(DCMI_IT_FRAME, ENABLE);
  DCMI_ITConfig(DCMI_IT_ERR, ENABLE);
  DCMI_ITConfig(DCMI_IT_OVF, ENABLE);
  NVIC_InitStructure.NVIC_IRQChannel = DCMI_IRQn;
  /* Configures the DMA2 to transfer Data from DCMI to the LCD ****************/
  DMA_InitStructure.DMA_PeripheralBaseAddr = DCMI_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) &image_array[0];
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  * @brief  Reset the OV9655 SCCB registers.
  * @param  None
  * @retval None
void DCMI_OV9655_Reset(void)
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM7, SCCB_REG_RESET);
  * @brief  Set the QVGA size(240*320).
  * @param  None
  * @retval None
void DCMI_OV9655_QVGASizeSetup(void)
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x00, 0x12);//
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x01, 0x80);//78
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x02, 0x80);//48
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x03, 0x02);//02
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x04, 0x03);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x05, 0x39);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x06, 0x39);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x07, 0x39);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x08, 0x38);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x09, 0x03);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0a, 0x96);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0b, 0x57);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0c, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0d, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0e, 0x01);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0f, 0x00);//old val 0xc0
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x10, 0x7b);//old val 7b
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x11, 0x00);//old val 0x80
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x12, 0x63);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x13, 0xEF);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x14, 0x2A);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x15, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x16, 0x24);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x17, 0x18);//18
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x18, 0x04);//04
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x19, 0x01);//01
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x1a, 0x81);//81
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x1b, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x1c, 0x7F);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x1d, 0xA2);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x1E, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x1F, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x20, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x21, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x22, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x23, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x24, 0x60);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x25, 0x36);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x26, 0x72);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x27, 0x08);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x28, 0x08);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x29, 0x15);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x2a, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x2b, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x2c, 0x08);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x2d, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x2e, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x2f, 0x38);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x30, 0x08);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x31, 0x30);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x32, 0x12);//12
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x33, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x34, 0x3f);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x35, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x36, 0x3a);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x37, 0x04);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x38, 0x72);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x39, 0x57);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x3a, 0xca);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x3b, 0x04);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x3c, 0x0c);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x3d, 0x99);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x3e, 0x02);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x3f, 0xc1);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x40, 0xd0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x41, 0x41);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x42, 0xc0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x43, 0x0a);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x44, 0xf0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x45, 0x46);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x46, 0x62);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x47, 0x2a);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x48, 0x3c);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x49, 0x48);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x4a, 0xec);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x4b, 0xfc);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x4c, 0x7f);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x4d, 0x7f);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x4e, 0x7f);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x4f, 0x98);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x50, 0x98);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x51, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x52, 0x28);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x53, 0x70);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x54, 0x98);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x55, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x56, 0x48);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x57, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x58, 0x1a);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x59, 0x85);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x5a, 0xa9);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x5b, 0x64);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x5c, 0x84);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x5d, 0x53);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x5e, 0x0e);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x5f, 0xf0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x60, 0xf0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x61, 0xf0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x62, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x63, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x64, 0x02);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x65, 0x20);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x66, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x67, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x68, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x69, 0x0a);//
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x6a, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x6b, 0x0a);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x6c, 0x04);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x6d, 0x55);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x6e, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x6f, 0x9d);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x70, 0x21);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x71, 0x78);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x72, 0x11);//
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x73, 0x01);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x74, 0x10);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x75, 0x10);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x76, 0x01);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x77, 0x02);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x78, 0x28);//Test
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x79, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x7A, 0x12);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x7B, 0x08);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x7C, 0x16);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x7D, 0x30);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x7E, 0x5e);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x7F, 0x72);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x80, 0x82);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x81, 0x8e);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x82, 0x9a);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x83, 0xa4);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x84, 0xac);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x85, 0xb8);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x86, 0xc3);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x87, 0xd6);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x88, 0xe6);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x89, 0xf2);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8a, 0x24);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8b, 0x04);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8c, 0x80);
//  Delay(TIMEOUT);
//  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8d, 0x00);
//  Delay(TIMEOUT);
//  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8e, 0x00);
//  Delay(TIMEOUT);
//  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8f, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x90, 0x71);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x91, 0x6f);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x9d, 0x02);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x9e, 0x02);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x9f, 0x7a);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa0, 0x6D);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa1, 0x40);//
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa2, 0x9D);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa4, 0x50);//50
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa5, 0x68);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa6, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa8, 0xc1);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa9, 0xef);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xaa, 0x92);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xab, 0x04);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xac, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xad, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xae, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xaf, 0x80);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb2, 0xf2);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb3, 0x20);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb4, 0x20);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb5, 0x00);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb6, 0xaf);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb7, 0xee);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb8, 0xee);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xb9, 0x0c);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbb, 0xae);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbc, 0x7c);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbd, 0x7d);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbe, 0x7e);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbf, 0x7f);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc0, 0xaa);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc1, 0xc0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc2, 0x01);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc3, 0x4e);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc5, 0x2e);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc6, 0x05);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc7, 0x81);//81
  Delay(TIMEOUT);
	DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc8, 0x06);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc9, 0xe0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xca, 0xe8);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xcb, 0xf0);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xcc, 0xd8);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xcd, 0x93);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xce, 0xe3);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xcf, 0x74);
  Delay(TIMEOUT);
  * @brief  Set the QQVGA size(120*160).
  * @param  None
  * @retval None
void DCMI_OV9655_QQVGASizeSetup(void)
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x00, 0x00);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x13, 0xef);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x14, 0x2a);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x1e, 0x00);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x32, 0xa4);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x4a, 0xfC);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x72, 0x22);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x73, 0x02);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x91, 0x6F);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xa2, 0x9D);//
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbc, 0x7C);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbd, 0x7D);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xbe, 0x7E);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0xc7, 0x82);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  Delay(TIMEOUT);
  * @brief  Read the OV9655 Manufacturer identifier.
  * @param  OV9655ID: pointer to the OV9655 Manufacturer identifier.
  * @retval None
void DCMI_OV9655_ReadID(OV9655_IDTypeDef* OV9655ID)
  OV9655ID->Manufacturer_ID1 = DCMI_SingleRandomRead(OV9655_DEVICE_WRITE_ADDRESS, OV9655_MIDH);
  OV9655ID->Manufacturer_ID2 = DCMI_SingleRandomRead(OV9655_DEVICE_WRITE_ADDRESS, OV9655_MIDL);
  OV9655ID->Version = DCMI_SingleRandomRead(OV9655_DEVICE_WRITE_ADDRESS, OV9655_VER);
  OV9655ID->PID = DCMI_SingleRandomRead(OV9655_DEVICE_WRITE_ADDRESS, OV9655_PID);
  * @brief  Set the Internal Clock Prescaler.
  * @param  OV9655_Prescaler: the new value of the prescaler.
  *   This parameter can be a value between 0x0 and 0x1F
  * @retval None
void DCMI_OV9655_SetPrescaler(uint8_t OV9655_Prescaler)
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_CLKRC, OV9655_Prescaler);
  * @brief  Select the Output Format.
  * @param  OV9655_OuputFormat: the Format of the ouput Data.
  *     @arg OUTPUT_FORMAT_RAWRGB_DATA
  *     @arg OUTPUT_FORMAT_RAWRGB_INTERP
  *     @arg OUTPUT_FORMAT_YUV
  *     @arg OUTPUT_FORMAT_RGB
  * @retval None
void DCMI_OV9655_SelectOutputFormat(uint8_t OV9655_OuputFormat)
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM7, OV9655_OuputFormat);
  * @brief  Select the Output Format Resolution.
  * @param  OV9655_FormatResolution: the Resolution of the ouput Data.
  *   This parameter can FORMAT_CTRL_15fpsVGA a value between 0x0 and 0x1F
  *     @arg FORMAT_CTRL_15fpsVGA
  *     @arg FORMAT_CTRL_30fpsVGA_NoVArioPixel
  *     @arg FORMAT_CTRL_30fpsVGA_VArioPixel
  * @retval None
void DCMI_OV9655_SelectFormatResolution(uint8_t OV9655_FormatResolution)
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM7, OV9655_FormatResolution);
  * @brief  Set the new value of OV9655 registers
  * @param  OV9655_Register: the OV9655 Register to be configured.
  * @param  Register_Val: The new value to be set
  * @retval None
void DCMI_OV9655_SetRegister(uint8_t OV9655_Register, uint8_t Register_Val)
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_Register, Register_Val);
  * @brief  Select the HREF Control signal option
  * @param  OV9665_HREFControl: the HREF Control signal option.
  *     @arg OV9665_HREFControl_Opt1: HREF edge offset to data output.
  *     @arg OV9665_HREFControl_Opt2: HREF end 3 LSB
  *     @arg OV9665_HREFControl_Opt3: HREF start 3 LSB
  * @retval None
void DCMI_OV9655_HREFControl(uint8_t OV9665_HREFControl)
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_HREF, OV9665_HREFControl);
  * @brief  Select the RGB format option
  * @param  OV9665_RGBOption: the RGB Format option.
  *     @arg RGB_NORMAL
  *     @arg RGB_565
  *     @arg RGB_555
  * @retval None
void DCMI_OV9655_SelectRGBOption(uint8_t OV9665_RGBOption)
  DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM15, OV9665_RGBOption);
  * @brief  config_OV7660_window
  * @param  //(140,16,640,480) is good for VGA
  *			//(272,16,320,240) is good for QVGA
  * @retval None
void OV9655_config_window(uint16_t startx, uint16_t starty, uint16_t width, uint16_t height)
	uint16_t endx=(startx+width);
	uint16_t endy=(starty+height*2);// must be "height*2"
	uint8_t temp_reg1=0, temp_reg2=0;
	uint8_t state,temp;
	state = state;	   //Prevent report warning
	state = DCMI_SingleRandomRead(OV9655_DEVICE_WRITE_ADDRESS, 0x03);
	temp_reg1 &= 0xC0;
	state = DCMI_SingleRandomRead(OV9655_DEVICE_WRITE_ADDRESS, 0x32);
	temp_reg2 &= 0xC0;
	// Horizontal
	temp = temp_reg2|((endx&0x7)<<3)|(startx&0x7);
	state = DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, 0x32, temp );
	temp = (startx&0x7F8)>>3;
	state = DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, 0x17, temp );
	temp = (endx&0x7F8)>>3;
	state = DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, 0x18, temp );
	// Vertical
	temp = temp_reg1|((endy&0x7)<<3)|(starty&0x7);
	state = DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, 0x03, temp );
	temp = (starty&0x7F8)>>3;
	state = DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, 0x19, temp );
	temp = (endy&0x7F8)>>3;
	state = DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, 0x1A, temp );
  * @brief  Writes a byte at a specific Camera register
  * @param  Device: OV9655 write address.
  * @param  Addr: OV9655 register address.
  * @param  Data: data to be written to the specific register
  * @retval None
uint8_t DCMI_SingleRandomWrite(uint8_t Device, uint16_t Addr, uint8_t Data)
	I2C_Delay();
	I2C_Start();
	I2C_SendByte(Device);
	if(I2C_WaitAck()==0xFF) return(0xFF);
	I2C_SendByte(Addr);
	I2C_SendByte(Data);
	I2C_Stop();
  return(0x00);
  * @brief  Reads a byte from a specific Camera register
  * @retval data read from the specific register
uint8_t DCMI_SingleRandomRead(uint8_t Device, uint16_t Addr)
	unsigned char Recieved_Data=0;
  I2C_Delay();
	I2C_Start();
	I2C_SendByte(Addr);
	I2C_Stop();
	I2C_Start();
	I2C_SendByte(Device+1);
	Recieved_Data=I2C_ReceiveByte();
	I2C_Stop();
	return Recieved_Data;
/******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
İnterrupt rutinlerimde aşağıdaki gibi.
  * @brief  This function handles DMA2_Stream1.
  * @param  None
  * @retval None
void DMA2_Stream1_IRQHandler(void)
	int i=0;
  if(DMA_GetITStatus(DMA2_Stream1, DMA_IT_TCIF1))
		STM_EVAL_LEDToggle(LED3);
    for (i=0;i<19200;i++)
      LCD_WriteRAM(image_array[i]);
    /* Clear DMA Stream Transfer Complete interrupt pending bit */
    DMA_ClearITPendingBit(DMA2_Stream1, DMA_IT_TCIF1);
  if(DMA_GetITStatus(DMA2_Stream1, DMA_IT_FEIF1))
    LCD_DisplayStringLine(0,170,"Fifo Error");
    DMA_ClearITPendingBit(DMA2_Stream1, DMA_IT_FEIF1);
  if(DMA_GetITStatus(DMA2_Stream1, DMA_IT_TEIF1))
    LCD_DisplayStringLine(0,170,"Transfer Error");
    DMA_ClearITPendingBit(DMA2_Stream1, DMA_IT_TEIF1);
  * @brief  This function handles DCMI Handler.
  * @param  None
  * @retval None
void DCMI_IRQHandler(void)
	if (DCMI_GetITStatus(DCMI_IT_VSYNC) != RESET)
		DCMI_ClearITPendingBit(DCMI_IT_VSYNC);
	if (DCMI_GetITStatus(DCMI_IT_LINE) != RESET)
		DCMI_ClearITPendingBit(DCMI_IT_LINE);
	if (DCMI_GetITStatus(DCMI_IT_FRAME) != RESET)
		DCMI_ClearITPendingBit(DCMI_IT_FRAME);
	if (DCMI_GetITStatus(DCMI_IT_OVF) != RESET)
		LCD_DisplayStringLine(0,170,"DCMI OverFlow Error");
		DCMI_ClearITPendingBit(DCMI_IT_OVF);
	if (DCMI_GetITStatus(DCMI_IT_ERR) != RESET)
		LCD_DisplayStringLine(0,170,"DCMI Error");
		DCMI_ClearITPendingBit(DCMI_IT_ERR);
Bu arada memory kısmında dizi tanımlamasını  &image_array[0] şeklinde yaptım.
Hocam DCMI ve DMA'nın bütün hata kesmeleri açık. Normal olarak çalışırken hiçbiri oluşmuyor. Overflow kesmeside oluşmuyor
Kamerayı ise QQVGA boyutlarında görüntü verecek şekilde init ediyorum. Yani image boyutu 160x120(19200) Bu görüntüyü DMA ile direk ekrana göndersem hiçbir problem çıkmıyor ama tanımladığım image_array isimli diziye yazınca sıkıntı oluşuyor.
DMA mode'yi normal yapıncada yine sıkıntı yok tek bir resim geliyor ekrana basılıyor ondan sonra artık resim gelmiyor ve DCMI Overflow kesmesi oluşuyor. (Normal bir durum diye düşünüyorum)
Benim aklıma birtek şu konu takılıyor
DCMI DR registeri 32 bitlik
Biz kameradan 16 bit RGB565 datası alıyoruz. DMA bu 32bitlik adresten datayı alıp benim tanımlamış olduğum 16 bitlik diziye taşıyor. Yaptığı bütün iş budur. Acaba Peripheral ile Memory data boyutları farklı olduğu içinmi donuyor?
DMA ayarlarında her türlü olasılığı denedim. Peripheral kısmı ile Memory kısmını HalfWord yapsam DMA çalışmıyor ve Transfer Error kesmesi oluşuyor. Peripheral Adresi Word olduğu sürece DMA çalışıyor. Ne yapayım sizce
SpeedyX
Alıntı yapılan: Mucit23 - 13 Nisan 2014, 12:40:09DMA mode'yi normal yapıncada yine sıkıntı yok tek bir resim geliyor ekrana basılıyor ondan sonra artık resim gelmiyor ve DCMI Overflow kesmesi oluşuyor. (Normal bir durum diye düşünüyorum)
Bütün kodlar aynıyken dma mode normal yapınca çalışıyor mu? Eğer evet ise; lcd ye yazma işlemini interrupt içinde yapma, zaten programın ilerledikçe ondan vazgeçmen gerekecek.
Streaming yaparken 2 buffer kullanılır, ilk buffer dolunca kesmede bir flag set ederek, dma mem adresi 2. buffer olarak düzenlenir, mainde bu buffer içeriği lcd ye gönderilir, diğer buffer dolunca, 1.buffer dma ile ilişkilendirilip, main de 2.buffer lcd ye gönderilir. Basit bir pointer ile bufferlar arası switch edilebilir. CMSIS de DoubleStreaming ile ilgili birşeyler görmüştüm sanki...
Kesme oluşup for döngüsünde lcd ye yazma yapılırken dma çalışmaya devam ediyor ve orada işler karışıyor olabilir.
Yada kolaylık olsun diye, kesme oluşunca DCMI duraklatılabilinir.
Senin program mantığına göre dma mode normal olup, resim buffera alındıktan sonra lcd ye gönderilir ve artından dma tekrar başlatılır, fakat yine dcmi duraklatma gerekebilir.
DMA neden hızlı çalışıyor? - DCMI tetikleme flagı hızlı değişiyor olabilir. Bu flag da kameradan alınan clock a dolaylı olarak bağlı.
Öncelikle kesmede lcd ye yazma işlemini kaldırmayı dene, sonucu görelim.
Tamam hocam interrupt içinde bir flagı aktif e dip main içerisinde lcd ye aktarım işlemi yapayım.
Mesajlarda sınır gibi birşey var dünki mesajımı kısa kesmek zorunda kalmıştım.
Main kodu'da aşağıdaki gibi.
int main()
	SystemInit();
	if (SysTick_Config(SystemCoreClock / 3119))//1ms
    /* Capture error */
    while (1);
  STM_EVAL_LEDInit(LED3);
  STM_EVAL_LEDInit(LED4);
  STM3240F_LCD_Init();
	LCD_Clear(Black);
	LCD_SetColors(Green,Black);
	LCD_SetFont(&Font8x8);
    if(OV9655_Configuration()==0xFF)
	     LCD_DisplayStringLine(0,0,"Camera Failed");
    }else{
       LCD_DisplayStringLine(0,0,"Camera OK!");
		/* Start Image capture */
	LCD_SetDisplayWindow(0, 0, 159, 119);
  LCD_WriteRAM_Prepare();
  /* Enable DMA transfer */
  DMA_Cmd(DMA2_Stream1, ENABLE);
  /* Enable DCMI interface */
  DCMI_Cmd(ENABLE);
  DCMI_CaptureCmd(ENABLE);
	while(1)
		 STM_EVAL_LEDToggle(LED4);
     for (i=0;i<1000000;i++);
