ESP8266 Wifi Module Örnek Uygulama
Başlatan MrDarK, 01 Kasım 2014, 11:47:01
Recep METE
ESP8266  CCS C  Kodlarını  buraya yapıştırayım.Belki birilerine lazım olur.Birde kodun bulunduğu sitesi falan  kapanır.İşi sağlama alalım.
main.
#include <18F4550.h>
#DEVICE ADC=8
#fuses HSPLL,MCLR,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(UART1,baud=115200,parity=N,bits=8,stream=WIFI_ESP,errors)//Khai bao su dung uart cung
#include <usb_cdc.h>
#include <usb_desc_cdc.h>
#define ledv  PIN_C2
#define ledr  PIN_C1
#define ledon output_low
#define ledoff output_high
#define led_on output_low
#define led_off output_high
#define LCD_ENABLE_PIN PIN_D2
#define LCD_RS_PIN PIN_D0
#define LCD_RW_PIN PIN_D1
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <lcd.c>
#include<wifi.c>
#include<sonbui/mystr.c>
char *SSID_JOIN="TU HU";//"SonBui-AP";
char *PASS_JOIN="12345679";//"a12344321";
char *DATA_SEND="GET /data/2.5/weather?id=1581130 HTTP/1.0\r\nHost: api.openweathermap.org\r\n\r\n" ;     //1581130: Hanoi-Viet nam
char *WEATHER_IP= "188.226.224.148"; //api.openweathermap.org
void get_internet()
   char *write = ">"
   int1 OK = False;
   printf(LCD_PUTC, "\fGData Hanoi,VN\nopenweathermap.org");
   delay_ms(1000);
   if( client_Start(0,TYPE_TCP,WEATHER_IP,80))   //kET NOI TOI SERVER DE LAY DU LIEU
      printf(LCD_PUTC, "\fGet data");
      int16 length=strlen(DATA_SEND);
      DO
         clear_mem();
         fprintf(WIFI_ESP, AT_SEND);
         fprintf(WIFI_ESP, "=%u", 0);
         fprintf(WIFI_ESP, ",%lu",length);
         fprintf(WIFI_ESP, CRLF);
         for (int mem_loop = 0; mem_loop < 150; mem_loop++) {
            wifi_buff[n] = timed_getc();
            n++;
            if (n > 150) n = 0;
            if (timeout_error) break;
         char *pch = strstr(wifi_buff, write);
         IF(pch) {
            OK = TRUE;
            break;
         delay_ms(100);
      WHILE(!OK);
      //Send http get
      clear_mem();
      printf(LCD_PUTC, "\fSend Get");
      fprintf(WIFI_ESP, "%s",DATA_SEND);
      Long LONG timeout;
      timeout = 0;
      WHILE(!kbhit(WIFI_ESP) && (++timeout < 2000000))  //20 second
         delay_us(10);
      WHILE(!(fgetc(WIFI_ESP)=='{')) ;
      printf(LCD_PUTC, "\f{");
      wifi_buff[0]='{';n=1;
      do {
         wifi_buff[n] = mili_getc();
         n++;
         if (n > 512) n = 0;
      }while(!timeout_error) ;
      printf(LCD_PUTC, "\fPrint Data");
      //printf(usb_cdc_putc, "\r\nWF:%s"wifi_buff);
      char *jstart="\"main\":{";
      char *jstop=",\"wind\"";
      char *p1 = strstr(wifi_buff,jstart);
      if(p1)
         // printf(usb_cdc_putc, "\r\n\fp1:%s"p1);
         char *p2 = strstr(p1,jstop);
         if(p2)
            // printf(usb_cdc_putc, "\r\n\fp2:%s"p2);
            size_t len = p2-p1;
            char *jmain = (char*)malloc(sizeof(char)*(len+1));
            strncpy(jmain, p1, len);
            jmain[len] = '\0'
            // printf(usb_cdc_putc, "\r\nRes:%s"jmain);
            char *temp="\"temp\":";
            char *temp_min=",\"temp_min\":";
            char *ap_suat=",\"pressure\":";
            char *ap_suat_end=",\"sea_level";
            char *do_am="\"humidity\":";
            char *do_am_end="}";
            double d_nhiet_do;
            free(res) ;
            char *nhiet_do=extract_string(temp,temp_min,jmain);
            if(nhiet_do)
               // printf(usb_cdc_putc, "\r\nNhiet do:%s"nhiet_do);
               d_nhiet_do = atof (nhiet_do);//treo neu gia tri nhiet do sai dinh dang
               d_nhiet_do -= 273.15; //kelvin-celsius
               printf (LCD_PUTC, "\fT=%f"d_nhiet_do);
            free(res) ;
            char *ap_suat_khi=extract_string(ap_suat,ap_suat_end,jmain);
            if(ap_suat)
               //  printf(usb_cdc_putc, "\r\nAp suat:%s"ap_suat_khi);
               printf (LCD_PUTC, "\nP=%s hpa"ap_suat_khi);
            free(res) ;
            char *do_am_khi=extract_string(do_am,do_am_end,jmain);
            if(do_am_khi)
               // printf(usb_cdc_putc, "\r\nDo am khi:%s"do_am_khi);
               lcd_gotoxy(10,1) ;
               printf (LCD_PUTC, "H=%s %%"do_am_khi);
            free(jmain) ;
      printf (LCD_PUTC, "\f Can't connect to\nopenweathermap.org");
      delay_ms(1000);
void main()
   lcd_init ();
   printf (LCD_PUTC, "\f MuaLinhKien.Vn\nPIC 16/18 Basic Kit");
   delay_ms(1000);
   printf (LCD_PUTC, "\fESP8266 Test\nmualinhkien.vn");
   esp_init();
   setup_AP(SSID_SET,PASS_SET,5,ECN_WAP2_PSK);
   delay_ms(1000);
   join_AP(SSID_JOIN,PASS_JOIN);
   delay_ms(1000);
   client_Start(0,TYPE_TCP,WEATHER_IP,80);   //kET NOI TOI SERVER DE LAY DU LIEU
   delay_ms(1000);
   get_ip();
   clear_mem();
   //!   usb_cdc_init();
   //!   usb_init();
   //!   usb_task();
   //!   usb_wait_for_enumeration();
   //!     while(!usb_cdc_connected());
   while (TRUE)
      get_internet();
      for(int loop=0;loop<120;loop++)
         output_toggle(ledr);
         delay_ms(500);
wifi.c  (kütühane dosyası)
Dung while de doc du lieu tra ve
Dung ngat de lay du lieu bat ki
#INCLUDE <stdlibm.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <wifi.h
char wifi_buff[512];
int16 n = 0;
INT1 timeout_error;
INT8 timeout_error_count = 0;
char CRLF[] = "\r\n";
char *SSID_SET = "VISMART.CO";
char *PASS_SET = "12345678";
char *STR_OK="\r\nOK\r\n" ;
char *STR_START=":" ;
char data_out[50];
void clear_mem(void) {
   for (int16 mem_loop = 0; mem_loop < 512; mem_loop++) {
      if (wifi_buff[mem_loop] == '\0')
      break;
      wifi_buff[mem_loop] = '\0';
   n = 0;
void clear_data(void) {
   for (int16 mem_loop = 0; mem_loop < 50; mem_loop++) {
      if (data_out[mem_loop] == '\0')
      break;
      data_out[mem_loop] = '\0';
   n = 0;
char timed_getc() {
   WHILE(!kbhit(WIFI_ESP));
   IF(kbhit(WIFI_ESP))
   RETURN(fgetc(WIFI_ESP));
   ELSE
      RETURN(0);
char *send_AT_result(char *command) {
   clear_mem();
   fprintf(WIFI_ESP, "%s", command);
      n++;
      if (n > 150) n = 0;
   return wifi_buff;
void send_AT_OK(char *command) {
   int1 OK = False;
   char *oks = "OK";
   DO
      clear_mem();
         n++;
         if (n > 150) n = 0;
      char *pch = strstr(wifi_buff, oks);
      IF(pch) {
         OK = TRUE;
         break;
      delay_ms(100);
   WHILE(!OK);
void esp_init() {
   int1 OK = False;
   char *oks = "OK";
   char *nc = "no change";
do { //ATE0
      clear_mem();
     fprintf(WIFI_ESP, AT_RESET);
   delay_ms(2000);
      fprintf(WIFI_ESP, AT_ECHO_OFF);
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fATE0");
      delay_ms(100);
   WHILE(!OK);
   do { //AT+CWMODE=3
      clear_mem();
      fprintf(WIFI_ESP, MODE_AT_STA);
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fAT+CWMODE=3");
      } else {
         char *no_change = strstr(wifi_buff, nc);
         IF(no_change) {
            OK = TRUE;
            printf(LCD_PUTC, "\fAT+CWMODE=3\nNo change");
      delay_ms(100);
   WHILE(!OK);
void setup_AP(unsigned char *ssid, unsigned char *password, int chl, int enc) {
   //AT+CWSAP="ssid","password",chl,enc
   int1 OK = False;
   char *oks = "OK";
   for (int loop = 0; loop < 5; loop++) {
      clear_mem();
      fprintf(WIFI_ESP, AT_SET_AP_PARAMS);
      fprintf(WIFI_ESP, "=\"%s\"", ssid);
      fprintf(WIFI_ESP, ",\"%s\"", password);
      fprintf(WIFI_ESP, ",%u", chl);
      fprintf(WIFI_ESP, ",%u", enc);
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fAT+CWSAP\nloop=%u", loop);
         break;
      delay_ms(100);
void join_AP(unsigned char *ssid, unsigned char *password) //Thuc hien mot lan vi khoi dong lai se tu ket noi
   //AT+CWJAP="ssid","password"
   int1 OK = False;
   char *oks = "OK";
   for (int loop = 0; loop < 3; loop++) {
      printf(LCD_PUTC, "\fCn to:%s\nLan %u", ssid, loop);
      clear_mem();
      fprintf(WIFI_ESP, AT_JOIN_AP);
      Long LONG timeout;
      timeout = 0;
      WHILE(!kbhit(WIFI_ESP) && (++timeout < 3000000)) //30 second
         delay_us(10);
         if (timeout % 3000 == 0) {
            timeout_error_count++;
            lcd_gotoxy(10, 2);
            int pos = timeout_error_count % 4;
            if (pos == 0)
            printf(LCD_PUTC, "    ");
            if (pos == 1)
            printf(LCD_PUTC, " .  ");
            if (pos == 2)
            if (pos == 3)
            printf(LCD_PUTC, "   .");
         n++;
         if (n > 150) n = 0;
         if (timeout_error)
         break;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fCnt To:%s\nLoop=%u", ssid, loop);
         break;
      ELSE
         printf(LCD_PUTC, "\fCn To:%s\nError!", ssid);
      delay_ms(100);
void quit_AP() {
   //AT+CWQAP
   int1 OK = False;
   char *oks = "OK";
   DO
      clear_mem();
      fprintf(WIFI_ESP, AT_QUIT_AP);
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fAT+CWQAP");
         break;
      delay_ms(100);
   WHILE(!OK);
void get_ip()
   //AT+CIFSR
   int1 OK = False;
   char *oks = "OK";
   DO
      clear_mem();
      fprintf(WIFI_ESP, AT_GET_IP);
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fIP:%s",wifi_buff);
         break;
      delay_ms(100);
   WHILE(!OK);
int1 client_Start(int id, int type, char *ip, unsigned int16 port)
   char *cmd = AT_SET_MUL_CON;
   int1 OK = False;
   char *oks = "OK";
   char *connected="ALREAY CONNECT"; //Ket noi da duoc ket noi tu truoc toi ip nay hoac ip khac voi id nay
   DO
      char *pch = strstr(send_AT_result(cmd), oks);
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\f%s", AT_SET_MUL_CON);
         break;
      delay_ms(100);
   WHILE(!OK);
      printf(LCD_PUTC, "\f%s\nPort:%5lu    %u", ip, port, loop);
      clear_mem();
      fprintf(WIFI_ESP, AT_START_CON);
      fprintf(WIFI_ESP, "=%u", id);
      if (type == TYPE_TCP
      fprintf(WIFI_ESP, ",\"TCP\"");
      fprintf(WIFI_ESP, ",\"UDP\"");
      fprintf(WIFI_ESP, ",\"%s\"", ip);
      fprintf(WIFI_ESP, ",%lu", port);
      Long LONG timeout;
      timeout = 0;
         delay_us(10);
            lcd_gotoxy(11, 2);
            if (pos == 0)
            if (pos == 1)
            if (pos == 2)
            if (pos == 3)
         n++;
         if (n > 150) n = 0;
         if (timeout_error)
         break;
      char *pch = strstr(wifi_buff, oks); //chu y con "ALREAY CONNECT"
      IF(pch) {
         OK = TRUE
         printf(LCD_PUTC, "\fIP:%s\nP:%5lu lan %u OK    ", ip, port, loop);
         break;
      ELSE
         char *link = strstr(wifi_buff, connected);
         IF(link) {
            OK = TRUE;
            printf(LCD_PUTC, "\fID CONNECTED!\nloop=%u", loop);
            break;
         OK = FALSE;
         printf(LCD_PUTC, "\fIP:%s\nP:%5lu Error", ip, port);
      delay_ms(100);
     return OK;
void server_Start(unsigned int16 port)   // Truoc khi chay phai restart
   int1 OK = False;
   char *oks = "OK";
   char *link_builded = "link is builded";
   DO
      char *pch = strstr(send_AT_result(cmd), oks); //chu y:link is builded
      IF(pch) {
         OK = TRUE;
         break;
         char *pch = strstr(send_AT_result(cmd), link_builded); //chu y:link is builded
         IF(pch) {
            OK = TRUE;
            printf(LCD_PUTC, "\fLink is Builded");
            break;
      delay_ms(100);
   WHILE(!OK);
      printf(LCD_PUTC, "\fServ Port:%5lu\nLan %u", port, loop);
      clear_mem();
      //AT+CIPSERVER=1,9999
      fprintf(WIFI_ESP, AT_SET_SERVER);
      fprintf(WIFI_ESP, "=1");
      Long LONG timeout;
      timeout = 0;
         delay_us(10);
            lcd_gotoxy(11, 2);
            if (pos == 0)
            if (pos == 1)
            if (pos == 2)
            if (pos == 3)
         n++;
         if (n > 150) n = 0;
         if (timeout_error)
         break;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fServ Port:%5lu\nLan %u OK", port, loop);
         break;
      ELSE
         printf(LCD_PUTC, "\fServ Port:%5lu\nLan %u Error!", port, loop);
      delay_ms(100);
//Cip close khi ket noi toi server phai co id
//close ket noi toi clinet(modlue khac hoac may tinh) thi ko can
void  close_connect(int id) //Tra ve ok hoac "link is not"
   // AT+CIPCLOSE=<id>
   int1 OK = False;
   char *not_link="link is not";   //chua ket noi
   char *oks="OK";
      clear_mem();
      fprintf(WIFI_ESP, AT_CLOSE_CON);
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fCLOSE CONNECT\nloop=%u", loop);
         break;
      ELSE
         char *link = strstr(wifi_buff, not_link);
         IF(link) {
            OK = TRUE;
            printf(LCD_PUTC, "\fNOT CONNECT\nloop=%u", loop);
            break;
void send_data(int id, char  *data)
   // AT+CIPSEND= <id>,<length>
   int1 OK = False;
   char *write = ">";
   char *send_ok="SEND OK";
   int16 length=strlen(data);
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         printf(LCD_PUTC, "\fSEND >\nlenght=%lu", length);
         //Gui noi dung
         char *sent = strstr(send_AT_result(data), send_ok);
         IF(sent) {
            OK = TRUE;
            printf(LCD_PUTC, "\fSEND OK\nlenght=%lu", length);
            break;
         OK = FALSE;
         printf(LCD_PUTC, "\fSEND FAIL!\nloop=%u", loop);
      delay_ms(100);
//Loi khi module reset ma client ko biet no dong
wifi.h     (kütüphane dosyası)
#define    ECN_OPEN          0      //Che do bao mat
#define    ECN_WEP           1
#define    ECN_WAP_PSK       2
#define    ECN_WAP2_PSK      3
#define    ECN_WAP_WAP2_PSK  4
#define    TYPE_TCP     1            //Che do ket noi
#define    TYPE_UDP     0
#define    TRAN_OPEN    1         //Che do truyen nhan
#define    TRAN_CLOSE   0
#define    MODE_STA     "AT+CWMODE=1"         //Che do wifi
#define    MODE_AP      "AT+CWMODE=2"
#define    MODE_AT_STA  "AT+CWMODE=3"
#define WIFI_TX_BUFFER_SIZE 128      //Bo dem
#define WIFI_RX_BUFFER_SIZE 128
//COMMAND
#define AT_ECHO_ON                  "ATE1"
#define AT_ECHO_OFF                 "ATE0"
#define AT_RESET                    "AT+RST"
#define AT_CFW                      "AT+GMR"
#define AT_WIFI_MODE                "AT+CWMODE"
#define AT_JOIN_AP                  "AT+CWJAP"
#define AT_GET_IP                   "AT+CIFSR"
#define AT_LIST_AP                  "AT+CWLAP"
#define AT_QUIT_AP                  "AT+CWQAP"
#define AT_SET_AP_PARAMS            "AT+CWSAP"
#define AT_CHECK_JOIN_AP            "AT+CWQAP"
#define AT_GET_CON_STATUS           "AT+CIPSTATUS"
#define AT_START_CON                "AT+CIPSTART"
#define AT_CIP_MODE                 "AT+CIPMODE"
#define AT_SEND                     "AT+CIPSEND"
#define AT_CLOSE_CON                "AT+CIPCLOSE"
#define AT_SET_MUL_CON              "AT+CIPMUX=1"
#define AT_SET_SERVER               "AT+CIPSERVER"
#define AT_SET_SERVER_TIMEOUT       "AT+CIPSTO"
#define AT_RECEIVED_DATA            "+IPD"
UTXD (TX) - modülü sinyal bacaklar mikro pimleri RX bağlı
URXD (RX)  - modülü sinyal bacaklar mikro pimleri RX bağlı
RST - modülün sert sıfırlama pimleri. Reset oluştuğunda sinyali düşük
GPIO0, GPIO2, CH_PD yüksek düzeyde bağlı.
VCC : 3.3V bağlanın
GND: 0V bağlayın
Biz 115200 baud hızında RS232 haberleşme yoluyla AT komutları kullanmak modülü iletişim kurmak için.
AT komut ESP8266 kümesi Bkz AT komutu ESP8266
//COMMAND
En sık kullanılan komutlar:
Adımlar ve notlar
+ RST AT modülü yeniden, bazı garip alınan veri, ve "hazır"
+ CWMODe = 3 AT çalışma modunu değiştirmek için 3, AP + STA, sadece (+ RST Le yapabilirsiniz Khi bu yapılır AT.) 3 En çok yönlü modunu kullanın
Router Katıl
+ CWLAP AT arama mevcut wifi nokta
+ AT CWJAP = "parola" "SSID" benim yönlendirici cıva nokta katılmak (ops, wifi şifre burada  :))
+ CWJAP AT =? başarıyla bağlı olmadığını kontrol edin, veya + CWJAP AT kullanmak?
TCP Client
+ CIPMUX = 1 AT birden bağlantıda dönüş
+ CIPSTART = 4 AT, "TCP", "192,168.1.104" 9999 uzak bir TCP sunucu 192.168.1.104 (PC) bağlanmak
+ CIPMODE = 1 AT tüy Into'yu veri iletim moduna girmek
+ = 4.5 CIPSEND AT kanal 4, 5 bayt uzunluğunda yoluyla veri göndermek bağlantılar Be hiçbir veri geçmesi Bulgular ki "bağlantısını kaldırmak" Will, (sadece alınan "seçmek", soket test sonucunda aşağıya bakınız)
TCP Server
+ CIPSERVER AT = 1,9999 port 9999 kurulum TCP sunucu, 1 kümeleme olanak demektir
+ CIFSR AT IP adresi kontrol modülü
Bu örnekte, istemci modunda çalışan modül esp8266 için ayarları openweathermap.org bağlanmak için json dize daha sonra hakkında bilgi almak için bu json dize analizi yapacak iade almak için HTTP GET gerçekleştirmek Sıcaklık, nem, hava basıncı.
Bağlantı olsun veriler: http://api.openweathermap.org/data/2.5/weather?id=1581130
1581130 Hanoi-Vietnam kimliği
YANDAKİ SİTEDEN ALINTIDIR.  "http://laptrinhpic.info/esp8266-wifi-module-hien-thi-thong-tin-thoi-tiet-len-lcd-esp8266-weather-display/"
Recep METE
yukarıdaki kodlarda hata var yeniden yayınlamak ihtiyacı doğdu
Code  Pic18f4550:
#DEVICE ADC=8
#define ledv  PIN_C2
#define ledr  PIN_C1
#include <lcd.c>
#include"esp/wifi.c"
#include"sonbui/mystr.c"
void get_internet()
char *write = ">"
int1 OK = False;
delay_ms(1000);
DO
clear_mem();
n++;
if (n > 150) n = 0;
IF(pch) {
OK = TRUE;
break;
delay_ms(100);
WHILE(!OK);
//Send http get
clear_mem();
Long LONG timeout;
timeout = 0;
delay_us(10);
do {
n++;
if (n > 512) n = 0;
if(p1)
if(p2)
size_t len = p2-p1;
jmain[len] = '\0'
double d_nhiet_do;
free(res) ;
if(nhiet_do)
free(res) ;
if(ap_suat)
free(res) ;
if(do_am_khi)
lcd_gotoxy(10,1) ;
free(jmain) ;
delay_ms(1000);
void main()
lcd_init ();
delay_ms(1000);
esp_init();
delay_ms(1000);
delay_ms(1000);
delay_ms(1000);
get_ip();
clear_mem();
//!   usb_cdc_init();
//!   usb_init();
//!   usb_task();
while (TRUE)
get_internet();
delay_ms(500);
Wifi.c:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <wifi.h
int16 n = 0;
INT1 timeout_error;
char data_out[50];
      break;
   n = 0;
      break;
   n = 0;
char timed_getc() {
   IF(kbhit(WIFI_ESP))
   ELSE
      RETURN(0);
   clear_mem();
      n++;
      if (n > 150) n = 0;
   return wifi_buff;
   int1 OK = False;
   char *oks = "OK";
   DO
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         break;
      delay_ms(100);
   WHILE(!OK);
void esp_init() {
   int1 OK = False;
   char *oks = "OK";
do { //ATE0
      clear_mem();
   delay_ms(2000);
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
      delay_ms(100);
   WHILE(!OK);
   do { //AT+CWMODE=3
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
      } else {
         IF(no_change) {
            OK = TRUE;
      delay_ms(100);
   WHILE(!OK);
   int1 OK = False;
   char *oks = "OK";
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         break;
      delay_ms(100);
   int1 OK = False;
   char *oks = "OK";
      clear_mem();
      Long LONG timeout;
      timeout = 0;
         delay_us(10);
            lcd_gotoxy(10, 2);
            if (pos == 0)
            if (pos == 1)
            if (pos == 2)
            if (pos == 3)
         n++;
         if (n > 150) n = 0;
         if (timeout_error)
         break;
      IF(pch) {
         OK = TRUE;
         break;
      ELSE
      delay_ms(100);
void quit_AP() {
   //AT+CWQAP
   int1 OK = False;
   char *oks = "OK";
   DO
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         break;
      delay_ms(100);
   WHILE(!OK);
void get_ip()
   //AT+CIFSR
   int1 OK = False;
   char *oks = "OK";
   DO
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         break;
      delay_ms(100);
   WHILE(!OK);
   int1 OK = False;
   char *oks = "OK";
   DO
      IF(pch) {
         OK = TRUE;
         break;
      delay_ms(100);
   WHILE(!OK);
      clear_mem();
      Long LONG timeout;
      timeout = 0;
         delay_us(10);
            lcd_gotoxy(11, 2);
            if (pos == 0)
            if (pos == 1)
            if (pos == 2)
            if (pos == 3)
         n++;
         if (n > 150) n = 0;
         if (timeout_error)
         break;
      IF(pch) {
         OK = TRUE
         break;
      ELSE
         IF(link) {
            OK = TRUE;
            break;
         OK = FALSE;
      delay_ms(100);
     return OK;
   int1 OK = False;
   char *oks = "OK";
   DO
      IF(pch) {
         OK = TRUE;
         break;
         IF(pch) {
            OK = TRUE;
            break;
      delay_ms(100);
   WHILE(!OK);
      clear_mem();
      Long LONG timeout;
      timeout = 0;
         delay_us(10);
            lcd_gotoxy(11, 2);
            if (pos == 0)
            if (pos == 1)
            if (pos == 2)
            if (pos == 3)
         n++;
         if (n > 150) n = 0;
         if (timeout_error)
         break;
      IF(pch) {
         OK = TRUE;
         break;
      ELSE
      delay_ms(100);
   // AT+CIPCLOSE=<id>
   int1 OK = False;
   char *oks="OK";
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         break;
      ELSE
         IF(link) {
            OK = TRUE;
            break;
   int1 OK = False;
   char *write = ">";
      clear_mem();
         n++;
         if (n > 150) n = 0;
      IF(pch) {
         OK = TRUE;
         //Gui noi dung
         IF(sent) {
            OK = TRUE;
            break;
         OK = FALSE;
      delay_ms(100);
Wifi.h:
#define    ECN_WEP           1
#define    TYPE_UDP     0
//COMMAND
115200 baud hızında RS232 haberleşme yoluyla AT komutları kullanarak modülle iletişim kurmak için:
//COMMAND
[imghttp://laptrinhpic.info/wp-content/uploads/2014/10/esp8266_pinout-300x124.png]http://[/img]
http://youtu.be/FD3tVrwhxxw
Gökhan BEKEN
#32
@Recep METE  nın dediği gibi bağlantı yaptığım halde modül cevap vermiyor. GPIO0 pinini boşta bırakıp çalıştırırsam seri porttan karışık bir şekilde sürekli veri geliyor.
Güncelleme yaptığım için baudrate 115200'de. Ne olur ne olmaz diye 9600'de de denedim yine cevap yok.
Cihaz AT komutlarıma cevap vermiyor (cr+lf eklediğim halde)
Ürünü burdan sipariş etmiştim: http://www.dx.com/p/esp8266-wi-fi-wireless-serial-port-data-transceiver-module-blue-black-369015#.VOZVxC5Jf20
Eksik birşey mi yapıyorum acaba?
mesaj birleştirme:: 20 Şubat 2015, 02:33:04
Tekrar güncelleyim dedim, güncelleme bitince, güncelleme programını kapatıp terminalden baktım, sürekli bu veriler geliyor:
mesaj birleştirme:: 20 Şubat 2015, 02:48:02
Tekrar güncelledim, 115200'de cevap vermedi ama 9600'de aşağıdaki görüntüyü alıyorum. GPIO 0 pini boşta olursa bu dediğim oluyor, vcc'de yine cevap yok.
Gökhan BEKEN
Güncel...
Sorunum hakkında bilgisi olan var mı?
Cemre.
Alıntı yapılan: Gökhan BEKEN - 21 Şubat 2015, 22:25:47
Güncel...
Hocam tümünü okuyacak zamanım olmadı ancak ben de benzer bir problemle karşılaştım ve nodemcu-firmware diye bir güncelleme yaptım. AT komutları kullanmak yerine Lua dilinde yazıyorsunuz kodunuzu ve modüle gömüyorsunuz. Enerjilendirdiğinizde o yapması gerekeni yapıyor. Bir araştırın derim. Ben de tam olarak çözebilmiş değilim ancak daha anlaşılır ve işlevsel olduğunu söyleyebilirim. Belki bu şekilde çözebilirsiniz sorunu.
esp8266.com'da LUA-Firmware forumundan bulabilirsiniz gerekli bilgiyi. Ayrıca http://benlo.com/esp8266/
Gökhan BEKEN
Teşekkür ederim, şurda: http://taylorcoffelt.com/article/1
terminalden güncellemeyi de anlatmışlar, yaptım ama güncelleme bitince yine sürekli veriler geliyor.
Bendeki modülden şüpheleniyorum bir de direnc.net'tekinden alıp denemeyi düşünüyorum.
Cemre.
#36
Hocam hangi sürüme güncelliyorsunuz?
Benim güncelleme yaptığım program ve güncellemede sorun çıkartmayan fw.ler bunlar.
0.9.5 şuan en güncel sanırım,
0.9.2.2
AT+GMR
0018000902
OK
Sonucunu  veriyor, nodemcu olan ise lua-firmware diye bahsedilen güncelleme.
Güncellemeyi de programı açıp gönderdiğim dosyadaki resimde görüldüğü gibi yapabilirsiniz. Sağdaki sekme önemli 0x00000 olması gerekiyor. Diğer tüm sekmeler kapalı olacak. Bunu yaptıktan sonra birinci sekmeden comport seçip flash diyeceksiniz. Tabi ki bunları yaparken gpio0 pini GND'ye bağlı olacak. Onun dışında herhangi bir bağlantı yapmadım. Sorunsuz çalışıyor bende.
Ek olarak, 9.2.2 sürümde MAC sorgulama amaçlı komutlarına ERROR dönüyor, onun dışında openweathermap'den veri çekmeyi sorunsuz yaptı vsvs.
9.5.0'da MAC sorgulamada sıkıntı yok ancak o da openweathermap'de sıkıntı çıkardı. İletişim için @FxDev hocamın yazdığı programı kullandım sade ve hızlı olduğunu düşündüğüm için. En azından test aşamasında bayağı işe yarıyor.
Ona da buradan teşekkürler.
http://www.dosya.tc/server39/JDSaQs/esp8266guncelleme.rar.html
Gökhan BEKEN
Hocam teşekkür ederim ama o program da işe yaramadı. Modülün bozuk olduğuna kanaat getirdim.
Bu arada modülü aldığımda versiyonu 0.9.2.4 idi. Sonra çince güncelleştirme programı ile dosya göstermeden tekrar güncelleme yaptığımda AT+GMR gönderdiğimde "0018000902" cevabını dönderiyordu.
Çince program ile dosya göstererek güncelleştirme yaptığımda sürekli saçma veriler dönderiyordu.
Ancak sizin program ile güncelleştir yaptığımda, sürekli veri döndermiyor ama AT komutlarıma da cevap vermiyor.
Cemre.
Hocam bağlantılarınızı doğru yapıyorsunuz değil mi?
VCC ve CH_PD 3.3V'a bağlı olacak, GND GND'ye, diğerlerini boş bırakabilirsiniz veya GPIO0'ı 3.3V'a bağlayabilirsiniz, bunun dışında hiç bir bağlantı yapmadan CH_PD pinini sürekli çıkarıp takma işlemi uygulayınca önce saçma sapan veriler geliyor daha sonra bir anda modül reset atmışsınız gibi cevap döndürüyor. Bu tarz birşeyler yapıp modüle bir kez ulaşınca geri kalan tüm işlemler sorunsuz oluyor. Eğer modülü enerjilendirirken reset veya ch_pd pini gnd'de değilse bir daha böyle birşeye ihtiyacınız kalmıyor. Ancak bu dediğim tüm modüller için geçerli mi bilemiyorum veya kim bununla uğraşmak ister onu da bilemiyorum  :D
volkanunal
Merhabalar esp8266 stm32f429 kitim ile basit bir web server yapmaya çalışıyorum  , kit üzerinden at komutlarına cevap alabiliyorum , ağa bağlı ve ip almış durumda , at komutlarını stm üzerinden gönderiyorum , anca html komutlarını göndererek ip üzerinden erişim sağlayamadım  , site bağlanmayı reddetti diyor , ve error döndürüyor.Daha önce deneyen var mıdır acaba?
MT
Hocam öncelikle bunun için temel ayarları yaptıktan sonra AT+CIPMUX= Multiple olarak ayarlanacak daha sonra uygun ip port değeri ile browser üzerinden bağlandığınızda gelen sorguya cevap AT+CIPSEND=ID( kaçıncı sekmeden sorgu var ise ID yerine o yazılır) cevap olarak gönderilir kısa bir süre beklenir hemen cevap verdiğimde error vermişti bende ve HTML komutları gönderilir. Kısa bir süre derken max süre aşımını AT+CIPSTO=2000 ms olarak ayarlamak  yeterli 500ms-1000ms gibi beklemeden sonra html kodunu gönderdiğimde bir sorun yaşamadım.   Umarım sorunuzu doğru anlayıp cevaplamışımdır.
volkanunal
hocam cipmux , cwmode ayarları yapılı zaten , elinizde örnek mevcut mu acaba ?
volkanunal
daha önce arduino üzerinde çalıştırabildim zaten
volkanunal
bir süre çalıştı , daha sonra tekrar gitti , espnin stabil çalışmadığına tanık oldum daha önce ama bu şekilde değildi
seyityildirim
Merhaba arkadaşlar,
Öncelikle çok faydalı bir konu olmuş. Emeği geçenlere teşekkürler... Benim sorum şu;
Örnek olması açısından https://learn.adafruit.com/diy-boost-calc/the-calculator bu sitedeki gibi kullanıcıdan değer bekleniyor.
Esp8266 kullanarak bu sitede bulunan kutucuklara değer girebilir miyim ? Konudaki ilk örnekte picproje sitesine bağlanılıyor. Ama daha sonra nasıl hareket ediliyor bir bilgim yok. Mesela bu modül ile picproje de konu açıp bu soruyu sorabilir miyim?
