st32f407VG
Başlatan selvi, 12 Şubat 2015, 14:10:37
selvi
   derleyicinin kendi projelerinden led isimli projedeki kodlari alip yeni bir proje olusturarak derleyince asagidaki gibi hata veriyor.
Build target 'Target 1'
assembling startup_stm32f40_41xxx.s...
compiling main.c...
main.c(17): error:  #5: cannot open source input file "LED.h": No such file or directory
  #include "LED.h"
main.c: 0 warnings, 1 error
".\Objects\den3.axf" - 1 Error(s), 0 Warning(s).
Target not created.
kod:
#include "STM32F4xx.h"
#include "LED.h"
const unsigned long led_mask[] = {1UL << 12, 1UL << 13, 1UL << 14, 1UL << 15};
  initialize LED Pins
void LED_Init (void) {
  RCC->AHB1ENR  |= ((1UL <<  3) );         /* Enable GPIOD clock                */
  GPIOD->MODER    &= ~((3UL << 2*12) |
                       (3UL << 2*13) |
                       (3UL << 2*14) |
                       (3UL << 2*15)  );   /* PD.12..15 is output               */
  GPIOD->MODER    |=  ((1UL << 2*12) |
                       (1UL << 2*13) |
                       (1UL << 2*14) |
                       (1UL << 2*15)  );
  GPIOD->OTYPER   &= ~((1UL <<   12) |
                       (1UL <<   13) |
                       (1UL <<   14) |
                       (1UL <<   15)  );   /* PD.12..15 is output Push-Pull     */
  GPIOD->OSPEEDR  &= ~((3UL << 2*12) |
                       (3UL << 2*13) |
                       (3UL << 2*14) |
                       (3UL << 2*15)  );   /* PD.12..15 is 50MHz Fast Speed     */
  GPIOD->OSPEEDR  |=  ((2UL << 2*12) |
                       (2UL << 2*13) |
                       (2UL << 2*14) |
                       (2UL << 2*15)  );
  GPIOD->PUPDR    &= ~((3UL << 2*12) |
                       (3UL << 2*13) |
                       (3UL << 2*14) |
                       (3UL << 2*15)  );   /* PD.12..15 is Pull up              */
  GPIOD->PUPDR    |=  ((1UL << 2*12) |
                       (1UL << 2*13) |
                       (1UL << 2*14) |
                       (1UL << 2*15)  );
  Function that turns on requested LED
void LED_On (unsigned int num) {
  if (num < LED_NUM) {
    GPIOD->BSRRL = led_mask[num];
  Function that turns off requested LED
void LED_Off (unsigned int num) {
    GPIOD->BSRRH = led_mask[num];
  Function that outputs value to LEDs
void LED_Out(unsigned int value) {
  int i;
  for (i = 0; i < LED_NUM; i++) {
    if (value & (1<<i)) {
      LED_On (i);
    } else {
      LED_Off(i);
Yaşam anlamlandırıldıkça kutsaldır....
atomx
Led.h dosyasi ayni klasorde olduguna emin olun ve include directory listesine header klasorunu ekleyin.
Hüseyin TECER
selvi
Alıntı yapılan: atomx - 12 Şubat 2015, 14:59:52
  derleyicinin kendi ornek projesini   "open proje" de actigimda derliyor.yani hata vermiyor.LED.h   dosyasini ekledim su sekilde hata verdi.
kod:
compiling main.c...
main.c(91): warning:  #1-D: last line of file ends without a newline
main.c: 1 warning, 0 errors
linking...
.\Objects\den4.axf: Error: L6218E: Undefined symbol SystemInit (referred from startup_stm32f40_41xxx.o).
.\Objects\den4.axf: Error: L6218E: Undefined symbol main (referred from __rtentry2.o).
Not enough information to list image symbols.
Finished: 1 information, 0 warning and 2 error messages.
".\Objects\den4.axf" - 2 Error(s), 1 Warning(s).
Target not created.
atomx
Keil kullaniyorsaniz eger c++ built symbol lerine USE_STDPERIPH_DRIVER komutunu eklemeyi deneyiniz eger stdlibrary projeye tam eklendiyse sorun olmamasu lazim pc basinda olabilsem resim atma imkanim olurdu kusura bakmayin
Hüseyin TECER
