stm32f te can haberleşme problemi?
Başlatan koray692, 12 Mart 2015, 07:58:19
koray692
merhaba arkadaşlar normal modda iki stm kartını haberleştirmeye çalışıyorum kod aşşağıda ancak debug yaptığımda RxMessage.Data
  • ya 0x58 yerleşiyor ve sonra hiç değişmiyor...derleyici olarak keil kullanıyorum. (mcp2551 kullandım)
    #include "stm32f4xx.h"
    #include <stm32f4xx_rcc.h>
    #include <stm32f4xx_can.h>
    #include <stm32f4xx_gpio.h>
    #define CAN_GPIO_PORT GPIOD
    #define CAN_RX_SOURCE GPIO_PinSource0 //PD0
    #define CAN_TX_SOURCE GPIO_PinSource1 //PD1
    #define CAN_AF_PORT GPIO_AF_CAN1
    #define CANx CAN1
    void CanBusInit(void);
    CanTxMsg TxMessage;
    CanRxMsg RxMessage;
    int main()
       int i=0;
       CanBusInit();
       TxMessage.StdId=0x321;
       TxMessage.ExtId=0x01;
       TxMessage.IDE=CAN_ID_STD;
       TxMessage.RTR=CAN_RTR_DATA;
       TxMessage.DLC=1;
       TxMessage.Data
  • =0;
      CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
       CAN_Transmit(CANx,&TxMessage);
       CAN_Receive(CANx,CAN_FIFO0,&RxMessage);
    //   RxMessage.StdId=;
    //   RxMessage.ExtId=;
    //   RxMessage.IDE=;
    //   RxMessage.RTR=;
    //   RxMessage.DLC=;
    //   RxMessage.Data=;
    //   RxMessage.FMI=;
       while(1)
          for(i=0;i<5000000;i++);
          TxMessage.Data
  • =RxMessage.Data[0]+1;
          if(RxMessage.Data[0]>5)
             GPIO_WriteBit(GPIOD,GPIO_Pin_12|GPIO_Pin_13, Bit_SET);
        CAN_InitTypeDef CAN_InitStructure;
        CAN_FilterInitTypeDef CANFilter_InitStructure;
        /* Enable GPIO clock */
       RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
       /* CAN configuration ********************************************************/
       /* Enable CAN clock */
       RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
       /* Connect CAN pins to AF9 */
       GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_RX_SOURCE, CAN_AF_PORT);
       GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_TX_SOURCE, CAN_AF_PORT);
       /* Configure CAN RX and TX pins */
       GPIO_InitStructure.GPIO_Pin = CAN_RX_SOURCE | CAN_TX_SOURCE;
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
       GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
       GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
       GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
       GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure);
       /* CAN register init */
       CAN_DeInit(CANx);
       /* CAN cell init */
       CAN_InitStructure.CAN_TTCM = DISABLE; // time-triggered communication mode = DISABLED
       CAN_InitStructure.CAN_ABOM = DISABLE; // automatic bus-off management mode = DISABLED
       CAN_InitStructure.CAN_AWUM = DISABLE; // automatic wake-up mode = DISABLED
       CAN_InitStructure.CAN_NART = ENABLE; // non-automatic retransmission mode = ENABLE (To prevent endless spam)
       CAN_InitStructure.CAN_RFLM = DISABLE; // receive FIFO locked mode = DISABLED
       CAN_InitStructure.CAN_TXFP = DISABLE; // transmit FIFO priority = DISABLED
       CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
       CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
       /* CAN Baudrate */
       CAN_InitStructure.CAN_BS1 = CAN_BS1_14tq;
       CAN_InitStructure.CAN_BS2 = CAN_BS2_6tq;
       CAN_InitStructure.CAN_Prescaler = 4;
       CAN_Init(CANx, &CAN_InitStructure);
         CANFilter_InitStructure.CAN_FilterActivation = ENABLE;
          CANFilter_InitStructure.CAN_FilterNumber = 14;
          CANFilter_InitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
          CANFilter_InitStructure.CAN_FilterScale = CAN_FilterScale_16bit;
          CANFilter_InitStructure.CAN_FilterIdHigh = 0x00;
          CANFilter_InitStructure.CAN_FilterIdLow = 0x00;
          CANFilter_InitStructure.CAN_FilterMaskIdHigh = 0x00;
          CANFilter_InitStructure.CAN_FilterMaskIdLow = 0x00;
          CANFilter_InitStructure.CAN_FilterFIFOAssignment = CAN_Filter_FIFO0;
          CAN_FilterInit(&CANFilter_InitStructure);
    void Led_Init(){
         GPIO_InitTypeDef gpioStructure;
        gpioStructure.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13;
        gpioStructure.GPIO_Mode = GPIO_Mode_OUT;
        gpioStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOD, &gpioStructure);
        GPIO_WriteBit(GPIOD,GPIO_Pin_12|GPIO_Pin_13, Bit_RESET);
