aşağıdaki kod ile internet varmı diye kontrol ediyorum. Fakat bilgisayarın network donanımının bağlı olup olmadığını kontrol ediyor. Oysaki Kablolu bağlı iken gateway vermezsem veya DNS vermezsem yada yanlış IP verirsem gene internet varmış gibi görüp işlem yapınca hata alıyorum. Bu durumda AKTİF ve KULLANILABİLEN bir internetin olup olmadığını nasıl tespit edebilirim ?
function Internetvarmi: Boolean;
const
INTERNET_CONNECTION_MODEM = 1; // local system uses a modem to connect to the Internet.
INTERNET_CONNECTION_LAN = 2; // local system uses a local area network to connect to the Internet.
INTERNET_CONNECTION_PROXY = 4; // local system uses a proxy server to connect to the Internet.
INTERNET_CONNECTION_MODEM_BUSY = 8; // local system's modem is busy with a non-Internet connection.
var
dwConnectionTypes: DWORD;
begin
dwConnectionTypes :=
INTERNET_CONNECTION_MODEM +
INTERNET_CONNECTION_LAN +
INTERNET_CONNECTION_PROXY;
Result := InternetGetConnectedState(@dwConnectionTypes, 0);
end;
uses Ping;
const ADP_IP = '77.223.128.170';
begin
If Ping.Ping(ADP_IP) then
ShowMessage('internet var');
end;
unit Ping;
interface
uses
Windows, SysUtils, Classes;
type
TSunB = packed record
s_b1, s_b2, s_b3, s_b4: byte;
end;
TSunW = packed record
s_w1, s_w2: word;
end;
PIPAddr = ^TIPAddr;
TIPAddr = record
case integer of
0: (S_un_b: TSunB);
1: (S_un_w: TSunW);
2: (S_addr: longword);
end;
IPAddr = TIPAddr;
function IcmpCreateFile : THandle; stdcall; external 'icmp.dll';
function IcmpCloseHandle (icmpHandle : THandle) : boolean;
function IcmpSendEcho
(IcmpHandle : THandle; DestinationAddress : IPAddr;
RequestData : Pointer; RequestSize : Smallint;
RequestOptions : pointer;
ReplyBuffer : Pointer;
ReplySize : DWORD;
Timeout : DWORD) : DWORD; stdcall; external 'icmp.dll';
function Ping(InetAddress : string) : boolean;
implementation
uses
WinSock;
function Fetch(var AInput: string;
const ADelim: string = ' ';
const ADelete: Boolean = true)
: string;
var
iPos: Integer;
begin
if ADelim = #0 then begin
// AnsiPos does not work with #0
iPos := Pos(ADelim, AInput);
end else begin
end;
if iPos = 0 then begin
Result := AInput;
if ADelete then begin
AInput := '';
end;
end else begin
result := Copy(AInput, 1, iPos - 1);
Delete(AInput, 1, iPos + Length(ADelim) - 1);
end;
end;
end;
procedure TranslateStringToTInAddr(AIP: string; var AInAddr);
var
phe: PHostEnt;
pac: PChar;
GInitData: TWSAData;
begin
WSAStartup($101, GInitData);
try
phe := GetHostByName(PChar(AIP));
if Assigned(phe) then
begin
pac := phe^.h_addr_list^;
if Assigned(pac) then
begin
with TIPAddr(AInAddr).S_un_b do begin
s_b1 := Byte(pac[0]);
s_b2 := Byte(pac[1]);
s_b3 := Byte(pac[2]);
s_b4 := Byte(pac[3]);
end;
end
begin
raise Exception.Create('Error getting IP from HostName');
end;
end
begin
raise Exception.Create('Error getting HostName');
end;
except
FillChar(AInAddr, SizeOf(AInAddr), #0);
end;
WSACleanup;
end;
var
Handle : THandle;
InAddr : IPAddr;
DW : DWORD;
rep : array[1..128] of byte;
begin
result := false;
Handle := IcmpCreateFile;
if Handle = INVALID_HANDLE_VALUE then
Exit;
TranslateStringToTInAddr(InetAddress, InAddr);
DW := IcmpSendEcho(Handle, InAddr, nil, 0, nil, @rep, 128, 0);
Result := (DW 0);
IcmpCloseHandle(Handle);
end;
end.
@t2 hocam teşekkürler..
Sorunu aştım. Aşağıdaki fonksiyon ile gideceği URL yi check ediyorum. Eğer true dönerse işlem yapıyorum. IP değiştirdim,gateway,dns vermediğim zaman false dönüyor. tam istediğim gibi.
function CheckUrl(url:string):boolean;
var
hSession, hfile, hRequest: hInternet;
dwindex,dwcodelen :dword;
dwcode:array[1..20] of char;
res : pchar;
begin
if pos('http://',lowercase(url))=0 then
url := 'http://'+url;
Result := false;
hSession := InternetOpen('InetURL:/1.0',
INTERNET_OPEN_TYPE_PRECONFIG,nil, nil, 0);
if assigned(hsession) then
begin
hfile := InternetOpenUrl(
hsession,
pchar(url),
nil,
0,
INTERNET_FLAG_RELOAD,
0);
dwIndex := 0;
dwCodeLen := 10;
HttpQueryInfo(hfile, HTTP_QUERY_STATUS_CODE,
@dwcode, dwcodeLen, dwIndex);
res := pchar(@dwcode);
result:= (res ='200') or (res ='302');
if assigned(hfile) then
InternetCloseHandle(hfile);
InternetCloseHandle(hsession);
end;
Merhaba sercan bende bunu kullanyorum.
site olarak www.google.com (http://www.google.com) seçtim ama bazı bilgisayarlarda çalışmaya biliyor çözüm için fonksiyondaki bölümü aşağıdaki gibi değiştir.
if pos('https://',lowercase(url))=0 then
url := 'https://'+url;
kolay gelsin
