Sony nin yeni chipi TransferJet™ LSI "CXD3271GW" 4.48GHz de 350Mbps veri transferi yapabiliyor
Operating frequency | | 4.48GHz | Chip rate | | 560Mcps | Modulation | | Direct sequence spread spectrum | Connection | | 1 to 1 | Transmission rate | | Capable of selecting the appropriate transmission rate | Receiving sensitivity | | -82dBm*3 when receiving Rate65 (Standard value -71dBm) -70dBm*3 when receiving Rate522 (Standard value -59dBm) | Power consumption | | 265mW*3 for continuous reception, 118mW*3 for continuous transmission, 263μW*3 for intermittent reception | Other features | | Embedded RF balun, RF switch for transmitter/receiver, LDO, OTP-ROM Multi-reference clock Error correction encoder and decoder LNA and VCO/PLL General port output (LED control, etc.) Power management function | Host I/F | | SDIO UHS-I | Package | | WFLGA 96pin 6.0mm x 6.0mm x 0.72mm(Max) |
http://www.sony.net/SonyInfo/News/Press/201202/12-027E/index.html (http://www.sony.net/SonyInfo/News/Press/201202/12-027E/index.html)
Bununla güzel wireless modemler ve telsizler yapılabilir gibi görünüyor. Bu konuda çalışanların dikkatine :) |
