Microchip tarafından imal edilen..
170 μA, 2 MHz Zero-Drift Op Amps
Başlığıyla lanse ettiği Çip.
Features
• High DC Precision:
-VOS Drift: ±150 nV/°C (maximum)
-VOS: ±25 μV (maximum)
-AOL: 111 dB (minimum, VDD = 5.5V)
-PSRR: 110 dB (minimum, VDD = 5.5V)
-CMRR: 112 dB (minimum, VDD = 5.5V)
-Eni: 0.45 μVP-P (typical), f = 0.1 Hz to 10 Hz
-Eni: 0.15 μVP-P (typical), f = 0.01 Hz to 1 Hz
• Enhanced EMI Protection:
- Electromagnetic Interference Rejection Ratio (EMIRR) at 1.8 GHz: 96 dB
• Low Power and Supply Voltages:
-IQ: 170 μA/amplifier (typical)
- Wide Supply Voltage Range: 2V to 5.5V
• Small Packages:
- Singles in SC70, SOT-23
- Duals in MSOP-8, 2x3 TDFN
- Quads in TSSOP-14
•Easy to Use:
- Rail-to-Rail Input/Output
- Gain Bandwidth Product: 2 MHz (typical)
- Unity Gain Stable
• Extended Temperature Range:
-40°C to +125°C
Typical Applications
• Portable Instrumentation
• Sensor Conditioning
• Temperature Measurement
• DC Offset Correction
• Medical Instrumentation
(https://i.ibb.co/hMfs3g6/resim.png) (https://ibb.co/1n6ZF0g)
MCP6V76-Family-Data-Sheet-DS20006323B.pdf (http://ww1.microchip.com/downloads/en/DeviceDoc/MCP6V76-Family-Data-Sheet-DS20006323B.pdf)
beş-on seneye ideal opampı satmaya başlayacaklar :)
