LC Hesapları
Başlatan Kahraman34, 04 Şubat 2016, 14:31:19
Kahraman34
Arkadaşlar inverter çıkışına vede buck konverter çıkışına, koymak üzere L vede C elemanlarının hesaplamalarını yapmaya çalışıyorum.
Birçok hesap buldum ama doğrusunu eğrisini tespit edemedim. 220 volt ve 25 ila 50 amper arası için 10 khz pwm ve üstü için bu hesapları yapmam lazım bu konuda türkçe kaynağa veya bilen bir arkadaşa ihtiyacım var. Yardımcı olursanız sevinirim, teşekkürler.
Kahraman34
http://www.irf.com/technical-info/appnotes/an-1095.pdf
Resimdeki şema için aşağıdaki hesaplamaları yapmışlar.
Output Filter Design Example
Let's be Ipk,max = 5A and Vdc = 300V.
Parasitic capacitors C8 and C9 be such that dV/dt ( without filter ) is 10V/nsec.  (BUNU NASIL BULDUN)
This is too much for the motor, we need a dV/dt lower than 5V/nsec. (BUNA NASIL KARAR VERDİN)
By Eq. [1]. choose C1 = 1nF ( 5A / 5V/nsec ) (DV DT İŞİNİ ZATEN ANLAMADIM HANGİ VOLTAJI HANGİ ZAMANA BÖLDÜK SONUÇ NASIL NANO FARAT OLDU)
BU KISMA KADAR DAHA ÇÖZEMEDİĞİM İÇİN GERİSİNİ GETİREMİYORUM.
According to Eq. [6], Ton,min can be as low as 200nsec ; at 20kHz, this represents 0.4%
of duty cycle which is far below the practical limits used.
From Eq.[5], it follows L2 = 4uH.
Zc results to be 63 Ohm, hence R2 >= 63 Ohm.
Let now suppose Irecovery = 5A. Di is, according to Eq [4], will be <= 2.4A.
Therefore, O/C protection will be set above 12.5Apk.
Rms current into R2 is 0.175A, which gives a power dissipation of about 2W.
Actually, by choosing R2 exactly equal to Zc generates some overshoot; for that reason
R2 should be slightly higher. A R2 value between Zc and 2 x Zc is suggested.
Figure 2 and 3 show the voltage across the inverter's leg ( before the filter ) and across
the motor ( after the filter ) for a R2 value = Zc and 2x Zc.
Even if the overshoot is well within the limits of motor's insulations and capacitor's
voltage ratings, increasing R2 gives benefits without increasing much power dissipation.
But, do not increase R2 too much otherwise dV/dt will not be anymore limited by C1!
Kahraman34
Arkadaşlar yanlış veya doğru yoldamıyım nerdeyim bari bir yorum yapın, boşamı kürek, veya bildiğiniz bak şuraya dediğiniz bir döküman ?
Kahraman34
