Aşağıdaki maddeler bir Frequency inverterinin operating instructions bilgi kitapçığından alınan bazı maddelerdir. Maddelerde bahsedilen toroidal çekirdek seçimi neye göre yapılmalıdır? Bu çekirdek iç piyasada nereden satın alınabilir?
5.1 EMC-compatible installation
When correctly installed (see below), the device corresponds to the following standards:
• EN 12015 Electromagnetic compatibility - Product family standard for lifts, escalators and moving
walks - Emission
• EN 12016 Product family standard for lifts, escalators and moving walks - Immunity
The following points must be observed if the above mentioned standards are to be adhered to:
• Integrate power choke and radio interference filter into the mains line
• Use only shielded cables for motor and brake chopper or brake resister connections.
• Max. motor line length is 25m
• Wind unshielded cables of brake resistors type BR09-1 and BR11-A around the toroidal core
provided (see figure)
• Feed the motor cables at output U/V/W of the frequency converter through the toroidal core
• If you must interrupt the shielding on a cable (e.g., to install a motor contactor), the shielding must
be subsequently continued with the lowest possible HF impedance.
• Use only shielded control cables
• The shielding of control cables (inputs and outputs, rotary encoder cable, etc.) must be connected
to earth potential on the inverter side
• Use shielded lines in the switching cabinet also
• Do not twist shielding for connections; use a suitable shield connection system (e.g. Shield-Kon®)
• Run the control cables and the encoder cables separate from the power cables
• Flawless electrical contact must exist between the grounded mounting plate and the metal housing
of the frequency inverter
• Provide connected inductances (brakes, motor contactors) with suppressors
(https://i.ibb.co/s6wTvTG/ferit-ekirdek.jpg) (https://ibb.co/s6wTvTG)
pratikde ısı olarak size geri dönecektir . milyon euro luk makinelerin nüzerindeki inverterlerde var kullanım amacını bilmiyorum kabloyu eritecek kadar ısı üretiyor.
Alıntı yapılan: a.zorba - 22 Mart 2022, 10:59:55pratikde ısı olarak size geri dönecektir . milyon euro luk makinelerin nüzerindeki inverterlerde var kullanım amacını bilmiyorum kabloyu eritecek kadar ısı üretiyor.
inverterin neresine bagli bu nuveler.
inverter çıkışı motor girişi .
Laptop adaptorlerinin kablosuna yuzuk gibi gecirilen nuveler gibi EMI etkisini azaltmak icindir.
Eger sarimlar tek tursa yada kablolar icinden gecip gidiyorsa cok da kritik bir sey olmamali.
Cihazi yapip degisik nuveler denenerek analizer cihazla kririk frekanslarda zayiflama oluyormu diye bakmak lazim.
motor girisinde neden emi filtresine ihtiyac olsunki, sok bobini niyetine olmasin.
Motora giden kablolarda pwm voltaj darbeleri var. Kablolardan akan akim ister yuksek olsun ister dusuk EMI yayiliMI yapar. Cunku kablo uzun. Ustelik motor akimlari dusuk frekanslidir uzerinde yuksek frekansli ripil barindirir.
Sok bobini olabilmesi icin kesim frekansi atiyorum 10Hz 100Hz araliginda olmali. Akimin da yuksek oldugu dusunulurse bu durumda sok bobinlerinin bayagi bir iri olmasi gerek.
Bu nedenle bu bobinler sok bobini amacli degil EMI amaclidir.
Bu çekirdeği kullanmadığımız da inverter yakınındaki tüm elektronik cihazlar sapıtıyor. Yapmaması gereken şeyler yapıyor. Eproma saçma veriler kaydediyor. Dokunmatik ekranlar kendi kendine karekterler giriyor. Asansörlerde ise motor dairesine en yakın olan yani invertere en yakın olan en üst kata geldiginde yanlış kayıtlar alip gitmemesi gereken cagrilmadigi katlara geri gidiyor. Motor ve inverter olupta bu çekirdeğin kullanilmadigi her devrede bu gibi sorunlar yaşanıyor. Yani bu bir emi filtresi ve motor kabloları duruma göre bir kaç tur sarılarak içinden geçiriliyor.
Toroidin İç çap ,dış çap yükseklik değerlerini hassas ölçün
Toroide 100 tur tel sarın endüktansını ölçün.
Al değerinin nasıl hesaplandığı araştırın(Ferride toroide lerde 1000 tur sarılıp mHenry olarak hesaba katılır)
Yurtdışındaki büyük toroide imalatçılarının (ferroxcube vb) bu değerlere göre aramalar yaptırıyordu sanırım .(Yada hangi uygulamada olduğunu onlara izah edin direkt ürün tavsiye ederler)
Bulabildiğiniz bilglere göre türk firmalarından numune isteklerinde bulunun.
Rengi ,çapı Al değeri yaklaşık aynı olan toroidlerle aynı seviyede EMI filtreleme yapabiliyormu testlerini yapın
