Bulduğum CCS C max6675 kodu budur ve bunu c18e dönüştürmeye çalıştım ancak proteusda yaptığım denemelerde değerleri okuyamadım bir bakar mısınız ?
* max6675.c - communicates with a MAX6675 thermcouple interface chip *
* Copyright Jimbob's Ma 2006 *
* This program is free software; you can redistribute it and/or *
* modify it under the terms of the GNU General Public License *
* as published by the Free Software Foundation version 2 *
* of the License. *
* This program is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU General Public License for more details. *
* You should have received a copy of the GNU General Public License *
* along with this program; if not, write to the Free Software *
* Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA. *
This is a diver for the MAX6675 K-type thermocouple interface chip. It implements an SPI
bus without the need for dedicated hardware (aka a bit-banged interface). The result from
toFloat_TC() is the temperature in degrees celcius of the thermocouple tip. The rest should
be self-evident. Have a look at the end of the file for example usage.
#ifndef TC_CLK
#define TC_CLK PIN_B1 //edit these pins as necessary
#endif
#ifndef TC_CS
#define TC_CS PIN_B2
#endif
#ifndef TC_DATA
#define TC_DATA PIN_B3
#endif
int1 thermocouple_error; //a handy dandy global error flag to tell you if a thermocouple is connected or not
void init_TC(void)
output_low(TC_CLK);
output_low(TC_DATA);
output_high(TC_CS); //if we idle high, the chip keeps doing conversions. Change this if you like
int16 read_TC(void) //It takes 200ms (ish) for the MAX6675 to perform a conversion
int8 i;
int16 data;
output_low(TC_CS); //stop any conversion processes
delay_us(1); //and give it some time to power up (not very much, admittedly)
for (i=0;i<16;i++){
shift_left(&data,2,input(TC_DATA)); //reads in 2 bytes to data from the pin TC_DATA
output_high(TC_CLK);
output_low(TC_CLK);
thermocouple_error=bit_test(data,2); //this is the thermocouple status bit
output_high(TC_CS);
return(data);
int16 sortout(int16 raw)
return(0x0FFF & (raw>>3)); //returns only the bits converning temperature
float toFloat_TC(int16 tmp)
return((float)tmp/4.0); //adjusts data to floating point format, and accounts for the decimal point
float do_everything(void)
init_TC();
delay_ms(200); //200ms is a long time to be doing nothing. use a timer interrupt to avoid wasting time here
return(toFloat_TC(sortout(read_TC())));
//example program
#define TC_CLK PIN_B2
#define TC_DATA PIN_B1
#include "max6675.c"
void main()
char msg[32];
delay_ms(50); //allow oscillator to stabilise
while(1){
delay_ms(800);
sprintf(msg,"%01.2f%cC\r\n",do_everything(),0xB0);
if(thermocouple_error)
printf("Thermocouple not connected\r\n");
printf("%s",msg);
C18'e çevirdiğim kod. Tamamını çevirmedim bu kısmı çevirip denedim sadece
init_TC(void)
TC_CLK = 0;
TC_DATA = 0;
TC_CS = 1;
int sortout(int raw)
int read_TC(void) //It takes 200ms (ish) for the MAX6675 to perform a conversion
int i;
int data;
TC_CS=0;
Delay10KTCYx(1);
for (i=0;i<16;i++){
// shift_left(&data,2,input(TC_DATA)); //reads in 2 bytes to data from the pin TC_DATA
//data |=(TC_DATA<<2);
data|=(TC_DATA<<2);
TC_CLK=1;
TC_CLK=0;
//thermocouple_error=bit_test(data,2); //this is the thermocouple status
TC_CS=1;
return(data);
Cold Junction K Tipi Kullanmayı düşünüyoruz. Sanırım dayanıklılık olarak daha iyiymiş ve oksitlenmesi azmış diye okudum.
tamam sağol bir de şunu sorayım bu sıcaklığı sabit tutma olayına PID diyorlarmış sanıyorum. Bu işlem için sıcaklığı array gibi bir yede tutup ortalamasını alıp ona göre ayar mı yapacağız
tamam dediğim gibi diziye atıp ortalamasına bakar ona göre iş yaparım
Bunu c18e çevirirken sıkıntı olur mu ? Benim kodda sorun ne bakabildin mi ?
tamam deneyeyim bakalım :) sağol
