C++ Builder ile bir USB Portuna takili Device'ye nasil erisilir derken söyle bir kod buldum.
Bu kod USB'ye baglanmis bir Termometre devresini okumak ve bu Devredeki bir Led lambayi kontrol etmek icin yazilmis anladigim kadaryila.
cy7c63001.cpp
#include <vcl.h>
#pragma hdrstop
#include "cy7c63001.h"
#pragma package(smart_init)
#pragma resource "*.dfm"
TForm1 *Form1;
__fastcall TForm1::TForm1(TComponent* Owner)
: TForm(Owner)
// Handle ermitteln
hTreiber = CreateFile( "\\\\.\\Thermometer_0",
GENERIC_WRITE,
FILE_SHARE_WRITE,
NULL,
OPEN_EXISTING,
0,
0 );
// Zeiger Ãnitialisieren
pIn = &szIn[0];
pOut = &szOut[0];
lpByte = &lByte;
// Anzeige setzen
Label1->Caption = "---°C";
// Fensterposition setzen
Form1->Top = 100;
Form1->Left = 100;
void __fastcall TForm1::FormDestroy(TObject *Sender)
CloseHandle( hTreiber );
void __fastcall TForm1::Timer1Timer(TObject *Sender)
Timer1->Enabled = false;
LeseTemp();
LeseS1();
Timer1->Enabled = true;
// Temperatur auslesen
void TForm1::LeseTemp( void )
int nTemp;
AnsiString sTemp;
// 0x04 = Control-Code; Funktionsnummer
// szOut[0] = Status; [1] = Temperatur; [2] = Vorzeichen; [3] = Schalter
szIn[0] = 0x0b;
DeviceIoControl( hTreiber, 0x04, pIn, sizeof(szIn), pOut,
sizeof(szOut), lpByte, NULL );
// Temperatur ermitteln
nTemp = szOut[1]/2;
// Ausgabe zusammensetzen
if ( szOut[2] == 0 ) sTemp += "+";
else sTemp += "-";
sTemp += nTemp;
sTemp += "°C";
Label1->Caption = sTemp;
// Helligkeit der LED D2 einstellen
void __fastcall TForm1::TrackBar1Change(TObject *Sender)
// Setze LED Helligkeit
szIn[0] = 0x0e;
szIn[1] = (char)TrackBar1->Position;
// Lese Port 1 lesen uns S1 auskodieren
void TForm1::LeseS1( void )
szIn[0] = 0x14; // Lese Port
szIn[1] = 0x1; // Port 1 auslesen
// Schalter 1 offen
if ( (szOut[1] & 0x04) == 0x4 )
Shape1->Brush->Color = clAqua;
Label3->Caption = "S1 offen";
// Schalter 1 geschlossen
Shape1->Brush->Color = clBtnFace;
Label3->Caption = "S1 geschlossen";
cy7c63001.h
#ifndef cy7c63001H
#define cy7c63001H
#include <Classes.hpp>
#include <Controls.hpp>
#include <StdCtrls.hpp>
#include <Forms.hpp>
#include <Buttons.hpp>
#include <ExtCtrls.hpp>
#include <ComCtrls.hpp>
class TForm1 : public TForm
__published: // Von der IDE verwaltete Komponenten
TTimer *Timer1;
TBitBtn *BitBtn1;
TTrackBar *TrackBar1;
TPanel *Panel1;
TLabel *Label1;
TLabel *Label2;
TShape *Shape1;
TLabel *Label3;
void __fastcall FormDestroy(TObject *Sender);
void __fastcall Timer1Timer(TObject *Sender);
void __fastcall TrackBar1Change(TObject *Sender);
private: // Anwenderdeklarationen
public: // Anwenderdeklarationen
HANDLE hTreiber;
char szIn[4]; // 4 * 8 Bit ; = long int
char * pIn;
char szOut[4]; // 4 * 8 Bit ; = long int
char *pOut;
unsigned long int lByte;
unsigned long int* lpByte;
void LeseTemp( void );
void LeseS1( void );
__fastcall TForm1(TComponent* Owner);
extern PACKAGE TForm1 *Form1;
#endif
Simdi Kodun su bölümünde
GENERIC_WRITE,
FILE_SHARE_WRITE,
NULL,
OPEN_EXISTING,
0,
0 );
"\\\\.\\Thermometer_0", ---> Bu nedir?
nerden bulup bunu yazmislar? Bu acaba USB'ye bagl Aletin Driverin adresi falanmi?
Ikinci konu USB'ye bagli Device'nin Outpointlerin adreselerine okuma ve yazma icin nasil ulasiliyor?
Bu adresleri nerden biliyorlar?
Simdi ben bu Kodlari elimdeki Memory Stick üzerindeki led lambasina nasil uyarlayabilirim?Bu Memory Stick'i PC taniyor ve üzerindeki Led lamba Bilgi Okuma ve Memory Stick'e yazma aninda yanip sönüyor.Simdi yukardaki Kodu ben bu Memory Stick'in PC'deki Driverine göre ayalayip Led lambayi high -low yapmak istiyorum bunu yapabilirmiyim?
Bana bunlari aciklayabilecek bir Arkadas varmi?
selamün aleyküm
Bu konuda bir bilgim yok fakat lambanın usb porttan kontrol edildiğini sanmıyorum en azından generic olarak yani eğer sana lambanın kontrolüne ait bir registere ulaşmana kontrol çipi izin verirse ulaşırsın ama bunu her memory stick ile yapabilirmisin bu konuda şüphelerim var benim kanaatim emin değilim ama veri alış verişi olduğunda bu lamba usb ile flash chipleri arasındaki trafiği yöneten chip tarafından yakılıyor olabilir mesela benim flash belleğim bekleme anında hiç bir veri transferi yok iken 1.5 saniye onn 1.5 saniye off oluyor ama başka bir bellekte bu olmuyor o sebepten koddan önce gerekirse belleğini açıp kontrolcüsünü öğren datasheet'e bak ondan sonra işe başla derim.
Şunuda ekleyeyim bu adamlar sanırım bu chipi baz almışlar
kodda kullanılan chipin pdf i (http://www.alldatasheet.com/datasheet-pdf/pdf/CYPRESS/CY7C63001.html) seninde o işi yapabilmen için her halde bu chip gibi h dosyasına ihtiyacın var en baştaki CY7C63001.h
zaten o fonksiyonların bazılarını sağlıyordur kanaatindeyim.
zaten datashettinde onun şöyle bir entegre olduğunu yazıyorLow-cost solution for low-speed USB peripherals such as mouse, joystick, and gamepad
Kisaca ben USB 'ye bagli bir Deviceye yukardaki Kodlarla nasil ulasabilirim onu ögrenmek istedim.
Memory Stick üzerindeki Lamba önemli değil.Bunu PIC18F4550 ile yapmis oldugum bir Devre olarak görürsek ben yukardaki Kodu kendi devreme nasil uyarlayip USB üzerinden bu devremi Kontrol edebilirim?
Yani yukardaki kodda
GENERIC_WRITE,
FILE_SHARE_WRITE,
NULL,
OPEN_EXISTING,
0,
0 );
"\\\\.\\Thermometer_0", ---> Bu nedir? Bu kismi kendi olusturdugum bir devre icin nasil uyarlamaliyim?
Yada söyle anlatayim Ben 18f4550 ile su asagidaki devreyi kurdum diyelim.
(http://www.sixca.com/eng/img/FS_USB.JPG)
Bu Devreye PC tarafi icin ben C++ Builder ile Program yazip , Yukardaki Devredeki LED lambalari yakip söndürmek istiyorum.
C++ Builder ile program yazacagim bu program USB'de Bagli devreye veri göndercek , PIC18F45550 gelen veriye göre islem yapacak.
Iste yukardaki Kodu degistirerek bunu yapmam mümkünmü?
yada bu isi yapabilecegim Kod veya yapilmis bir proje örnegi varmi?
Insallah anlatabilmisimdir.
Ögrenmek istedigim USB'ye PC tarafindan C++ ile veri göndermek.
Selam
Bildiğim kadarıyla
\\\\.\\com10
yazınca com10 u dosya gibi açıyor.
Zaten bu C ve php gibi ortamlarda herşey dosya değilmidir :)
m_hCommPort = CreateFile(m_strPort,GENERIC_READ | GENERIC_WRITE,
0, NULL, OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL | FILE_FLAG_OVERLAPPED |
FILE_FLAG_NO_BUFFERING,NULL);
if (m_hCommPort == INVALID_HANDLE_VALUE) return FALSE;
Bu tarz birşey ile erişebilirsin sanırım (okuma ve yazma)
yada
m_hPort = CreateFile (\\\\.\\com10,
0,
NULL,
OPEN_EXISTING,
0,
NULL);
com10 ise kendi tanımladığın, driverın yönettiği usb portu
USB üzerinden tanittigim bir Alete PC com1,com2 veya com3 gibi isimler atamiyorki?
Ben örnegin USB Protundan tanittigim bir Printerin hangi Com port oldugunu nerden bilecegim?
Serial Portta ok oluyor ama USB'de nasil bilmiyorum.
Sizin verdiğiniz program USB ye direkt erişmiyor ki.
Erişmek için arada driver kullanıyor (FT232 vs..)
Bu işler için Human Interface Devices (HID) diye bir olay var.
http://www.lvr.com/hidpage.htm
http://www.intel.com/intelpress/usb/examples/ZipFiles/DUSBVC.htm
http://www.alanmacek.com/usb/
#include "usb.h"
#include <setupapi.h>
#include <hidsdi.h>
HANDLE connectToIthUSBHIDDevice (DWORD deviceIndex)
GUID hidGUID;
HDEVINFO hardwareDeviceInfoSet;
SP_DEVICE_INTERFACE_DATA deviceInterfaceData;
PSP_INTERFACE_DEVICE_DETAIL_DATA deviceDetail;
ULONG requiredSize;
HANDLE deviceHandle = INVALID_HANDLE_VALUE;
DWORD result;
//Get the HID GUID value - used as mask to get list of devices
HidD_GetHidGuid (&hidGUID);
//Get a list of devices matching the criteria (hid interface, present)
hardwareDeviceInfoSet = SetupDiGetClassDevs (&hidGUID,
NULL, // Define no enumerator (global)
NULL, // Define no
(DIGCF_PRESENT | // Only Devices present
DIGCF_DEVICEINTERFACE)); // Function class devices.
deviceInterfaceData.cbSize = sizeof(SP_DEVICE_INTERFACE_DATA);
//Go through the list and get the interface data
result = SetupDiEnumDeviceInterfaces (hardwareDeviceInfoSet,
NULL, //infoData,
&hidGUID, //interfaceClassGuid,
deviceIndex,
&deviceInterfaceData);
/* Failed to get a device - possibly the index is larger than the number of devices */
if (result == FALSE)
SetupDiDestroyDeviceInfoList (hardwareDeviceInfoSet);
return INVALID_HANDLE_VALUE;
//Get the details with null values to get the required size of the buffer
SetupDiGetDeviceInterfaceDetail (hardwareDeviceInfoSet,
&deviceInterfaceData,
NULL, //interfaceDetail,
0, //interfaceDetailSize,
&requiredSize,
0); //infoData))
//Allocate the buffer
deviceDetail = (PSP_INTERFACE_DEVICE_DETAIL_DATA)malloc(requiredSize);
deviceDetail->cbSize = sizeof(SP_INTERFACE_DEVICE_DETAIL_DATA);
//Fill the buffer with the device details
if (!SetupDiGetDeviceInterfaceDetail (hardwareDeviceInfoSet,
deviceDetail,
requiredSize,
&requiredSize,
NULL))
free (deviceDetail);
//Open file on the device
deviceHandle = CreateFile (deviceDetail->DevicePath,
GENERIC_READ,
FILE_SHARE_READ | FILE_SHARE_WRITE,
NULL, // no SECURITY_ATTRIBUTES structure
OPEN_EXISTING, // No special create flags
0,
NULL); // No template file
return deviceHandle;
HANDLE connectToUSBHIDDevice (DWORD *vendorID, DWORD *productID, DWORD *versionNumber)
DWORD index = 0;
HIDD_ATTRIBUTES deviceAttributes;
BOOL matched = FALSE;
while (!matched && (deviceHandle = connectToIthUSBHIDDevice (index)) != INVALID_HANDLE_VALUE)
if (!HidD_GetAttributes (deviceHandle, &deviceAttributes))
if ((vendorID == 0 || deviceAttributes.VendorID == *vendorID) &&
(productID == 0 || deviceAttributes.ProductID == *productID) &&
(versionNumber == 0 || deviceAttributes.VersionNumber == *versionNumber))
return deviceHandle; /* matched */
CloseHandle (deviceHandle); /* not a match - close and try again */
index++;
http://www.alanmacek.com/usb/usb.c
Dostum bu bukadar nasil zor olur ya.Anlamiyorum.
Alt tarafi PIC18F4550 ile yaptigim bir devreyi USB'ye baglayim ona PC ortamindan komut göndermek.Bu iside C++ Builder ile yazmak.Bu Serial Port ortaminda gayet basitti.Neden USB ile bukadar zor?
Bu neden bu kadar zor ki?
C bu hocam, daha kolay bir yolu varsada ben bilmiyorum.
Belki CreateFile ile USB yi de comport gibi açabiliyordur. Ondan emin değilim. Cihazlarla haberleşmek için genelde HID kullanılır.
Su linkte eleman cok güzel örnekler yapmis.
Hepsini USB üzerinden uyarlamis ama kullandigi Programlarin source kodlarini vermemis.
Bu tahminimce bir Yugoslav .Türkce böyle bu isi anlatan bir site yokmu bildiginiz .Türkce kaynaklar cok az her konuda.
http://milan.milanovic.org/skola/parport/usbport-00.htm
Selam,
Kodu biraz açıklayayım ondan sonra belki bir ışık yanabilir :)
Alıntı yapılan: "Digimensch""\\\\.\\Thermometer_0", ---> Bu nedir?
Bu arkadaş Cypress'in cy7c63001 psoc'u ile yapmış devresini. Sürücüsü kendisini tanıtırken de Thermometer_0 olarak sisteme kaydolmuş. Bağlantı noktaları kısmında Thermometer_0 şeklinde bir "bağlantı noktası" oluşturulmuş. Daha sonra bunu arkadaş güzelce createfile fonksiyonu ile açmış filehandle almış. Arkasından htreiber pointeri üzerinden DeviceIoControl prosedürü ile okumuş.
DeviceIoControl çağırılmadan önce SizeIn ile komut yönlendiriliyor SizeOut ile veri alınıyor.
Senin devrende ise yine CreateFile ile bir file stream açılıp; bu stream'e writefile()/readfile() fonksiyonları ile erişilip, yazılıp okunması gerekiyor.
Eğer istersen sen de DeviceIoControl ile erişmen mümkün. Mesela portu açıp bir bilgi gönderirsin. 18F4550'de gelen bilgiyi alır mukayese eder uygunsa istediğin ledi yakar/söndürür.
Analyzer
O arkadaş VB kullanmış, C++ değil.
Alıntı YapBiblioteka IO.DLL
Za rad pod WindowXP i Windows2000 operativnom sistemu neophodno je da preuzmete ovu biblioteku i da je iskopirate u folder \Windows\System32.
io.dll kütüphane dosyasını \Windows\System32 dizinine kopyalıyor ve VB programı ile verileri ona gönderiyor.
Ve dikkat ederseniz HID kullanıyor.
Evet dostum VB kullanmis biliyorum ama ben Türkce olarak ne C++ ,ne VB nede Delphi ile anlatilmis bir kaynak bulamadim onu ifade etmeye calistim.
Ayrica bu konu acildikca aciliyor .
Peki simdi bu bahsettigin HID ne?
HID bir pc arabirimi.. Human Interface Devices..
Microsoft , intel ve birkaç büyük firmanın kurduğu usb.org sitesi tarafından standartlaştırılan. Pcde ( özellikle windows 2000 ve xpde sorunsuz ) bir driver gerektirmeden ( aslında driver gerektirmeyen değilde zaten OS da standart bulunması düşünülmüş ) çalışabilen bir arabirim..
İlk aşamada klavye , mouse ve oyun konsolları için düşünülmüş ama yakın zamanda elektronik geliştiricileri tarafından saygıyla karşılanmış bir araç.
İyi Çalışmalar..
http://www.jungo.com/embedded_usb_hid.html
http://www.lvr.com/hidpage.htm (multilanguage örnekler)
http://www.usb.org/developers/devclass_docs/HID1_11.pdf *
sağol(http://img151.imageshack.us/img151/9500/dilimdilim2ge7ak5.jpg) (http://imageshack.us) un arkadaslar bu konuyu biraz arastirayim.
saygilar
Arkadaşım, piyasadaki bircok dil senin bu istediklerine cevap veremez... versede sinirli kalir, ister cpp ister delphi olsun bu dedigin islemleri yapmak icin ya component kullanirsin yada bu isleri Assembler gibi bir makine diline en yakin dillerden birini kullanarak cozersin, sana tavsiyem Assembler, kesinlikle sinir tanimaz istedigin donanimin adresine veri gonderir istediginden de okursun; fakat burda bir kucuk nokta var kullandigin adreslere dikkat etmelisin, SIK SIK sistem cokmeleri yasayacagindan eminim, bu zamana kadar donanimla ilgili ne isim olduysa ben bu dille hallettim. ...bu arada sana C builderdan vazgec diyen yok Assembler kodlarini onun icine gomersin olur biter.
Gonderi zamaninin farkindayim ama olurya belki isine yarar. Saglicakla kal
VB de USB çalışmak için örnek kodu çok aramış ama bulamamıştım ve vazgeçmiştim.
Geçenlerde bir API örneği ile karşılaştım, PC ye biryerlere kaydettim, henüz denemedim. Bulunca buraya yüklerim.
Edit;
http://moty22.free.fr/moty22/index.php
burda şu link var belki işe yarar
http://www.lvr.com/files/usbhidio_vc6.zip
birde bunu buldum
http://www.waitingforfriday.com/index.php/Open_Source_Visual_C%2B%2B_Class_for_USB_Generic_HID_Communication
Alıntı yapılan: Karahan - 14 Temmuz 2010, 15:36:04
Adamlar yetersiz dediğin c++ ile işletim sistemi ve oyun yazıyorlar daha ne yapsın uzaya mı çıksın
Alıntı yapılan: orhanc - 14 Temmuz 2010, 23:03:27
Hocam şu verdiğiniz linkler 2002 den beri forumda onlarca yerde bir çok kişi tarafından verildi, siz de başka konuda aynı linkleri vermişsiniz, bu konuda ben 2 defa aynı linki 2006 da yazmışım...
Forumda sürekli tekrarlanıp boşuna yer kaplayan, dejavu yaşatan çok mesaj olduğunu düşünüyorum.
Alıntı yapılan: orhanc - 14 Temmuz 2010, 23:09:41
Doğru söylüyorsun adamlar işletim sistemi yazıyor ancak dikkat ederseniz donanım erişimi için ille de komponent kullanmaniz gerekiyor yada dll dosyasi, adamların kodları kapalı istediğin kadar kendini kas;kısaca bu "USB" ye win üzerinden erişeceksen yolu budur,işin aslı usb den okuyup yazmak için tek gereken erişim adresleri... "asm" ile git şu adresi oku git şu adrese yaz...ne yazık ki biz bu adresleri bilmiyoruz,asıl problem de budur...
Eger PC ye taktiginiz usb cihazi PC comport olarak goruyorsa sorun yok.
CreateFile(ComName, GENERIC_READ or GENERIC_WRITE, 0, nil, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, 0); gibi bir satirla dosya aciyorsunuz.
Com port ayarlarini yaptiktan sonra dosya icine yazabiliyor yada okuyabiliyorsunuz.
Soruma gelirsek;
Eger PC ye takilan usb hid cihaz PC tarafindan comport olarak gorulmuyorsa bununla haberlesmek icin createfile benzeri bir windows komutu varmi?
Mesela mouse, klavye, usb paralel port vs...
CreateFile komutuna windows komutu diyorum ama bu komut tam olarak kime aittir. Standart bir dll icindeki komutmudur?
