Arkadaşlar merhaba aşağıda lcd port pinleri P0.4-P0.5-P0.6-P0.7 ne yaparsam yapayım portları kaydıramadım gözden kaçırdığım nokta neresi.
#define LCD_D4 0x10 //P0.04
#define LCD_D5 0x20 //P0.05
#define LCD_D6 0x40 //P0.06
#define LCD_D7 0x80 //P0.07
Örnek : LCD_D4 = 0x10 (hex)----> 00010000 ---- LPC2104 'nın P0.4
Kodun Tamamı
#include "lcd.h"
#include "lpc210x.h"
void lcd_wait(){
int loop=2800; //more than enough
//busy loop
while(loop--);
void lcd_out_data4(unsigned char val){
IOCLR |= (LCD_DATA);
IOSET |= (val<<4);
void lcd_write_nibbles(unsigned char val){
//higher-order byte
lcd_en_set();
lcd_out_data4((val>>4)&0x0F);
lcd_en_clr();
lcd_wait();
//lower-order byte
lcd_en_set();
lcd_out_data4((val)&0x0F);
lcd_en_clr();
lcd_wait();
Mehmet Ekledi.. Lcd_gotoxy
* Go to the specified position
void
lcd_goto(unsigned char pos)
lcd_rs_clr();
lcd_write_nibbles(0x80+pos);
//************* Eklenen Fonksiyon ***********
void lcd_write_control(unsigned char val){
lcd_rs_clr();
lcd_write_nibbles(val);
void lcd_init(){
PINSEL0 &= (~LCD_GPIO_SEL0);
PINSEL1 &= (~LCD_GPIO_SEL1);
/* we only work on OUTPUT so far */
IODIR |= LCD_IOALL;
/* IO init complete, init LCD */
/* init 4-bit ops*/
lcd_rs_clr();
lcd_rw_clr();
lcd_en_clr();
//wait VDD raise > 4.5V
lcd_wait();
//dummy inst
lcd_write_nibbles(0x30);
//FUNCTION SET
//001DL N F XX
//DL=1: 8bit
//DL=0: 4bit
//N=0: 1 line display
//N=1: 2 line display
//F=0: 5x7 dots
//F=1: 5x10 dots
//our case:
//0010 1000
lcd_en_set();
lcd_out_data4(0x2);
lcd_en_clr();
lcd_wait();
lcd_write_nibbles(0x28);
//LCD ON
lcd_write_nibbles(0x0E);
//Clear Display
lcd_write_nibbles(0x01);
//Entry mode
lcd_write_nibbles(0x06);
void lcd_putchar(unsigned char c){
lcd_rs_set();
lcd_write_nibbles(c);
void lcd_print(unsigned char* str){
int i;
//limit 1 line display for prints
for (i=0;i<16 && str[i]!=0;i++){
lcd_putchar(str[i]);
// Copyright (c) 2004 senz at arm.dreamislife.com
// THIS FILE IS PROVIDED AS IS WITH NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
/* LCD routines for OLIMEX LPC-MT-2106 */
/* 16x2 Character LCD 1602K */
/* 4-bit mode operation */
/* DEFINE IOMASK */
#define LCD_EN 0x400000 //P0.22
#define LCD_RS 0x800000 //P0.23
#define LCD_RW 0x1000000 //P0.24
#define LCD_DATA (LCD_D4|LCD_D5|LCD_D6|LCD_D7)
#define LCD_IOALL (LCD_D4|LCD_D5|LCD_D6|LCD_D7|LCD_EN|LCD_RS|LCD_RW)
#define LCD_GPIO_SEL0 0x0000FF00 //MASK for P0.04-P0.07
#define LCD_GPIO_SEL1 0x0003F000 //MASK for P0.22-P0.24
/* Functions Header */
/* internal I/O functions */
#define lcd_rs_set() IOSET |= LCD_RS
#define lcd_rs_clr() IOCLR |= LCD_RS
#define lcd_en_set() IOSET |= LCD_EN
#define lcd_en_clr() IOCLR |= LCD_EN
#define lcd_rw_set() IOSET |= LCD_RW
#define lcd_rw_clr() IOCLR |= LCD_RW
/* wait until lcd controller is free */
void lcd_wait(void);
void lcd_out_data4(unsigned char);
void lcd_write_nibbles(unsigned char);
void lcd_write_control(unsigned char);
/* initialize both the GPIO of lpc and LCD */
void lcd_init(void);
#define lcd_clear() lcd_write_control(0x01)
#define lcd_cursor_home() lcd_write_control(0x02)
#define lcd_display_on() lcd_write_control(0x0E)
#define lcd_display_off() lcd_write_control(0x08)
#define lcd_cursor_blink() lcd_write_control(0x0F)
#define lcd_cursor_on() lcd_write_control(0x0E)
#define lcd_cursor_off() lcd_write_control(0x0C)
#define lcd_cursor_left() lcd_write_control(0x10)
#define lcd_cursor_right() lcd_write_control(0x14)
#define lcd_display_sleft() lcd_write_control(0x18)
#define lcd_display_sright() lcd_write_control(0x1C)
/* put a character out to lcd */
void lcd_putchar(unsigned char);
/* print a string */
void lcd_print(unsigned char*);
/* Go to the specified position */
extern void lcd_goto(unsigned char pos);
#define S1_1 0x00
#define S1_2 0x01
#define S1_3 0x02
#define S1_4 0x03
#define S1_5 0x04
#define S1_6 0x05
#define S1_7 0x06
#define S1_8 0x07
#define S1_9 0x08
#define S1_10 0x09
#define S1_11 0x0A
#define S1_12 0x0B
#define S1_13 0x0C
#define S1_14 0x0D
#define S1_15 0x0E
#define S1_16 0x0F
#define S1_17 0x10
#define S1_18 0x11
#define S1_19 0x12
#define S1_20 0x13
#define S2_1 0x40
#define S2_2 0x41
#define S2_3 0x42
#define S2_4 0x43
#define S2_5 0x44
#define S2_6 0x45
#define S2_7 0x46
#define S2_8 0x47
#define S2_9 0x48
#define S2_10 0x49
#define S2_11 0x4A
#define S2_12 0x4B
#define S2_13 0x4C
#define S2_14 0x4D
#define S2_15 0x4E
#define S2_16 0x4F
#define S2_17 0x50
#define S2_18 0x51
#define S2_19 0x52
#define S2_20 0x53
#define S3_1 0x14
#define S3_2 0x15
#define S3_3 0x16
#define S3_4 0x17
#define S3_5 0x18
#define S3_6 0x19
#define S3_7 0x1A
#define S3_8 0x1B
#define S3_9 0x1C
#define S3_10 0x1D
#define S3_11 0x1E
#define S3_12 0x1F
#define S3_13 0x20
#define S3_14 0x21
#define S3_15 0x22
#define S3_16 0x23
#define S3_17 0x24
#define S3_18 0x25
#define S3_19 0x26
#define S3_20 0x27
#define S4_1 0x54
#define S4_2 0x55
#define S4_3 0x56
#define S4_4 0x57
#define S4_5 0x58
#define S4_6 0x59
#define S4_7 0x5A
#define S4_8 0x5B
#define S4_9 0x5C
#define S4_10 0x5D
#define S4_11 0x5E
#define S4_12 0x5F
#define S4_13 0x60
#define S4_14 0x61
#define S4_15 0x62
#define S4_16 0x63
#define S4_17 0x64
#define S4_18 0x65
#define S4_19 0x66
#define S4_20 0x67
Yukarıdaki 2 satırıda uygun şekilde değiştirdiniz mi? Birde bu dosyalar bu haliyle çalışıyor değil mi?
#define LCD_D4 0x10 //P0.04 #define LCD_D5 0x20 //P0.05 #define LCD_D6 0x40 //P0.06 #define LCD_D7 0x80 //P0.07
bu satırları mı değiştirdiniz sadece.
Evet iki satırıda değiştirdim.
