Windows API leri kullanarak HID yapisinda USB bir cihaz tasarlamaya calisiyorum.
Amacim olabildigince hizli bir sekilde her iki yonde de veri aktarimi.
Bu amacla USB kartin kendi yazilimini komplikelestirden yapabilecegim en yalin cihaz sinifi ne olabilir?
Secenekler cok. Ornegin Keyboard, mouse, trackball, joystick, font-panel controls, telephones, VCR remote controls,
games or simulation devices vs vs
Fakat sectigim cihaz tipinin isletim sistemine olumsuz etkisi de olmamali. Atiyorum, mouse gibi tasarlanmis bir cihaz PC ile veri aktarimi yaparken kursorun ordan oraya ziplamasi hos olmaz.
En yalın sınıf budur bunu kullanmalısın. Ben çok kullandım. hala da kullanıyorum
;Configuration Descriptor
___Config1
retlw (__Interface1-___Config1) / 2 ; bLength Length of this descriptor
retlw __DSC_CFG ; bDescType 2 = CONFIGURATION
__Config1Len
retlw low ((__EndConfig1 - ___Config1) / 2) ; Length of this configuration
retlw high ((__EndConfig1 - ___Config1) / 2)
retlw 0x01 ; bNumInterfaces Number of interfaces
retlw 0x01 ; bConfigValue Configuration Value
retlw 0x04 ; iConfig String Index for this config = #01
retlw 0xA0 ; bmAttributes attributes - bus powered
; Max power consumption (2X mA)
retlw 0x32
__Interface1
retlw (__HIDDescriptor1 - __Interface1) / 2 ; length of descriptor
retlw __DSC_INTF
retlw 0x00 ; number of interface, 0 based array
retlw 0x00 ; alternate setting
retlw 0x02 ; number of endpoints used in this interface
retlw 0x03 ; interface CLASS - assigned by the USB
retlw 0x00 ; boot device
retlw 0x00 ; interface protocol - mouse
retlw 0x00 ; index to string descriptor that describes this interface
__HIDDescriptor1
retlw (__Endpoint1In - __HIDDescriptor1) / 2 ; descriptor size (9 bytes)
retlw 0x21 ; descriptor type (HID)
dt 0x00, 0x00 ; HID CLASS release number (1.00) low byte, high byte
retlw 0x00 ; Localised country code (none)
retlw 0x01 ; Number of HID CLASS descriptor to follow (1)
retlw 0x22 ; Report descriptor type (HID)
__ReportDescriptor1Len
retlw low ((__EndReportDescriptor1 - __ReportDescriptor1) / 2)
retlw high ((__EndReportDescriptor1 - __ReportDescriptor1) / 2)
__Endpoint1In
retlw (__EndPoint1Out - __Endpoint1In) / 2 ; length of descriptor
retlw __DSC_EP
retlw 0x81 ; EP1, IN
retlw 0x03 ; Interrupt
dt 0x40, 0x00 ; This should be the size of the endpoint buffer low byte, high byte
retlw 0x01 ; Polling interval
__EndPoint1Out
retlw (__EndConfig1 - __EndPoint1Out) / 2 ; Length of this Endpoint Descriptor
retlw __DSC_EP ; bDescriptorType = 5 for Endpoint Descriptor
retlw 0x01 ; Endpoint number & direction
retlw 0x03 ; Transfer type supported by this Endpoint
__EndConfig1
__ReportDescriptor1
; vendor defined usage page
retlw 0x06
retlw 0x00
retlw 0xFF
retlw 0x09
retlw 0x00
; collection(application)
retlw 0xA1
retlw 0x01
; *** INPUT REPORT ***
retlw 0x09
retlw 0x01
retlw 0x15 ; logical minimum (-128)
retlw 0x80 ;
retlw 0x25 ; logical maximum (127)
retlw 0x7F ;
retlw 0x35 ; Physical Minimum (0)
retlw 0x00 ;
retlw 0x45 ; Physical Maximum (255)
retlw 0xFF ;
; report size in bits
retlw 0x75
retlw 0x08
; report count (number of fields)
retlw 0x95
retlw 0x40
; Input (Data, Variable, Absolute)
retlw 0x81
retlw 0x02
; *** OUTPUT REPORT ***
retlw 0x09 ; usage (Vendor Defined)
retlw 0x02 ;
retlw 0x80 ;
retlw 0x7F ;
retlw 0x00 ;
retlw 0xFF ;
retlw 0x75
retlw 0x08
retlw 0x95
retlw 0x40
; Output (Data, Variable, Absolute)
retlw 0x91
retlw 0x02
retlw 0xC0 ; end collection
Bu da olur. Genel amaçlı insan arabirim aygıtı olarak görünür. fare gibi bilindik bir aygıt sınıfı olması gerekmez.
/* Device Descriptor */
ROM USB_DEVICE_DESCRIPTOR device_dsc=
0x12, // Size of this descriptor in bytes
USB_DESCRIPTOR_DEVICE, // DEVICE descriptor type
0x0200, // USB Spec Release Number in BCD format
0x00, // Class Code
0x00, // Subclass code
0x00, // Protocol code
USB_EP0_BUFF_SIZE, // Max packet size for EP0, see usb_config.h
0x04D8, // Vendor ID
0x003F, // Product ID: Custom HID demo
0x0002, // Device release number in BCD format
0x01, // Manufacturer string index
0x02, // Product string index
0x00, // Device serial number string index
0x01 // Number of possible configurations
/* Configuration 1 Descriptor */
ROM BYTE configDescriptor1[]={
/* Configuration Descriptor */
0x09,//sizeof(USB_CFG_DSC), // Size of this descriptor in bytes
USB_DESCRIPTOR_CONFIGURATION, // CONFIGURATION descriptor type
0x29,0x00, // Total length of data for this cfg
1, // Number of interfaces in this cfg
1, // Index value of this configuration
0, // Configuration string index
_DEFAULT | _SELF, // Attributes, see usb_device.h
50, // Max power consumption (2X mA)
/* Interface Descriptor */
0x09,//sizeof(USB_INTF_DSC), // Size of this descriptor in bytes
USB_DESCRIPTOR_INTERFACE, // INTERFACE descriptor type
0, // Interface Number
0, // Alternate Setting Number
2, // Number of endpoints in this intf
HID_INTF, // Class code
0, // Subclass code
0, // Protocol code
0, // Interface string index
/* HID Class-Specific Descriptor */
0x09,//sizeof(USB_HID_DSC)+3, // Size of this descriptor in bytes
DSC_HID, // HID descriptor type
0x11,0x01, // HID Spec Release Number in BCD format (1.11)
0x00, // Country Code (0x00 for Not supported)
HID_NUM_OF_DSC, // Number of class descriptors, see usbcfg.h
DSC_RPT, // Report descriptor type
HID_RPT01_SIZE,0x00,//sizeof(hid_rpt01), // Size of the report descriptor
/* Endpoint Descriptor */
0x07,/*sizeof(USB_EP_DSC)*/
USB_DESCRIPTOR_ENDPOINT, //Endpoint Descriptor
HID_EP | _EP_IN, //EndpointAddress
_INTERRUPT, //Attributes
0x40,0x00, //size
0x01, //Interval
HID_EP | _EP_OUT, //EndpointAddress
0x40,0x00, //size
0x01 //Interval
//Language code string descriptor
ROM struct{BYTE bLength;BYTE bDscType;WORD string[1];}sd000={
sizeof(sd000),USB_DESCRIPTOR_STRING,{0x0409
//Class specific descriptor - HID
ROM struct{BYTE report[HID_RPT01_SIZE];}hid_rpt01={
0x06, 0x00, 0xFF, // Usage Page = 0xFF00 (Vendor Defined Page 1)
0x09, 0x01, // Usage (Vendor Usage 1)
0xA1, 0x01, // Collection (Application)
0x19, 0x01, // Usage Minimum
0x29, 0x40, // Usage Maximum //64 input usages total (0x01 to 0x40)
0x15, 0x01, // Logical Minimum (data bytes in the report may have minimum value = 0x00)
0x25, 0x40, // Logical Maximum (data bytes in the report may have maximum value = 0x00FF = unsigned 255)
0x75, 0x08, // Report Size: 8-bit field size
0x95, 0x40, // Report Count: Make sixty-four 8-bit fields (the next time the parser hits an "Input", "Output", or "Feature" item)
0x81, 0x00, // Input (Data, Array, Abs): Instantiates input packet fields based on the above report size, count, logical min/max, and usage.
0x29, 0x40, // Usage Maximum //64 output usages total (0x01 to 0x40)
0x91, 0x00, // Output (Data, Array, Abs): Instantiates output packet fields. Uses same report size and count as "Input" fields, since nothing new/different was specified to the parser since the "Input" item.
0xC0} // End Collection
Inceledigim kadariyla verdigin bu tablolarda bazi degerler header dosyadan geliyor ve adi sanirim usbcfg.h.
Bu dosyayi da ekleyebilirmisin?
Projeye ait tüm dosyalar burada:
http://www.speedyshare.com/files/26496261/USB_Device_-_HID_-_Simple_Custom_Demo_-_C18_-_PICDEM_FSUSB.rar
