93c46 seri eeproma 8 bit (org=vss)yazma ve okuma rutinleri lazım.yardımcı olabilirmisiniz teşekkürler.
http://www.microchip.com/download/appnote/eeproms/00613.pdf
http://www.microchip.com/10
10/suppdoc/appnote/product/memory/sereemwr/index.htm buralara bir
bak
http://www.microchip.com/download/appnote/eeproms/00698a.pdf
appnotlara bakmıstım zaten. 8bit acık kodları moduler buraya yazabilirmisiniz. teşekkürler
93c46 için kaynak kod
;=======93C46.
list p=16c84
radix
hex
; cpu equates (memory map)
status equ 0x03
porta equ 0x05
portb equ
0x06
cook equ 0x0c
hibyte equ 0x0d
count equ 0x0e
address equ 0x0f
data_hi equ 0x10
data_lo equ 0x11
temp equ 0x12
trisa equ
0x85
trisb equ 0x86
; bit equates
rp0 equ 5
org
0x000
start bsf status,rp0 ;switch to bank 1
movlw b'00000001' ;bit 0 = input
movwf trisa
movlw b'00000000'
;outputs
movwf trisb
bcf status,rp0 ;switch back to bank
0
bcf porta,1 ;initialize
bcf porta,2 ;initialize
bcf porta,3 ;initialize
movlw 0x00 ;00000000
movwf portb ;LEDs off
movlw 0x00 ;define
test address
movwf address
movlw 0x80 ;define test hi byte
movwf data_hi
movlw 0x0f ;define test lo byte
movwf data_lo
call write ;write
subroutine
call read ;read subroutine
movf cook,w ;get lo byte
movwf portb ;display via LEDs
circle goto circle
;done
ewen movlw 0x30 ;ewen op code
movwf cook ;to cook
bsf porta,1 ;send start
bit
bsf porta,2 ;shift
bcf porta,2
call sendbits ;send ewen op code
return
ewds movlw 0x00 ;ewds
op code
movwf cook ;to cook
bsf porta,1 ;send start bit
bsf porta,2 ;shift
bcf porta,2
call sendbits ;send ewds op
code
return
write bsf porta,3 ;cs high
call ewen ;erase/write enable
bcf porta,3 ;cs low
nop ;1
microsecond min
movf address,w ;get address
movwf cook ;store in cook
bcf cook,7 ;op code
bsf cook,6 ;ms 2
bits
bsf porta,2 ;shift
bcf porta,2
call sendbits ;send address
movf data_hi,w ;get data
hi
movwf cook
call sendbits ;send data hi
movf data_lo,w ;get data lo
movwf cook
call sendbits ;send data lo
bcf porta,3 ;cs
low
nop ;1 microsecond min
ecycle2 btfss porta,0 ;erase cycle complete?
goto ecycle2 ;not yet
bcf porta,3 ;cs
low
call ewds ;yes, erase/write disable
bcf porta,3 ;cs low
nop ;1 microsecond
min
return
read bsf porta,3 ;cs high
movwf cook
bsf cook,7 ;op
code
bcf cook,6 ;ms 2 bits
bsf porta,2 ;shift
bcf porta,2
call getprom ;shift hi 8 bits
out of eeprom
movf cook,w ;hi byte result in hibyte
movwf hibyte
call getprom ;shift lo 8 bits out of eeprom
bcf porta,3 ;cs low
nop ;1microsecond
min
return ;exit sub with lo byte in cook
sendbits
movlw 0x08 ;count=8
movwf count
sbit call sendbit ;send 1 bit
decfsz count,f ;done?
goto sftcook ;no
return ;yes
sftcook rlf cook,f ;shift
cook left
goto sbit ;again
sendbit bcf porta,1 ;default
btfsc cook,7 ;test cook bit 7
bsf porta,1 ;bit is
set
shift1 bsf porta,2 ;shift
bcf porta,2
return
getprom movlw 0x08 ;count=8
movwf count
shif
t2 bsf porta,2 ;shift
bcf porta,2
movf porta,w ;read port A
movwf temp ;store copy
rrf temp,f ;rotate bit into carry flag
rlf cook,f ;rotate carry flag
into cook
decfsz count,f ;decrement counter
goto shift2
return ;done
end
;at blast time, select:
; memory unprotected
; watchdog timer disabled (default is enabled)
; standard crystal
(using 4 MHz osc for test) XT
; power-up timer
on
erase bsf porta,3 ;c
s high
bcf porta,3 ;cs low
movf address,w ;get
address
bsf cook,7 ;op code
bsf cook,6 ;ms 2 bits
bit
bsf porta,2 ;shift
bcf porta,2
bcf porta,3 ;cs low
bsf porta,3 ;cs
high
ecycle1 btfss porta,0 ;erase cycle complete?
goto ecycle1 ;not yet
bcf porta,3 ;cs low
nop ;1microsecond min
disable
bcf porta,3 ;cs low
return
