CLK_DeInit();
CLK_HSECmd(DISABLE);
CLK_LSICmd(ENABLE);
CLK_HSICmd(ENABLE);
while(CLK_GetFlagStatus(CLK_FLAG_HSIRDY) == RESET);
CLK_ClockSwitchCmd(ENABLE);
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV2);
CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV4);
CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO, CLK_SOURCE_HSI,
DISABLE, CLK_CURRENTCLOCKSTATE_ENABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_SPI, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_I2C, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_ADC, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_AWU, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_UART1, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER1, ENABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER2, ENABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER4, DISABLE);
void TIM2_setup(void)
TIM2_DeInit();
TIM2_TimeBaseInit(TIM2_PRESCALER_512, 2);
TIM2_Cmd(ENABLE);
clock ve timer conf. burada 16Mhz işlemcim var.
/* INTERRUPT VECTOR TABLE FOR STM8 devices */
#include "stm8s_it.h"
#ifdef _COSMIC_
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
unsigned char interrupt_instruction;
interrupt_handler_t interrupt_handler;
@far [member=28622]interrupt[/member] void NonHandledInterrupt (void){
return;
extern void _stext(); /* startup routine */
struct interrupt_vector const _vectab[] = {
{0x82, (interrupt_handler_t)_stext}, /* reset */
{0x82, NonHandledInterrupt}, /* trap */
{0x82, NonHandledInterrupt}, /* irq0 */
{0x82, NonHandledInterrupt}, /* irq1 */
{0x82, NonHandledInterrupt}, /* irq2 */
{0x82, NonHandledInterrupt}, /* irq3 */
{0x82, NonHandledInterrupt}, /* irq4 */
{0x82, NonHandledInterrupt}, /* irq5 */
{0x82, NonHandledInterrupt}, /* irq6 */
{0x82, NonHandledInterrupt}, /* irq7 */
{0x82, NonHandledInterrupt}, /* irq8 */
{0x82, NonHandledInterrupt}, /* irq9 */
{0x82, NonHandledInterrupt}, /* irq10 */
{0x82, TIM1_UPD_OVF_TRG_BRK_IRQHandler}, /* irq11 */
{0x82, TIM1_CAP_COM_IRQHandler}, /* irq12 */
{0x82, TIM2_UPD_OVF_TRG_BRK_IRQHandler}, /* irq13 */
{0x82, NonHandledInterrupt}, /* irq14 */
{0x82, NonHandledInterrupt}, /* irq15 */
{0x82, NonHandledInterrupt}, /* irq16 */
{0x82, NonHandledInterrupt}, /* irq17 */
{0x82, NonHandledInterrupt}, /* irq18 */
{0x82, NonHandledInterrupt}, /* irq19 */
{0x82, NonHandledInterrupt}, /* irq20 */
{0x82, NonHandledInterrupt}, /* irq21 */
{0x82, NonHandledInterrupt}, /* irq22 */
{0x82, NonHandledInterrupt}, /* irq23 */
{0x82, NonHandledInterrupt}, /* irq24 */
{0x82, NonHandledInterrupt}, /* irq25 */
{0x82, NonHandledInterrupt}, /* irq26 */
{0x82, NonHandledInterrupt}, /* irq27 */
{0x82, NonHandledInterrupt}, /* irq28 */
{0x82, NonHandledInterrupt}, /* irq29 */
#endif /* _COSMIC_ */
vector.c file'da bunu yaptım.
* @file stm8s_it.h
* @author MCD Application Team
* @version V2.3.0
* @date 16-June-2017
* @brief This file contains the headers of the interrupt handlers
* @attention
* <h2><center>© COPYRIGHT 2014 STMicroelectronics</center></h2>
* Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
* You may not use this file except in compliance with the License.
* You may obtain a copy of the License at:
* http://www.st.com/software_license_agreement_liberty_v2
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM8S_IT_H
#define __STM8S_IT_H
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
#ifdef _COSMIC_
void _stext(void); /* RESET startup routine */
@far [member=28622]interrupt[/member] void TIM2_UPD_OVF_TRG_BRK_IRQHandler(void)
#ifdef _COSMIC_
@far [member=28622]interrupt[/member] void TIM1_CAP_COM_IRQHandler(void)
#ifdef _COSMIC_
@far [member=28622]interrupt[/member] void TIM1_UPD_OVF_TRG_BRK_IRQHandler(void)
#ifndef _RAISONANCE_
INTERRUPT void TRAP_IRQHandler(void); /* TRAP */
INTERRUPT void TLI_IRQHandler(void); /* TLI */
INTERRUPT void AWU_IRQHandler(void); /* AWU */
INTERRUPT void CLK_IRQHandler(void); /* CLOCK */
INTERRUPT void EXTI_PORTA_IRQHandler(void); /* EXTI PORTA */
INTERRUPT void EXTI_PORTB_IRQHandler(void); /* EXTI PORTB */
INTERRUPT void EXTI_PORTC_IRQHandler(void); /* EXTI PORTC */
INTERRUPT void EXTI_PORTD_IRQHandler(void); /* EXTI PORTD */
INTERRUPT void EXTI_PORTE_IRQHandler(void); /* EXTI PORTE */
#if defined(STM8S903) || defined(STM8AF622x)
INTERRUPT void EXTI_PORTF_IRQHandler(void); /* EXTI PORTF */
#endif /* (STM8S903) || (STM8AF622x) */
#if defined (STM8S208) || defined (STM8AF52Ax)
INTERRUPT void CAN_RX_IRQHandler(void); /* CAN RX */
INTERRUPT void CAN_TX_IRQHandler(void); /* CAN TX/ER/SC */
#endif /* (STM8S208) || (STM8AF52Ax) */
INTERRUPT void SPI_IRQHandler(void); /* SPI */
INTERRUPT void TIM1_CAP_COM_IRQHandler(void); /* TIM1 CAP/COM */
INTERRUPT void TIM1_UPD_OVF_TRG_BRK_IRQHandler(void); /* TIM1 UPD/OVF/TRG/BRK */
INTERRUPT void TIM5_UPD_OVF_BRK_TRG_IRQHandler(void); /* TIM5 UPD/OVF/BRK/TRG */
INTERRUPT void TIM5_CAP_COM_IRQHandler(void); /* TIM5 CAP/COM */
#else /* (STM8S208) || (STM8S207) || (STM8S105) || (STM8S103) || (STM8AF52Ax) || (STM8AF62Ax) || (STM8A626x) */
INTERRUPT void TIM2_UPD_OVF_BRK_IRQHandler(void); /* TIM2 UPD/OVF/BRK */
INTERRUPT void TIM2_CAP_COM_IRQHandler(void); /* TIM2 CAP/COM */
#if defined (STM8S208) || defined(STM8S207) || defined(STM8S007) || defined(STM8S105) || \
defined(STM8S005) || defined (STM8AF52Ax) || defined (STM8AF62Ax) || defined (STM8AF626x)
INTERRUPT void TIM3_UPD_OVF_BRK_IRQHandler(void); /* TIM3 UPD/OVF/BRK */
INTERRUPT void TIM3_CAP_COM_IRQHandler(void); /* TIM3 CAP/COM */
#endif /* (STM8S208) || (STM8S207) || (STM8S105) || (STM8AF52Ax) || (STM8AF62Ax) || (STM8A626x) */
#if defined (STM8S208) || defined(STM8S207) || defined(STM8S007) || defined(STM8S103) || \
defined (STM8S001) || defined(STM8S003) || defined (STM8AF52Ax) || defined (STM8AF62Ax) || defined (STM8S903)
INTERRUPT void UART1_TX_IRQHandler(void); /* UART1 TX */
INTERRUPT void UART1_RX_IRQHandler(void); /* UART1 RX */
#endif /* (STM8S208) || (STM8S207) || (STM8S903) || (STM8S103) || (STM8S001) || (STM8AF52Ax) || (STM8AF62Ax) */
#if defined (STM8AF622x)
INTERRUPT void UART4_TX_IRQHandler(void); /* UART4 TX */
INTERRUPT void UART4_RX_IRQHandler(void); /* UART4 RX */
#endif /* (STM8AF622x) */
INTERRUPT void I2C_IRQHandler(void); /* I2C */
#if defined(STM8S105) || defined(STM8S005) || defined (STM8AF626x)
INTERRUPT void UART2_RX_IRQHandler(void); /* UART2 RX */
INTERRUPT void UART2_TX_IRQHandler(void); /* UART2 TX */
#endif /* (STM8S105) || (STM8AF626x) */
#if defined(STM8S207) || defined(STM8S007) || defined(STM8S208) || defined (STM8AF52Ax) || defined (STM8AF62Ax)
INTERRUPT void UART3_RX_IRQHandler(void); /* UART3 RX */
INTERRUPT void UART3_TX_IRQHandler(void); /* UART3 TX */
#endif /* (STM8S207) || (STM8S208) || (STM8AF62Ax) || (STM8AF52Ax) */
INTERRUPT void ADC2_IRQHandler(void); /* ADC2 */
#else /* (STM8S105) || (STM8S103) || (STM8S903) || (STM8AF622x) */
INTERRUPT void ADC1_IRQHandler(void); /* ADC1 */
INTERRUPT void TIM6_UPD_OVF_TRG_IRQHandler(void); /* TIM6 UPD/OVF/TRG */
#else /* (STM8S208) || (STM8S207) || (STM8S105) || (STM8S103) || (STM8AF62Ax) || (STM8AF52Ax) || (STM8AF626x) */
INTERRUPT void TIM4_UPD_OVF_IRQHandler(void); /* TIM4 UPD/OVF */
INTERRUPT void EEPROM_EEC_IRQHandler(void); /* EEPROM ECC CORRECTION */
#endif /* _RAISONANCE_ */
#endif /* __STM8S_IT_H */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
stm8s_it.h ı böyle değiştirdim
INTERRUPT_HANDLER(TIM2_UPD_OVF_BRK_IRQHandler, 13)
GPIO_Init(GPIOC, GPIO_PIN_7, GPIO_MODE_OUT_PP_LOW_FAST);
GPIO_WriteReverse(GPIOC, GPIO_PIN_7);
// TIM1_ClearFlag( TIM1_FLAG_UPDATE);
TIM2_ClearITPendingBit(TIM2_IT_UPDATE);
stm8_it.c de bunu kurdum fakat sonuc yok neden olabilir ?
