AC 220V Okuma
Başlatan PICaso, 23 Kasım 2020, 15:33:29
PICaso
Arkadaşlar merhaba,
Pic18f45K22 ile şebeke gerilimini okuyup lcd ye yazmak istiyorum. Fakat lcd ye yazdığım değer 200v-240V arasında
sürekli değişiyor. Kodda ne gibi değişiklikler yapabilirim? Herkese kolay gelsin.
#include "config.h"
#include "lcd_16x2.h"
uint32_t led_timestamp = 0;
static uint8_t led_state = FALSE;
uint32_t adcUpdate_timestamp = 0;
char lcd_msg[LCD_BUFFER_LEN] = { 0 };
#define ADC_BUFFER_LENGTH   40u
uint16_t adc_data[ADC_BUFFER_LENGTH] = {0};
uint8_t adc_data_index = 0;
void main()
  // Select 16MHz Internal Oscillator
  OSCCONbits.IRCF = 0x07;             // From 1MHz to 16MHz
  InitTimer0 ();
  LCD_Init ();
  // Configure ADC
  ANSELAbits.ANSA0 = 1;     // Disable the Digital Input Buffer on AN0
  TRISAbits.RA0 = 1;        // AN0 as Input Pin
  ADCON1bits.PVCFG = 0x00;  // +Vref = AVDD
  ADCON1bits.NVCFG = 0x00;  // -Vref = AVSS
  ADCON2bits.ADFM = 0x01;   // Right Justified
  ADCON2bits.ACQT = 0x01;   // 2TAD
  ADCON2bits.ADCS = 0x05;   // FOSC/16
  ADCON0bits.CHS = 0x00;    // AN0 Selected
  ADCON0bits.ADON = 1;      // Enable ADC
  sprintf (lcd_msg, "    Embedded");
  LCD_Print_Line (0, lcd_msg);
  sprintf ( lcd_msg, "AC RMS = %dV", 0u);
  LCD_Print_Line (1, lcd_msg);
  LCD_Update ();
  while(1)
     sprintf ( lcd_msg, " VOLTAJ  OLCUMU ");
     LCD_Update ();
    // ADC Update Task
    if( millis() - adcUpdate_timestamp >= 1u )
      uint32_t ac_value = 0;
      adcUpdate_timestamp = millis ();
      ADCON0bits.GODONE = 1;  // Start Conversion
      while(ADCON0bits.GO == 1);
      uint8_t adc_lo = ADRESL;
      uint8_t adc_hi = ADRESH;
      adc_data[adc_data_index] =  (uint16_t)(adc_hi << 8) | (uint16_t)adc_lo;
      adc_data_index++;
      if( adc_data_index >= ADC_BUFFER_LENGTH )
        adc_data_index = 0u;
        // Time to Process and Display Data
        uint32_t adc_filter_val = 0;
        uint16_t adc_buf_local = 0;
        for( uint8_t i=0; i<ADC_BUFFER_LENGTH; i++ )
          adc_buf_local = adc_data[i];
          adc_filter_val += ((uint32_t)(adc_buf_local*(uint32_t)adc_buf_local ));
        // 625*625 = 390625
        // 128*128 = 16384
        // 625^2 / 128^2 = 23.8414
        adc_filter_val = (uint32_t)((float)adc_filter_val * 23.84);
        adc_filter_val /= ADC_BUFFER_LENGTH;      // mean squared sum
        adc_filter_val *= 2;
        ac_value = (uint16_t)sqrt(adc_filter_val);// root mean square
        ac_value *= 68u;
        ac_value /= 1000u;
       sprintf ( lcd_msg, "AC RMS = %luV", ac_value);
        LCD_Update();
PICaso
Kullandığın devrede sıkıntı war.
-Bir kere kapasitör kullanmazsan 0 +230 arası tüm değerleri görürsün
Kapasitör kullandığında da deşarj olabilmeli.
Kısacası kurgun yanlış.
-ikincisi kurduğun devre senin çarpılma riskinide getirir.
Zira şebekeden gelen faz ile nötr kazara yer değiştirse devrenin tamamı yüksek voltaja bağlanmış olur.
Mümkünse trafo kullan.
yada optik veya galvanik izolasyon kullan.
Yüksek empedans girişli (10-50 MOhm gibi) bir fark amplifikatörü ile bağlanmaya çalış.
Şurada paylaştığım devre sana fikir verebilir.
Benzer şeylerde paylaşmıştım forumda aramanı tavsiye ederim.
https://www.picproje.org/index.php/topic,78254.msg601150.html#msg601150
PICaso
Alıntı yapılan: Mehmet Salim GÜLLÜCE - 23 Kasım 2020, 15:58:18Kullandığın devrede sıkıntı war.
hocam trafo kullanmayı düşünmüyorum. proteusda program gayet güzel çalışıyor. Dediğiniz fişin takılma yönü önemli. AC
 nin 1 alternansını kullanarak, gerilim bölücüyle bu işi yapmak imkansız mıdır?
Mr.Thinking
bir multimetre de nasıl ölçülüyor ac voltaj? inceleyip uygulayabilirsiniz. Piyasa da endüstriyel bir sürü pano tipi ac ölçen cihazlar var çoğunda trafo kullanılmıyor. Onlara da bakabilirsiniz.
ego=1/Knowledge
Alıntı yapılan: PICaso - 23 Kasım 2020, 16:53:10hocam trafo kullanmayı düşünmüyorum. proteusda program gayet güzel çalışıyor. Dediğiniz fişin takılma yönü önemli. AC
Verdiğim linkteki devre alternans falan dinlemez iki giriş ucu arasındaki gerilim farkına bakar.
Çıkışındaki Opamp İntegral şeklinde revize edilip RMS DC ye dönüştürüldüğünde istediğini elde etmiş olursun.
İstersen 2000 volt ölç (Giriş dirençleri o voltaja dayanıklı olması şartı ile) farketmez ondan sonra.
PICaso
Alıntı yapılan: Mehmet Salim GÜLLÜCE - 23 Kasım 2020, 19:13:45Verdiğim linkteki devre alternans falan dinlemez iki giriş ucu arasındaki gerilim farkına bakar.
Hocam AC voltaj rms değeri azaldığı ya da arttığı durumlarda opamp çıkışı da lineer olarak değişir mi?
TS954 yerine kullanabileceğim muadil entegre neler olabilir?
LM358 veya LM324 kullanabilirsin.
Differantial amplifier yapısı endüstriyel elektronikte sıklıkla kullanılır.
Gerilim kazancı = 3K / (2x220K) olarak hesaplanır.
Çıkışın Ofset gerilimi 2.5v'tur.
Whats-App-Image-2020-11-24-at-11-47-46" border="0
Opampın Çıkışında 2.5V ofset gerilimine bindirilmiş 3/440 oranında zayıflatılmış girişteki AC sinyali göreceksin.
Bunu da ADC yardımıyla True RMS olarak okuyabilirsin.
Proteus
Kolay gelsin,
https://tr.aliexpress.com/item/33004868114.html
Diğer opamplı devreler ile aynı , en büyük farkı trafo ile izolasyon olması,
Kolay gelsin
PICaso
Alıntı yapılan: Erol YILMAZ - 24 Kasım 2020, 11:51:25LM358 veya LM324 kullanabilirsin.
Hocam True RMS ile ilgili bir tecrübem olmadı. Pic 18f45k22 ile yapılabilir mi?
tabi ki çok basit...
ZC dan sonraki 90° de adc okuma yapabilirsiniz.
Buna göre de istediğiniz işlem yapılabilir...
PICaso
Alıntı yapılan: mehmet - 24 Kasım 2020, 14:50:59ZC dan sonraki 90° de adc okuma yapabilirsiniz.
True RMS konusu ile yapmaya çalışacağım. Dediğiniz gibi ZC yi algılayıp, 5ms timer başlatıp, timer sonunda ADC ile peak voltajı okumakta mantıklı.
ACM
Erol hocamın devresi  sıfır geçişide yakalıyor yani ? Hemde direkt 220V girişle. Süüüüper , kopyala hemen.
