2g in Turkey
Başlatan igorlahtin88, 03 Şubat 2021, 15:21:30
igorlahtin88
Hello dear friends. Sorry for English on your forum, but I don't know Turkish.
I have a little question about Sim800c module. It is working only in 2g mobile nets. Do you have 2g in Turkey? How to choose the right sim card to work with sim800c? My device now in Turkey, and the man, that works with it, says that he tryed to buy 2g sim card, but mobile operator says that there is no 2g in Turkey. But I see on this forum that peoples use this modules. I will be glad to any information about it.
I translate my message in google on Turkish:
Merhaba, sevgili arkadaşlar. Forumunuzdaki İngilizce için özür dilerim, ancak Türkçe bilmiyorum.
Sım800c modülü hakkında küçük bir sorum var. Sadece 2G mobil ağlarda çalışır. Türkiye'de 2g var mı? SIM800C ile çalışmak için doğru SIM kartı nasıl seçerim? Cihazım şimdi Türkiye'de ve kişi? onunla çalışan kişi 2g SIM kart almaya çalıştığını söylüyor, ancak mobil operatör Türkiye'de 2g olmadığını söylüyor. Ama bu forumda insanların bu modülleri kullandığını görüyorum. Bu konuda herhangi bir bilgiye sahip olmaktan mutluluk duyacağım.
Yes, 2G is useable in Turkey.
brandice5
You don't need any special SIM card to work with 2G. Any SIM card you get from any operator (it doesn't matter if it says 3G or 4G) will work with 2G.
Sozuak
If sim800c module is compatible with new, latest generation sim cards which can be obtained from Turkish operators, Turkish mobile operators networks are  backward compatible so no matter you can use 2g here. We (you-he) can validate this by choosing network in the  network mode selection menu  of  any mobile phone located in Turkey (LTE/3G/GSM etc).
sadogan
igorlahtin88
Thank you so much for your help, friends.Super fast response! ::ok  Now I have the confidence that everything should work. We will deal with the user what is the problem.
ismail kaya
It may be necessary to enter the apn username and password of the gsm operator or the sim lock may not be removed.
ilyas KAYA
Imei kaydi yapmamış bence problem o dur
