nokia 6610 lcd için driver isteği
Başlatan gazel, 21 Ocak 2008, 17:49:43
gazel
merhaba arkadaşlar
CCS uyumlu 6610 lcd driveri (epson) arıyorum.
yardımcı olacak arkadaşlara şimdiden teşekkürler
mp3dragon
M_B
merhaba
umarım asagıdakı fıkır verır.
kolay gelsın
// This is the prototype for a Nokia 6610
// 132*132 pixel colour LCD driver.
// Rohit de Sa
// 24Dec07
// ver1.0
#include <18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
// defines for pins
#define hard_cs      pin_a1         //Chip select
#define hard_res   pin_a2         //Reset
#define hard_clk   pin_b1         //SPI clock
#define hard_sdo   pin_c7         //SPI data out
// defines for constants
#define sleepout   0x11         //from datasheet
#define invon      0x21
#define colmod      0x3a
#define setcon      0x25
#define dispon      0x29
#define ramwr      0x2c
#define paset      0x2b
#define caset      0x2a
#bit    SSPEN = 0xfc6.5
int1 command=0;
int1 data=1;
int i=0;
void write_command (int command)
   SSPEN=0;
   output_low(hard_clk);
   delay_us(2);
   output_low(hard_sdo);
   delay_us(2);
   output_high(hard_clk);
   delay_us(2);
   SSPEN=1;
   spi_write(command);
   delay_us(2);
void write_data (int data)
   SSPEN=0;
   delay_us(2);
   output_high(hard_sdo);
   delay_us(2);
   delay_us(2);
   SSPEN=1;
   spi_write(data);
   delay_us(2);
void main (void)
   output_high(hard_cs);         //initializing the LCD
   output_low(hard_res);         //holding the LCD in reset
   output_high(pin_a0);         //pin connected to LCD backlight
   setup_spi(spi_master|spi_h_to_l|spi_clk_div_64);
   delay_ms(2);               //are these delays necessary?
   output_high(hard_res);         //bringing LCD out of reset
   delay_ms(2);
   output_low(hard_cs);         //enabling LCD
   delay_us(2);
   write_command(sleepout);
   write_command(invon);
   write_command(colmod);
   write_data(0x03);
   write_command(setcon);
   write_data(0x10);
   write_command(dispon);
   write_command(paset);
   write_data(0x00);
   write_data(131);
   write_command(caset);
   write_data(0x00);
   write_data(131);
   write_command(ramwr);      //shading part of the LCD white
   for (i=0;i<255;i++)
      write_data(0xff);
      write_data(0xff);
      write_data(0xff);
   delay_us(2);
   output_high(hard_cs);      //deselecting the LCD
   while (true)
smyomekatronik
bu sitede CCS ile yapılmış örnek devre var yalnız lcd ekran philips epson değil kolay gelsin.
http://www.hobbypic.com/index.php?option=com_content&task=view&id=15&Itemid=36
gazel
mp3dragon arkadaşımızın verdiği kodu çevirmeyi deniyecem.
Teşekkürler arkadaşlar
