Absolute Database v6.03 for Delphi 2006-2007-2009
Başlatan gcolak, 05 Temmuz 2009, 05:02:42
gcolak
Is a Delphi database engine which lets you forget the Borland Database Engine (BDE). This BDE replacement is the compact, high-speed, robust and easy-to-use database engine. With Absolute Database you will not need special installation and configuration, it compiles right into your EXE. Make your application faster and smaller with Absolute Database BDE alternative!
features:
   * No BDE; no DLLs
   * Single-file database
   * SQL'92 (DDL & DML) support
   * Compatible with standard and third-party database controls
   * Single-user and multi-user mode (file-server)
   * Works great on all versions of Windows - from 98 to Vista, doesn't require any updates or service packs
   * Ultra-fast in-memory tables
   * Unmatched ease-of-use
   * Strong encryption
   * BLOB compression
http://rapidshare.com/files/251685349/Absolute_Database_v6.04_for_Delphi2009-AT4RE.zip
http://rapidshare.com/files/251684435/Absolute_Database_v6.04_for_Delphi2007-AT4RE.zip
http://rapidshare.com/files/251683475/Absolute_Database_v6.04_for_Delphi2006-AT4RE.zip
http://www.downtr.net/65523-absolute-database-v603-for-delphi-2006-2007-2009.html
