CCS C to PIC basic ??
Başlatan 122055221, 16 Ekim 2009, 13:59:19
122055221
Arkadaşlar CCS C' ye yabancı olduğum için, aşağıdaki programı Pic BasicPro ya dönüştürmek için yardım edebilirmisiniz. Şimdiden teşekkürler....
#include <16F84A.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT
#use delay(clock=10000000)
#use rs232(baud=19200, xmit=PIN_A2, rcv=PIN_A3)
//#use i2c(master,sda=PIN_C7,scl=PIN_C6,FORCE_HW)
#use i2c(master,sda=PIN_A1,scl=PIN_A0,SLOW)
#define GREEN_LED PIN_B2
#define TRIGGER PIN_B3
BYTE wait_response(void);
BYTE read_response(BYTE *response);
BYTE get_token(void);
BYTE start_read(void);
void main()
     BYTE buffer[22];
     BYTE token;
     while(1)
        while(1)
        output_high(GREEN_LED);
        delay_ms(500);
        output_low(GREEN_LED);
        delay_ms(500);
        delay_ms(500);
        //Read Token - We expect 0x6A or 0x6B
        printf("Read Token:");
        token=get_token();
        printf("%X",token);
        printf("\n \r");
        printf("%X",token);
        printf("\n \r");
        //Start Read
        printf("Starting Read:");
        token=start_read();
        printf("%X",token);
        printf("\n \r");
        //Wait until we get 0x6E token
        printf("Waiting Tag \n \r");
        while(token!=0x6E)
        token=get_token();
        printf("%X",token);
        printf("\n \r");
        delay_ms(500);
        //Now we have 0x6E token. A tag was read . We will request data
        output_high(TRIGGER);
        delay_ms(1000);
        delay_ms(1000);
        delay_ms(1000);
        printf("A Tag was read! \n \r");
        i2c_start();
        i2c_write(0x82);
        i2c_write('R');
        i2c_stop();
        i2c_start();
        i2c_write(0x83);     //0x41h<<1 = 0x82 | 1  = 0x83 (READ )
        buffer[0]=i2c_read();
        buffer[1]=i2c_read();
        buffer[2]=i2c_read();
        buffer[3]=i2c_read();
        buffer[4]=i2c_read(0);
        i2c_stop();
        printf("%X",buffer[0]);
        printf("%X",buffer[1]);
        printf("%X",buffer[2]);
        printf("%X",buffer[3]);
        printf("%X",buffer[4]);
        printf("\n \r");
        i2c_start();
        i2c_stop();
        printf("\n \r");
        output_low(TRIGGER);
        delay_ms(500);
BYTE tk;
        tk=0;
        i2c_start();
        tk=i2c_read(0);      //NACK before Stop.
        i2c_stop();
        return tk;
BYTE tk;
        i2c_start();
        i2c_write(0x82);     //0x41h<<1 = 0x82 | 0  = 0x82 (WRITE )
        i2c_write(0x10);     //Read Command
        i2c_write(0x03);     //EM4100
        i2c_write(0x02);     //Read two Blocks ( 2 x 4Byte)
        i2c_write(0x00);     //Null
        i2c_write(0x15);     //Checksum 0x10 + 0x03 + 0x02 + 0x00 .... 0x00
        i2c_stop();
        //Read Token - We expect 0x6B (Read is Active). If we read 0x88(busy) token, then make a new read until we dont get 0x88 token.
        tk=0x88;
        while(tk==0x88)
           tk=get_token();
          //Good to put some delay
           delay_ms(1);
        return tk;
Okan AKÇA
slm yanlış yerden başlmışsınız kod degistirme diye bir şeyyok tur sadece aynı mantıkda claısan kod yazabilirsiniz
koordinat
bu isteğiniz herhalde amatör yardımdan sapıyor
122055221
Benim kastettiğim öyle bişey değildi zaten, Ben Pic BasicPro dilini biliyorum, CCS diline yabancıyım. Bu iki dili bilen bir arkadaş bu programı picbasic pro için yorumlayabilir mi acaba....
122055221
Alıntı yapılan: "koordinat"bu isteğiniz herhalde amatör yardımdan sapıyor
Nedemek istediğinizi anlayamadım ama bu kodlar pek profesyonel olmasa gerek. İncelerseniz amatörce bir I2C veri transferiyle ilgili bir program.
koordinat
i2c protokolünü biliyormusunuz.ben şahsen kullanmadım ama programın neresinde takıldıysanız açıklamaya çalışayım
122055221
Dediğim gibi CCS ye yabancı olduğumdan, programı tam anlamıyla analiz edemiyorum. Bana genel olarak programın başından sonuna gelene kadar ne yapılmış açıklayabilirmisiniz. Bende bu sayede basicpro ya çevirebilirim. Teşekkürler....
122055221
Birde burayı anlamadım. Bu değişkenler nasıl değişken
koordinat
Alıntı yapılan: "122055221"
#include <16F84A.h>
#use i2c(master,sda=PIN_A1,scl=PIN_A0,SLOW)  //veri sda dır,scl //clocktur
BYTE wait_response(void);           //değişkenler
void main()
     BYTE buffer[22];    //dizi tanımlanıyor 22 elemanlık
     BYTE token;
     while(1)
        while(1)                                     //burası silinmiş
        delay_ms(500);
        delay_ms(500);
        output_high(GREEN_LED);     //yeşil ledi yaktık
        delay_ms(500);                    //0.5sn bekledik
        printf("Read Token:");        //seri iletişimle token ı oku yazdırıyoruz
        token=get_token();         //get_token fonks.??nerede anlamadım
        printf("%X",token);         //yazdırmaya devam
        printf("\n \r");
        printf("%X",token);         //yazdırma rs232ye
        printf("\n \r");
        //Start Read
        printf("Starting Read:");        //okumaya başlıyoruz
        token=start_read();            //fonks.çağırılıo
        printf("%X",token);
        printf("\n \r");
        while(token!=0x6E)           //token0x6e olmadığı sürece
        token=get_token();        //çağır bakalım
        printf("%X",token);
        printf("\n \r");              //yazdır
        delay_ms(500);          //beklet
        output_high(TRIGGER);    //tetikleme pinini lojik1 yap
        delay_ms(1000);
        delay_ms(1000);   //beklee 1sn her seferde
        delay_ms(1000);
        i2c_start();            //i2c haberleşmesi hazır kütüphanesini çağırdı
        i2c_write(0x82);   //0x82 gönderdi
        i2c_write('R');        //yazdı
        i2c_stop();            //durdurdu
        i2c_start();
        i2c_stop();
        printf("\n \r");
        i2c_start();
        i2c_stop();
        printf("\n \r");
        output_low(TRIGGER);   //tetik sinyalini lojik 0 yaptı
        output_low(GREEN_LED); //yeşil ledi de
        delay_ms(500);
BYTE tk;
        tk=0;
        i2c_start();
        i2c_stop();
        return tk;
BYTE tk;
        i2c_start();
        i2c_stop();
   //biz 0x6b (okuma aktif )jetonu bekiyoruz.ama 0x88(meşgul)jetonu gelirse taki okuma akitf olana kadar yeni okuma yapıyoruz
        tk=0x88;
        while(tk==0x88)
           tk=get_token();
           delay_ms(1);
        return tk;
koordinat
bence program eksik.eksiksiz olduğuna emin misiniz?bazı fonksiyonlar gözükmüyor
