IR sensör denemesine başlarken sorun..
Başlatan solidus, 10 Kasım 2010, 09:10:05
solidus
C dilini öğrenmeye yeni başladım. http://www.pyroelectro.com/projects/ir_radar/schematic.html adresindeki devreyi kurdum. Adreste açık kodlar mevcut fakat nasıl derleyeceğimi bilmiyorum. Yardım edebilecek bi arkadaşım varsa sevinirim.
justice_for_all
sitedeki kodu indirdim ama o kod cok karmasık onu duzerlemen gerek yoksa derleyici hata verir...
solidus
Kodun tamamı aşağıda. Nasıl bir düzenleme gerekiyor ? Bilgi verirmisiniz ?
Program:
This program makes a servo pan back and forth and takes
data at 5 different points, interprets that data & displays
it on the output leds using PORTD & PORTC to talk with
the 74LS373's.
//Initial Includes
#include <p18f452.h>
#include <timers.h>
#include <delays.h>
#include <adc.h>
#include <stdlib.h>
//Servo Initialization
int servo0 = 0xFC17;
//More Initializations
int radar_direction = 0;
int whichway = 0;
int count = 0;
int result = 0;
int round = 0;
//Function Declarations
void InterruptHandlerHigh (void);
int Ir_Data_Eval(int, int);
void main(void)
//Allow Interrupts
RCON = 0b000000000;
INTCON = 0b10100000;
//Setup & Open A/D, Timers
OpenTimer0( TIMER_INT_ON & T0_16BIT & T0_SOURCE_INT & T0_PS_1_2 );
OpenTimer1( TIMER_INT_ON & T1_16BIT_RW & T1_SOURCE_INT & T1_PS_1_2 & T1_OSC1EN_OFF & T1_SYNC_EXT_OFF );
//Initialize Timers
WriteTimer0( 0xB1DF );
WriteTimer1( 0xFC17 );
//Initialize Port Directions
TRISD = 0x00;
TRISB = 0x00;
TRISC = 0x00;
//Initially Light Up All Leds & Turn Them Off
PORTB = 0xFF;
PORTD = 0xFF;
Delay10TCYx(100);
PORTD = 0x00;
Delay10KTCYx(100);
PORTB = 0x00;
PORTD = 0xFF;
Delay10TCYx(100);
PORTD = 0x00;
Delay10KTCYx(100);
//Infinite While Loop
   while(1)
      //If radar is at one of 5 spots take a/d & output it to the leds
      switch(radar_direction)
         case 0:
               ConvertADC();
               while( BusyADC() );
                  result = ReadADC();
               PORTB = Ir_Data_Eval(result, 1);
               PORTD = 0x01;
               Delay10TCYx(10);
               result = 0;
               PORTD = 0x00;
               break;
         case 1:
               ConvertADC();
               while( BusyADC() );
                  result = ReadADC();
               PORTB = Ir_Data_Eval(result, 0);
               PORTD = 0x02;
               Delay10TCYx(10);
               result = 0;
               PORTD = 0x00;
               break;
         case 2:
               ConvertADC();
               while( BusyADC() );
                  result = ReadADC();
               PORTD = 0x04;
               Delay10TCYx(10);
               result = 0;
               PORTD = 0x00;
               break;
         case 3:
               ConvertADC();
               while( BusyADC() );
                  result = ReadADC();
               PORTD = 0x08;
               Delay10TCYx(10);
               result = 0;
               PORTD = 0x00;
               break;
         case 4:
               ConvertADC();
               while( BusyADC() );
                  result = ReadADC();
               PORTD = 0x10;
               Delay10TCYx(10);
               result = 0;
               PORTD = 0x00;
               break;
//INTERRUPT CONTROL
#pragma code InterruptVectorHigh = 0x08                //interrupt pointer address (0x18 low priority)
void InterruptVectorHigh (void)
        _asm        //assembly code starts
        goto InterruptHandlerHigh                //interrupt control
        _endasm //assembly code ends
#pragma code
#pragma interrupt InterruptHandlerHigh        //enf.
void InterruptHandlerHigh()        // declaration of InterruptHandler
{//this gets ran when ever the timers flop over from FFFF->0000
        if(INTCONbits.TMR0IF)                        //check if TMR0 interrupt flag is set
            count = 0;
             INTCONbits.TMR0IF = 0;                //clear TMR0 flag
        if(PIR1bits.TMR1IF == 1 && PIE1bits.TMR1IE == 1)        //if set controls the first servo
      count++;
            switch(count){
         case 1:     PORTC = 0x01; // First Stage
                   WriteTimer1( servo0 );
                  break;
         default:   PORTC = 0x00; // Left Gripper
                  WriteTimer1(0);
                  break;
                PIR1bits.TMR1IF = 0;                        //clear Timer1 flag
                PIE1bits.TMR1IE = 1;                        //clear Timer1 enable flag set to zero
Begin Direction Control
   //Move the Servo In Small Steps
   if(whichway)
      servo0+=5;
   if(!whichway)
      servo0-=5;
   //When 90 degrees or 0 degrees is reached, switch direction
   if(servo0 <= 0xF82F ){
      whichway = 1;
      round++;
   if(servo0 >= 0xFC17){
      whichway = 0;
      round++;
End Direction Control
Begin Radar Directional Lighting Control
//If 120 < servo0 < 130
if(servo0 > 0xF8A7 && servo0 < 0xF8B1)
   if(whichway == 0)
   if(whichway == 1)
      radar_direction = 1;
//If 370 < servo0 < 380
if(servo0 > 0xF9A1 && servo0 < 0xF9AB)
   if(whichway == 0)
   if(whichway == 1)
      radar_direction = 2;
//If 620 < servo0 < 630
if(servo0 > 0xFA9B && servo0 < 0xFAA5)
   if(whichway == 0)
   if(whichway == 1)
      radar_direction = 3;
//If 870 < servo0 < 880
if(servo0 > 0xFB95 && servo0 < 0xFB9F)
   if(whichway == 0)
   if(whichway == 1)
      radar_direction = 4;
End Radar Directional Lighting Control
    INTCONbits.GIE = 1;                                //re-enable all interrupts
int Ir_Data_Eval(int ir_data, int isCHIP0)
   //   @ 70cm+
if(ir_data > 0x171 && ir_data <= 0x19E){
   if(isCHIP0)
      return 0xC0;
      return 0x40;
   //   @ 60cm+
else if(ir_data > 0x19E && ir_data <= 0x1C3 ){
   if(isCHIP0)
      return 0xA0;
      return 0x20;
   //   @ 50cm+
else if(ir_data > 0x1C3 && ir_data <= 0x1EB ){
   if(isCHIP0)
      return 0x90;
      return 0x10;
   //   @ 40cm+
else if(ir_data > 0x1EB && ir_data <= 0x20D ){
   if(isCHIP0)
      return 0x88;
      return 0x08;
   //   @ 30cm+
else if(ir_data > 0x20D && ir_data <= 0x262 ){
   if(isCHIP0)
      return 0x84;
      return 0x04;
   //   @ 20cm+
else if(ir_data > 0x262 && ir_data <= 0x2C6 ){
   if(isCHIP0)
      return 0x82;
      return 0x02;
   //   @ 10cm+
else if(ir_data > 0x2DA){
   if(isCHIP0)
      return 0x81;
      return 0x01;
   //If chip 0 make sure to turn on the very first led
if(isCHIP0)
   return 0x80;
return 0x00;
cetinkaya
solidus
Ben derleyemedim bile. Mümkünse paylaşırmısınız ?
justice_for_all
pardon ya benim indirdigim dosya karman cormandi...
ne hatasi veriyo peki...
solidus
nasıl derleyeceğimi bilmiyorum. PIC C Compiler CCS PCWHD v4.068 kurdum. kodları kopyalayıp PCW ilk açılış ekranına yapıştırdım. Compile dediğimde include lardan #defines __18F452_H invalid pre-processor directive diye bi hata veriyor ?
justice_for_all
islemciyi taniyamamis CCS kullanmayi biliymusunuz...
proje olusturmayi...
justice_for_all
arkadasim ozur kodu inceledim bu CCS diil bu microchip C18 derleyici arkadasim o derleyici olmasi gerek...
ama istersen ben derleyip sana hexi yollarim...
solidus
Alıntı yapılan: justice_for_all - 11 Kasım 2010, 19:41:54
bunu yaparsanız sevinirim.. Ama C18 derleyiciyi nerden bulabilirim ben de öğrenmiş olayım..
justice_for_all
oncelikli microchipin sitesinden mplab ide programin indirip kurmaniz gerek...
data sonra yine microchipin sitesinde arama kismina C18 yazarsaniz cikar...
http://www.4shared.com/file/ZxTCHgcI/demo.html
bu linkte hex kodu bulunmakta...
Kolay gelsin
solidus
ISIS simülasyonunda gene aynı şey oluyor. Acaba gene ISIS'in azizliğimidir ? LED' lerde hiç hareket yok. Simülasyon dosyalarını atsam ilgilenirmisiniz ? Benmi hata yapıyorum yoksa ISIS'mi beni yanıltıyor ?
justice_for_all
ok yukleyip linkini verin bende bi kontrol edeyim...
solidus
justice_for_all
arkadasim sen bu devreyi nerden aldim dedin kodda ADC oku var ama ADC acilmamis ki neye gore okusun bu ayrica ADC ne icin kullanilmis orjinal devresi varmi bunun...
