SHT11 I2C yardım
Başlatan taytis, 03 Nisan 2011, 21:30:02
taytis
Arkadaşlar selam ; aşağıdaki kodu lpc2138 ile yapmaya çalışıcam ama takıldım.
#define   DATA      P1_1         //p1_1 yeri pisel'i mi tanıtmam gerekiyor ? 2368 hangi ayağını sda olarak kullanıcaksam
#define   SCK      P1_0
if (i & value) DATA=1;              //burada o pini 1 'mi yapmam gerekiyor ?
konu hakkında yardımlarınızı bekliyorumç
Project:          SHT1x/7x demo program (V2.4)
Filename:         SHT1x_sample_code.c
Prozessor:        80C51 family
Compiler:         Keil Version 6.23a
Autor:            MST
Copyrigth:        (c) Sensirion AG
// Revisions:
// V2.4    calc_sht11()       Coefficients for humidity and temperature conversion
//                          changed (for V4 sensors)
//       calc_dewpoint()   New formula for dew point calculation
#include <AT89s53.h> //Microcontroller specific library, e.g. port definitions
#include <intrins.h> //Keil library (is used for _nop()_ operation)
#include <math.h>    //Keil library
#include <stdio.h>   //Keil library
typedef union
{ unsigned int i;
  float f;
} value;
// modul-var
enum {TEMP,HUMI};
#define   DATA      P1_1
#define   SCK      P1_0
#define noACK 0
#define ACK   1
                            //adr  command  r/w
#define STATUS_REG_W 0x06   //000   0011    0
#define STATUS_REG_R 0x07   //000   0011    1
#define MEASURE_TEMP 0x03   //000   0001    1
#define MEASURE_HUMI 0x05   //000   0010    1
#define RESET        0x1e   //000   1111    0
char s_write_byte(unsigned char value)
// writes a byte on the Sensibus and checks the acknowledge
  unsigned char i,error=0;
  for (i=0x80;i>0;i/=2)             //shift bit for masking
  { if (i & value) DATA=1;          //masking value with i , write to SENSI-BUS
    else DATA=0;
    _nop_();                        //observe setup time
    SCK=1;                          //clk for SENSI-BUS
    _nop_();_nop_();_nop_();        //pulswith approx. 5 us
    SCK=0;
    _nop_();                         //observe hold time
  DATA=1;                           //release DATA-line
  SCK=1;                            //clk #9 for ack
  error=DATA;                       //check ack (DATA will be pulled down by SHT11)
  SCK=0;
  return error;                     //error=1 in case of no acknowledge
char s_read_byte(unsigned char ack)
// reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
  unsigned char i,val=0;
  { SCK=1;                          //clk for SENSI-BUS
    if (DATA) val=(val | i);        //read bit
    SCK=0;
  DATA=!ack;                        //in case of "ack==1" pull down DATA-Line
  SCK=0;
  return val;
void s_transstart(void)
// generates a transmission start
//       _____         ________
// DATA:      |_______|
//           ___     ___
// SCK : ___|   |___|   |______
   DATA=1; SCK=0;                   //Initial state
   _nop_();
   SCK=1;
   _nop_();
   DATA=0;
   _nop_();
   SCK=0;
   SCK=1;
   _nop_();
   DATA=1;
   _nop_();
   SCK=0;
void s_connectionreset(void)
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
//       _____________________________________________________         ________
// DATA:                                                      |_______|
//          _    _    _    _    _    _    _    _    _        ___     ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______|   |___|   |______
  unsigned char i;
  for(i=0;i<9;i++)                  //9 SCK cycles
  { SCK=1;
    SCK=0;
  s_transstart();                   //transmission start
char s_softreset(void)
// resets the sensor by a softreset
  unsigned char error=0;
  s_connectionreset();              //reset communication
  error+=s_write_byte(RESET);       //send RESET-command to sensor
  return error;                     //error=1 in case of no response form the sensor
char s_read_statusreg(unsigned char *p_value, unsigned char *p_checksum)
// reads the status register with checksum (8-bit)
  error=s_write_byte(STATUS_REG_R); //send command to sensor
  *p_value=s_read_byte(ACK);        //read status register (8-bit)
  *p_checksum=s_read_byte(noACK);   //read checksum (8-bit)
char s_write_statusreg(unsigned char *p_value)
// writes the status register with checksum (8-bit)
  error+=s_write_byte(STATUS_REG_W);//send command to sensor
  error+=s_write_byte(*p_value);    //send value of status register
  return error;                     //error>=1 in case of no response form the sensor
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
// makes a measurement (humidity/temperature) with checksum
  unsigned int i;
  switch(mode){                     //send command to sensor
    case TEMP   : error+=s_write_byte(MEASURE_TEMP); break;
    case HUMI   : error+=s_write_byte(MEASURE_HUMI); break;
    default     : break;
  for (i=0;i<65535;i++) if(DATA==0) break; //wait until sensor has finished the measurement
  if(DATA) error+=1;                // or timeout (~2 sec.) is reached
  *(p_value)  =s_read_byte(ACK);    //read the first byte (MSB)
  *(p_value+1)=s_read_byte(ACK);    //read the second byte (LSB)
  *p_checksum =s_read_byte(noACK);  //read checksum
  return error;
void init_uart()
//9600 bps @ 11.059 MHz
{SCON  = 0x52;
TMOD  = 0x20;
TCON  = 0x69;
TH1   = 0xfd;
void calc_sth11(float *p_humidity ,float *p_temperature)
// calculates temperature [°C] and humidity [%RH]
// input :  humi [Ticks] (12 bit)
//          temp [Ticks] (14 bit)
// output:  humi [%RH]
//          temp [°C]
{ const float C1=-2.0468;           // for 12 Bit RH
  const float C2=+0.0367;           // for 12 Bit RH
  const float C3=-0.0000015955;     // for 12 Bit RH
  const float T1=+0.01;             // for 12 Bit RH
  const float T2=+0.00008;          // for 12 Bit RH
  float rh=*p_humidity;             // rh:      Humidity [Ticks] 12 Bit
  float t=*p_temperature;           // t:       Temperature [Ticks] 14 Bit
  float rh_lin;                     // rh_lin:  Humidity linear
  float rh_true;                    // rh_true: Temperature compensated humidity
  float t_C;                        // t_C   :  Temperature [°C]
  t_C=t*0.01 - 40.1;                //calc. temperature [°C] from 14 bit temp. ticks @ 5V
  rh_lin=C3*rh*rh + C2*rh + C1;     //calc. humidity from ticks to [%RH]
  rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;   //calc. temperature compensated humidity [%RH]
  if(rh_true>100)rh_true=100;       //cut if the value is outside of
  if(rh_true<0.1)rh_true=0.1;       //the physical possible range
  *p_temperature=t_C;               //return temperature [°C]
  *p_humidity=rh_true;              //return humidity[%RH]
float calc_dewpoint(float h,float t)
// calculates dew point
// input:   humidity [%RH], temperature [°C]
// output:  dew point [°C]
{ float k,dew_point ;
  k = (log10(h)-2)/0.4343 + (17.62*t)/(243.12+t);
  dew_point = 243.12*k/(17.62-k);
  return dew_point;
void main()
// sample program that shows how to use SHT11 functions
// 1. connection reset
// 2. measure humidity [ticks](12 bit) and temperature [ticks](14 bit)
// 3. calculate humidity [%RH] and temperature [°C]
// 4. calculate dew point [°C]
// 5. print temperature, humidity, dew point
{ value humi_val,temp_val;
  float dew_point;
  unsigned char error,checksum;
  unsigned int i;
  init_uart();
  while(1)
  { error=0;
    error+=s_measure((unsigned char*) &humi_val.i,&checksum,HUMI);  //measure humidity
    error+=s_measure((unsigned char*) &temp_val.i,&checksum,TEMP);  //measure temperature
    if(error!=0) s_connectionreset();                 //in case of an error: connection reset
    { humi_val.f=(float)humi_val.i;                   //converts integer to float
      temp_val.f=(float)temp_val.i;                   //converts integer to float
      calc_sth11(&humi_val.f,&temp_val.f);            //calculate humidity, temperature
      dew_point=calc_dewpoint(humi_val.f,temp_val.f); //calculate dew point
      printf("temp:%5.1fC humi:%5.1f%% dew point:%5.1fC\n",temp_val.f,humi_val.f,dew_point);
    //----------wait approx. 0.8s to avoid heating up SHTxx------------------------------
    for (i=0;i<40000;i++);     //(be sure that the compiler doesn't eliminate this line!)
X-Fi
SHT 11 sensör tam I2C sayılmaz kendine has fonksiyonlar türetmişler o yüzden manual olarak yazacağız ben sizin için aşağıda bir örnek çalıştırdım yalnız cortex m3 de lcd ye gönderirken kullandığım sprintf fonksiyonu lpc2138 de çalışmadı int olarak düzenlemek zorunda kaldım biraz araştırma yaparsanız belki siz çözersiniz.
http://hotfile.com/dl/113184516/ebbb196/SHT11LPC2138.rar.html
http://www.coskunergan.com/    (Yürümekle varılmaz, lakin varanlar yürüyenlerdir.)
taytis
Çok teşekkür ederim tam istediğimdi. sht11.h ve sht11.c dosyasını sizmi yazdınız ?
X-Fi
1 ay kadar önce ben düzenledim yukarıda paylaştığınız koduda incelemiştim farklı kaynakların birleşimi sayılır.
arm7 de float değeri lcd ye yazdıramadığım için sprintf ile float değer dönüşümlü çalışmıyor bu konu hakkında bişeyler geliştirirseniz burada paylaşınız.
taytis
Tekrar çok teşekkür ederim. Şimdi sizin gönderdiğiniz kodla sht'nin sitesinden indirdiğim kodu kontrol edicem.
Yasal Uyarı: Picproje.org sitemizde 5651 sayılı kanunun 8. maddesine ve T.C.Knın 125. maddesine göre tüm üyelerimiz yaptıkları paylaşımlardan kendileri sorumludur. Picproje.org hakkında yapılacak tüm hukuksal şikayetleri İletişim sayfamızdan bize bildirdikten en geç 3 (üç) iş günü içerisinde ilgili kanunlar ve yönetmelikler çerçevesinde tarafımızca incelenerek gereken işlemler yapılacak ve site yöneticilerimiz tarafından bilgi verilecektir.
