STM32F10X Çalışmalarım
Başlatan Mucit23, 12 Mart 2012, 11:17:48
Hocam I2C ile uğraşıyorum. Keil library si içerisindeki stm32f10x_i2c.h dosyası içerisindeki aşağıdaki foksiyonlar nerede icra edilir
void I2C_DeInit(I2C_TypeDef* I2Cx);
void I2C_Init(I2C_TypeDef* I2Cx, I2C_InitTypeDef* I2C_InitStruct);
void I2C_StructInit(I2C_InitTypeDef* I2C_InitStruct);
void I2C_Cmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_DMACmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_DMALastTransferCmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_GenerateSTART(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_GenerateSTOP(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_AcknowledgeConfig(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_OwnAddress2Config(I2C_TypeDef* I2Cx, u8 Address);
void I2C_DualAddressCmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_GeneralCallCmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_ITConfig(I2C_TypeDef* I2Cx, u16 I2C_IT, FunctionalState NewState);
void I2C_SendData(I2C_TypeDef* I2Cx, u8 Data);
u8 I2C_ReceiveData(I2C_TypeDef* I2Cx);
void I2C_Send7bitAddress(I2C_TypeDef* I2Cx, u8 Address, u8 I2C_Direction);
u16 I2C_ReadRegister(I2C_TypeDef* I2Cx, u8 I2C_Register);
void I2C_SoftwareResetCmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_SMBusAlertConfig(I2C_TypeDef* I2Cx, u16 I2C_SMBusAlert);
void I2C_TransmitPEC(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_PECPositionConfig(I2C_TypeDef* I2Cx, u16 I2C_PECPosition);
void I2C_CalculatePEC(I2C_TypeDef* I2Cx, FunctionalState NewState);
u8 I2C_GetPEC(I2C_TypeDef* I2Cx);
void I2C_ARPCmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_StretchClockCmd(I2C_TypeDef* I2Cx, FunctionalState NewState);
void I2C_FastModeDutyCycleConfig(I2C_TypeDef* I2Cx, u16 I2C_DutyCycle);
u32 I2C_GetLastEvent(I2C_TypeDef* I2Cx);
ErrorStatus I2C_CheckEvent(I2C_TypeDef* I2Cx, u32 I2C_EVENT);
FlagStatus I2C_GetFlagStatus(I2C_TypeDef* I2Cx, u32 I2C_FLAG);
void I2C_ClearFlag(I2C_TypeDef* I2Cx, u32 I2C_FLAG);
ITStatus I2C_GetITStatus(I2C_TypeDef* I2Cx, u32 I2C_IT);
void I2C_ClearITPendingBit(I2C_TypeDef* I2Cx, u32 I2C_IT);
Bu fonsiyonları bulamadım bir türlü..
X-Fi
Önce kütüpaneyi derle sonra fonksiyona çift tıklayıp "Go To definition of " a tıkla fonksiyon karşına gelir.
stm32f10x_i2c.c nin içinde olacak muhtemelen.
Hocam dediğiniz yöntem benim hazırladığım fonksiyonlarda çalışıyor. Ama kayıp fonskiyonları ararken çalışmadı.
keil bana bunu söylüyor
photo uploader
Sanırım tarayıcıda tanımlanmamış diyor. ilginç :o :o
X-Fi
kütüpanenin C uzantısını bulun C/C++ menüsünden adresini görebileceği biyere yapıştırın veya bulunduğu adresi gösterin sonra derleyin go to komutu çalışacaktır.
Anlamadımki bende  :o
Kütüphane içerisindeki stm32f10x_i2c.h dosyasının içeriği bu şekilde
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : stm32f10x_i2c.h
* Author             : MCD Application Team
* Version            : V2.0.1
* Date               : 06/13/2008
* Description        : This file contains all the functions prototypes for the
*                      I2C firmware library.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32F10x_I2C_H
#define __STM32F10x_I2C_H
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_map.h"
/* Exported types ------------------------------------------------------------*/
/* I2C Init structure definition */
typedef struct
  u16 I2C_Mode;
  u16 I2C_DutyCycle;
  u16 I2C_OwnAddress1;
  u16 I2C_Ack;
  u16 I2C_AcknowledgedAddress;
  u32 I2C_ClockSpeed;
}I2C_InitTypeDef;
/* Exported constants --------------------------------------------------------*/
#define IS_I2C_ALL_PERIPH(PERIPH) (((*(u32*)&(PERIPH)) == I2C1_BASE) || \
                                   ((*(u32*)&(PERIPH)) == I2C2_BASE))
/* I2C modes */
#define I2C_Mode_I2C                    ((u16)0x0000)
#define I2C_Mode_SMBusDevice            ((u16)0x0002)
#define I2C_Mode_SMBusHost              ((u16)0x000A)
#define IS_I2C_MODE(MODE) (((MODE) == I2C_Mode_I2C) || \
                           ((MODE) == I2C_Mode_SMBusDevice) || \
                           ((MODE) == I2C_Mode_SMBusHost))
/* I2C duty cycle in fast mode */
#define I2C_DutyCycle_16_9              ((u16)0x4000)
#define I2C_DutyCycle_2                 ((u16)0xBFFF)
#define IS_I2C_DUTY_CYCLE(CYCLE) (((CYCLE) == I2C_DutyCycle_16_9) || \
                                  ((CYCLE) == I2C_DutyCycle_2))
/* I2C cknowledgementy */
#define I2C_Ack_Enable                  ((u16)0x0400)
#define I2C_Ack_Disable                 ((u16)0x0000)
#define IS_I2C_ACK_STATE(STATE) (((STATE) == I2C_Ack_Enable) || \
                                 ((STATE) == I2C_Ack_Disable))
/* I2C transfer direction */
#define  I2C_Direction_Transmitter      ((u8)0x00)
#define  I2C_Direction_Receiver         ((u8)0x01)
#define IS_I2C_DIRECTION(DIRECTION) (((DIRECTION) == I2C_Direction_Transmitter) || \
                                     ((DIRECTION) == I2C_Direction_Receiver))
/* I2C acknowledged address defines */
#define I2C_AcknowledgedAddress_7bit    ((u16)0x4000)
#define I2C_AcknowledgedAddress_10bit   ((u16)0xC000)
#define IS_I2C_ACKNOWLEDGE_ADDRESS(ADDRESS) (((ADDRESS) == I2C_AcknowledgedAddress_7bit) || \
                                             ((ADDRESS) == I2C_AcknowledgedAddress_10bit))
/* I2C registers */
#define I2C_Register_CR1                ((u8)0x00)
#define I2C_Register_CR2                ((u8)0x04)
#define I2C_Register_OAR1               ((u8)0x08)
#define I2C_Register_OAR2               ((u8)0x0C)
#define I2C_Register_DR                 ((u8)0x10)
#define I2C_Register_SR1                ((u8)0x14)
#define I2C_Register_SR2                ((u8)0x18)
#define I2C_Register_CCR                ((u8)0x1C)
#define I2C_Register_TRISE              ((u8)0x20)
#define IS_I2C_REGISTER(REGISTER) (((REGISTER) == I2C_Register_CR1) || \
                                   ((REGISTER) == I2C_Register_CR2) || \
                                   ((REGISTER) == I2C_Register_OAR1) || \
                                   ((REGISTER) == I2C_Register_OAR2) || \
                                   ((REGISTER) == I2C_Register_DR) || \
                                   ((REGISTER) == I2C_Register_SR1) || \
                                   ((REGISTER) == I2C_Register_SR2) || \
                                   ((REGISTER) == I2C_Register_CCR) || \
                                   ((REGISTER) == I2C_Register_TRISE))
/* I2C SMBus alert pin level */
#define I2C_SMBusAlert_Low              ((u16)0x2000)
#define I2C_SMBusAlert_High             ((u16)0xDFFF)
#define IS_I2C_SMBUS_ALERT(ALERT) (((ALERT) == I2C_SMBusAlert_Low) || \
                                   ((ALERT) == I2C_SMBusAlert_High))
/* I2C PEC position */
#define I2C_PECPosition_Next            ((u16)0x0800)
#define I2C_PECPosition_Current         ((u16)0xF7FF)
#define IS_I2C_PEC_POSITION(POSITION) (((POSITION) == I2C_PECPosition_Next) || \
                                       ((POSITION) == I2C_PECPosition_Current))
/* I2C interrupts definition */
#define I2C_IT_BUF                      ((u16)0x0400)
#define I2C_IT_EVT                      ((u16)0x0200)
#define I2C_IT_ERR                      ((u16)0x0100)
#define IS_I2C_CONFIG_IT(IT) ((((IT) & (u16)0xF8FF) == 0x00) && ((IT) != 0x00))
#define I2C_IT_SMBALERT                 ((u32)0x10008000)
#define I2C_IT_TIMEOUT                  ((u32)0x10004000)
#define I2C_IT_PECERR                   ((u32)0x10001000)
#define I2C_IT_OVR                      ((u32)0x10000800)
#define I2C_IT_AF                       ((u32)0x10000400)
#define I2C_IT_ARLO                     ((u32)0x10000200)
#define I2C_IT_BERR                     ((u32)0x10000100)
#define I2C_IT_TXE                      ((u32)0x00000080)
#define I2C_IT_RXNE                     ((u32)0x00000040)
#define I2C_IT_STOPF                    ((u32)0x60000010)
#define I2C_IT_ADD10                    ((u32)0x20000008)
#define I2C_IT_BTF                      ((u32)0x60000004)
#define I2C_IT_ADDR                     ((u32)0xA0000002)
#define I2C_IT_SB                       ((u32)0x20000001)
#define IS_I2C_CLEAR_IT(IT) (((IT) == I2C_IT_SMBALERT) || ((IT) == I2C_IT_TIMEOUT) || \
                             ((IT) == I2C_IT_PECERR) || ((IT) == I2C_IT_OVR) || \
                             ((IT) == I2C_IT_AF) || ((IT) == I2C_IT_ARLO) || \
                             ((IT) == I2C_IT_BERR) || ((IT) == I2C_IT_STOPF) || \
                             ((IT) == I2C_IT_ADD10) || ((IT) == I2C_IT_BTF) || \
                             ((IT) == I2C_IT_ADDR) || ((IT) == I2C_IT_SB))
#define IS_I2C_GET_IT(IT) (((IT) == I2C_IT_SMBALERT) || ((IT) == I2C_IT_TIMEOUT) || \
                           ((IT) == I2C_IT_BERR) || ((IT) == I2C_IT_TXE) || \
                           ((IT) == I2C_IT_RXNE) || ((IT) == I2C_IT_STOPF) || \
/* I2C flags definition */
#define I2C_FLAG_DUALF                  ((u32)0x00800000)
#define I2C_FLAG_SMBHOST                ((u32)0x00400000)
#define I2C_FLAG_SMBDEFAULT             ((u32)0x00200000)
#define I2C_FLAG_GENCALL                ((u32)0x00100000)
#define I2C_FLAG_TRA                    ((u32)0x00040000)
#define I2C_FLAG_BUSY                   ((u32)0x00020000)
#define I2C_FLAG_MSL                    ((u32)0x00010000)
#define I2C_FLAG_SMBALERT               ((u32)0x10008000)
#define I2C_FLAG_TIMEOUT                ((u32)0x10004000)
#define I2C_FLAG_PECERR                 ((u32)0x10001000)
#define I2C_FLAG_OVR                    ((u32)0x10000800)
#define I2C_FLAG_AF                     ((u32)0x10000400)
#define I2C_FLAG_ARLO                   ((u32)0x10000200)
#define I2C_FLAG_BERR                   ((u32)0x10000100)
#define I2C_FLAG_TXE                    ((u32)0x00000080)
#define I2C_FLAG_RXNE                   ((u32)0x00000040)
#define I2C_FLAG_STOPF                  ((u32)0x60000010)
#define I2C_FLAG_ADD10                  ((u32)0x20000008)
#define I2C_FLAG_BTF                    ((u32)0x60000004)
#define I2C_FLAG_ADDR                   ((u32)0xA0000002)
#define I2C_FLAG_SB                     ((u32)0x20000001)
#define IS_I2C_CLEAR_FLAG(FLAG) (((FLAG) == I2C_FLAG_SMBALERT) || ((FLAG) == I2C_FLAG_TIMEOUT) || \
                                 ((FLAG) == I2C_FLAG_PECERR) || ((FLAG) == I2C_FLAG_OVR) || \
                                 ((FLAG) == I2C_FLAG_AF) || ((FLAG) == I2C_FLAG_ARLO) || \
                                 ((FLAG) == I2C_FLAG_BERR) || ((FLAG) == I2C_FLAG_STOPF) || \
                                 ((FLAG) == I2C_FLAG_ADD10) || ((FLAG) == I2C_FLAG_BTF) || \
                                 ((FLAG) == I2C_FLAG_ADDR) || ((FLAG) == I2C_FLAG_SB))
#define IS_I2C_GET_FLAG(FLAG) (((FLAG) == I2C_FLAG_DUALF) || ((FLAG) == I2C_FLAG_SMBHOST) || \
                               ((FLAG) == I2C_FLAG_SMBDEFAULT) || ((FLAG) == I2C_FLAG_GENCALL) || \
                               ((FLAG) == I2C_FLAG_TRA) || ((FLAG) == I2C_FLAG_BUSY) || \
                               ((FLAG) == I2C_FLAG_MSL) || ((FLAG) == I2C_FLAG_SMBALERT) || \
                               ((FLAG) == I2C_FLAG_TIMEOUT) || ((FLAG) == I2C_FLAG_PECERR) || \
                               ((FLAG) == I2C_FLAG_OVR) || ((FLAG) == I2C_FLAG_AF) || \
                               ((FLAG) == I2C_FLAG_ARLO) || ((FLAG) == I2C_FLAG_BERR) || \
                               ((FLAG) == I2C_FLAG_TXE) || ((FLAG) == I2C_FLAG_RXNE) || \
                               ((FLAG) == I2C_FLAG_STOPF) || ((FLAG) == I2C_FLAG_ADD10) || \
                               ((FLAG) == I2C_FLAG_BTF) || ((FLAG) == I2C_FLAG_ADDR) || \
/* I2C Events */
/* EV1 */
#define  I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED       ((u32)0x00060082) /* TRA, BUSY, TXE and ADDR flags */
#define  I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED          ((u32)0x00020002) /* BUSY and ADDR flags */
#define  I2C_EVENT_SLAVE_TRANSMITTER_SECONDADDRESS_MATCHED ((u32)0x00860080)  /* DUALF, TRA, BUSY and TXE flags */
#define  I2C_EVENT_SLAVE_RECEIVER_SECONDADDRESS_MATCHED    ((u32)0x00820000)  /* DUALF and BUSY flags */
#define  I2C_EVENT_SLAVE_GENERALCALLADDRESS_MATCHED        ((u32)0x00120000)  /* GENCALL and BUSY flags */
/* EV2 */
#define  I2C_EVENT_SLAVE_BYTE_RECEIVED                     ((u32)0x00020040)  /* BUSY and RXNE flags */
/* EV3 */
#define  I2C_EVENT_SLAVE_BYTE_TRANSMITTED                  ((u32)0x00060084)  /* TRA, BUSY, TXE and BTF flags */
/* EV4 */
#define  I2C_EVENT_SLAVE_STOP_DETECTED                     ((u32)0x00000010)  /* STOPF flag */
/* EV5 */
#define  I2C_EVENT_MASTER_MODE_SELECT                      ((u32)0x00030001)  /* BUSY, MSL and SB flag */
/* EV6 */
#define  I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED        ((u32)0x00070082)  /* BUSY, MSL, ADDR, TXE and TRA flags */
#define  I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED           ((u32)0x00030002)  /* BUSY, MSL and ADDR flags */
/* EV7 */
#define  I2C_EVENT_MASTER_BYTE_RECEIVED                    ((u32)0x00030040)  /* BUSY, MSL and RXNE flags */
/* EV8 */
#define  I2C_EVENT_MASTER_BYTE_TRANSMITTED                 ((u32)0x00070084)  /* TRA, BUSY, MSL, TXE and BTF flags */
/* EV9 */
#define  I2C_EVENT_MASTER_MODE_ADDRESS10                   ((u32)0x00030008)  /* BUSY, MSL and ADD10 flags */
/* EV3_2 */
#define  I2C_EVENT_SLAVE_ACK_FAILURE                       ((u32)0x00000400)  /* AF flag */
#define IS_I2C_EVENT(EVENT) (((EVENT) == I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED) || \
                             ((EVENT) == I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED) || \
                             ((EVENT) == I2C_EVENT_SLAVE_TRANSMITTER_SECONDADDRESS_MATCHED) || \
                             ((EVENT) == I2C_EVENT_SLAVE_RECEIVER_SECONDADDRESS_MATCHED) || \
                             ((EVENT) == I2C_EVENT_SLAVE_GENERALCALLADDRESS_MATCHED) || \
                             ((EVENT) == I2C_EVENT_SLAVE_BYTE_RECEIVED) || \
                             ((EVENT) == (I2C_EVENT_SLAVE_BYTE_RECEIVED | I2C_FLAG_DUALF)) || \
                             ((EVENT) == (I2C_EVENT_SLAVE_BYTE_RECEIVED | I2C_FLAG_GENCALL)) || \
                             ((EVENT) == I2C_EVENT_SLAVE_BYTE_TRANSMITTED) || \
                             ((EVENT) == (I2C_EVENT_SLAVE_BYTE_TRANSMITTED | I2C_FLAG_DUALF)) || \
                             ((EVENT) == (I2C_EVENT_SLAVE_BYTE_TRANSMITTED | I2C_FLAG_GENCALL)) || \
                             ((EVENT) == I2C_EVENT_SLAVE_STOP_DETECTED) || \
                             ((EVENT) == I2C_EVENT_MASTER_MODE_SELECT) || \
                             ((EVENT) == I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED) || \
                             ((EVENT) == I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED) || \
                             ((EVENT) == I2C_EVENT_MASTER_BYTE_RECEIVED) || \
                             ((EVENT) == I2C_EVENT_MASTER_BYTE_TRANSMITTED) || \
                             ((EVENT) == I2C_EVENT_MASTER_MODE_ADDRESS10) || \
                             ((EVENT) == I2C_EVENT_SLAVE_ACK_FAILURE))
/* I2C own address1 -----------------------------------------------------------*/
#define IS_I2C_OWN_ADDRESS1(ADDRESS1) ((ADDRESS1) <= 0x3FF)
/* I2C clock speed ------------------------------------------------------------*/
#define IS_I2C_CLOCK_SPEED(SPEED) (((SPEED) >= 0x1) && ((SPEED) <= 400000))
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
#endif /*__STM32F10x_I2C_H */
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
Bu dosyanın .c uzantılı olanını bulamıyorum. Muhtemelen burada tanımlanmış fonksiyonlar orada icra ediliyor. Onu bulamıyorum.
Hocam verdiğiniz için teşekkür ederim.
Ben Şunu merak ediyorum aslında. Bu verdiğim kütüphanelerin .c dosyaları kullanılmıyormu? Kullanılmıyorsa eğer nasıl program çalılışıyor. Bu sorumun cevabını arıyorum. Kütüphanenin gösterdiği .h dosyalarında hepsi tanımlı.
Klein
kullanılmaz olur mu? kullanılıyor tabi ki.
.H dosyada fonksiyonların prototipleri tanımlı.
.C dosyasında  ise, fonksiyonun kendisi.
Derleyici önce .C dosyalarını ayrı ayrı derliyor.  Diyelim ki sizin main.c derlenirken, read_i2c(...)  diye bir fonksiyon gördü. Amca bu fonksiyonu çağıracak kodu oluşturacak ama, fonksiyonun parametreleri nelerdir? parametre tipleri nedir?, dönüş tipi nedir? bunları bilmiyor.  bunu bilmek için gidip .H dosyasından bunlara bakıyor. O an gerçekte fonksiyonun ne iş yaptığını bilmiyor, sadece parametrelerini vs... öğreniyor.  ilgili .C dosyası da aynı şekilde derleniyor. Derleme sonunda bir dosya oluşuyor , bu dosyada  çağırılacak fonksiyonlar , bunların parametreleri vs.. sembolik.  Sonra link aşamasına geçiliyor. Link aşamasında bütün bu sembolik tanımlar gerçek tanımlarla çevriliyor, ona göre adres ayarlamaları vs.. yapılıp hex kod üretiliyor.
Bulamadığım gizli .c dosyaları derlenirken mi ortaya çıkıyor? Bu kısmı tam olarak anlayamadım.
Klein
https://www.picproje.org/index.php/topic,43088.0.html
bu mesajdaki gibi proje ağacının olduğu kısmın ve project components bölümünün resimlerini yükleyebilirmisin.
Soldaki proje ağacında .C dosyalar  görünmüyor mu?
Derlenmiş kütüphane ile mi çalışıyorsun acaba?
Hocam Proje ağacı resimdeki gibi.
image hosting sites
Proje ağacında benim hazırlamış olduğum kütüphaneler görünüyor. ama keilin kütüphanesine ait olanlardan sadece .h olanlar görünüyor.
proje ağacında main.c altına baktığımda dosyalar aşağıdaki gibi.
images
Klein
Derlenmiş kütüphane ile çalıştığın için göremiyorsun.  Proje ağacında "STM32F10xR.Lib" var.
Bütün kütüphane derlenip .LIB dosyası haline getirilmiş.
Kaynak kodları görmek istiyorsan,  ST'nin sitesinden kütüphaneyi indirip, kullanacaklarını projeye dahil etmen gerek.
Anladım demek istediğinizi. Teşekkür ederim.
Arkadaşlar 20ms de bir kesme oluşmasını istiyorum. Bu iş için timer bölücü ayarlarını nasıl yapmalıyım. Hesaplamaları nasıl oluyor
Klein
systick kullanabilirsin.
SysTick_Config(SystemCoreClock/20000);
Timer kullanacaksan
InitStruct.TIM_Prescaler =72 ;
InitStruct.TIM_Period =19999;
