Android Oscilloscope
Başlatan SERRO EFE, 03 Nisan 2013, 09:00:18
SERRO EFE
Belki meraklısı çıkar :)
 Dual channel data acquisition using 8 bit A/D Converters
(range 1[Hz] - 40[MHz]). Signal input voltage of +/- 5[V]
 Continuous sampling rate around 1 [Msps].
 High resolution single shot sampling with 40 [Msps] resolution,
only around 2k samples per channel.
 UI with common oscilloscope cursor and trigger functionality.
 Running on the Beagleboard or Devkit8000.
 Product specifications of Hardware and Software
 Documentation of the application, hardware and software
http://www.osciprime.com/index.php?p=project
