Mcu arayışı
Başlatan Ramiz, 10 Ocak 2014, 17:45:50
Ramiz
Selam. Aşağıdaki özelliklerde mcu aramaktayım.
-3.3v
-min 32k rom, min 1 k ram
-2 pwm output
-1 uart, 1 spi, 1 i2c, 1 external int.
- Rtc
- eeprom min 256 byte
Birde varsa usb hid.
-Pin değeri minimum olsa çok iyi olur ve max. 64 pin e kadar çıkılabilir. SMD olması zorunlu...
-Lütfen pic16 ve pic18 serilerini önermeyiniz..
-Önerilen mcular 5$ ve altı olmalı
-Önerilen mcular Tr de bulunmalı
Herşey için şimdiden teşekkürler.
Electrical & Electronics Engineering -> Step one
hgs
Ramiz
Hiç birtanesinde yok.
Eeprom lazımsa program hafızasını kullanırsın.
Ramiz
Program flashına yazabiliyorsak, çok iyi..
Daha mantıklı öneri gelene kadar, STM32F100 ü tercih edeceğim.
stm32f103rbt6 lqfp 64pin
3usd  ;D
http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164487
Alıntı YapARM 32-bit Cortex™-M3 CPU Core
72 MHz maximum frequency,1.25 DMIPS/MHz (Dhrystone 2.1) performance at 0 wait state memory access
Single-cycle multiplication and hardware division
Memories
64 or 128 Kbytes of Flash memory
20 Kbytes of SRAM
Clock, reset and supply management
2.0 to 3.6 V application supply and I/Os
POR, PDR, and programmable voltage detector (PVD)
4-to-16 MHz crystal oscillator
Internal 8 MHz factory-trimmed RC
Internal 40 kHz RC
PLL for CPU clock
32 kHz oscillator for RTC with calibration
Low power
Sleep, Stop and Standby modes
VBAT supply for RTC and backup registers
2 x 12-bit, 1 μs A/D converters (up to 16 channels)
Conversion range: 0 to 3.6 V
Dual-sample and hold capability
Temperature sensor
DMA
7-channel DMA controller
Peripherals supported: timers, ADC, SPIs, I2Cs and USARTs
Up to 80 fast I/O ports
26/37/51/80 I/Os, all mappable on 16 external interrupt vectors and almost all 5 V-tolerant
Debug mode
Serial wire debug (SWD) & JTAG interfaces
7 timers
Three 16-bit timers, each with up to 4 IC/OC/PWM or pulse counter and quadrature (incremental) encoder input
16-bit, motor control PWM timer with dead-time generation and emergency stop
2 watchdog timers (Independent and Window)
SysTick timer 24-bit downcounter
Up to 9 communication interfaces
Up to 2 x I2C interfaces (SMBus/PMBus)
Up to 3 USARTs (ISO 7816 interface, LIN, IrDA capability, modem control)
Up to 2 SPIs (18 Mbit/s)
CAN interface (2.0B Active)
USB 2.0 full-speed interface
CRC calculation unit, 96-bit unique ID
Packages are ECOPACK®
http://www.ebay.com/itm/1PCS-STM32F103RBT6-STM32F103-LQFP-64-LQFP64-128Kbytes-ARM-ST-/260984247565?pt=LH_DefaultDomain_0&hash=item3cc3df950d
mesaj birleştirme:: 11 Ocak 2014, 01:14:44
Yurtiçinde de bulursun.
x-nomek
low power olayında çalışma frekanslarına göre  ne kadar akım çekiyor pinler boşken ?
Alternatif olaral LPC13xx aileside düşünüle bilir. $4.25 ile $4.85 arası distiribütör fiyatı var.
LPC1347FBD64
Alıntı Yap
    ARM Cortex-M3 r2p1 processor, running at frequencies of up to 72 MHz
    ARM Cortex-M3 built-in Nested Vectored Interrupt Controller (NVIC).
    Non Maskable Interrupt (NMI) input selectable from several input sources
    System tick timer
    64 kB on-chip flash program memory with a 256 byte page erase function
    In-System Programming (ISP) and In-Application Programming (IAP)
    4 kB on-chip EEPROM data memory with on-chip API support
    12 kB SRAM data memory
    16 kB boot ROM with API support
    Standard JTAG test interface for BSDL
    Serial Wire Debug
    Support for ETM ARM Cortex-M3 debug time stamping
    51 General Purpose I/O (GPIO) pins
    8 GPIO pins can be selected as edge and level sensitive interrupt sources
    Two GPIO grouped interrupt modules
    High-current source output driver (20 mA) on one pin (P0_7)
    High-current sink driver (20 mA) on true open-drain pins (P0_4 and P0_5)
    Four general purpose counter/timers
    Programmable Windowed WatchDog Timer (WWDT)
    Repetitive Interrupt Timer (RI Timer)
    12-bit ADC with eight input channels and sampling rates of up to 500 kSamples/s
    USB 2.0 full-speed device controller
    USART with fractional baud rate generation
    Two SSP controllers with FIFO and multi-protocol capabilities
    I2C-bus interface supporting the full I2C-bus specification and Fast-mode Plus
    Crystal Oscillator with an operating range of 1 MHz to 25 MHz
    12 MHz high-frequency Internal RC oscillator (IRC) trimmed to 1 % accuracy
    Internal low-power, low-frequency WatchDog Oscillator (WDO)
    PLL allows CPU operation up to the maximum CPU rate
    A second, dedicated PLL is provided for USB
    Clock output function with divider
    Four reduced power modes
    Power profiles residing in boot ROM
    Processor wake-up
    Integrated PMU (Power Management Unit)
    Power-On Reset (POR)
    Brownout detect with four separate thresholds for interrupt and forced reset
    Unique device serial number for identification
    Single 3.3 V power supply (2.0 V to 3.6 V)
Ramiz
Yanıtlar için teşekkür ederim. Fakat mantıken ve fiyaten halen stm32f100 ü geçebilecek öneri gelmedi.
Yukarıda saydığım özellikler sonrasında en önemli etken fiyat. Bu özelliklerin üzerine çıkmamız gerekmiyor.(çünkü çıkınca fiyat yükseliyor)
fgokcegoz
STM32F1 serisine gerek yok. F0 serisi rahat rahat işini görür.
STM32F030C6 : LQFP-48
32 Kbytes Flash
48 MHz CPU
4 Kbytes Ram
Liste fiyatı : 0.586$
http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1574/LN1826/PF258966
"Vicdanın ziyası, ulûm-u diniyedir. Aklın nuru, fünun-u medeniyedir. İkisinin imtizacıyla hakikat tecelli eder." (Bediüzzaman Said Nursi)
ilhan_mkp
Ramiz
#11
Alıntı yapılan: fgokcegoz - 11 Ocak 2014, 13:56:45
32 Kbytes Flash
48 MHz CPU
4 Kbytes Ram
Tr de bulunuyormu?
mesaj birleştirme:: 11 Ocak 2014, 14:36:11
Farnell de ve ebay de bile yok bu mcu.. Tr den temin edebileceğim birşey olmalı..
f100varmı türkiyede,
Ramiz
F100 daha yaygın. Farnell, ebay ve digikey de yaygın olarak var. St Tr temsilcisindede çok yüksek olasılıkla vardır yada hızlıca temin ediyordur ama F0 bu saydığım sitelerde bile yok..
JKramer
Digikey'de STM32F030C6T6 var. fgokcegoz'ün verdiği sitede Sample&Buy bölümünden başka bulunan yerleri görebilirsiniz. Bir de Türkiye'de bulunan derken ST distribütörlerini (Empa, vs.) kastediyorsanız, hızlıca temin duruma göre değişir; dün olan bir şeyi yarın sorarsanız 8-10 haftada temin edilme durumu olabilir. Bu durumda yine Digikey,vs. yolu görünür.
